[PATCH v3 0/2] board: phytec_imx8mp: Use 2GHz RAM timings for PCL-070 from pcb_rev 1
PCL-070 supports 2GHz RAM-timings from pcb_rev 1 and newer. PCM-070 supports 2GHz RAM-timings only from pcb_rev 3 and newer.
Signed-off-by: Benjamin Hahn B.Hahn@phytec.de --- Changes in v3: - change variable name from somtyp to somtype - change enum names from PCL to SOM_TYPE_PCL - Link to v2: https://lore.kernel.org/r/20240304-pcl-070-patches-v2-0-c534960c4b8b@phytec....
Changes in v2: - Fix mistakes that prevented building - Link to v1: https://lore.kernel.org/r/20240304-pcl-070-patches-v1-0-6aa6c89e3b81@phytec....
--- Benjamin Hahn (2): board: phytec: common: phytec_som_detection: Add phytec_get_som_type board: phycore_imx8mp: Use 2GHz RAM timings for PCL-070 from pcb_rev 1
board/phytec/common/phytec_som_detection.c | 10 ++++++++++ board/phytec/common/phytec_som_detection.h | 8 ++++++++ board/phytec/phycore_imx8mp/spl.c | 6 ++++-- 3 files changed, 22 insertions(+), 2 deletions(-) --- base-commit: eac52e4be4e234d563d6911737ee7ccdc0ada1f1 change-id: 20240304-pcl-070-patches-d31b989cf5b3
Add a function that gets the som_type from the EEPROM. Add an enum for the som_type.
Signed-off-by: Benjamin Hahn B.Hahn@phytec.de --- board/phytec/common/phytec_som_detection.c | 10 ++++++++++ board/phytec/common/phytec_som_detection.h | 8 ++++++++ 2 files changed, 18 insertions(+)
diff --git a/board/phytec/common/phytec_som_detection.c b/board/phytec/common/phytec_som_detection.c index c73bf9721b2f..f9607b018dea 100644 --- a/board/phytec/common/phytec_som_detection.c +++ b/board/phytec/common/phytec_som_detection.c @@ -203,6 +203,16 @@ u8 __maybe_unused phytec_get_rev(struct phytec_eeprom_data *data) return api2->pcb_rev; }
+u8 __maybe_unused phytec_get_som_type(struct phytec_eeprom_data *data) +{ + if (!data) + data = &eeprom_data; + if (data->api_rev < PHYTEC_API_REV2) + return PHYTEC_EEPROM_INVAL; + + return data->data.data_api2.som_type; +} + #else
inline int phytec_eeprom_data_setup(struct phytec_eeprom_data *data, diff --git a/board/phytec/common/phytec_som_detection.h b/board/phytec/common/phytec_som_detection.h index 11009240875c..7edbfa3ca5c6 100644 --- a/board/phytec/common/phytec_som_detection.h +++ b/board/phytec/common/phytec_som_detection.h @@ -19,6 +19,13 @@ enum { PHYTEC_API_REV2, };
+enum phytec_som_type_str { + SOM_TYPE_PCM = 0, + SOM_TYPE_PCL, + SOM_TYPE_KSM, + SOM_TYPE_KSP, +}; + static const char * const phytec_som_type_str[] = { "PCM", "PCL", @@ -67,5 +74,6 @@ void __maybe_unused phytec_print_som_info(struct phytec_eeprom_data *data);
char * __maybe_unused phytec_get_opt(struct phytec_eeprom_data *data); u8 __maybe_unused phytec_get_rev(struct phytec_eeprom_data *data); +u8 __maybe_unused phytec_get_som_type(struct phytec_eeprom_data *data);
#endif /* _PHYTEC_SOM_DETECTION_H */
We need to differ between PCL-070 and PCM-070. PCL-070 supports 2GHz RAM timings from pcb rev 1 or newer. PCM-070 supports 2GHz RAM timings from pcb rev 3 or newer.
Signed-off-by: Benjamin Hahn B.Hahn@phytec.de --- board/phytec/phycore_imx8mp/spl.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/phytec/phycore_imx8mp/spl.c b/board/phytec/phycore_imx8mp/spl.c index d38f6368fe36..df158024654e 100644 --- a/board/phytec/phycore_imx8mp/spl.c +++ b/board/phytec/phycore_imx8mp/spl.c @@ -46,8 +46,10 @@ void spl_dram_init(void) if (!ret) phytec_print_som_info(NULL);
- ret = phytec_get_rev(NULL); - if (ret >= 3 && ret != PHYTEC_EEPROM_INVAL) { + u8 rev = phytec_get_rev(NULL); + u8 somtype = phytec_get_som_type(NULL); + + if (rev != PHYTEC_EEPROM_INVAL && (rev >= 3 || (somtype == SOM_TYPE_PCL && rev >= 1))) { dram_timing.ddrc_cfg[3].val = 0x1323; dram_timing.ddrc_cfg[4].val = 0x1e84800; dram_timing.ddrc_cfg[5].val = 0x7a0118;
Hi Benjamin,
v3 looks good.
Is this material for U-Boot 2024.04 or 2024.07?
Hi Fabio,
On 07.03.24 21:26, Fabio Estevam wrote:
Hi Benjamin,
v3 looks good.
If it can be merged into 2024.04 this would be preferred. Otherwise 2024.07 would also be okay.
Benjamin
Applied all, thanks.
Benjamin Hahn
Fabio Estevam
