[U-Boot] [PATCH] ARM: uniphier: change UNIPHIER_SERIAL to default y option
This is very likely to be necessary for normal use cases. Set its default to 'y' for shorter defconfig files.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
configs/uniphier_ld11_defconfig | 1 - configs/uniphier_ld20_defconfig | 1 - configs/uniphier_ld4_sld8_defconfig | 1 - configs/uniphier_pro4_defconfig | 1 - configs/uniphier_pxs2_ld6b_defconfig | 1 - configs/uniphier_sld3_defconfig | 1 - drivers/serial/Kconfig | 1 + 7 files changed, 1 insertion(+), 6 deletions(-)
diff --git a/configs/uniphier_ld11_defconfig b/configs/uniphier_ld11_defconfig index 57b9c07..9b32d68 100644 --- a/configs/uniphier_ld11_defconfig +++ b/configs/uniphier_ld11_defconfig @@ -25,7 +25,6 @@ CONFIG_MISC=y CONFIG_I2C_EEPROM=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y -CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/uniphier_ld20_defconfig b/configs/uniphier_ld20_defconfig index e6aa525..7623381 100644 --- a/configs/uniphier_ld20_defconfig +++ b/configs/uniphier_ld20_defconfig @@ -26,7 +26,6 @@ CONFIG_I2C_EEPROM=y CONFIG_MMC_UNIPHIER=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y -CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 47b577a..f51e0da 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -31,7 +31,6 @@ CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y -CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/uniphier_pro4_defconfig b/configs/uniphier_pro4_defconfig index e156ec5..c47d02f 100644 --- a/configs/uniphier_pro4_defconfig +++ b/configs/uniphier_pro4_defconfig @@ -30,7 +30,6 @@ CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y -CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_pxs2_ld6b_defconfig index f943516..9eebad1 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_pxs2_ld6b_defconfig @@ -31,7 +31,6 @@ CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y -CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/uniphier_sld3_defconfig b/configs/uniphier_sld3_defconfig index 598cde2..2f6f476 100644 --- a/configs/uniphier_sld3_defconfig +++ b/configs/uniphier_sld3_defconfig @@ -28,7 +28,6 @@ CONFIG_NAND_DENALI=y CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y -CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 9ff7234..ab5df70 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -344,6 +344,7 @@ config SANDBOX_SERIAL config UNIPHIER_SERIAL bool "Support for UniPhier on-chip UART" depends on ARCH_UNIPHIER + default y help If you have a UniPhier based board and want to use the on-chip serial ports, say Y to this option. If unsure, say N.
2016-08-25 19:00 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
