[U-Boot] [PATCH 0/4] powerpc, 8xx: Add support for MCR3000 board from CSSI
This serie adds MCR3000 board from CS Systemes d'Information.
Christophe Leroy (4): powerpc, 8xx: add support for LXT973 PHY powerpc, 8xx: Implement GLL2 ERRATA powerpc, 8xx: Properly set CPM frequency in the device tree powerpc, 8xx: Add support for MCR3000 board from CSSI
arch/powerpc/cpu/mpc8xx/Kconfig | 5 + arch/powerpc/cpu/mpc8xx/cpu_init.c | 14 ++ arch/powerpc/cpu/mpc8xx/fdt.c | 2 + arch/powerpc/cpu/mpc8xx/fec.c | 24 ++ board/cssi/MAINTAINERS | 6 + board/cssi/MCR3000/Kconfig | 15 ++ board/cssi/MCR3000/MCR3000.c | 436 +++++++++++++++++++++++++++++++++++++ board/cssi/MCR3000/Makefile | 9 + board/cssi/MCR3000/nand.c | 77 +++++++ board/cssi/MCR3000/u-boot.lds | 91 ++++++++ configs/MCR3000_defconfig | 37 ++++ include/configs/MCR3000.h | 293 +++++++++++++++++++++++++ 12 files changed, 1009 insertions(+) create mode 100644 board/cssi/MAINTAINERS create mode 100644 board/cssi/MCR3000/Kconfig create mode 100644 board/cssi/MCR3000/MCR3000.c create mode 100644 board/cssi/MCR3000/Makefile create mode 100644 board/cssi/MCR3000/nand.c create mode 100644 board/cssi/MCR3000/u-boot.lds create mode 100644 configs/MCR3000_defconfig create mode 100644 include/configs/MCR3000.h
LXT973 PHY is a PHY of the LXT970 family. This patch ensures the fec driver supports it.
Signed-off-by: Christophe Leroy christophe.leroy@c-s.fr --- arch/powerpc/cpu/mpc8xx/fec.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/powerpc/cpu/mpc8xx/fec.c b/arch/powerpc/cpu/mpc8xx/fec.c index b27310fffb..680d286964 100644 --- a/arch/powerpc/cpu/mpc8xx/fec.c +++ b/arch/powerpc/cpu/mpc8xx/fec.c @@ -738,6 +738,7 @@ static void fec_halt(struct eth_device* dev) */ #define PHY_ID_LXT970 0x78100000 /* LXT970 */ #define PHY_ID_LXT971 0x001378e0 /* LXT971 and 972 */ +#define PHY_ID_LXT973 0x00137A10 /* LXT973 */ #define PHY_ID_82555 0x02a80150 /* Intel 82555 */ #define PHY_ID_QS6612 0x01814400 /* QS6612 */ #define PHY_ID_AMD79C784 0x00225610 /* AMD 79C784 */ @@ -814,6 +815,9 @@ static int mii_discover_phy(struct eth_device *dev) case PHY_ID_LXT971: printf("LXT971\n"); break; + case PHY_ID_LXT973: + printf("LXT973\n"); + break; case PHY_ID_82555: printf("82555\n"); break;
And, please make a note on your TODO list that the driver needs to be updated to use phylib, thanks!
Dear Christophe,
[adding Joe on Cc:]
In message c1a9e6b6347fe9e2c36858f082f3ca452b328fd2.1498132599.git.christophe.leroy@c-s.fr you wrote:
This patch is totally unrelated to 8xx; it should go through the network maintainer [adding Joe on Cc:]
Otherwise:
Reviewed-by: Wolfgang Denk wd@denx.de
On Fri, Jun 23, 2017 at 8:45 AM, Wolfgang Denk wd@denx.de wrote:
Dear Christophe,
[adding Joe on Cc:]
This file does not exist. All support for 8xx has been removed.
Otherwise:
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Artificial Intelligence is the study of how to make real computers act like the ones in movies. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Signed-off-by: Christophe Leroy christophe.leroy@c-s.fr --- arch/powerpc/cpu/mpc8xx/cpu_init.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/powerpc/cpu/mpc8xx/cpu_init.c b/arch/powerpc/cpu/mpc8xx/cpu_init.c index f621d6285c..5da12faf21 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc8xx/cpu_init.c @@ -64,6 +64,18 @@ void cpu_init_f (volatile immap_t * immr) reg |= CONFIG_SYS_SCCR; immr->im_clkrst.car_sccr = reg;
+#ifdef CONFIG_MPC86x + /* BUG MPC866 GLL2 consideration */ + reg = immr->im_clkrst.car_sccr; + /* probably we use the mode 1:2:1 */ + if ((reg & 0x00060000) == 0x00020000) { + reg &= ~0x00060000; + immr->im_clkrst.car_sccr = reg; + reg |= 0x00020000; + immr->im_clkrst.car_sccr = reg; + } +#endif + /* PLL (CPU clock) settings (15-30) */
immr->im_clkrstk.cark_plprcrk = KAPWR_KEY;
Dear Christophe Leroy,
In message 8be66e1dd57e24e6442e88ec175161f5c819f993.1498132599.git.christophe.leroy@c-s.fr you wrote:
NAK.
The patch does not even apply as there is no such file in mainline:
CONFLICT (modify/delete): arch/powerpc/cpu/mpc8xx/cpu_init.c deleted in 431c66a3bad13e13c1d44ef4ec3638f95e72e11d and modified in powerpc, 8xx: Implement GLL2 ERRATA. Version powerpc, 8xx: Implement GLL2 ERRATA of arch/powerpc/cpu/mpc8xx/cpu_init.c left in tree.
NAK.
Clearly depends on the "bring back mpc8xx" patch. So yes, you can fault Christophe for not stating in the cover letter that of course the series depends on that patch. Please otherwise review the content of the patch with that in mind, thanks.
For processors whose core runs at twice the bus frequency, the fallback frequency calculation in Linux provides a wrong result. Therefore, U-boot needs to pass the correct value.
Signed-off-by: Christophe Leroy christophe.leroy@c-s.fr --- arch/powerpc/cpu/mpc8xx/fdt.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/powerpc/cpu/mpc8xx/fdt.c b/arch/powerpc/cpu/mpc8xx/fdt.c index 34d36478d3..5688671fba 100644 --- a/arch/powerpc/cpu/mpc8xx/fdt.c +++ b/arch/powerpc/cpu/mpc8xx/fdt.c @@ -20,6 +20,8 @@ void ft_cpu_setup(void *blob, bd_t *bd) "bus-frequency", bd->bi_busfreq, 1); do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, "clock-frequency", bd->bi_intfreq, 1); + do_fixup_by_compat_u32(blob, "fsl,pq1-soc", "clock-frequency", + bd->bi_intfreq, 1); do_fixup_by_compat_u32(blob, "fsl,cpm-brg", "clock-frequency", gd->arch.brg_clk, 1);
In message 243f0cadb778fb5186d026bf0900fde56487e636.1498132599.git.christophe.leroy@c-s.fr you wrote:
Does not apply: 'arch/powerpc/cpu/mpc8xx/fdt.c': No such file or directory
Naked-by: Wolfgang Denk wd@denx.de
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000 and CMPC885 which are respectively based on MPC866 and MPC885 processors.
This patch adds support for the first board.
Signed-off-by: Christophe Leroy christophe.leroy@c-s.fr --- arch/powerpc/cpu/mpc8xx/Kconfig | 5 + arch/powerpc/cpu/mpc8xx/cpu_init.c | 2 + arch/powerpc/cpu/mpc8xx/fec.c | 20 ++ board/cssi/MAINTAINERS | 6 + board/cssi/MCR3000/Kconfig | 15 ++ board/cssi/MCR3000/MCR3000.c | 436 +++++++++++++++++++++++++++++++++++++ board/cssi/MCR3000/Makefile | 9 + board/cssi/MCR3000/nand.c | 77 +++++++ board/cssi/MCR3000/u-boot.lds | 91 ++++++++ configs/MCR3000_defconfig | 37 ++++ include/configs/MCR3000.h | 293 +++++++++++++++++++++++++ 11 files changed, 991 insertions(+) create mode 100644 board/cssi/MAINTAINERS create mode 100644 board/cssi/MCR3000/Kconfig create mode 100644 board/cssi/MCR3000/MCR3000.c create mode 100644 board/cssi/MCR3000/Makefile create mode 100644 board/cssi/MCR3000/nand.c create mode 100644 board/cssi/MCR3000/u-boot.lds create mode 100644 configs/MCR3000_defconfig create mode 100644 include/configs/MCR3000.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index a425cba8aa..817c240a8a 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -8,6 +8,11 @@ choice prompt "Target select" optional
+config TARGET_MCR3000 + bool "Support MCR3000 board from CSSI" + endchoice
+source "board/cssi/MCR3000/Kconfig" + endmenu diff --git a/arch/powerpc/cpu/mpc8xx/cpu_init.c b/arch/powerpc/cpu/mpc8xx/cpu_init.c index 5da12faf21..2f7437f6f5 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc8xx/cpu_init.c @@ -37,7 +37,9 @@ void cpu_init_f (volatile immap_t * immr)
/* SYPCR - contains watchdog control (11-9) */
+#ifndef CONFIG_TARGET_MCR3000 immr->im_siu_conf.sc_sypcr = CONFIG_SYS_SYPCR; +#endif
#if defined(CONFIG_WATCHDOG) reset_8xx_watchdog (immr); diff --git a/arch/powerpc/cpu/mpc8xx/fec.c b/arch/powerpc/cpu/mpc8xx/fec.c index 680d286964..bdad8791be 100644 --- a/arch/powerpc/cpu/mpc8xx/fec.c +++ b/arch/powerpc/cpu/mpc8xx/fec.c @@ -443,6 +443,26 @@ static void fec_pin_init(int fecidx) immr->im_ioport.iop_pddir = 0x1c58; /* Pre rev. D */ else immr->im_ioport.iop_pddir = 0x1fff; /* Rev. D and later */ + +#if defined (CONFIG_TARGET_MCR3000) + immr->im_ioport.iop_papar = 0xBBFF; + immr->im_ioport.iop_padir = 0x04F0; + immr->im_ioport.iop_paodr = 0x0000; + + immr->im_cpm.cp_pbpar = 0x000133FF; + immr->im_cpm.cp_pbdir = 0x0003BF0F; + immr->im_cpm.cp_pbodr = 0x00000000; + + immr->im_ioport.iop_pcpar = 0x0400; + immr->im_ioport.iop_pcdir = 0x0080; + immr->im_ioport.iop_pcso = 0x0D53; + immr->im_ioport.iop_pcint = 0x0000; + + immr->im_ioport.iop_pdpar = 0x03FE; + immr->im_ioport.iop_pddir = 0x1C09; + + immr->im_ioport.utmode |= 0x80; +#endif #endif
#endif /* CONFIG_ETHER_ON_FEC1 */ diff --git a/board/cssi/MAINTAINERS b/board/cssi/MAINTAINERS new file mode 100644 index 0000000000..cbf1406a54 --- /dev/null +++ b/board/cssi/MAINTAINERS @@ -0,0 +1,6 @@ +BOARDS from CS Systemes d'Information +M: Christophe Leroy christophe.leroy@c-s.fr +S: Maintained +F: board/cssi/ +F: include/configs/MCR3000.h +F: configs/MCR3000_defconfig diff --git a/board/cssi/MCR3000/Kconfig b/board/cssi/MCR3000/Kconfig new file mode 100644 index 0000000000..ecfd90fd4c --- /dev/null +++ b/board/cssi/MCR3000/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MCR3000 + +config SYS_BOARD + default "MCR3000" + +config SYS_VENDOR + default "cssi" + +config SYS_CONFIG_NAME + default "MCR3000" + +config SYS_TEXT_BASE + default 0x04000000 + +endif diff --git a/board/cssi/MCR3000/MCR3000.c b/board/cssi/MCR3000/MCR3000.c new file mode 100644 index 0000000000..b99c5f6fc3 --- /dev/null +++ b/board/cssi/MCR3000/MCR3000.c @@ -0,0 +1,436 @@ +/* + * Copyright (C) 2010-2017 CS Systemes d'Information + * Florent Trinh Thai florent.trinh-thai@c-s.fr + * Christophe Leroy christophe.leroy@c-s.fr + * + * Board specific routines for the MCR3000 board + * + * - initialisation + * - memory controller + * - serial io initialisation + * - ethernet io initialisation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <hwconfig.h> +#include <mpc8xx.h> +#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + + +/* ------------------------------------------------------------------------- + * constant + */ +static const uint cs1_dram_table_66[] = { + /* DRAM - single read. (offset 0 in upm RAM) + */ + 0x0F3DFC04, 0x0FEFBC04, 0x00BE7804, 0x0FFDF400, + 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + + /* DRAM - burst read. (offset 8 in upm RAM) + */ + 0x0F3DFC04, 0x0FEFBC04, 0x00BF7C04, 0x00FFFC00, + 0x00FFFC00, 0x00FEF800, 0x0FFDF400, 0x1FFFFC05, + 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + + /* DRAM - single write. (offset 18 in upm RAM) + */ + 0x0F3DFC04, 0x0FEFB800, 0x00BF7404, 0x0FFEF804, + 0x0FFDF404, 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, + + /* DRAM - burst write. (offset 20 in upm RAM) + */ + 0x0F3DFC04, 0x0FEFB800, 0x00BF7400, 0x00FFFC00, + 0x00FFFC00, 0x00FFFC04, 0x0FFEF804, 0x0FFDF404, + 0x1FFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, + + /* refresh (offset 30 in upm RAM) + */ + 0x0FFDF404, 0x0FFEBC04, 0x0FFD7C84, 0x0FFFFC04, + 0x0FFFFC04, 0x0FFFFC04, 0x1FFFFC85, 0xFFFFFFFF, + + /* init + */ + 0x0FEEB874, 0x0FBD7474, 0x1FFFFC45, 0xFFFFFFFF, + + /* exception. (offset 3c in upm RAM) + */ + 0xFFFFFC05, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, +}; + +/* ------------------------------------------------------------------------- + * Device Tree Support + */ +#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) +int fdt_set_node_and_value (void *blob, char *nodename, char *regname, void *var, int size) +{ + int ret = 0; + int nodeoffset = 0; + + nodeoffset = fdt_path_offset (blob, nodename); + if (nodeoffset >= 0) { + ret = fdt_setprop (blob, nodeoffset, regname, var, + size); + if (ret < 0) { + printf("ft_blob_update(): cannot set %s/%s property; err: %s\n", nodename, regname, fdt_strerror (ret)); + } + } else { + printf("ft_blob_update(): cannot find %s node err:%s\n", nodename, fdt_strerror (nodeoffset)); + } + return ret; +} + +int fdt_del_node_name (void *blob, char *nodename) +{ + int ret = 0; + int nodeoffset = 0; + + nodeoffset = fdt_path_offset (blob, nodename); + if (nodeoffset >= 0) { + ret = fdt_del_node (blob, nodeoffset); + if (ret < 0) { + printf("%s: cannot delete %s; err: %s\n", __func__, nodename, fdt_strerror (ret)); + } + } else { + printf("%s: cannot find %s node err:%s\n", __func__, nodename, fdt_strerror (nodeoffset)); + } + return ret; +} + +int fdt_del_prop_name (void *blob, char *nodename, char *propname) +{ + int ret = 0; + int nodeoffset = 0; + + nodeoffset = fdt_path_offset (blob, nodename); + if (nodeoffset >= 0) { + ret = fdt_delprop (blob, nodeoffset, propname); + if (ret < 0) { + printf("%s: cannot delete %s %s; err: %s\n", __func__, nodename, propname, fdt_strerror (ret)); + } + } else { + printf("%s: cannot find %s node err:%s\n", __func__, nodename, fdt_strerror (nodeoffset)); + } + return ret; +} + +/* + * update "brg" property in the blob + */ +void ft_blob_update (void *blob, bd_t *bd) +{ + uchar enetaddr[6]; + ulong brg_data = 0; + + /* BRG */ + brg_data = cpu_to_be32(bd->bi_busfreq); + fdt_set_node_and_value(blob, "/soc/cpm", "brg-frequency", &brg_data, sizeof(brg_data)); + + /* MAC addr */ + if (eth_getenv_enetaddr("ethaddr", enetaddr)) { + fdt_set_node_and_value(blob, "ethernet0", "local-mac-address", enetaddr, sizeof(u8) * 6); + } + + /* Bus Frequency for CPM */ + fdt_set_node_and_value(blob, "/soc", "bus-frequency", &bd->bi_busfreq, sizeof(u32)); +} + +void ft_e1_setup (void *blob) +{ + ulong data_rate = 2; + ulong channel_phase = 0; + char *sync = "receive"; + + /* Set data rate */ + fdt_set_node_and_value(blob, "/localbus/e1-wan", "data-rate", &data_rate, + sizeof(u32)); + + /* Set channel phase to 0 */ + fdt_set_node_and_value(blob, "/localbus/e1-wan", "channel-phase", + &channel_phase, sizeof(u32)); + + /* rising edge sync pulse transmit */ + fdt_set_node_and_value(blob, "/localbus/e1-wan", "rising-edge-sync-pulse", + sync, sizeof(u8) * strlen(sync)); +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + ft_blob_update(blob, bd); + ft_e1_setup(blob); +} +#endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ + + + +/* ------------------------------------------------------------------------- + * return CPU frequency + */ +/*static unsigned int board_get_cpufreq (void) +{ + return (CONFIG_SYS_CLK_FREQ); +}*/ + + +/* ------------------------------------------------------------------------- + * Check Board Identity: + */ +int checkboard (void) +{ + serial_putc ('B'); + serial_putc ('O'); + serial_putc ('A'); + serial_putc ('R'); + serial_putc ('D'); + serial_putc (':'); + serial_putc (' '); + serial_putc ('M'); + serial_putc ('C'); + serial_putc ('R'); + serial_putc ('3'); + serial_putc ('0'); + serial_putc ('0'); + serial_putc ('0'); + serial_putc (' '); + serial_putc ('C'); + serial_putc ('S'); + serial_putc ('S'); + serial_putc ('I'); + serial_putc ('\n'); + + return 0; +} + + +/* ------------------------------------------------------------------------- + * Initialize SDRAM + */ +int dram_init(void) +{ + volatile immap_t *immap = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile memctl8xx_t *memctl = &immap->im_memctl; + long int ram_sz = 0; + + /* + * Only initialize memory controller when running from FLASH. + * When running from RAM, don't touch it. + */ + if ( ((ulong) dram_init & CONFIG_SYS_FLASH_BASE) == CONFIG_SYS_FLASH_BASE) { + printf("UPMA init for SDRAM (CAS latency 2), "); + printf("init address 0x%08x, size ",(int)dram_init); + /* Configure UPMA for cs1 */ + upmconfig (UPMA, (uint *) cs1_dram_table_66, sizeof (cs1_dram_table_66) / sizeof (uint)); + udelay(10); + memctl->memc_mptpr = 0x0200; + memctl->memc_mamr = 0x14904000; + udelay(10); + memctl->memc_or1 = CONFIG_SYS_OR1_PRELIM; + memctl->memc_br1 = CONFIG_SYS_BR1_PRELIM; + udelay(10); + memctl->memc_mcr = 0x80002830; + memctl->memc_mar = 0x00000088; + memctl->memc_mcr = 0x80002038; + udelay(200); + /* now map other option and base registers */ + memctl->memc_or2 = CONFIG_SYS_OR2_PRELIM; + memctl->memc_br2 = CONFIG_SYS_BR2_PRELIM; + memctl->memc_or3 = CONFIG_SYS_OR3_PRELIM; + memctl->memc_br3 = CONFIG_SYS_BR3_PRELIM; + memctl->memc_or4 = CONFIG_SYS_OR4_PRELIM; + memctl->memc_br4 = CONFIG_SYS_BR4_PRELIM; + memctl->memc_or5 = CONFIG_SYS_OR5_PRELIM; + memctl->memc_br5 = CONFIG_SYS_BR5_PRELIM; + memctl->memc_or6 = CONFIG_SYS_OR6_PRELIM; + memctl->memc_br6 = CONFIG_SYS_BR6_PRELIM; + memctl->memc_or7 = CONFIG_SYS_OR7_PRELIM; + memctl->memc_br7 = CONFIG_SYS_BR7_PRELIM; + + ram_sz = get_ram_size(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_MAX_SIZE); + } + + gd->ram_size = ram_sz; + + return 0; +} + +/* ------------------------------------------------------------------------- + * Specific board pre-initialization + */ +int board_early_init_r (void) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + char *s; + +#if defined(CONFIG_WATCHDOG) + s = getenv("watchdog"); + /* watchdog disabled */ + if (strcmp(s, "off") == 0) { + printf(" Watchdog disabled\n"); + immr->im_siu_conf.sc_sypcr = CONFIG_SYS_SYPCR & ~(SYPCR_SWE | SYPCR_SWRI); + + /* watchdog is enabled */ + } else { + + /* NMI mode */ + if (strcmp(s, "nmi") == 0) { + printf(" Watchdog enabled nmi\n"); + immr->im_siu_conf.sc_sypcr = (CONFIG_SYS_SYPCR & ~(SYPCR_SWRI)) | SYPCR_SWE; + + /* normal mode by default */ + } else { + printf(" Watchdog enabled\n"); + immr->im_siu_conf.sc_sypcr = CONFIG_SYS_SYPCR | SYPCR_SWE | SYPCR_SWRI; + } + } +#else + immr->im_siu_conf.sc_sypcr = CONFIG_SYS_SYPCR & ~(SYPCR_SWE | SYPCR_SWRI); +#endif + return 0; +} + +/* ------------------------------------------------------------------------- + * Miscelaneous init + */ + +#define ADDR_CPLD_R_ETAT ((unsigned short *)0x10000806) +#define R_ID_CPLD_MASK 0xFF00 + +#define ADDR_FLASH_ENV_AREA ((unsigned short *)0x04040000) + +struct environment { + uint32_t crc; + uint8_t data[]; +}; + + +#define LEN_STR 80 + +int misc_init_r (void) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile iop8xx_t *iop = (iop8xx_t *) &immr->im_ioport; + char str[LEN_STR]; + char s_ethaddr[LEN_STR]; + char s_id_cpld[LEN_STR]; + char s_num_serie[LEN_STR]; + char s_password[LEN_STR]; + unsigned short version_cpld; + struct environment *env; + uint32_t crc; + char *s; + int i, j; + + /* -------------------------------------------- + * GPIO or per. Function + * PCPAR[13] = 0 [0x0004] -> GPIO: (BTN_ACQ_AL) + * -------------------------------------------- */ + iop->iop_pcpar |= 0x0000; /* set bits */ + iop->iop_pcpar &= ~0x0004; /* reset bit */ + + /* ---------------------------------------------- + * In/Out or per. Function 0/1 + * PCDIR[13] = 1 [0x0004] -> GPIO: IN (CS_POT1_5V) + * ---------------------------------------------- */ + iop->iop_pcdir |= 0x0000; + iop->iop_pcdir &= ~0x0004; + + /* if BTN_ACQ_IN is pressed then bootdelay is changed to 60 second */ + if ((iop->iop_pcdat & 0x0004) == 0) { + setenv("bootdelay", "60"); + } + + /* verifying environment variable area */ + env = (struct environment *)CONFIG_ENV_ADDR; + crc = crc32(0, env->data, (CONFIG_ENV_SIZE - sizeof(uint32_t))); + if (crc != env->crc) { + /* It can be an update request */ + for (i=0 ; i<8 ; i++) {str[i] = *(((uint8_t *)CONFIG_ENV_ADDR) + i); str[(i+1)] = 0;} + if (strcmp(str, "ETHADDR=") == 0) { + /* getting saved value */ + i = 0; + for (j=0 ; j<4 ; j++) { + while (*(((uint8_t *)CONFIG_ENV_ADDR) + i) != '=') { + i++; + } + switch (j) { + case 0: s = s_ethaddr; break; + case 1: s = s_num_serie; break; + case 2: s = s_id_cpld; break; + case 3: s = s_password; break; + } + do { + i++; + *s = *(((uint8_t *)CONFIG_ENV_ADDR) + i); + s++; + } while (*(((uint8_t *)CONFIG_ENV_ADDR) + i) != 0x00); + } + + /* creating or updating environment variable */ + if (s_ethaddr[0] != 0x00) { + setenv("ethaddr", s_ethaddr); + } + if (s_num_serie[0] != 0x00) { + setenv("num_serie", s_num_serie); + } + if (s_id_cpld[0] != 0x00) { + setenv("id_cpld", s_id_cpld); + } + if (s_password[0] != 0x00) { + setenv("password", s_password); + } + saveenv(); + } + } + + /* we do not modify environment variable area if CRC is false */ + crc = crc32(0, env->data, (CONFIG_ENV_SIZE - sizeof(uint32_t))); + if (crc == env->crc) { + /* getting version value in CPLD register */ + for (i=0 ; i<LEN_STR ; i++) str[i] = 0; + version_cpld = *ADDR_CPLD_R_ETAT & R_ID_CPLD_MASK; + if (((version_cpld >> 12) & 0x000f) < 0x000a) { + str[0] = ((version_cpld >> 12) & 0x000f) + 0x30; + } else { + str[0] = (((version_cpld >> 12) & 0x000f) - 0x000a) + 0x41; + } + if (((version_cpld >> 8) & 0x000f) < 0x000a) { + str[1] = ((version_cpld >> 8) & 0x000f) + 0x30; + } else { + str[1] = (((version_cpld >> 8) & 0x000f) - 0x000a) + 0x41; + } + str[2] = 0x30; + str[3] = 0x30; + + /* updating "id_cpld" variable if not corresponding with the value in register */ + s = getenv("id_cpld"); + if ((s == NULL) || (strcmp(s, str) != 0)) { + setenv("id_cpld", str); + saveenv(); + } + } + + return 0; +} + +int board_early_init_f (void) +{ + volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + + /* + * Erase FPGA(s) for reboot + */ + immr->im_cpm.cp_pbdat &= ~0x00020000; /* PROGFPGA down */ + immr->im_cpm.cp_pbdir |= 0x00020000; /* PROGFPGA output */ + udelay(1); /* Wait more than 300ns */ + immr->im_cpm.cp_pbdat |= 0x00020000; /* PROGFPGA up */ + return 0; +} + diff --git a/board/cssi/MCR3000/Makefile b/board/cssi/MCR3000/Makefile new file mode 100644 index 0000000000..4ae57b8bdc --- /dev/null +++ b/board/cssi/MCR3000/Makefile @@ -0,0 +1,9 @@ +# +# Copyright (C) 2010-2017 CS Systemes d'Information +# Christophe Leroy christophe.leroy@c-s.fr +# +# SPDX-License-Identifier: GPL-2.0+ +# +# + +obj-y = MCR3000.o nand.o diff --git a/board/cssi/MCR3000/nand.c b/board/cssi/MCR3000/nand.c new file mode 100644 index 0000000000..5c43205907 --- /dev/null +++ b/board/cssi/MCR3000/nand.c @@ -0,0 +1,77 @@ +/* + * Copyright (C) 2010-2017 CS Systemes d'Information + * Florent Trinh Thai florent.trinh-thai@c-s.fr + * Christophe Leroy christophe.leroy@c-s.fr + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> + +#if defined(CONFIG_CMD_NAND) +#include <nand.h> + +#define BIT_CLE ((unsigned short)0x0800) +#define BIT_ALE ((unsigned short)0x0400) +#define BIT_NCE ((unsigned short)0x1000) + +static void nand_hwcontrol(struct mtd_info *mtdinfo, int cmd, unsigned int ctrl) +{ + struct nand_chip *this = mtdinfo->priv; + volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; + unsigned short pddat = 0; + + + /* The hardware control change */ + if (ctrl & NAND_CTRL_CHANGE) { + + /* saving current value */ + pddat = immr->im_ioport.iop_pddat; + + /* Clearing ALE and CLE */ + pddat &= ~(BIT_CLE | BIT_ALE); + + /* Driving NCE pin */ + if (ctrl & NAND_NCE) { + pddat &= ~BIT_NCE; + } else { + pddat |= BIT_NCE; + } + + /* Driving CLE and ALE pin */ + if (ctrl & NAND_CLE) { + pddat |= BIT_CLE; + } + if (ctrl & NAND_ALE) { + pddat |= BIT_ALE; + } + + /* applying new value */ + immr->im_ioport.iop_pddat = pddat; + } + + /* Writing the command */ + if (cmd != NAND_CMD_NONE) { + *((unsigned char *)this->IO_ADDR_W) = (unsigned char)cmd; + } +} + +int board_nand_init(struct nand_chip *nand) +{ + volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; + + /* Set GPIO Port */ + immr->im_ioport.iop_pddir |= 0x1c00; + immr->im_ioport.iop_pdpar &= ~0x1c00; + immr->im_ioport.iop_pddat |= 0x1000; /* au repos CE doit etre à 1 */ + immr->im_ioport.iop_pddat &= ~0x0c00; /* au repos ALE et CLE sont à 0 */ + + nand->chip_delay = 60; + nand->ecc.mode = NAND_ECC_SOFT; + nand->cmd_ctrl = nand_hwcontrol; + + return 0; +} + +#endif /* defined(CONFIG_CMD_NAND) */ diff --git a/board/cssi/MCR3000/u-boot.lds b/board/cssi/MCR3000/u-boot.lds new file mode 100644 index 0000000000..2234bd8d1d --- /dev/null +++ b/board/cssi/MCR3000/u-boot.lds @@ -0,0 +1,91 @@ +/* + * Copyright (C) 2010-2017 CS Systemes d'Information + * Christophe Leroy christophe.leroy@c-s.fr + * + * (C) Copyright 2001-2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * Modified by Yuli Barcohen yuli@arabellasw.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +OUTPUT_ARCH(powerpc) +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .text : + { + arch/powerpc/cpu/mpc8xx/start.o (.text) + arch/powerpc/cpu/mpc8xx/start.o (.text*) + arch/powerpc/cpu/mpc8xx/traps.o (.text*) + arch/powerpc/cpu/mpc8xx/built-in.o (.text*) + arch/powerpc/lib/built-in.o (.text*) + board/cssi/MCR3000/built-in.o (.text*) + disk/built-in.o (.text*) + drivers/net/built-in.o (.text*) + + *(.text) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + + /* Read-write section, merged into data segment: */ + . = (. + 0x0FFF) & 0xFFFFF000; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + _GOT2_TABLE_ = .; + KEEP(*(.got2)) + KEEP(*(.got)) + _FIXUP_TABLE_ = .; + KEEP(*(.fixup)) + } + __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data*) + *(.sdata*) + } + _edata = .; + PROVIDE (edata = .); + + . = .; + + . = ALIGN(4); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(4096); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(4096); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.bss*) + *(.sbss*) + *(COMMON) + . = ALIGN(4); + } + __bss_end = . ; + PROVIDE (end = .); +} +ENTRY(_start) diff --git a/configs/MCR3000_defconfig b/configs/MCR3000_defconfig new file mode 100644 index 0000000000..61fea2ee09 --- /dev/null +++ b/configs/MCR3000_defconfig @@ -0,0 +1,37 @@ +CONFIG_PPC=y +CONFIG_8xx=y +CONFIG_TARGET_MCR3000=y +CONFIG_BOOTDELAY=5 +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_NET=y +CONFIG_CMD_DHCP=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +# CONFIG_MMC is not set +CONFIG_MTD_NOR_FLASH=y +# CONFIG_PCI is not set +CONFIG_OF_LIBFDT=y +CONFIG_SYS_PROMPT="S3K> " + +CONFIG_CMD_SAVEENV=y +CONFIG_CMD_FLASH=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_REGINFO=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_NAND=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_MD5SUM is not set +# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SETGETDCR is not set +# CONFIG_CMD_SHA1 is not set +# CONFIG_CMD_SOURCE is not set diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h new file mode 100644 index 0000000000..8268ba438e --- /dev/null +++ b/include/configs/MCR3000.h @@ -0,0 +1,293 @@ +/* + * Copyright (C) 2010-2017 CS Systemes d'Information + * Christophe Leroy christophe.leroy@c-s.fr + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/*----------------------------------------------------------------------- + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_MPC866 1 + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_BOARD_EARLY_INIT_R 1 /* Call board_early_init_r */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ + +#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ +#undef CONFIG_8xx_CONS_SMC2 +#undef CONFIG_8xx_CONS_NONE +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_EXTRA_ENV_SETTINGS "sdram_type=SDRAM\0" \ + "flash_type=AM29LV160DB\0" \ + "loadaddr=0x400000\0" \ + "filename=uImage.lzma\0" \ + "nfsroot=/opt/ofs\0" \ + "dhcp_ip=ip=:::::eth0:dhcp\0" \ + "console_args=console=ttyCPM0,115200N8\0" \ + "flashboot=setenv bootargs " \ + "${console_args} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:mcr3k:eth0:off " \ + "${ofl_args}; " \ + "bootm 0x04060000 - 0x04050000\0" \ + "tftpboot=setenv bootargs " \ + "${console_args} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:mcr3k:eth0:off " \ + "${ofl_args}; " \ + "tftp ${loadaddr} ${filename};" \ + "tftp 0xf00000 mcr3000.dtb;" \ + "bootm ${loadaddr} - 0xf00000\0" \ + "netboot=dhcp ${loadaddr} ${filename};" \ + "tftp 0xf00000 mcr3000.dtb;" \ + "setenv bootargs " \ + "root=/dev/nfs rw " \ + "${console_args} " \ + "${dhcp_ip};" \ + "bootm ${loadaddr} - 0xf00000\0" \ + "nfsboot=setenv bootargs " \ + "root=/dev/nfs rw nfsroot=${serverip}:${nfsroot} " \ + "${console_args} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:mcr3k:eth0:off;" \ + "bootm 0x04060000 - 0x04050000\0" \ + "dhcpboot=dhcp ${loadaddr} ${filename};" \ + "tftp 0xf00000 mcr3000.dtb;" \ + "setenv bootargs " \ + "${console_args} " \ + "${dhcp_ip} " \ + "${ofl_args}; " \ + "bootm ${loadaddr} - 0xf00000\0" + +#define CONFIG_BOOTDELAY 5 /* autoboot. Put -1 to disabled */ + +#define CONFIG_IPADDR 192.168.0.3 +#define CONFIG_SERVERIP 192.168.0.1 +#define CONFIG_NETMASK 255.0.0.0 + +#define CONFIG_BOOTCOMMAND "run flashboot" +#define CONFIG_BOOTARGS "ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs rootflags=sync " \ + "console=ttyCPM0,115200N8 " \ + "ip=${ipaddr}:::${netmask}:mcr3k:eth0:off" + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#undef CONFIG_LOADS_BAUD_CHANGE /* don't allow baudrate change */ + +#define CONFIG_WATCHDOG 1 /* watchdog enabled */ + + + +/*----------------------------------------------------------------------- + * Password configuration. + */ +#define CONFIG_AUTOBOOT_KEYED 1 /* Enable "password" protection */ +#define CONFIG_AUTOBOOT_PROMPT "\nEnter password - autoboot in %d sec...\n" +#define CONFIG_AUTOBOOT_DELAY_STR "root" /* 1st password */ + + + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#ifdef CONFIG_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "S3K> " +#endif + +#define CONFIG_SYS_MEMTEST_START 0x00002000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x00800000 /* 8 KB ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR 0x200000 /* default load address */ + +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + + +#define CONFIG_SYS_CLK_FREQ 132000000 +#define CONFIG_8xx_GCLK_FREQ 132000000 + + + +/*----------------------------------------------------------------------- + * Physical memory map of the MCR3000 board + */ +#define CONFIG_SYS_IMMR 0xFF000000 /* Internal Memory Mapped Register*/ + +#define CONFIG_SYS_OR0_PRELIM 0xFFC00926 +#define CONFIG_SYS_BR0_PRELIM 0x04000801 +#define CONFIG_SYS_OR1_PRELIM 0xFE000E00 +#define CONFIG_SYS_BR1_PRELIM 0x00000081 +#define CONFIG_SYS_OR2_PRELIM 0xFFFF8F2A +#define CONFIG_SYS_BR2_PRELIM 0x08000801 +#define CONFIG_SYS_OR3_PRELIM 0xFFFF8142 +#define CONFIG_SYS_BR3_PRELIM 0x0C000401 +#define CONFIG_SYS_OR4_PRELIM 0xFFFF8D08 +#define CONFIG_SYS_BR4_PRELIM 0x10000801 +#define CONFIG_SYS_OR5_PRELIM 0xFFFF8916 +#define CONFIG_SYS_BR5_PRELIM 0x14000801 +#define CONFIG_SYS_OR6_PRELIM 0xFFFF0908 +#define CONFIG_SYS_BR6_PRELIM 0x18000801 +#define CONFIG_SYS_OR7_PRELIM 0xFFFF810A +#define CONFIG_SYS_BR7_PRELIM 0x1C000001 + +#define ADDR_FLASH ( CONFIG_SYS_BR0_PRELIM & 0xFFFF0000) +#define ADDR_SDRAM ( CONFIG_SYS_BR1_PRELIM & 0xFFFF0000) +#define ADDR_RAMDP ( CONFIG_SYS_BR2_PRELIM & 0xFFFF0000) +#define ADDR_NAND ( CONFIG_SYS_BR3_PRELIM & 0xFFFF0000) +#define ADDR_MTSL1 ((CONFIG_SYS_BR4_PRELIM & 0xFFFF0000) | 0x00000000) +#define ADDR_MTSL2 ((CONFIG_SYS_BR4_PRELIM & 0xFFFF0000) | 0x00000200) +#define ADDR_E1 ((CONFIG_SYS_BR4_PRELIM & 0xFFFF0000) | 0x00000400) +#define ADDR_SEM ((CONFIG_SYS_BR4_PRELIM & 0xFFFF0000) | 0x00000600) +#define ADDR_CPLD ((CONFIG_SYS_BR4_PRELIM & 0xFFFF0000) | 0x00000800) + + + +/*----------------------------------------------------------------------- + * Definitions for initial stack pointer and data area (in DPRAM) + */ +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR +#define CONFIG_SYS_INIT_RAM_SIZE 0x2f00 /* End of used area in DPRAM */ +#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size (bytes) reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + + + +/*----------------------------------------------------------------------- + * RAM configuration (note that CONFIG_SYS_SDRAM_BASE must be zero) + */ +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_MAX_SIZE (32*1024*1024) /* 32 Mega Bytes */ + + + +/*----------------------------------------------------------------------- + * FLASH organization + */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_TEXT_BASE /* FLASH address */ +#define CONFIG_SYS_FLASH_CFI 1 /* The flash is CFI compatible */ +#define CONFIG_FLASH_CFI_DRIVER 1 /* Use common CFI driver */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 35 /* max number of sectors on one chip */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + + + +/*----------------------------------------------------------------------- + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 KB for Monitor */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_MALLOC_LEN (4096 << 10) /* Reserve 4096 KB for malloc() */ + + + +/*----------------------------------------------------------------------- + * Environment Configuration + */ +/* environment is in FLASH */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE (64 * 1024) /* Total size of Environment Sector */ +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR - CONFIG_SYS_FLASH_BASE) +#define CONFIG_ENV_OVERWRITE 1 /* Allow user to modify environment */ + + + +/*----------------------------------------------------------------------- + * Cache Configuration + */ +#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ + + + +/*----------------------------------------------------------------------- + * Configuration registers + */ +#if defined(CONFIG_WATCHDOG) +#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWE | SYPCR_SWRI | SYPCR_SWP) + +#else +#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) +#endif + +#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11 | SIUMCR_MLRC01) + +/* TBSCR - Time Base Status and Control Register */ +#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF | TBSCR_TBE) + +/* PISCR - Periodic Interrupt Status and Control */ +#define CONFIG_SYS_PISCR 0x0000 + +/* PLPRCR */ +#define CONFIG_SYS_PLPRCR (0x00460004) + +/* SCCR - System Clock and reset Control Register */ +#define SCCR_MASK SCCR_COM00 +#define CONFIG_SYS_SCCR (SCCR_RTSEL | SCCR_CRQEN | SCCR_EBDF01) + +#define CONFIG_SYS_DER (0x2002000F) + + + +/*----------------------------------------------------------------------- + * Ethernet configuration part + */ +#define CONFIG_MII 1 +#define CONFIG_SYS_DISCOVER_PHY 1 +#define CONFIG_MII_INIT 1 +#define FEC_ENET 1 + + + +/*----------------------------------------------------------------------- + * NAND configuration part + */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_MAX_CHIPS 1 +#define CONFIG_SYS_NAND_BASE 0x0C000000 /* Base address of the NAND FLASH */ + + + +/*----------------------------------------------------------------------- + * Pass open firmware flat tree + */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + + + +/*----------------------------------------------------------------------- + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + + + +/*----------------------------------------------------------------------- + * Misc Settings + */ +#define CONFIG_LZMA +#define CONFIG_SHA256 + + + +#endif /* __CONFIG_H */
In message 2ffe402f2d7b3c4d2156e6e1e9a871304c551efd.1498132599.git.christophe.leroy@c-s.fr you wrote:
Does not apply.
Christophe: it makes no sense to submit patches based on code that is no longer in the tree. The patches submitted to re-add the old code as is have been and will be NAKed. Sorry.
OK, please v2 this series on top of your v5 patch to bring back mpc8xx and v1 of your 7 part series to clean up various parts of mpc8xx, thanks!
Christophe Leroy
Joe Hershberger
