[U-Boot] [PATCH v3] Add single register pin controller driver
This patch adds a pin controller driver supporting devices using a single configuration register per pin.
Signed-off-by: Felix Brack fb@ltec.ch [james@balean.com.au: changed .set_state_simple operation to .set_state] Signed-off-by: James Balean james@balean.com.au --- drivers/pinctrl/Kconfig | 10 +++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-single.c | 141 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 152 insertions(+) create mode 100644 drivers/pinctrl/pinctrl-single.c
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index efcb4c0..a2b9212 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -175,6 +175,16 @@ config PIC32_PINCTRL by a device tree node which contains both GPIO defintion and pin control functions.
+config PINCTRL_SINGLE + bool "Single register pin-control and pin-multiplex driver" + depends on PINCTRL_FULL || SPL_PINCTRL_FULL + help + This enables pinctrl driver for systems using a single register for + pin configuration and multiplexing. TI's AM335X SoCs are examples of + such systems. + Depending on the platform make sure to also enable OF_TRANSLATE and + eventually SPL_OF_TRANSLATE to get correct address translations. + endif
source "drivers/pinctrl/meson/Kconfig" diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 512112a..f148f94 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -16,3 +16,4 @@ obj-$(CONFIG_PIC32_PINCTRL) += pinctrl_pic32.o obj-$(CONFIG_PINCTRL_EXYNOS) += exynos/ obj-$(CONFIG_PINCTRL_MESON) += meson/ obj-$(CONFIG_PINCTRL_MVEBU) += mvebu/ +obj-$(CONFIG_PINCTRL_SINGLE) += pinctrl-single.o diff --git a/drivers/pinctrl/pinctrl-single.c b/drivers/pinctrl/pinctrl-single.c new file mode 100644 index 0000000..a5b4d75 --- /dev/null +++ b/drivers/pinctrl/pinctrl-single.c @@ -0,0 +1,141 @@ +/* + * Copyright (C) EETS GmbH, 2017, Felix Brack f.brack@eets.ch + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm/device.h> +#include <dm/pinctrl.h> +#include <libfdt.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct single_pdata { + fdt_addr_t base; /* first configuration register */ + int offset; /* index of last configuration register */ + u32 mask; /* configuration-value mask bits */ + int width; /* configuration register bit width */ +}; + +struct single_fdt_pin_cfg { + fdt32_t reg; /* configuration register offset */ + fdt32_t val; /* configuration register value */ +}; + +/** + * single_configure_pins() - Configure pins based on FDT data + * + * @dev: Pointer to single pin configuration device which is the parent of + * the pins node holding the pin configuration data. + * @pins: Pointer to the first element of an array of register/value pairs + * of type 'struct single_fdt_pin_cfg'. Each such pair describes the + * the pin to be configured and the value to be used for configuration. + * This pointer points to a 'pinctrl-single,pins' property in the + * device-tree. + * @size: Size of the 'pins' array in bytes. + * The number of register/value pairs in the 'pins' array therefore + * equals to 'size / sizeof(struct single_fdt_pin_cfg)'. + */ +static int single_configure_pins(struct udevice *dev, + const struct single_fdt_pin_cfg *pins, + int size) +{ + struct single_pdata *pdata = dev->platdata; + int count = size / sizeof(struct single_fdt_pin_cfg); + int n, reg; + u32 val; + + for (n = 0; n < count; n++) { + reg = fdt32_to_cpu(pins->reg); + if ((reg < 0) || (reg > pdata->offset)) { + dev_dbg(dev, " invalid register offset 0x%08x\n", reg); + pins++; + continue; + } + reg += pdata->base; + switch (pdata->width) { + case 32: + val = readl(reg) & ~pdata->mask; + val |= fdt32_to_cpu(pins->val) & pdata->mask; + writel(val, reg); + dev_dbg(dev, " reg/val 0x%08x/0x%08x\n", + reg, val); + break; + default: + dev_warn(dev, "unsupported register width %i\n", + pdata->width); + } + pins++; + } + return 0; +} + +static int single_set_state(struct udevice *dev, struct udevice *config) +{ + const void *fdt = gd->fdt_blob; + const struct single_fdt_pin_cfg *prop; + int len; + + prop = fdt_getprop(fdt, config->of_offset, "pinctrl-single,pins", &len); + if (prop) { + dev_dbg(dev, "configuring pins for %s\n", config->name); + if (len % sizeof(struct single_fdt_pin_cfg)) { + dev_dbg(dev, " invalid pin configuration in fdt\n"); + return -FDT_ERR_BADSTRUCTURE; + } + single_configure_pins(dev, prop, len); + len = 0; + } + + return len; +} + +static int single_ofdata_to_platdata(struct udevice *dev) +{ + fdt_addr_t addr; + u32 of_reg[2]; + int res; + struct single_pdata *pdata = dev->platdata; + + pdata->width = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "pinctrl-single,register-width", 0); + + res = fdtdec_get_int_array(gd->fdt_blob, dev->of_offset, + "reg", of_reg, 2); + if (res) + return res; + pdata->offset = of_reg[1] - pdata->width / 8; + + addr = dev_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) { + dev_dbg(dev, "no valid base register address\n"); + return -EINVAL; + } + pdata->base = addr; + + pdata->mask = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "pinctrl-single,function-mask", + 0xffffffff); + return 0; +} + +const struct pinctrl_ops single_pinctrl_ops = { + .set_state = single_set_state, +}; + +static const struct udevice_id single_pinctrl_match[] = { + { .compatible = "pinctrl-single" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(single_pinctrl) = { + .name = "single-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = single_pinctrl_match, + .ops = &single_pinctrl_ops, + .flags = DM_FLAG_PRE_RELOC, + .platdata_auto_alloc_size = sizeof(struct single_pdata), + .ofdata_to_platdata = single_ofdata_to_platdata, +};
Reviewed-by: Lukasz Majewski lukma@denx.de
- bool "Single register pin-control and pin-multiplex driver"
- depends on PINCTRL_FULL || SPL_PINCTRL_FULL
- help
register for
examples of
such systems.
OF_TRANSLATE and
- Copyright (C) EETS GmbH, 2017, Felix Brack f.brack@eets.ch
- fdt_addr_t base; /* first configuration register */
- int offset; /* index of last configuration
register */
- u32 mask; /* configuration-value mask bits */
- int width; /* configuration register bit
width */ +};
- fdt32_t reg; /* configuration register offset
- fdt32_t val; /* configuration register value
- single_configure_pins() - Configure pins based on FDT data
- @dev: Pointer to single pin configuration device which is the
parent of
- @pins: Pointer to the first element of an array of register/value
pairs
describes the
configuration.
the
device-tree.
- @size: Size of the 'pins' array in bytes.
therefore
*pins,
int size)
- struct single_pdata *pdata = dev->platdata;
- int count = size / sizeof(struct single_fdt_pin_cfg);
- int n, reg;
- u32 val;
- for (n = 0; n < count; n++) {
0x%08x\n", reg);
pins++;
continue;
reg += pdata->base;
case 32:
writel(val, reg);
reg, val);
break;
default:
%i\n",
pdata->width);
pins++;
- const void *fdt = gd->fdt_blob;
- const struct single_fdt_pin_cfg *prop;
- int len;
- prop = fdt_getprop(fdt, config->of_offset,
- if (prop) {
config->name);
fdt\n");
len = 0;
- return len;
- fdt_addr_t addr;
- u32 of_reg[2];
- int res;
- pdata->width = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
- res = fdtdec_get_int_array(gd->fdt_blob, dev->of_offset,
"reg", of_reg, 2);
- if (res)
return res;
- pdata->offset = of_reg[1] - pdata->width / 8;
- addr = dev_get_addr(dev);
- if (addr == FDT_ADDR_T_NONE) {
return -EINVAL;
- pdata->base = addr;
- pdata->mask = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
0xffffffff);
- .set_state = single_set_state,
- { .compatible = "pinctrl-single" },
- { /* sentinel */ }
- .name = "single-pinctrl",
- .id = UCLASS_PINCTRL,
- .of_match = single_pinctrl_match,
- .ops = &single_pinctrl_ops,
- .flags = DM_FLAG_PRE_RELOC,
- .platdata_auto_alloc_size = sizeof(struct single_pdata),
- .ofdata_to_platdata = single_ofdata_to_platdata,
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Remove this "Signed-off-by" tag as I neither made nor tested these modifications. Furthermore it might not be good idea to name your modifications to my patch "v3 ..." as this too could make people belief I'm the originator or co-author of your modifications. What if I fix a bug in my v2 patch? Should I then increase from v2 to v4? Don't just 'hijack' a patch. Better add your comments, modification requests, bug reports and explanations to the v2 thread of this patch as I already suggested to you.
Felix
- help
such systems.
endif
- int offset; /* index of last configuration register */
- int width; /* configuration register bit width */
- fdt32_t reg; /* configuration register offset */
- fdt32_t val; /* configuration register value */
- @dev: Pointer to single pin configuration device which is the parent of
- @pins: Pointer to the first element of an array of register/value pairs
device-tree.
int size)
- int n, reg;
- u32 val;
pins++;
continue;
reg += pdata->base;
case 32:
writel(val, reg);
reg, val);
break;
default:
pdata->width);
pins++;
- int len;
- prop = fdt_getprop(fdt, config->of_offset, "pinctrl-single,pins", &len);
- if (prop) {
len = 0;
- return len;
- fdt_addr_t addr;
- u32 of_reg[2];
- int res;
"reg", of_reg, 2);
- if (res)
return res;
return -EINVAL;
0xffffffff);
Hi Felix,
Not 'hijacking' a patch, just following Linux Developer's Certificate of Origin 1.1 guidelines.
As you know, I contacted you directly with this patch suggestion prior to posting to the mailing list (keeping strictly to rule c). I had hoped you would make a new version:
On 09.03.2017 08:53, James Balean wrote:
Did you want to test/submit this?
Perhaps I misinterpreted your response, which stated:
On Fri, 10 Mar 2017 at 04:13, Felix Brack fb@ltec.ch wrote:
This and probably more has to be accessible by _all_ mailing list
subscribers. Please post there.
This was confusing, as I could see no way to convert this work to a patch of your unapproved v2 patch (being new to this process).
modifications.
My understanding from the 'submitting patches' guide is that the square bracket nomenclature I used indicates minor changes to an existing patch, thereby providing you with credit whilst also denoting that you do not endorse the changes.
What if I fix a
Perhaps someone can clarify, but it seems logical that the version number is in order of contribution to the project, rather than being tied to any specific user. Especially given the software license it is under.
Kind regards, James Balean
On 11 March 2017 at 04:52, James james@balean.com.au wrote:
Hi Felix,
modifications.
What if I fix a
It is better to make comments on the patch and let the original author respin it. If you have not heard after a week then I suppose you can resend it with the changes, i.w.c. I think you DO need to keep the original author's sign-off and increment the version.
Felix, are you planning to resend this?
Hello Simon,
Hi Felix,
modifications.
What if I fix a
Yes, I will try to do so next week.
Regards Felix
Hi James,
On 11.03.2017 12:52, James wrote:
Hi Felix,
See following remark please.
My answer to the question above was: 'If required I will fix and test things myself. I will then post the next version of the patch ASAP, for a further review of course.' Please quote completely and correctly.
On Fri, 10 Mar 2017 at 04:13, Felix Brack <fb@ltec.ch mailto:fb@ltec.ch> wrote:
Okay, maybe that was a bad formulation, sorry, I will try to rephrase. Consider this to be my point of view rather then a rule being carved in stone. The patch originator posts the patch (this starts a new thread). Now the probably most important part of the process starts: everyone is invited to comment on the patch _within the newly started thread_. This will make sure that the thread started by posting the patch contains all information that would probably lead to further versions of that patch. Also this will make sure that everyone interested will be able to follow the entire discussion. These comments (your's too, of course) are extremely appreciated - the more eyes looking at a patch, the better. Whenever possible comments should also contain concrete suggestions about how to do better as well as a little explanation about why to do so (imho). After a more or less extensive process of commenting and resubmitting of the patch the responsible custodian may finally pick it up to be added to the U-Boot repository.
On Sat, 11 Mar 2017 at 00:07, Felix Brack <fb@ltec.ch mailto:fb@ltec.ch> wrote:
modifications.
What if I fix a
Regards, Felix
participants (5)
Felix Brack
James
James Balean
Lukasz Majewski
