[U-Boot] [PATCH v2 0/4] Add UniPhier GPIO driver support
Masahiro Yamada (4): gpio: UniPhier: add driver for UniPhier GPIO controller gpio: do not include <asm/arch/gpio.h> for UniPhier ARM: UniPhier: enable UniPhier GPIO driver ARM: dts: UniPhier: add GPIO controller nodes
arch/arm/Kconfig | 1 + arch/arm/dts/uniphier-ph1-ld4.dtsi | 7 ++ arch/arm/dts/uniphier-ph1-pro4.dtsi | 7 ++ arch/arm/dts/uniphier-ph1-sld3.dtsi | 7 ++ arch/arm/dts/uniphier-ph1-sld8.dtsi | 7 ++ arch/arm/include/asm/gpio.h | 2 + configs/ph1_ld4_defconfig | 1 + configs/ph1_pro4_defconfig | 1 + configs/ph1_sld8_defconfig | 1 + drivers/gpio/Kconfig | 6 ++ drivers/gpio/Makefile | 1 + drivers/gpio/gpio-uniphier.c | 192 ++++++++++++++++++++++++++++++++++++ 12 files changed, 233 insertions(+) create mode 100644 drivers/gpio/gpio-uniphier.c
This GPIO controller device is used on UniPhier SoCs.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - Do not use "ngpio" property to specify the number of GPIO pins. Instead, use .data field of OF match table.
drivers/gpio/Kconfig | 6 ++ drivers/gpio/Makefile | 1 + drivers/gpio/gpio-uniphier.c | 192 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 199 insertions(+) create mode 100644 drivers/gpio/gpio-uniphier.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 0c43777..1176e3f 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -36,6 +36,12 @@ config SANDBOX_GPIO_COUNT of 'anonymous' GPIOs that do not belong to any device or bank. Select a suitable value depending on your needs.
+config GPIO_UNIPHIER + bool "UniPhier GPIO" + depends on ARCH_UNIPHIER + help + Say yes here to support UniPhier GPIOs. + config VYBRID_GPIO bool "Vybrid GPIO driver" depends on DM diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 5864850..5ec4ad7 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -44,5 +44,6 @@ oby-$(CONFIG_SX151X) += sx151x.o obj-$(CONFIG_SUNXI_GPIO) += sunxi_gpio.o obj-$(CONFIG_LPC32XX_GPIO) += lpc32xx_gpio.o obj-$(CONFIG_STM32_GPIO) += stm32_gpio.o +obj-$(CONFIG_GPIO_UNIPHIER) += gpio-uniphier.o obj-$(CONFIG_ZYNQ_GPIO) += zynq_gpio.o obj-$(CONFIG_VYBRID_GPIO) += vybrid_gpio.o diff --git a/drivers/gpio/gpio-uniphier.c b/drivers/gpio/gpio-uniphier.c new file mode 100644 index 0000000..e65e9f3 --- /dev/null +++ b/drivers/gpio/gpio-uniphier.c @@ -0,0 +1,192 @@ +/* + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <mapmem.h> +#include <linux/io.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <dm/device.h> + +/* + * Unfortunately, the hardware specification adopts weird GPIO pin labeling. + * The ports are named as + * PORT00, PORT01, PORT02, ..., PORT07, + * PORT10, PORT11, PORT12, ..., PORT17, + * PORT20, PORT21, PORT22, ..., PORT27, + * ... + * PORT90, PORT91, PORT92, ..., PORT97, + * PORT100, PORT101, PORT102, ..., PORT107, + * ... + * + * The PORTs with 8 or 9 in the one's place are missing, i.e. the one's place + * is octal, while the other places are decimal. If we handle the port numbers + * as seen in the hardware documents, the GPIO offsets must be non-contiguous. + * It is possible to have sparse GPIO pins, but not handy for GPIO range + * mappings, register accessing, etc. + * + * To make things simpler (for driver and device tree implementation), this + * driver takes contiguously-numbered GPIO offsets. GPIO consumers should make + * sure to convert the PORT number into the one that fits in this driver. + * The conversion logic is very easy math, for example, + * PORT15 --> GPIO offset 13 (8 * 1 + 5) + * PORT123 --> GPIO offset 99 (8 * 12 + 3) + */ +#define UNIPHIER_GPIO_PORTS_PER_BANK 8 + +#define UNIPHIER_GPIO_REG_DATA 0 /* data */ +#define UNIPHIER_GPIO_REG_DIR 4 /* direction (1:in, 0:out) */ + +/* delete the following when BIT(nr) is added to include/linux/bitops.h */ +#define BIT(nr) (1UL << (nr)) + +struct uniphier_gpio_priv { + void __iomem *base; +}; + +static unsigned uniphier_gpio_bank_to_reg(unsigned bank, unsigned reg_type) +{ + unsigned reg; + + reg = (bank + 1) * 8 + reg_type; + + /* + * Unfortunately, there is a register hole at offset 0x90-0x9f. + * Add 0x10 when crossing the hole. + */ + if (reg >= 0x90) + reg += 0x10; + + return reg; +} + +static void uniphier_gpio_offset_write(struct udevice *dev, unsigned offset, + unsigned reg_type, int value) +{ + struct uniphier_gpio_priv *priv = dev_get_priv(dev); + unsigned bank = offset / UNIPHIER_GPIO_PORTS_PER_BANK; + unsigned bit = offset % UNIPHIER_GPIO_PORTS_PER_BANK; + unsigned reg; + u32 tmp; + + reg = uniphier_gpio_bank_to_reg(bank, reg_type); + + tmp = readl(priv->base + reg); + if (value) + tmp |= BIT(bit); + else + tmp &= ~BIT(bit); + writel(tmp, priv->base + reg); +} + +static int uniphier_gpio_offset_read(struct udevice *dev, unsigned offset, + unsigned reg_type) +{ + struct uniphier_gpio_priv *priv = dev_get_priv(dev); + unsigned bank = offset / UNIPHIER_GPIO_PORTS_PER_BANK; + unsigned bit = offset % UNIPHIER_GPIO_PORTS_PER_BANK; + unsigned reg; + + reg = uniphier_gpio_bank_to_reg(bank, reg_type); + + return readl(priv->base + reg) & BIT(bit) ? 1 : 0; +} + +static int uniphier_gpio_direction_input(struct udevice *dev, unsigned offset) +{ + uniphier_gpio_offset_write(dev, offset, UNIPHIER_GPIO_REG_DIR, 1); + + return 0; +} + +static int uniphier_gpio_direction_output(struct udevice *dev, unsigned offset, + int value) +{ + uniphier_gpio_offset_write(dev, offset, UNIPHIER_GPIO_REG_DATA, value); + uniphier_gpio_offset_write(dev, offset, UNIPHIER_GPIO_REG_DIR, 0); + + return 0; +} + +static int uniphier_gpio_get_value(struct udevice *dev, unsigned offset) +{ + return uniphier_gpio_offset_read(dev, offset, UNIPHIER_GPIO_REG_DATA); +} + +static int uniphier_gpio_set_value(struct udevice *dev, unsigned offset, + int value) +{ + uniphier_gpio_offset_write(dev, offset, UNIPHIER_GPIO_REG_DATA, value); + + return 0; +} + +static int uniphier_gpio_get_function(struct udevice *dev, unsigned offset) +{ + return uniphier_gpio_offset_read(dev, offset, UNIPHIER_GPIO_REG_DIR) ? + GPIOF_INPUT : GPIOF_OUTPUT; +} + +static const struct dm_gpio_ops uniphier_gpio_ops = { + .direction_input = uniphier_gpio_direction_input, + .direction_output = uniphier_gpio_direction_output, + .get_value = uniphier_gpio_get_value, + .set_value = uniphier_gpio_set_value, + .get_function = uniphier_gpio_get_function, +}; + +static int uniphier_gpio_probe(struct udevice *dev) +{ + struct uniphier_gpio_priv *priv = dev_get_priv(dev); + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + DECLARE_GLOBAL_DATA_PTR; + fdt_addr_t addr; + fdt_size_t size; + + addr = fdtdec_get_addr_size(gd->fdt_blob, dev->of_offset, "reg", + &size); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->base = map_sysmem(addr, size); + if (!priv->base) + return -ENOMEM; + + uc_priv->gpio_count = UNIPHIER_GPIO_PORTS_PER_BANK * dev->driver_data; + + return 0; +} + +static int uniphier_gpio_remove(struct udevice *dev) +{ + struct uniphier_gpio_priv *priv = dev_get_priv(dev); + + unmap_sysmem(priv->base); + + return 0; +} + +/* .data = the number of GPIO banks */ +static const struct udevice_id uniphier_gpio_match[] = { + { .compatible = "socionext,ph1-sld3-gpio", .data = 17 }, + { .compatible = "socionext,ph1-ld4-gpio", .data = 17 }, + { .compatible = "socionext,ph1-pro4-gpio", .data = 31 }, + { .compatible = "socionext,ph1-sld8-gpio", .data = 17 }, + { .compatible = "socionext,ph1-pro5-gpio", .data = 31 }, + { .compatible = "socionext,proxstream2-gpio", .data = 29 }, + { .compatible = "socionext,ph1-ld6b-gpio", .data = 29 }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(uniphier_gpio) = { + .name = "uniphier_gpio", + .id = UCLASS_GPIO, + .of_match = uniphier_gpio_match, + .probe = uniphier_gpio_probe, + .remove = uniphier_gpio_remove, + .priv_auto_alloc_size = sizeof(struct uniphier_gpio_priv), + .ops = &uniphier_gpio_ops, +};
Hi Masahiro,
On 17 July 2015 at 05:15, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Changes in v2:
Since this seems to be in my queue. Please see below for a question.
help
- Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com
- Unfortunately, the hardware specification adopts weird GPIO pin labeling.
- The ports are named as
- PORT00, PORT01, PORT02, ..., PORT07,
- PORT10, PORT11, PORT12, ..., PORT17,
- PORT20, PORT21, PORT22, ..., PORT27,
- PORT90, PORT91, PORT92, ..., PORT97,
- PORT100, PORT101, PORT102, ..., PORT107,
- The PORTs with 8 or 9 in the one's place are missing, i.e. the one's place
- is octal, while the other places are decimal. If we handle the port numbers
- as seen in the hardware documents, the GPIO offsets must be non-contiguous.
- It is possible to have sparse GPIO pins, but not handy for GPIO range
- mappings, register accessing, etc.
- To make things simpler (for driver and device tree implementation), this
- driver takes contiguously-numbered GPIO offsets. GPIO consumers should make
- sure to convert the PORT number into the one that fits in this driver.
- The conversion logic is very easy math, for example,
- PORT15 --> GPIO offset 13 (8 * 1 + 5)
- PORT123 --> GPIO offset 99 (8 * 12 + 3)
void __iomem *base;
unsigned reg;
if (reg >= 0x90)
reg += 0x10;
return reg;
unsigned reg;
u32 tmp;
if (value)
tmp |= BIT(bit);
else
tmp &= ~BIT(bit);
unsigned reg_type)
unsigned reg;
int value)
int value)
fdt_addr_t addr;
fdt_size_t size;
&size);
return -EINVAL;
if (!priv->base)
return -ENOMEM;
But I just want to check - here you are not setting a bank name. In fact you are only defining a single bank of GPIOs and the only way to access them will be by number (both in device tree and on command line).
I see your Linux patches do a similar thing so I guess this is right.
{ /* sentinel */ }
.id = UCLASS_GPIO,
1.9.1
2015-08-26 12:53 GMT+09:00 Simon Glass sjg@chromium.org:
Hi Masahiro,
Changes in v2:
[snip]
Yes, numbering access is available.
This GPIO driver has not been applied in Linux either. Nor I have not decided the design policy yet.
I marked this series as Deferred to not have you under obligation.
I will come back here after finishing Linux GPIO stuff.
I implemented a GPIO driver based on Driver Model for the UniPhier SoC family, but I could not find any good reason why such SoC specific GPIO headers are needed.
Changes in v2: None
arch/arm/include/asm/gpio.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/gpio.h b/arch/arm/include/asm/gpio.h index d49ad08..fe4419c 100644 --- a/arch/arm/include/asm/gpio.h +++ b/arch/arm/include/asm/gpio.h @@ -1,2 +1,4 @@ +#ifndef CONFIG_ARCH_UNIPHIER #include <asm/arch/gpio.h> +#endif #include <asm-generic/gpio.h>
Changes in v2: None
It is true that with device tree this probably isn't needed.
Some other boards just have dummy files. How do you suggest we deal with this? I feel that adding dummy files is a reasonable approach until everything is converted.
But I suppose this is another way.
Hi Simon,
Changes in v2: None
I do not prefer dummy files.
We can increase ifdefs with conversion progress
#if !defined(CONFIG_ARCH_UNIPHIER) && \ !defined(CONFIG_ARCH_FOO) && \ !defined(CONFIG_ARCH_BAR) #include <asm/arch/gpio.h> #endif
Or, let SoCs select HAVE_ARCH_GPIO.
In Kconfig,
config TEGRA ... select HAVE_ARCH_GPIO
then,
#ifdef CONFIG_HAVE_ARCH_GPIO #include <asm/arch/gpio.h> #endif
We can later drop "select HAVE_ARCH_GPIO" after converting the GPIO to DM.
Changes in v2: None
arch/arm/Kconfig | 1 + configs/ph1_ld4_defconfig | 1 + configs/ph1_pro4_defconfig | 1 + configs/ph1_sld8_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 506463c..89c33ae 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -809,6 +809,7 @@ config ARCH_UNIPHIER select SPL select OF_CONTROL select DM + select DM_GPIO select DM_SERIAL select DM_I2C select SPL_DISABLE_OF_CONTROL diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index f84dcdf..37d8eb3 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y CONFIG_UNIPHIER_SERIAL=y +CONFIG_GPIO_UNIPHIER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 2fc844d..f64ef5d 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y CONFIG_UNIPHIER_SERIAL=y +CONFIG_GPIO_UNIPHIER=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index 2af45d2..ca30192 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y CONFIG_UNIPHIER_SERIAL=y +CONFIG_GPIO_UNIPHIER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y
Changes in v2: None
Add GPIO (generic port) controller nodes for PH1-sLD3, PH1-LD4, PH1-Pro4 and PH1-sLD8.
Changes in v2: - Drop "ngpio" property - Change the compatibility string
arch/arm/dts/uniphier-ph1-ld4.dtsi | 7 +++++++ arch/arm/dts/uniphier-ph1-pro4.dtsi | 7 +++++++ arch/arm/dts/uniphier-ph1-sld3.dtsi | 7 +++++++ arch/arm/dts/uniphier-ph1-sld8.dtsi | 7 +++++++ 4 files changed, 28 insertions(+)
diff --git a/arch/arm/dts/uniphier-ph1-ld4.dtsi b/arch/arm/dts/uniphier-ph1-ld4.dtsi index 39d7b24..ac4336c 100644 --- a/arch/arm/dts/uniphier-ph1-ld4.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld4.dtsi @@ -71,6 +71,13 @@ clock-frequency = <36864000>; };
+ gpio: gpio@55000000 { + compatible = "socionext,ph1-ld4-gpio"; + reg = <0x55000000 0x200>; + gpio-controller; + #gpio-cells = <2>; + }; + i2c0: i2c@58400000 { compatible = "socionext,uniphier-i2c"; #address-cells = <1>; diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index f06906c..c70e977 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -78,6 +78,13 @@ clock-frequency = <73728000>; };
+ gpio: gpio@55000000 { + compatible = "socionext,ph1-pro4-gpio"; + reg = <0x55000000 0x200>; + gpio-controller; + #gpio-cells = <2>; + }; + i2c0: i2c@58780000 { compatible = "socionext,uniphier-fi2c"; #address-cells = <1>; diff --git a/arch/arm/dts/uniphier-ph1-sld3.dtsi b/arch/arm/dts/uniphier-ph1-sld3.dtsi index 2fa42a6..f378072 100644 --- a/arch/arm/dts/uniphier-ph1-sld3.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld3.dtsi @@ -93,6 +93,13 @@ clock-frequency = <36864000>; };
+ gpio: gpio@55000000 { + compatible = "socionext,ph1-sld3-gpio"; + reg = <0x55000000 0x200>; + gpio-controller; + #gpio-cells = <2>; + }; + i2c0: i2c@58400000 { compatible = "socionext,uniphier-i2c"; #address-cells = <1>; diff --git a/arch/arm/dts/uniphier-ph1-sld8.dtsi b/arch/arm/dts/uniphier-ph1-sld8.dtsi index 15df50f..b208f3c 100644 --- a/arch/arm/dts/uniphier-ph1-sld8.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld8.dtsi @@ -71,6 +71,13 @@ clock-frequency = <80000000>; };
+ gpio: gpio@55000000 { + compatible = "socionext,ph1-sld8-gpio"; + reg = <0x55000000 0x200>; + gpio-controller; + #gpio-cells = <2>; + }; + i2c0: i2c@58400000 { compatible = "socionext,uniphier-i2c"; #address-cells = <1>;
Changes in v2:
Masahiro Yamada
