[U-Boot] [PATCH] QONG: fix and update board config file
Fix flash memory map and other updates for QONG board:
- adjust/fix "kernel_addr" settings - adjust/fix mtdparts NOR flash settings - add mtdparts NAND flash mapping - sort command list - enable "setexpr" command - enable ext2 support - delete bogus comment
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Stefano Babic sbabic@denx.de --- include/configs/qong.h | 32 ++++++++++++++------------------ 1 files changed, 14 insertions(+), 18 deletions(-)
diff --git a/include/configs/qong.h b/include/configs/qong.h index f26ced1..426d90d 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -102,6 +102,7 @@ #define CONFIG_USB_STORAGE #define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT +#define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #endif /* CONFIG_CMD_USB */
@@ -124,25 +125,16 @@ #include <config_cmd_default.h>
#define CONFIG_CMD_CACHE -#define CONFIG_CMD_PING +#define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP -#define CONFIG_CMD_NET #define CONFIG_CMD_MII #define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_SETEXPR #define CONFIG_CMD_SPI -#define CONFIG_CMD_DATE -#define BOARD_LATE_INIT
-/* - * You can compile in a MAC address and your custom net settings by using - * the following syntax. - * - * #define CONFIG_ETHADDR xx:xx:xx:xx:xx:xx - * #define CONFIG_SERVERIP <server ip> - * #define CONFIG_IPADDR <board ip> - * #define CONFIG_GATEWAYIP <gateway ip> - * #define CONFIG_NETMASK <your netmask> - */ +#define BOARD_LATE_INIT
#define CONFIG_BOOTDELAY 5
@@ -164,7 +156,7 @@ "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ "addmisc=setenv bootargs ${bootargs}\0" \ "uboot_addr=A0000000\0" \ - "kernel_addr=A00A0000\0" \ + "kernel_addr=A00C0000\0" \ "ramdisk_addr=A0300000\0" \ "u-boot=qong/u-boot.bin\0" \ "kernel_addr_r=80800000\0" \ @@ -296,10 +288,14 @@ extern int qong_nand_rdy(void *chip); #define CONFIG_LZO #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_FLASH_CFI_MTD -#define MTDIDS_DEFAULT "nor0=physmap-flash.0" +#define MTDIDS_DEFAULT "nor0=physmap-flash.0," \ + "nand0=gen_nand" #define MTDPARTS_DEFAULT \ - "mtdparts=physmap-flash.0:384k(U-Boot),128k(env1)," \ - "128k(env2),2432k(kernel),13m(ramdisk),-(user)" + "mtdparts=physmap-flash.0:" \ + "512k(U-Boot),128k(env1),128k(env2)," \ + "2304k(kernel),13m(ramdisk),-(user);" \ + "gen_nand:" \ + "128m(nand)"
/* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0x80000000
- sort command list
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Stefano Babic
