[U-Boot] [PATCH-OMAP3] OMAP3: Fix broken NAND ECC HW switch
Fix broken NAND ECC HW switch and invert logic of if(!hardware) for easier reading.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
--- drivers/mtd/nand/omap_gpmc.c | 21 ++++++++++++++++----- 1 files changed, 16 insertions(+), 5 deletions(-)
Index: u-boot-arm/drivers/mtd/nand/omap_gpmc.c =================================================================== --- u-boot-arm.orig/drivers/mtd/nand/omap_gpmc.c +++ u-boot-arm/drivers/mtd/nand/omap_gpmc.c @@ -255,12 +255,17 @@ void omap_nand_switch_ecc(int32_t hardwa nand->options = NAND_NO_PADDING | NAND_CACHEPRG | NAND_NO_AUTOINCR | NAND_NO_AUTOINCR;
+ /* Reset ecc interface */ + nand->ecc.read_page = NULL; + nand->ecc.write_page = NULL; + nand->ecc.read_oob = NULL; + nand->ecc.write_oob = NULL; + nand->ecc.hwctl = NULL; + nand->ecc.correct = NULL; + nand->ecc.calculate = NULL; + /* Setup the ecc configurations again */ - if (!hardware) { - nand->ecc.mode = NAND_ECC_SOFT; - /* Use mtd default settings */ - nand->ecc.layout = NULL; - } else { + if (hardware) { nand->ecc.mode = NAND_ECC_HW; nand->ecc.layout = &hw_nand_oob; nand->ecc.size = 512; @@ -269,6 +274,12 @@ void omap_nand_switch_ecc(int32_t hardwa nand->ecc.correct = omap_correct_data; nand->ecc.calculate = omap_calculate_ecc; omap_hwecc_init(nand); + printf("HW ECC selected\n"); + } else { + nand->ecc.mode = NAND_ECC_SOFT; + /* Use mtd default settings */ + nand->ecc.layout = NULL; + printf("SW ECC selected\n"); }
/* Update NAND handling after ECC mode switch */
Applied to u-boot-arm/omap
Best Regards, J.
dirk.behmeï¼ googlemail.com
Jean-Christophe PLAGNIOL-VILLARD
