[U-Boot] [PATCH v7 00/12] SPI-NAND support
During the last months, Boris Brezillon shared his work to support serial flashes within Linux. First, he delivered (and merged) a new layer called spi-mem. He also initiated in Linux MTD subsystem the move of all 'raw' NAND related code to a raw/ subdirectory, adding at the same time a NAND core that would be shared with all NAND devices. Then, he contributed a generic SPI-NAND driver, making use of this NAND core, as well as some vendor code to drive a few chips.
On top of this work, I made some cleanups in the MTD layer and added an 'mtd' U-Boot command to handle all sort of MTD devices. This should become the default command instead of having one per flash flavor ('sf', 'nand', 'spi-nand' ?).
The series has been tested on an Ocelot board PCB123 (VSC7514), featuring a Macronix SPI NAND chip.
TL;DR: the series contains (stripped version since 23 patches have already been taken): - Various fixes - Support for spi-nand devices in mtdparts. - Generics mtdparts/mtdids parsers. - A new 'mtd' command. - A note to set mtdparts command legacy.
To test your SPI-NAND device with U-Boot, you can test someting like:
setenv mtdparts 'spi-nand0:1m(foo),-(bar)' setenv mtdids 'spi-nand0=spi0.0' # spi0.0 is Linux MTD name for this device ubi part bar # create a static UBI volume in the bar partition mtd list # show the current MTD devices/partitions
Thanks, Miquèl
Changes since v7: ----------------- * Added Stefan R-b tags. * Used tolower() as suggested by Stefan in lib/strto.c. * Added a mention saying that we continue to abuse the kB suffix in lib/strto.c by not making a difference between kB and kiB which both mean "* 1024" for us. This has been added in the commit log. * Fixed various bugs in the mtd command and in the parsers, they should be pretty stable now (tested with two MTD devices probed and several different partition configurations). * mtdids is not deprecated at all as opposed at what I wrote in v6. U-Boot still uses its own MTD names (being <type><idx> like nor0 or spi-nand1) and mtdids is still needed to do the glue. * Removed a useless patch removing a Kconfig entry I added myself since during a rebase someone else also added this symbol.
Changes since v6: ----------------- * Squashed Boris' fixes about build issues in Travis. * Merged Stefan Roese's contributions. * cmd: mtdparts: * added fallthrough comments in switch blocks deriving sizes. * balanced debug messages to compare freed and allocated partitions. * move mtdparts_init() declaration in mtd/partitions.h to be used in mtd command as well. * introduced a "compatibility" function to return what the MTD device name could be thanks to the mtdids environment variable (which is useless with the new partitioning logic). * mtd: mtdpart: * reworked the way partitions are created/handled. * cmd: mtd: * implement a partitioning logic that takes the best out of the MTD layer without re-inventing the wheel. Partitions are all freed correctly when the value of mtdparts changes. * balance get_mtd_device() by put_mtd_device() calls. * prevent memory leak by reorganizing the code a bit in do_mtd. * do not reconstruct partition list when a partition is already in use (complain about that instead). * add support for the legacy mtdids (not needed anymore if mtdparts directly uses the MTD device names as in Linux. * cmd: ubi: * clean and simplify the partition handling a bit to make use the best use of the MTD layer as well and keep the code simple.
Changes since v5: ----------------- * Included Boris fixup about the build issues. * Added Rb/Ab tags from Jagan on patchs 20/21.
Changes since v4: ----------------- * Added Jagan's Acked-by tags to every patch related to the SPI-mem/SPI-NAND addition. * Rebased on top of master.
Changes since v3: ----------------- * Fixed the debug messages in spi-mem to print either Rx or Tx data. * Fixed a Kconfig error that prevented to build mtdparts with plain defconfig. * Fixed a compilation error due to the above error that prevented one file to be compiled. * Adapted the mtd command to probe MTD partitions also. * Declared mtd_probe_devices() in a header so mtdparts or UBI could use it too (to probe all devices and MTD partitions in a clean way). * As I worked on mtdparts, I found annoying and completely useless the fact that we need to prefix the environment variable with "mtdparts=". Canceled this obligation. * Added one patch to allow spi-nand devices to be recognized by mtdparts (this is purely useless but needed to be done in order to use this command). * Removed useless definitions of MTD device types in UBI code. * Wrote a generic mtdparts environment variable parser, used by the mtd command. * Used the mtd_probe_devices() function from get_mtd_info() in cmd/mtdparts.c to be sure the desired partition really does not exist (otherwise it will be probed and then found).
Changes since v2: ----------------- * Rebased on u-boot master branch. * Removed extra-parenthesis in "mtd: Fallback to ->_read/write() when ->_read/write_oob() is missing" * s/fiels/files/ in "mtd: move NAND fiels into a raw/ subdirectory" * Do not describe generic SPI device properties in SPI NAND bindings. * Changes in the mtd command: * Printing more information in 'mtd list' (device type, device characteristics) * Switch to do_div() instead of '(u32)value64b % value32b' which only worked because value32b was a power of 2. * Removed erase.chip option. * By default, erase/read/write happen on the full MTD device while a dump will only work on a single page.
Changes since v1: ----------------- * Fixed the nand_memorg structure of the MX35LF2GE4AB chip. * Added Reviewed-by tags from Jagan. * Backported and squashed two patches fixing things in the SPI NAND core received on the Linux ML. * Backported more changes in mtdcore.c from Linux. * Added a patch to add a fallback on mtd->_read/_write() in mtdcore.c when mtd->_read/write_oob() is not supported. * Removed the DT changes, useless as the DTs are not available in mainline yet. * Addressed Boris/Stefan comments on the 'mtd' command. * Added support for multi-pages OOB read/write.
Miquel Raynal (12): lib: strto: parse all lowercase metric prefixes in ustrtoul[l] lib: strto: fix metric suffix parsing in strtoul[l] cmd: mtdparts: accept spi-nand devices cmd: mtdparts: remove mandatory 'mtdparts=' prefix mtd: uclass: add probe function mtd: uclass: add a generic 'mtdparts' parser mtd: uclass: search for an equivalent MTD name with the mtdids mtd: mtdpart: implement proper partition handling cmd: mtd: add 'mtd' command cmd: mtdparts: try to probe the MTD devices as a fallback cmd: ubi: clean the partition handling cmd: mtdparts: describe as legacy
cmd/Kconfig | 18 +- cmd/Makefile | 1 + cmd/mtd.c | 521 ++++++++++++++++++++++++++ cmd/mtdparts.c | 46 ++- cmd/ubi.c | 100 ++--- drivers/mtd/Makefile | 2 +- drivers/mtd/mtd-uclass.c | 16 + drivers/mtd/mtdcore.c | 2 + drivers/mtd/mtdpart.c | 660 +++++++++++++++++++++------------ include/jffs2/load_kernel.h | 7 +- include/linux/mtd/mtd.h | 31 ++ include/linux/mtd/partitions.h | 5 +- include/mtd.h | 3 + lib/strto.c | 36 +- 14 files changed, 1094 insertions(+), 354 deletions(-) create mode 100644 cmd/mtd.c
Both ustrtoul and ustrtoull interpret 1k but not 1m or 1g. Even if the SI symbols for Mega and Giga are 'M' and 'G', certain entries of eg. mtdparts also use (wrongly) the metric prefix 'm' and 'g'.
I do not see how parsing lowercase prefixes could break anything, so parse them like their uppercase counterpart.
Also, even though kiB is not equal to kB in general, lets not change U-Boot behavior and always use kiB and kB (same applies for MiB vs. MB and GiB vs. GB) as a representation for 1024 instead of 1000.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Stefan Roese sr@denx.de --- lib/strto.c | 14 ++++++-------- 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/lib/strto.c b/lib/strto.c index 7f6076909a..b7fc31d6e5 100644 --- a/lib/strto.c +++ b/lib/strto.c @@ -85,14 +85,13 @@ long simple_strtol(const char *cp, char **endp, unsigned int base) unsigned long ustrtoul(const char *cp, char **endp, unsigned int base) { unsigned long result = simple_strtoul(cp, endp, base); - switch (**endp) { - case 'G': + switch (tolower(**endp)) { + case 'g': result *= 1024; /* fall through */ - case 'M': + case 'm': result *= 1024; /* fall through */ - case 'K': case 'k': result *= 1024; if ((*endp)[1] == 'i') { @@ -108,14 +107,13 @@ unsigned long ustrtoul(const char *cp, char **endp, unsigned int base) unsigned long long ustrtoull(const char *cp, char **endp, unsigned int base) { unsigned long long result = simple_strtoull(cp, endp, base); - switch (**endp) { - case 'G': + switch (tolower(**endp)) { + case 'g': result *= 1024; /* fall through */ - case 'M': + case 'm': result *= 1024; /* fall through */ - case 'K': case 'k': result *= 1024; if ((*endp)[1] == 'i') {
While 1kB or 1kiB will be parsed correctly, 1k will return the right amount, but the metric suffix will not be escaped once the char pointer updated. Fix this situation by simplifying the move of the endp pointer.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Stefan Roese sr@denx.de --- lib/strto.c | 22 ++++++++++------------ 1 file changed, 10 insertions(+), 12 deletions(-)
diff --git a/lib/strto.c b/lib/strto.c index b7fc31d6e5..55ff9f7437 100644 --- a/lib/strto.c +++ b/lib/strto.c @@ -94,12 +94,11 @@ unsigned long ustrtoul(const char *cp, char **endp, unsigned int base) /* fall through */ case 'k': result *= 1024; - if ((*endp)[1] == 'i') { - if ((*endp)[2] == 'B') - (*endp) += 3; - else - (*endp) += 2; - } + (*endp)++; + if (**endp == 'i') + (*endp)++; + if (**endp == 'B') + (*endp)++; } return result; } @@ -116,12 +115,11 @@ unsigned long long ustrtoull(const char *cp, char **endp, unsigned int base) /* fall through */ case 'k': result *= 1024; - if ((*endp)[1] == 'i') { - if ((*endp)[2] == 'B') - (*endp) += 3; - else - (*endp) += 2; - } + (*endp)++; + if (**endp == 'i') + (*endp)++; + if (**endp == 'B') + (*endp)++; } return result; }
Let spi-nand devices be recognized by mtdparts. This is superfluous but a full mtdparts rework would be very time-consuming.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Acked-by: Jagan Teki jagan@openedev.com Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com Reviewed-by: Stefan Roese sr@denx.de --- cmd/mtdparts.c | 13 ++++++++----- include/jffs2/load_kernel.h | 7 +++++-- 2 files changed, 13 insertions(+), 7 deletions(-)
diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 756fc6018f..2e547894c6 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -37,7 +37,7 @@ * mtdids=<idmap>[,<idmap>,...] * * <idmap> := <dev-id>=<mtd-id> - * <dev-id> := 'nand'|'nor'|'onenand'<dev-num> + * <dev-id> := 'nand'|'nor'|'onenand'|'spi-nand'<dev-num> * <dev-num> := mtd device number, 0... * <mtd-id> := unique device tag used by linux kernel to find mtd device (mtd->name) * @@ -339,7 +339,7 @@ static int part_validate_eraseblock(struct mtdids *id, struct part_info *part)
if (!mtd->numeraseregions) { /* - * Only one eraseregion (NAND, OneNAND or uniform NOR), + * Only one eraseregion (NAND, SPI-NAND, OneNAND or uniform NOR), * checking for alignment is easy here */ offset = part->offset; @@ -1030,7 +1030,7 @@ static struct mtdids* id_find_by_mtd_id(const char *mtd_id, unsigned int mtd_id_ }
/** - * Parse device id string <dev-id> := 'nand'|'nor'|'onenand'<dev-num>, + * Parse device id string <dev-id> := 'nand'|'nor'|'onenand'|'spi-nand'<dev-num>, * return device type and number. * * @param id string describing device id @@ -1054,6 +1054,9 @@ int mtd_id_parse(const char *id, const char **ret_id, u8 *dev_type, } else if (strncmp(p, "onenand", 7) == 0) { *dev_type = MTD_DEV_TYPE_ONENAND; p += 7; + } else if (strncmp(p, "spi-nand", 8) == 0) { + *dev_type = MTD_DEV_TYPE_SPINAND; + p += 8; } else { printf("incorrect device type in %s\n", id); return 1; @@ -1636,7 +1639,7 @@ static int parse_mtdids(const char *const ids) while(p && (*p != '\0')) {
ret = 1; - /* parse 'nor'|'nand'|'onenand'<dev-num> */ + /* parse 'nor'|'nand'|'onenand'|'spi-nand'<dev-num> */ if (mtd_id_parse(p, &p, &type, &num) != 0) break;
@@ -2112,7 +2115,7 @@ static char mtdparts_help_text[] = "'mtdids' - linux kernel mtd device id <-> u-boot device id mapping\n\n" "mtdids=<idmap>[,<idmap>,...]\n\n" "<idmap> := <dev-id>=<mtd-id>\n" - "<dev-id> := 'nand'|'nor'|'onenand'<dev-num>\n" + "<dev-id> := 'nand'|'nor'|'onenand'|'spi-nand'<dev-num>\n" "<dev-num> := mtd device number, 0...\n" "<mtd-id> := unique device tag used by linux kernel to find mtd device (mtd->name)\n\n" "'mtdparts' - partition list\n\n" diff --git a/include/jffs2/load_kernel.h b/include/jffs2/load_kernel.h index 1ddff062ad..9346d7ee9f 100644 --- a/include/jffs2/load_kernel.h +++ b/include/jffs2/load_kernel.h @@ -15,9 +15,12 @@ #define MTD_DEV_TYPE_NOR 0x0001 #define MTD_DEV_TYPE_NAND 0x0002 #define MTD_DEV_TYPE_ONENAND 0x0004 +#define MTD_DEV_TYPE_SPINAND 0x0008
-#define MTD_DEV_TYPE(type) ((type == MTD_DEV_TYPE_NAND) ? "nand" : \ - (type == MTD_DEV_TYPE_ONENAND) ? "onenand" : "nor") +#define MTD_DEV_TYPE(type) (type == MTD_DEV_TYPE_NAND ? "nand" : \ + (type == MTD_DEV_TYPE_NOR ? "nor" : \ + (type == MTD_DEV_TYPE_ONENAND ? "onenand" : \ + "spi-nand"))) \
struct mtd_device { struct list_head link;
All U-Boot users must define the mtdparts environment variable with: setenv mtdparts mtdparts=...
While this may ease the partition declaration job to be passed to Linux, this is a pure software limitation and forcing this prefix is a complete non-sense. Let the user to declare manually the mtdparts variable without the prefix.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Acked-by: Jagan Teki jagan@openedev.com Reviewed-by: Stefan Roese sr@denx.de --- cmd/mtdparts.c | 17 ++++++----------- 1 file changed, 6 insertions(+), 11 deletions(-)
diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 2e547894c6..f7ed1a0779 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -44,7 +44,7 @@ * * 'mtdparts' - partition list * - * mtdparts=mtdparts=<mtd-def>[;<mtd-def>...] + * mtdparts=[mtdparts=]<mtd-def>[;<mtd-def>...] * * <mtd-def> := <mtd-id>:<part-def>[,<part-def>...] * <mtd-id> := unique device tag used by linux kernel to find mtd device (mtd->name) @@ -62,11 +62,11 @@ * * 1 NOR Flash, with 1 single writable partition: * mtdids=nor0=edb7312-nor - * mtdparts=mtdparts=edb7312-nor:- + * mtdparts=[mtdparts=]edb7312-nor:- * * 1 NOR Flash with 2 partitions, 1 NAND with one * mtdids=nor0=edb7312-nor,nand0=edb7312-nand - * mtdparts=mtdparts=edb7312-nor:256k(ARMboot)ro,-(root);edb7312-nand:-(home) + * mtdparts=[mtdparts=]edb7312-nor:256k(ARMboot)ro,-(root);edb7312-nand:-(home) * */
@@ -1099,9 +1099,6 @@ static int generate_mtdparts(char *buf, u32 buflen) return 0; }
- strcpy(p, "mtdparts="); - p += 9; - list_for_each(dentry, &devices) { dev = list_entry(dentry, struct mtd_device, link);
@@ -1572,11 +1569,9 @@ static int parse_mtdparts(const char *const mtdparts) if (!p) p = mtdparts;
- if (strncmp(p, "mtdparts=", 9) != 0) { - printf("mtdparts variable doesn't start with 'mtdparts='\n"); - return err; - } - p += 9; + /* Skip the useless prefix, if any */ + if (strncmp(p, "mtdparts=", 9) == 0) + p += 9;
while (*p != '\0') { err = 1;
The user might want to trigger the probe of any MTD device, export these functions so they can be called from a command source file.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Acked-by: Jagan Teki jagan@openedev.com Reviewed-by: Stefan Roese sr@denx.de --- drivers/mtd/mtd-uclass.c | 16 ++++++++++++++++ include/mtd.h | 2 ++ 2 files changed, 18 insertions(+)
diff --git a/drivers/mtd/mtd-uclass.c b/drivers/mtd/mtd-uclass.c index 9ca049c437..5418217431 100644 --- a/drivers/mtd/mtd-uclass.c +++ b/drivers/mtd/mtd-uclass.c @@ -5,9 +5,25 @@
#include <common.h> #include <dm.h> +#include <dm/device-internal.h> #include <errno.h> #include <mtd.h>
+/** + * mtd_probe - Probe the device @dev if not already done + * + * @dev: U-Boot device to probe + * + * @return 0 on success, an error otherwise. + */ +int mtd_probe(struct udevice *dev) +{ + if (device_active(dev)) + return 0; + + return device_probe(dev); +} + /* * Implement a MTD uclass which should include most flash drivers. * The uclass private is pointed to mtd_info. diff --git a/include/mtd.h b/include/mtd.h index 548e7f191b..6e6da3002f 100644 --- a/include/mtd.h +++ b/include/mtd.h @@ -19,4 +19,6 @@ static inline struct mtd_info *mtd_get_info(struct udevice *dev) return dev_get_uclass_priv(dev); }
+int mtd_probe(struct udevice *dev); + #endif /* _MTD_H_ */
The current parser is very specific to U-Boot mtdparts implementation. It does not use MTD structures like mtd_info and mtd_partition. Copy and adapt the current parser in drivers/mtd/mtd-uclass.c (to not break the current use of mtdparts.c itself) and write some kind of a wrapper around the current implementation to allow other commands to benefit from this parsing in a user-friendly way.
This new function will allocate an mtd_partition array for each successful call. This array must be freed after use by the caller. The given 'mtdparts' buffer pointer will be moved forward to the next MTD device (if any, it will point towards a '\0' character otherwise).
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Acked-by: Jagan Teki jagan@openedev.com Reviewed-by: Stefan Roese sr@denx.de --- drivers/mtd/mtdpart.c | 187 +++++++++++++++++++++++++++++++++ include/linux/mtd/partitions.h | 2 + 2 files changed, 189 insertions(+)
diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c index 9ccb1b3361..eecdb650ad 100644 --- a/drivers/mtd/mtdpart.c +++ b/drivers/mtd/mtdpart.c @@ -76,6 +76,193 @@ char *kstrdup(const char *s, gfp_t gfp) } #endif
+#define MTD_SIZE_REMAINING (~0LLU) +#define MTD_OFFSET_NOT_SPECIFIED (~0LLU) + +/** + * mtd_parse_partition - Parse @mtdparts partition definition, fill @partition + * with it and update the @mtdparts string pointer. + * + * The partition name is allocated and must be freed by the caller. + * + * This function is widely inspired from part_parse (mtdparts.c). + * + * @mtdparts: String describing the partition with mtdparts command syntax + * @partition: MTD partition structure to fill + * + * @return 0 on success, an error otherwise. + */ +static int mtd_parse_partition(const char **_mtdparts, + struct mtd_partition *partition) +{ + const char *mtdparts = *_mtdparts; + const char *name = NULL; + int name_len; + char *buf; + + /* Ensure the partition structure is empty */ + memset(partition, 0, sizeof(struct mtd_partition)); + + /* Fetch the partition size */ + if (*mtdparts == '-') { + /* Assign all remaining space to this partition */ + partition->size = MTD_SIZE_REMAINING; + mtdparts++; + } else { + partition->size = ustrtoull(mtdparts, (char **)&mtdparts, 0); + if (partition->size < SZ_4K) { + printf("Minimum partition size 4kiB, %lldB requested\n", + partition->size); + return -EINVAL; + } + } + + /* Check for the offset */ + partition->offset = MTD_OFFSET_NOT_SPECIFIED; + if (*mtdparts == '@') { + mtdparts++; + partition->offset = ustrtoull(mtdparts, (char **)&mtdparts, 0); + } + + /* Now look for the name */ + if (*mtdparts == '(') { + name = ++mtdparts; + mtdparts = strchr(name, ')'); + if (!mtdparts) { + printf("No closing ')' found in partition name\n"); + return -EINVAL; + } + name_len = mtdparts - name + 1; + if ((name_len - 1) == 0) { + printf("Empty partition name\n"); + return -EINVAL; + } + mtdparts++; + } else { + /* Name will be of the form size@offset */ + name_len = 22; + } + + /* Check if the partition is read-only */ + if (strncmp(mtdparts, "ro", 2) == 0) { + partition->mask_flags |= MTD_WRITEABLE; + mtdparts += 2; + } + + /* Check for a potential next partition definition */ + if (*mtdparts == ',') { + if (partition->size == MTD_SIZE_REMAINING) { + printf("No partitions allowed after a fill-up\n"); + return -EINVAL; + } + ++mtdparts; + } else if ((*mtdparts == ';') || (*mtdparts == '\0')) { + /* NOP */ + } else { + printf("Unexpected character '%c' in mtdparts\n", *mtdparts); + return -EINVAL; + } + + /* + * Allocate a buffer for the name and either copy the provided name or + * auto-generate it with the form 'size@offset'. + */ + buf = malloc(name_len); + if (!buf) + return -ENOMEM; + + if (name) + strncpy(buf, name, name_len - 1); + else + snprintf(buf, name_len, "0x%08llx@0x%08llx", + partition->size, partition->offset); + + buf[name_len - 1] = '\0'; + partition->name = buf; + + *_mtdparts = mtdparts; + + return 0; +} + +/** + * mtdparts_parse_part - Create a partition array from an mtdparts definition + * + * Stateless function that takes a @parent MTD device, a string @_mtdparts + * describing the partitions (with the "mtdparts" command syntax) and creates + * the corresponding MTD partition structure array @_parts. Both the name and + * the structure partition itself must be freed freed by the caller. + * + * @parent: MTD device which contains the partitions + * @_mtdparts: Pointer to a string describing the partitions with "mtdparts" + * command syntax. + * @_parts: Allocated array containing the partitions, must be freed by the + * caller. + * @_nb_parts: Size of @_parts array. + * + * @return 0 on success, an error otherwise. + */ +int mtd_parse_partitions(struct mtd_info *parent, const char **_mtdparts, + struct mtd_partition **_parts, int *_nb_parts) +{ + struct mtd_partition partition = {}, *parts; + const char *mtdparts = *_mtdparts; + int cur_off = 0, cur_sz = 0; + int nb_parts = 0; + int ret, idx; + u64 sz; + + /* First, iterate over the partitions until we know their number */ + while (mtdparts[0] != '\0' && mtdparts[0] != ';') { + ret = mtd_parse_partition(&mtdparts, &partition); + if (ret) + return ret; + + free((char *)partition.name); + nb_parts++; + } + + /* Allocate an array of partitions to give back to the caller */ + parts = malloc(sizeof(*parts) * nb_parts); + if (!parts) { + printf("Not enough space to save partitions meta-data\n"); + return -ENOMEM; + } + + /* Iterate again over each partition to save the data in our array */ + for (idx = 0; idx < nb_parts; idx++) { + ret = mtd_parse_partition(_mtdparts, &parts[idx]); + if (ret) + return ret; + + if (parts[idx].size == MTD_SIZE_REMAINING) + parts[idx].size = parent->size - cur_sz; + cur_sz += parts[idx].size; + + sz = parts[idx].size; + if (sz < parent->writesize || do_div(sz, parent->writesize)) { + printf("Partition size must be a multiple of %d\n", + parent->writesize); + return -EINVAL; + } + + if (parts[idx].offset == MTD_OFFSET_NOT_SPECIFIED) + parts[idx].offset = cur_off; + cur_off += parts[idx].size; + + parts[idx].ecclayout = parent->ecclayout; + } + + /* Offset by one mtdparts to point to the next device if any */ + if (*_mtdparts[0] == ';') + (*_mtdparts)++; + + *_parts = parts; + *_nb_parts = nb_parts; + + return 0; +} + /* * MTD methods which simply translate the effective address and pass through * to the _real_ device. diff --git a/include/linux/mtd/partitions.h b/include/linux/mtd/partitions.h index ce0e8dbee4..ed4ece5e13 100644 --- a/include/linux/mtd/partitions.h +++ b/include/linux/mtd/partitions.h @@ -86,5 +86,7 @@ int mtd_add_partition(struct mtd_info *master, const char *name, long long offset, long long length); int mtd_del_partition(struct mtd_info *master, int partno); uint64_t mtd_get_device_size(const struct mtd_info *mtd); +int mtd_parse_partitions(struct mtd_info *parent, const char **_mtdparts, + struct mtd_partition **_parts, int *_nb_parts);
#endif
Using an MTD device (resp. partition) name in mtdparts is simple and straightforward. However, for a long time already, another name was given in mtdparts to indicate a device (resp. partition) so the "mtdids" environment variable was created to do the match.
Let's create a function that, from an MTD device (resp. partition) name, search for the equivalent name in the "mtdparts" environment variable thanks to the "mtdids" string.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Stefan Roese sr@denx.de --- drivers/mtd/mtdpart.c | 61 ++++++++++++++++++++++++++++++++++ include/linux/mtd/partitions.h | 2 ++ 2 files changed, 63 insertions(+)
diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c index eecdb650ad..09427b7b87 100644 --- a/drivers/mtd/mtdpart.c +++ b/drivers/mtd/mtdpart.c @@ -263,6 +263,67 @@ int mtd_parse_partitions(struct mtd_info *parent, const char **_mtdparts, return 0; }
+/** + * mtd_search_alternate_name - Search an alternate name for @mtdname thanks to + * the mtdids legacy environment variable. + * + * The mtdids string is a list of comma-separated 'dev_id=mtd_id' tupples. + * Check if one of the mtd_id matches mtdname, in this case save dev_id in + * altname. + * + * @mtdname: Current MTD device name + * @altname: Alternate name to return + * @max_len: Length of the alternate name buffer + * + * @return 0 on success, an error otherwise. + */ +int mtd_search_alternate_name(const char *mtdname, char *altname, + unsigned int max_len) +{ + const char *mtdids, *equal, *comma, *dev_id, *mtd_id; + int dev_id_len, mtd_id_len; + + mtdids = env_get("mtdids"); + if (!mtdids) + return -EINVAL; + + do { + /* Find the '=' sign */ + dev_id = mtdids; + equal = strchr(dev_id, '='); + if (!equal) + break; + dev_id_len = equal - mtdids; + mtd_id = equal + 1; + + /* Find the end of the tupple */ + comma = strchr(mtdids, ','); + if (comma) + mtd_id_len = comma - mtd_id; + else + mtd_id_len = &mtdids[strlen(mtdids)] - mtd_id + 1; + + if (!dev_id_len || !mtd_id_len) + return -EINVAL; + + if (dev_id_len + 1 > max_len) + continue; + + /* Compare the name we search with the current mtd_id */ + if (!strncmp(mtdname, mtd_id, mtd_id_len)) { + strncpy(altname, dev_id, dev_id_len); + altname[dev_id_len] = 0; + + return 0; + } + + /* Go to the next tupple */ + mtdids = comma + 1; + } while (comma); + + return -EINVAL; +} + /* * MTD methods which simply translate the effective address and pass through * to the _real_ device. diff --git a/include/linux/mtd/partitions.h b/include/linux/mtd/partitions.h index ed4ece5e13..082a4966ea 100644 --- a/include/linux/mtd/partitions.h +++ b/include/linux/mtd/partitions.h @@ -88,5 +88,7 @@ int mtd_del_partition(struct mtd_info *master, int partno); uint64_t mtd_get_device_size(const struct mtd_info *mtd); int mtd_parse_partitions(struct mtd_info *parent, const char **_mtdparts, struct mtd_partition **_parts, int *_nb_parts); +int mtd_search_alternate_name(const char *mtdname, char *altname, + unsigned int max_len);
#endif
Instead of collecting partitions in a flat list, create a hierarchy within the mtd_info structure: use a partitions list to keep track of the partitions of an MTD device (which might be itself a partition of another MTD device), a pointer to the parent device (NULL when the MTD device is the root one, not a partition).
By also saving directly in mtd_info the offset of the partition, we can get rid of the mtd_part structure.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Stefan Roese sr@denx.de --- drivers/mtd/mtdcore.c | 2 + drivers/mtd/mtdpart.c | 412 ++++++++++++++------------------- include/linux/mtd/mtd.h | 31 +++ include/linux/mtd/partitions.h | 1 - 4 files changed, 208 insertions(+), 238 deletions(-)
diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index fb1d68d5e2..fb6c779abb 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -426,6 +426,8 @@ int add_mtd_device(struct mtd_info *mtd) mtd->index = i; mtd->usecount = 0;
+ INIT_LIST_HEAD(&mtd->partitions); + /* default value if not set by driver */ if (mtd->bitflip_threshold == 0) mtd->bitflip_threshold = mtd->ecc_strength; diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c index 09427b7b87..fae780855d 100644 --- a/drivers/mtd/mtdpart.c +++ b/drivers/mtd/mtdpart.c @@ -29,29 +29,12 @@
#include "mtdcore.h"
-/* Our partition linked list */ -static LIST_HEAD(mtd_partitions); #ifndef __UBOOT__ static DEFINE_MUTEX(mtd_partitions_mutex); #else DEFINE_MUTEX(mtd_partitions_mutex); #endif
-/* Our partition node structure */ -struct mtd_part { - struct mtd_info mtd; - struct mtd_info *master; - uint64_t offset; - struct list_head list; -}; - -/* - * Given a pointer to the MTD object in the mtd_part structure, we can retrieve - * the pointer to that structure with this macro. - */ -#define PART(x) ((struct mtd_part *)(x)) - - #ifdef __UBOOT__ /* from mm/util.c */
@@ -332,19 +315,18 @@ int mtd_search_alternate_name(const char *mtdname, char *altname, static int part_read(struct mtd_info *mtd, loff_t from, size_t len, size_t *retlen, u_char *buf) { - struct mtd_part *part = PART(mtd); struct mtd_ecc_stats stats; int res;
- stats = part->master->ecc_stats; - res = part->master->_read(part->master, from + part->offset, len, - retlen, buf); + stats = mtd->parent->ecc_stats; + res = mtd->parent->_read(mtd->parent, from + mtd->offset, len, + retlen, buf); if (unlikely(mtd_is_eccerr(res))) mtd->ecc_stats.failed += - part->master->ecc_stats.failed - stats.failed; + mtd->parent->ecc_stats.failed - stats.failed; else mtd->ecc_stats.corrected += - part->master->ecc_stats.corrected - stats.corrected; + mtd->parent->ecc_stats.corrected - stats.corrected; return res; }
@@ -352,17 +334,13 @@ static int part_read(struct mtd_info *mtd, loff_t from, size_t len, static int part_point(struct mtd_info *mtd, loff_t from, size_t len, size_t *retlen, void **virt, resource_size_t *phys) { - struct mtd_part *part = PART(mtd); - - return part->master->_point(part->master, from + part->offset, len, - retlen, virt, phys); + return mtd->parent->_point(mtd->parent, from + mtd->offset, len, + retlen, virt, phys); }
static int part_unpoint(struct mtd_info *mtd, loff_t from, size_t len) { - struct mtd_part *part = PART(mtd); - - return part->master->_unpoint(part->master, from + part->offset, len); + return mtd->parent->_unpoint(mtd->parent, from + mtd->offset, len); } #endif
@@ -371,17 +349,13 @@ static unsigned long part_get_unmapped_area(struct mtd_info *mtd, unsigned long offset, unsigned long flags) { - struct mtd_part *part = PART(mtd); - - offset += part->offset; - return part->master->_get_unmapped_area(part->master, len, offset, - flags); + offset += mtd->offset; + return mtd->parent->_get_unmapped_area(mtd->parent, len, offset, flags); }
static int part_read_oob(struct mtd_info *mtd, loff_t from, struct mtd_oob_ops *ops) { - struct mtd_part *part = PART(mtd); int res;
if (from >= mtd->size) @@ -406,7 +380,7 @@ static int part_read_oob(struct mtd_info *mtd, loff_t from, return -EINVAL; }
- res = part->master->_read_oob(part->master, from + part->offset, ops); + res = mtd->parent->_read_oob(mtd->parent, from + mtd->offset, ops); if (unlikely(res)) { if (mtd_is_bitflip(res)) mtd->ecc_stats.corrected++; @@ -419,99 +393,87 @@ static int part_read_oob(struct mtd_info *mtd, loff_t from, static int part_read_user_prot_reg(struct mtd_info *mtd, loff_t from, size_t len, size_t *retlen, u_char *buf) { - struct mtd_part *part = PART(mtd); - return part->master->_read_user_prot_reg(part->master, from, len, - retlen, buf); + return mtd->parent->_read_user_prot_reg(mtd->parent, from, len, + retlen, buf); }
static int part_get_user_prot_info(struct mtd_info *mtd, size_t len, size_t *retlen, struct otp_info *buf) { - struct mtd_part *part = PART(mtd); - return part->master->_get_user_prot_info(part->master, len, retlen, - buf); + return mtd->parent->_get_user_prot_info(mtd->parent, len, retlen, + buf); }
static int part_read_fact_prot_reg(struct mtd_info *mtd, loff_t from, size_t len, size_t *retlen, u_char *buf) { - struct mtd_part *part = PART(mtd); - return part->master->_read_fact_prot_reg(part->master, from, len, - retlen, buf); + return mtd->parent->_read_fact_prot_reg(mtd->parent, from, len, + retlen, buf); }
static int part_get_fact_prot_info(struct mtd_info *mtd, size_t len, size_t *retlen, struct otp_info *buf) { - struct mtd_part *part = PART(mtd); - return part->master->_get_fact_prot_info(part->master, len, retlen, - buf); + return mtd->parent->_get_fact_prot_info(mtd->parent, len, retlen, + buf); }
static int part_write(struct mtd_info *mtd, loff_t to, size_t len, size_t *retlen, const u_char *buf) { - struct mtd_part *part = PART(mtd); - return part->master->_write(part->master, to + part->offset, len, - retlen, buf); + return mtd->parent->_write(mtd->parent, to + mtd->offset, len, + retlen, buf); }
static int part_panic_write(struct mtd_info *mtd, loff_t to, size_t len, size_t *retlen, const u_char *buf) { - struct mtd_part *part = PART(mtd); - return part->master->_panic_write(part->master, to + part->offset, len, - retlen, buf); + return mtd->parent->_panic_write(mtd->parent, to + mtd->offset, len, + retlen, buf); }
static int part_write_oob(struct mtd_info *mtd, loff_t to, struct mtd_oob_ops *ops) { - struct mtd_part *part = PART(mtd); - if (to >= mtd->size) return -EINVAL; if (ops->datbuf && to + ops->len > mtd->size) return -EINVAL; - return part->master->_write_oob(part->master, to + part->offset, ops); + return mtd->parent->_write_oob(mtd->parent, to + mtd->offset, ops); }
static int part_write_user_prot_reg(struct mtd_info *mtd, loff_t from, size_t len, size_t *retlen, u_char *buf) { - struct mtd_part *part = PART(mtd); - return part->master->_write_user_prot_reg(part->master, from, len, - retlen, buf); + return mtd->parent->_write_user_prot_reg(mtd->parent, from, len, + retlen, buf); }
static int part_lock_user_prot_reg(struct mtd_info *mtd, loff_t from, size_t len) { - struct mtd_part *part = PART(mtd); - return part->master->_lock_user_prot_reg(part->master, from, len); + return mtd->parent->_lock_user_prot_reg(mtd->parent, from, len); }
#ifndef __UBOOT__ static int part_writev(struct mtd_info *mtd, const struct kvec *vecs, unsigned long count, loff_t to, size_t *retlen) { - struct mtd_part *part = PART(mtd); - return part->master->_writev(part->master, vecs, count, - to + part->offset, retlen); + return mtd->parent->_writev(mtd->parent, vecs, count, + to + mtd->offset, retlen); } #endif
static int part_erase(struct mtd_info *mtd, struct erase_info *instr) { - struct mtd_part *part = PART(mtd); int ret;
- instr->addr += part->offset; - ret = part->master->_erase(part->master, instr); + instr->addr += mtd->offset; + ret = mtd->parent->_erase(mtd->parent, instr); if (ret) { if (instr->fail_addr != MTD_FAIL_ADDR_UNKNOWN) - instr->fail_addr -= part->offset; - instr->addr -= part->offset; + instr->fail_addr -= mtd->offset; + instr->addr -= mtd->offset; } return ret; } @@ -519,11 +481,9 @@ static int part_erase(struct mtd_info *mtd, struct erase_info *instr) void mtd_erase_callback(struct erase_info *instr) { if (instr->mtd->_erase == part_erase) { - struct mtd_part *part = PART(instr->mtd); - if (instr->fail_addr != MTD_FAIL_ADDR_UNKNOWN) - instr->fail_addr -= part->offset; - instr->addr -= part->offset; + instr->fail_addr -= instr->mtd->offset; + instr->addr -= instr->mtd->offset; } if (instr->callback) instr->callback(instr); @@ -532,107 +492,112 @@ EXPORT_SYMBOL_GPL(mtd_erase_callback);
static int part_lock(struct mtd_info *mtd, loff_t ofs, uint64_t len) { - struct mtd_part *part = PART(mtd); - return part->master->_lock(part->master, ofs + part->offset, len); + return mtd->parent->_lock(mtd->parent, ofs + mtd->offset, len); }
static int part_unlock(struct mtd_info *mtd, loff_t ofs, uint64_t len) { - struct mtd_part *part = PART(mtd); - return part->master->_unlock(part->master, ofs + part->offset, len); + return mtd->parent->_unlock(mtd->parent, ofs + mtd->offset, len); }
static int part_is_locked(struct mtd_info *mtd, loff_t ofs, uint64_t len) { - struct mtd_part *part = PART(mtd); - return part->master->_is_locked(part->master, ofs + part->offset, len); + return mtd->parent->_is_locked(mtd->parent, ofs + mtd->offset, len); }
static void part_sync(struct mtd_info *mtd) { - struct mtd_part *part = PART(mtd); - part->master->_sync(part->master); + mtd->parent->_sync(mtd->parent); }
#ifndef __UBOOT__ static int part_suspend(struct mtd_info *mtd) { - struct mtd_part *part = PART(mtd); - return part->master->_suspend(part->master); + return mtd->parent->_suspend(mtd->parent); }
static void part_resume(struct mtd_info *mtd) { - struct mtd_part *part = PART(mtd); - part->master->_resume(part->master); + mtd->parent->_resume(mtd->parent); } #endif
static int part_block_isreserved(struct mtd_info *mtd, loff_t ofs) { - struct mtd_part *part = PART(mtd); - ofs += part->offset; - return part->master->_block_isreserved(part->master, ofs); + ofs += mtd->offset; + return mtd->parent->_block_isreserved(mtd->parent, ofs); }
static int part_block_isbad(struct mtd_info *mtd, loff_t ofs) { - struct mtd_part *part = PART(mtd); - ofs += part->offset; - return part->master->_block_isbad(part->master, ofs); + ofs += mtd->offset; + return mtd->parent->_block_isbad(mtd->parent, ofs); }
static int part_block_markbad(struct mtd_info *mtd, loff_t ofs) { - struct mtd_part *part = PART(mtd); int res;
- ofs += part->offset; - res = part->master->_block_markbad(part->master, ofs); + ofs += mtd->offset; + res = mtd->parent->_block_markbad(mtd->parent, ofs); if (!res) mtd->ecc_stats.badblocks++; return res; }
-static inline void free_partition(struct mtd_part *p) +static inline void free_partition(struct mtd_info *p) { - kfree(p->mtd.name); + kfree(p->name); kfree(p); }
/* * This function unregisters and destroy all slave MTD objects which are - * attached to the given master MTD object. + * attached to the given master MTD object, recursively. */ - -int del_mtd_partitions(struct mtd_info *master) +static int do_del_mtd_partitions(struct mtd_info *master) { - struct mtd_part *slave, *next; + struct mtd_info *slave, *next; int ret, err = 0;
- debug("Deleting MTD partitions on "%s":\n", master->name); + list_for_each_entry_safe(slave, next, &master->partitions, node) { + if (mtd_has_partitions(slave)) + del_mtd_partitions(slave);
- mutex_lock(&mtd_partitions_mutex); - list_for_each_entry_safe(slave, next, &mtd_partitions, list) - if (slave->master == master) { - ret = del_mtd_device(&slave->mtd); - if (ret < 0) { - err = ret; - continue; - } - list_del(&slave->list); - free_partition(slave); + debug("Deleting %s MTD partition\n", slave->name); + ret = del_mtd_device(slave); + if (ret < 0) { + printf("Error when deleting partition "%s" (%d)\n", + slave->name, ret); + err = ret; + continue; } - mutex_unlock(&mtd_partitions_mutex); + + list_del(&slave->node); + free_partition(slave); + }
return err; }
-static struct mtd_part *allocate_partition(struct mtd_info *master, - const struct mtd_partition *part, int partno, - uint64_t cur_offset) +int del_mtd_partitions(struct mtd_info *master) { - struct mtd_part *slave; + int ret; + + debug("Deleting MTD partitions on "%s":\n", master->name); + + mutex_lock(&mtd_partitions_mutex); + ret = do_del_mtd_partitions(master); + mutex_unlock(&mtd_partitions_mutex); + + return ret; +} + +static struct mtd_info *allocate_partition(struct mtd_info *master, + const struct mtd_partition *part, + int partno, uint64_t cur_offset) +{ + struct mtd_info *slave; char *name;
/* allocate the partition structure */ @@ -647,85 +612,87 @@ static struct mtd_part *allocate_partition(struct mtd_info *master, }
/* set up the MTD object for this partition */ - slave->mtd.type = master->type; - slave->mtd.flags = master->flags & ~part->mask_flags; - slave->mtd.size = part->size; - slave->mtd.writesize = master->writesize; - slave->mtd.writebufsize = master->writebufsize; - slave->mtd.oobsize = master->oobsize; - slave->mtd.oobavail = master->oobavail; - slave->mtd.subpage_sft = master->subpage_sft; + slave->type = master->type; + slave->flags = master->flags & ~part->mask_flags; + slave->size = part->size; + slave->writesize = master->writesize; + slave->writebufsize = master->writebufsize; + slave->oobsize = master->oobsize; + slave->oobavail = master->oobavail; + slave->subpage_sft = master->subpage_sft;
- slave->mtd.name = name; - slave->mtd.owner = master->owner; + slave->name = name; + slave->owner = master->owner; #ifndef __UBOOT__ - slave->mtd.backing_dev_info = master->backing_dev_info; + slave->backing_dev_info = master->backing_dev_info;
/* NOTE: we don't arrange MTDs as a tree; it'd be error-prone * to have the same data be in two different partitions. */ - slave->mtd.dev.parent = master->dev.parent; + slave->dev.parent = master->dev.parent; #endif
if (master->_read) - slave->mtd._read = part_read; + slave->_read = part_read; if (master->_write) - slave->mtd._write = part_write; + slave->_write = part_write;
if (master->_panic_write) - slave->mtd._panic_write = part_panic_write; + slave->_panic_write = part_panic_write;
#ifndef __UBOOT__ if (master->_point && master->_unpoint) { - slave->mtd._point = part_point; - slave->mtd._unpoint = part_unpoint; + slave->_point = part_point; + slave->_unpoint = part_unpoint; } #endif
if (master->_get_unmapped_area) - slave->mtd._get_unmapped_area = part_get_unmapped_area; + slave->_get_unmapped_area = part_get_unmapped_area; if (master->_read_oob) - slave->mtd._read_oob = part_read_oob; + slave->_read_oob = part_read_oob; if (master->_write_oob) - slave->mtd._write_oob = part_write_oob; + slave->_write_oob = part_write_oob; if (master->_read_user_prot_reg) - slave->mtd._read_user_prot_reg = part_read_user_prot_reg; + slave->_read_user_prot_reg = part_read_user_prot_reg; if (master->_read_fact_prot_reg) - slave->mtd._read_fact_prot_reg = part_read_fact_prot_reg; + slave->_read_fact_prot_reg = part_read_fact_prot_reg; if (master->_write_user_prot_reg) - slave->mtd._write_user_prot_reg = part_write_user_prot_reg; + slave->_write_user_prot_reg = part_write_user_prot_reg; if (master->_lock_user_prot_reg) - slave->mtd._lock_user_prot_reg = part_lock_user_prot_reg; + slave->_lock_user_prot_reg = part_lock_user_prot_reg; if (master->_get_user_prot_info) - slave->mtd._get_user_prot_info = part_get_user_prot_info; + slave->_get_user_prot_info = part_get_user_prot_info; if (master->_get_fact_prot_info) - slave->mtd._get_fact_prot_info = part_get_fact_prot_info; + slave->_get_fact_prot_info = part_get_fact_prot_info; if (master->_sync) - slave->mtd._sync = part_sync; + slave->_sync = part_sync; #ifndef __UBOOT__ if (!partno && !master->dev.class && master->_suspend && master->_resume) { - slave->mtd._suspend = part_suspend; - slave->mtd._resume = part_resume; + slave->_suspend = part_suspend; + slave->_resume = part_resume; } if (master->_writev) - slave->mtd._writev = part_writev; + slave->_writev = part_writev; #endif if (master->_lock) - slave->mtd._lock = part_lock; + slave->_lock = part_lock; if (master->_unlock) - slave->mtd._unlock = part_unlock; + slave->_unlock = part_unlock; if (master->_is_locked) - slave->mtd._is_locked = part_is_locked; + slave->_is_locked = part_is_locked; if (master->_block_isreserved) - slave->mtd._block_isreserved = part_block_isreserved; + slave->_block_isreserved = part_block_isreserved; if (master->_block_isbad) - slave->mtd._block_isbad = part_block_isbad; + slave->_block_isbad = part_block_isbad; if (master->_block_markbad) - slave->mtd._block_markbad = part_block_markbad; - slave->mtd._erase = part_erase; - slave->master = master; + slave->_block_markbad = part_block_markbad; + slave->_erase = part_erase; + slave->parent = master; slave->offset = part->offset; + INIT_LIST_HEAD(&slave->partitions); + INIT_LIST_HEAD(&slave->node);
if (slave->offset == MTDPART_OFS_APPEND) slave->offset = cur_offset; @@ -741,41 +708,41 @@ static struct mtd_part *allocate_partition(struct mtd_info *master, } if (slave->offset == MTDPART_OFS_RETAIN) { slave->offset = cur_offset; - if (master->size - slave->offset >= slave->mtd.size) { - slave->mtd.size = master->size - slave->offset - - slave->mtd.size; + if (master->size - slave->offset >= slave->size) { + slave->size = master->size - slave->offset + - slave->size; } else { debug("mtd partition "%s" doesn't have enough space: %#llx < %#llx, disabled\n", part->name, master->size - slave->offset, - slave->mtd.size); + slave->size); /* register to preserve ordering */ goto out_register; } } - if (slave->mtd.size == MTDPART_SIZ_FULL) - slave->mtd.size = master->size - slave->offset; + if (slave->size == MTDPART_SIZ_FULL) + slave->size = master->size - slave->offset;
debug("0x%012llx-0x%012llx : "%s"\n", (unsigned long long)slave->offset, - (unsigned long long)(slave->offset + slave->mtd.size), slave->mtd.name); + (unsigned long long)(slave->offset + slave->size), slave->name);
/* let's do some sanity checks */ if (slave->offset >= master->size) { /* let's register it anyway to preserve ordering */ slave->offset = 0; - slave->mtd.size = 0; + slave->size = 0; printk(KERN_ERR"mtd: partition "%s" is out of reach -- disabled\n", part->name); goto out_register; } - if (slave->offset + slave->mtd.size > master->size) { - slave->mtd.size = master->size - slave->offset; + if (slave->offset + slave->size > master->size) { + slave->size = master->size - slave->offset; printk(KERN_WARNING"mtd: partition "%s" extends beyond the end of device "%s" -- size truncated to %#llx\n", - part->name, master->name, (unsigned long long)slave->mtd.size); + part->name, master->name, slave->size); } if (master->numeraseregions > 1) { /* Deal with variable erase size stuff */ int i, max = master->numeraseregions; - u64 end = slave->offset + slave->mtd.size; + u64 end = slave->offset + slave->size; struct mtd_erase_region_info *regions = master->eraseregions;
/* Find the first erase regions which is part of this @@ -788,44 +755,44 @@ static struct mtd_part *allocate_partition(struct mtd_info *master,
/* Pick biggest erasesize */ for (; i < max && regions[i].offset < end; i++) { - if (slave->mtd.erasesize < regions[i].erasesize) { - slave->mtd.erasesize = regions[i].erasesize; + if (slave->erasesize < regions[i].erasesize) { + slave->erasesize = regions[i].erasesize; } } - BUG_ON(slave->mtd.erasesize == 0); + BUG_ON(slave->erasesize == 0); } else { /* Single erase size */ - slave->mtd.erasesize = master->erasesize; + slave->erasesize = master->erasesize; }
- if ((slave->mtd.flags & MTD_WRITEABLE) && - mtd_mod_by_eb(slave->offset, &slave->mtd)) { + if ((slave->flags & MTD_WRITEABLE) && + mtd_mod_by_eb(slave->offset, slave)) { /* Doesn't start on a boundary of major erase size */ /* FIXME: Let it be writable if it is on a boundary of * _minor_ erase size though */ - slave->mtd.flags &= ~MTD_WRITEABLE; + slave->flags &= ~MTD_WRITEABLE; printk(KERN_WARNING"mtd: partition "%s" doesn't start on an erase block boundary -- force read-only\n", part->name); } - if ((slave->mtd.flags & MTD_WRITEABLE) && - mtd_mod_by_eb(slave->mtd.size, &slave->mtd)) { - slave->mtd.flags &= ~MTD_WRITEABLE; + if ((slave->flags & MTD_WRITEABLE) && + mtd_mod_by_eb(slave->size, slave)) { + slave->flags &= ~MTD_WRITEABLE; printk(KERN_WARNING"mtd: partition "%s" doesn't end on an erase block -- force read-only\n", part->name); }
- slave->mtd.ecclayout = master->ecclayout; - slave->mtd.ecc_step_size = master->ecc_step_size; - slave->mtd.ecc_strength = master->ecc_strength; - slave->mtd.bitflip_threshold = master->bitflip_threshold; + slave->ecclayout = master->ecclayout; + slave->ecc_step_size = master->ecc_step_size; + slave->ecc_strength = master->ecc_strength; + slave->bitflip_threshold = master->bitflip_threshold;
if (master->_block_isbad) { uint64_t offs = 0;
- while (offs < slave->mtd.size) { + while (offs < slave->size) { if (mtd_block_isbad(master, offs + slave->offset)) - slave->mtd.ecc_stats.badblocks++; - offs += slave->mtd.erasesize; + slave->ecc_stats.badblocks++; + offs += slave->erasesize; } }
@@ -838,7 +805,7 @@ int mtd_add_partition(struct mtd_info *master, const char *name, long long offset, long long length) { struct mtd_partition part; - struct mtd_part *p, *new; + struct mtd_info *p, *new; uint64_t start, end; int ret = 0;
@@ -867,21 +834,20 @@ int mtd_add_partition(struct mtd_info *master, const char *name, end = offset + length;
mutex_lock(&mtd_partitions_mutex); - list_for_each_entry(p, &mtd_partitions, list) - if (p->master == master) { - if ((start >= p->offset) && - (start < (p->offset + p->mtd.size))) - goto err_inv; + list_for_each_entry(p, &master->partitions, node) { + if (start >= p->offset && + (start < (p->offset + p->size))) + goto err_inv;
- if ((end >= p->offset) && - (end < (p->offset + p->mtd.size))) - goto err_inv; - } + if (end >= p->offset && + (end < (p->offset + p->size))) + goto err_inv; + }
- list_add(&new->list, &mtd_partitions); + list_add_tail(&new->node, &master->partitions); mutex_unlock(&mtd_partitions_mutex);
- add_mtd_device(&new->mtd); + add_mtd_device(new);
return ret; err_inv: @@ -893,18 +859,17 @@ EXPORT_SYMBOL_GPL(mtd_add_partition);
int mtd_del_partition(struct mtd_info *master, int partno) { - struct mtd_part *slave, *next; + struct mtd_info *slave, *next; int ret = -EINVAL;
mutex_lock(&mtd_partitions_mutex); - list_for_each_entry_safe(slave, next, &mtd_partitions, list) - if ((slave->master == master) && - (slave->mtd.index == partno)) { - ret = del_mtd_device(&slave->mtd); + list_for_each_entry_safe(slave, next, &master->partitions, node) + if (slave->index == partno) { + ret = del_mtd_device(slave); if (ret < 0) break;
- list_del(&slave->list); + list_del(&slave->node); free_partition(slave); break; } @@ -928,20 +893,10 @@ int add_mtd_partitions(struct mtd_info *master, const struct mtd_partition *parts, int nbparts) { - struct mtd_part *slave; + struct mtd_info *slave; uint64_t cur_offset = 0; int i;
-#ifdef __UBOOT__ - /* - * Need to init the list here, since LIST_INIT() does not - * work on platforms where relocation has problems (like MIPS - * & PPC). - */ - if (mtd_partitions.next == NULL) - INIT_LIST_HEAD(&mtd_partitions); -#endif - debug("Creating %d MTD partitions on "%s":\n", nbparts, master->name);
for (i = 0; i < nbparts; i++) { @@ -950,12 +905,12 @@ int add_mtd_partitions(struct mtd_info *master, return PTR_ERR(slave);
mutex_lock(&mtd_partitions_mutex); - list_add(&slave->list, &mtd_partitions); + list_add_tail(&slave->node, &master->partitions); mutex_unlock(&mtd_partitions_mutex);
- add_mtd_device(&slave->mtd); + add_mtd_device(slave);
- cur_offset = slave->offset + slave->mtd.size; + cur_offset = slave->offset + slave->size; }
return 0; @@ -1058,29 +1013,12 @@ int parse_mtd_partitions(struct mtd_info *master, const char *const *types, } #endif
-int mtd_is_partition(const struct mtd_info *mtd) -{ - struct mtd_part *part; - int ispart = 0; - - mutex_lock(&mtd_partitions_mutex); - list_for_each_entry(part, &mtd_partitions, list) - if (&part->mtd == mtd) { - ispart = 1; - break; - } - mutex_unlock(&mtd_partitions_mutex); - - return ispart; -} -EXPORT_SYMBOL_GPL(mtd_is_partition); - /* Returns the size of the entire flash chip */ uint64_t mtd_get_device_size(const struct mtd_info *mtd) { - if (!mtd_is_partition(mtd)) - return mtd->size; + if (mtd_is_partition(mtd)) + return mtd->parent->size;
- return PART(mtd)->master->size; + return mtd->size; } EXPORT_SYMBOL_GPL(mtd_get_device_size); diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index b8c2c3fd59..ba582d38bc 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -307,6 +307,27 @@ struct mtd_info { struct udevice *dev; #endif int usecount; + + /* MTD devices do not have any parent. MTD partitions do. */ + struct mtd_info *parent; + + /* + * Offset of the partition relatively to the parent offset. + * Is 0 for real MTD devices (ie. not partitions). + */ + u64 offset; + + /* + * List node used to add an MTD partition to the parent + * partition list. + */ + struct list_head node; + + /* + * List of partitions attached to this MTD device (the parent + * MTD device can itself be a partition). + */ + struct list_head partitions; };
#if IS_ENABLED(CONFIG_DM) @@ -334,6 +355,16 @@ static inline const struct device_node *mtd_get_of_node(struct mtd_info *mtd) } #endif
+static inline bool mtd_is_partition(const struct mtd_info *mtd) +{ + return mtd->parent; +} + +static inline bool mtd_has_partitions(const struct mtd_info *mtd) +{ + return !list_empty(&mtd->partitions); +} + int mtd_ooblayout_ecc(struct mtd_info *mtd, int section, struct mtd_oob_region *oobecc); int mtd_ooblayout_find_eccregion(struct mtd_info *mtd, int eccbyte, diff --git a/include/linux/mtd/partitions.h b/include/linux/mtd/partitions.h index 082a4966ea..b8db1b0a58 100644 --- a/include/linux/mtd/partitions.h +++ b/include/linux/mtd/partitions.h @@ -81,7 +81,6 @@ extern void register_mtd_parser(struct mtd_part_parser *parser); extern void deregister_mtd_parser(struct mtd_part_parser *parser); #endif
-int mtd_is_partition(const struct mtd_info *mtd); int mtd_add_partition(struct mtd_info *master, const char *name, long long offset, long long length); int mtd_del_partition(struct mtd_info *master, int partno);
There should not be a 'nand' command, a 'sf' command and certainly not a new 'spi-nand' command. Write a 'mtd' command instead to manage all MTD devices/partitions at once. This should be the preferred way to access any MTD device.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Acked-by: Jagan Teki jagan@openedev.com Reviewed-by: Stefan Roese sr@denx.de --- cmd/Kconfig | 10 +- cmd/Makefile | 1 + cmd/mtd.c | 521 +++++++++++++++++++++++++++++++++++++++++++ drivers/mtd/Makefile | 2 +- include/mtd.h | 1 + 5 files changed, 532 insertions(+), 3 deletions(-) create mode 100644 cmd/mtd.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index f97d3df328..b5bd978f6d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -854,6 +854,12 @@ config CMD_MMC_SWRITE Enable support for the "mmc swrite" command to write Android sparse images to eMMC.
+config CMD_MTD + bool "mtd" + select MTD_PARTITIONS + help + MTD commands support. + config CMD_NAND bool "nand" default y if NAND_SUNXI @@ -1678,14 +1684,14 @@ config CMD_MTDPARTS
config MTDIDS_DEFAULT string "Default MTD IDs" - depends on CMD_MTDPARTS || CMD_NAND || CMD_FLASH + depends on CMD_MTD || CMD_MTDPARTS || CMD_NAND || CMD_FLASH help Defines a default MTD IDs list for use with MTD partitions in the Linux MTD command line partitions format.
config MTDPARTS_DEFAULT string "Default MTD partition scheme" - depends on CMD_MTDPARTS || CMD_NAND || CMD_FLASH + depends on CMD_MTD || CMD_MTDPARTS || CMD_NAND || CMD_FLASH help Defines a default MTD partitioning scheme in the Linux MTD command line partitions format diff --git a/cmd/Makefile b/cmd/Makefile index 414187f073..8107cb0aa8 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -91,6 +91,7 @@ obj-$(CONFIG_CMD_MISC) += misc.o obj-$(CONFIG_CMD_MMC) += mmc.o obj-$(CONFIG_CMD_MMC_SPI) += mmc_spi.o obj-$(CONFIG_MP) += mp.o +obj-$(CONFIG_CMD_MTD) += mtd.o obj-$(CONFIG_CMD_MTDPARTS) += mtdparts.o obj-$(CONFIG_CMD_NAND) += nand.o obj-$(CONFIG_CMD_NET) += net.o diff --git a/cmd/mtd.c b/cmd/mtd.c new file mode 100644 index 0000000000..d771c5d223 --- /dev/null +++ b/cmd/mtd.c @@ -0,0 +1,521 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * mtd.c + * + * Generic command to handle basic operations on any memory device. + * + * Copyright: Bootlin, 2018 + * Author: Miquèl Raynal miquel.raynal@bootlin.com + */ + +#include <command.h> +#include <common.h> +#include <console.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/partitions.h> +#include <malloc.h> +#include <mapmem.h> +#include <mtd.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> + +#define MTD_NAME_MAX_LEN 20 + +static char *old_mtdparts; +static char *old_mtdids; + +static void mtd_dump_buf(u8 *buf, uint len, uint offset) +{ + int i, j; + + for (i = 0; i < len; ) { + printf("0x%08x:\t", offset + i); + for (j = 0; j < 8; j++) + printf("%02x ", buf[i + j]); + printf(" "); + i += 8; + for (j = 0; j < 8; j++) + printf("%02x ", buf[i + j]); + printf("\n"); + i += 8; + } +} + +static void mtd_show_parts(struct mtd_info *mtd, int level) +{ + struct mtd_info *part; + int i; + + list_for_each_entry(part, &mtd->partitions, node) { + for (i = 0; i < level; i++) + printf("\t"); + printf(" - 0x%012llx-0x%012llx : "%s"\n", + part->offset, part->offset + part->size, part->name); + + mtd_show_parts(part, level + 1); + } +} + +static void mtd_show_device(struct mtd_info *mtd) +{ + /* Device */ + printf("* %s\n", mtd->name); + if (mtd->dev) { + printf(" - device: %s\n", mtd->dev->name); + printf(" - parent: %s\n", mtd->dev->parent->name); + printf(" - driver: %s\n", mtd->dev->driver->name); + } + + /* MTD device information */ + printf(" - type: "); + switch (mtd->type) { + case MTD_RAM: + printf("RAM\n"); + break; + case MTD_ROM: + printf("ROM\n"); + break; + case MTD_NORFLASH: + printf("NOR flash\n"); + break; + case MTD_NANDFLASH: + printf("NAND flash\n"); + break; + case MTD_DATAFLASH: + printf("Data flash\n"); + break; + case MTD_UBIVOLUME: + printf("UBI volume\n"); + break; + case MTD_MLCNANDFLASH: + printf("MLC NAND flash\n"); + break; + case MTD_ABSENT: + default: + printf("Unknown\n"); + break; + } + + printf(" - block size: 0x%x bytes\n", mtd->erasesize); + printf(" - min I/O: 0x%x bytes\n", mtd->writesize); + + if (mtd->oobsize) { + printf(" - OOB size: %u bytes\n", mtd->oobsize); + printf(" - OOB available: %u bytes\n", mtd->oobavail); + } + + if (mtd->ecc_strength) { + printf(" - ECC strength: %u bits\n", mtd->ecc_strength); + printf(" - ECC step size: %u bytes\n", mtd->ecc_step_size); + printf(" - bitflip threshold: %u bits\n", + mtd->bitflip_threshold); + } + + printf(" - 0x%012llx-0x%012llx : "%s"\n", + mtd->offset, mtd->offset + mtd->size, mtd->name); + + /* MTD partitions, if any */ + mtd_show_parts(mtd, 1); +} + +#if IS_ENABLED(CONFIG_MTD) +static void mtd_probe_uclass_mtd_devs(void) +{ + struct udevice *dev; + int idx = 0; + + /* Probe devices with DM compliant drivers */ + while (!uclass_find_device(UCLASS_MTD, idx, &dev) && dev) { + mtd_probe(dev); + idx++; + } +} +#else +static void mtd_probe_uclass_mtd_devs(void) { } +#endif + +int mtd_probe_devices(void) +{ + const char *mtdparts = env_get("mtdparts"); + const char *mtdids = env_get("mtdids"); + bool remaining_partitions = true; + struct mtd_info *mtd; + int i; + + mtd_probe_uclass_mtd_devs(); + + /* Check if mtdparts/mtdids changed since last call, otherwise: exit */ + if (!strcmp(mtdparts, old_mtdparts) && !strcmp(mtdids, old_mtdids)) + return CMD_RET_SUCCESS; + + /* Update the local copy of mtdparts */ + free(old_mtdparts); + free(old_mtdids); + old_mtdparts = strdup(mtdparts); + old_mtdids = strdup(mtdids); + + /* If at least one partition is still in use, do not delete anything */ + mtd_for_each_device(mtd) { + if (mtd->usecount) { + printf("Partition "%s" already in use, aborting\n", + mtd->name); + return CMD_RET_FAILURE; + } + } + + /* + * Everything looks clear, remove all partitions. It is not safe to + * remove entries from the mtd_for_each_device loop as it uses idr + * indexes and the partitions removal is done in bulk (all partitions of + * one device at the same time), so break and iterate from start each + * time a new partition is found and deleted. + */ + while (remaining_partitions) { + remaining_partitions = false; + mtd_for_each_device(mtd) { + if (!mtd_is_partition(mtd) && mtd_has_partitions(mtd)) { + del_mtd_partitions(mtd); + remaining_partitions = true; + break; + } + } + } + + /* Start the parsing by ignoring the extra 'mtdparts=' prefix, if any */ + if (strstr(mtdparts, "mtdparts=")) + mtdparts += 9; + + /* For each MTD device in mtdparts */ + while (mtdparts[0] != '\0') { + char mtd_name[MTD_NAME_MAX_LEN], *colon; + struct mtd_partition *parts; + int mtd_name_len, len; + int ret; + + colon = strchr(mtdparts, ':'); + if (!colon) { + printf("Wrong mtdparts: %s\n", mtdparts); + return CMD_RET_FAILURE; + } + + mtd_name_len = colon - mtdparts; + strncpy(mtd_name, mtdparts, mtd_name_len); + mtd_name[mtd_name_len] = '\0'; + /* Move the pointer forward (including the ':') */ + mtdparts += mtd_name_len + 1; + mtd = get_mtd_device_nm(mtd_name); + if (IS_ERR_OR_NULL(mtd)) { + char linux_name[MTD_NAME_MAX_LEN]; + + /* + * The MTD device named "mtd_name" does not exist. Try + * to find a correspondance with an MTD device having + * the same type and number as defined in the mtdids. + */ + debug("No device named %s\n", mtd_name); + ret = mtd_search_alternate_name(mtd_name, linux_name, + MTD_NAME_MAX_LEN); + if (!ret) + mtd = get_mtd_device_nm(linux_name); + + /* + * If no device could be found, move the mtdparts + * pointer forward until the next set of partitions. + */ + if (ret || IS_ERR_OR_NULL(mtd)) { + printf("Could not find a valid device for %s\n", + mtd_name); + mtdparts = strchr(mtdparts, ';'); + if (mtdparts) + mtdparts++; + + continue; + } + } + put_mtd_device(mtd); + + /* + * Parse the MTD device partitions. It will update the mtdparts + * pointer, create an array of parts (that must be freed), and + * return the number of partition structures in the array. + */ + ret = mtd_parse_partitions(mtd, &mtdparts, &parts, &len); + if (ret) { + printf("Could not parse device %s\n", mtd->name); + return CMD_RET_FAILURE; + } + + if (!len) + continue; + + /* + * Create the new MTD partitions and free the structures + * allocated during the parsing. + */ + add_mtd_partitions(mtd, parts, len); + + for (i = 0; i < len; i++) + free((char *)parts[i].name); + free(parts); + } + + return CMD_RET_SUCCESS; +} + +static uint mtd_len_to_pages(struct mtd_info *mtd, u64 len) +{ + do_div(len, mtd->writesize); + + return len; +} + +static bool mtd_is_aligned_with_min_io_size(struct mtd_info *mtd, u64 size) +{ + return do_div(size, mtd->writesize); +} + +static bool mtd_is_aligned_with_block_size(struct mtd_info *mtd, u64 size) +{ + return do_div(size, mtd->erasesize); +} + +static int do_mtd_list(void) +{ + struct mtd_info *mtd; + int dev_nb = 0; + +#if IS_ENABLED(CONFIG_MTD) + /* Ensure all devices (and their partitions) are probed */ + mtd_probe_devices(); +#endif + + printf("List of MTD devices:\n"); + mtd_for_each_device(mtd) { + if (!mtd_is_partition(mtd)) + mtd_show_device(mtd); + + dev_nb++; + } + + if (!dev_nb) { + printf("No MTD device found\n"); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static int do_mtd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct mtd_info *mtd; + const char *cmd; + char *mtd_name; + int ret; + + /* All MTD commands need at least two arguments */ + if (argc < 2) + return CMD_RET_USAGE; + + /* Parse the command name and its optional suffixes */ + cmd = argv[1]; + + /* List the MTD devices if that is what the user wants */ + if (strcmp(cmd, "list") == 0) + return do_mtd_list(); + + /* + * The remaining commands require also at least a device ID. + * Check the selected device is valid. Ensure it is probed. + */ + if (argc < 3) + return CMD_RET_USAGE; + + mtd_name = argv[2]; + mtd_probe_devices(); + mtd = get_mtd_device_nm(mtd_name); + if (IS_ERR_OR_NULL(mtd)) { + printf("MTD device %s not found, ret %ld\n", + mtd_name, PTR_ERR(mtd)); + return CMD_RET_FAILURE; + } + put_mtd_device(mtd); + + argc -= 3; + argv += 3; + + /* Do the parsing */ + if (!strncmp(cmd, "read", 4) || !strncmp(cmd, "dump", 4) || + !strncmp(cmd, "write", 5)) { + struct mtd_oob_ops io_op = {}; + bool dump, read, raw, woob; + uint user_addr = 0; + uint nb_pages; + u8 *buf; + u64 off, len, default_len; + u32 oob_len; + + dump = !strncmp(cmd, "dump", 4); + read = dump || !strncmp(cmd, "read", 4); + raw = strstr(cmd, ".raw"); + woob = strstr(cmd, ".oob"); + + if (!dump) { + if (!argc) + return CMD_RET_USAGE; + + user_addr = simple_strtoul(argv[0], NULL, 16); + argc--; + argv++; + } + + default_len = dump ? mtd->writesize : mtd->size; + off = argc > 0 ? simple_strtoul(argv[0], NULL, 16) : 0; + len = argc > 1 ? simple_strtoul(argv[1], NULL, 16) : + default_len; + nb_pages = mtd_len_to_pages(mtd, len); + oob_len = woob ? nb_pages * mtd->oobsize : 0; + + if (mtd_is_aligned_with_min_io_size(mtd, off)) { + printf("Offset not aligned with a page (0x%x)\n", + mtd->writesize); + return CMD_RET_FAILURE; + } + + if (mtd_is_aligned_with_min_io_size(mtd, len)) { + printf("Size not a multiple of a page (0x%x)\n", + mtd->writesize); + return CMD_RET_FAILURE; + } + + if (dump) + buf = kmalloc(len + oob_len, GFP_KERNEL); + else + buf = map_sysmem(user_addr, 0); + + if (!buf) { + printf("Could not map/allocate the user buffer\n"); + return CMD_RET_FAILURE; + } + + printf("%s %lldB (%d page(s)) at offset 0x%08llx%s%s\n", + read ? "Reading" : "Writing", len, nb_pages, off, + raw ? " [raw]" : "", woob ? " [oob]" : ""); + + io_op.mode = raw ? MTD_OPS_RAW : MTD_OPS_AUTO_OOB; + io_op.len = len; + io_op.ooblen = oob_len; + io_op.datbuf = buf; + io_op.oobbuf = woob ? &buf[len] : NULL; + + if (read) + ret = mtd_read_oob(mtd, off, &io_op); + else + ret = mtd_write_oob(mtd, off, &io_op); + + if (!ret && dump) { + uint page; + + for (page = 0; page < nb_pages; page++) { + u64 data_off = page * mtd->writesize; + + printf("\nDump %d data bytes from 0x%08llx:\n", + mtd->writesize, data_off); + mtd_dump_buf(buf, mtd->writesize, data_off); + + if (woob) { + u64 oob_off = page * mtd->oobsize; + + printf("Dump %d OOB bytes from page at 0x%08llx:\n", + mtd->oobsize, data_off); + mtd_dump_buf(&buf[len + oob_off], + mtd->oobsize, 0); + } + } + } + + if (dump) + kfree(buf); + else + unmap_sysmem(buf); + + if (ret) { + printf("%s on %s failed with error %d\n", + read ? "Read" : "Write", mtd->name, ret); + return CMD_RET_FAILURE; + } + + } else if (!strcmp(cmd, "erase")) { + bool scrub = strstr(cmd, ".dontskipbad"); + struct erase_info erase_op = {}; + u64 off, len; + + off = argc > 0 ? simple_strtoul(argv[0], NULL, 16) : 0; + len = argc > 1 ? simple_strtoul(argv[1], NULL, 16) : mtd->size; + + if (mtd_is_aligned_with_block_size(mtd, off)) { + printf("Offset not aligned with a block (0x%x)\n", + mtd->erasesize); + return CMD_RET_FAILURE; + } + + if (mtd_is_aligned_with_block_size(mtd, len)) { + printf("Size not a multiple of a block (0x%x)\n", + mtd->erasesize); + return CMD_RET_FAILURE; + } + + printf("Erasing 0x%08llx ... 0x%08llx (%d eraseblock(s))\n", + off, off + len - 1, mtd_div_by_eb(len, mtd)); + + erase_op.mtd = mtd; + erase_op.addr = off; + erase_op.len = len; + erase_op.scrub = scrub; + + while (erase_op.len) { + ret = mtd_erase(mtd, &erase_op); + + /* Abort if its not an bad block error */ + if (ret != -EIO) + break; + + printf("Skipping bad block at 0x%08llx\n", + erase_op.fail_addr); + + /* Skip bad block and continue behind it */ + erase_op.len -= erase_op.fail_addr - erase_op.addr; + erase_op.len -= mtd->erasesize; + erase_op.addr = erase_op.fail_addr + mtd->erasesize; + } + } else { + return CMD_RET_USAGE; + } + + if (ret) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +} + +static char mtd_help_text[] = +#ifdef CONFIG_SYS_LONGHELP + "- generic operations on memory technology devices\n\n" + "mtd list\n" + "mtd read[.raw][.oob] <name> <addr> [<off> [<size>]]\n" + "mtd dump[.raw][.oob] <name> [<off> [<size>]]\n" + "mtd write[.raw][.oob] <name> <addr> [<off> [<size>]]\n" + "mtd erase[.dontskipbad] <name> [<off> [<size>]]\n" + "\n" + "With:\n" + "\t<name>: NAND partition/chip name\n" + "\t<addr>: user address from/to which data will be retrieved/stored\n" + "\t<off>: offset in <name> in bytes (default: start of the part)\n" + "\t\t* must be block-aligned for erase\n" + "\t\t* must be page-aligned otherwise\n" + "\t<size>: length of the operation in bytes (default: the entire device)\n" + "\t\t* must be a multiple of a block for erase\n" + "\t\t* must be a multiple of a page otherwise (special case: default is a page with dump)\n" +#endif + ""; + +U_BOOT_CMD(mtd, 10, 1, do_mtd, "MTD utils", mtd_help_text); diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index cdf515256a..22ceda93c0 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifneq (,$(findstring y,$(CONFIG_MTD_DEVICE)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND)$(CONFIG_CMD_SF))) +ifneq (,$(findstring y,$(CONFIG_MTD_DEVICE)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND)$(CONFIG_CMD_SF)$(CONFIG_CMD_MTD))) obj-y += mtdcore.o mtd_uboot.o endif obj-$(CONFIG_MTD) += mtd-uclass.o diff --git a/include/mtd.h b/include/mtd.h index 6e6da3002f..04b1c50ac7 100644 --- a/include/mtd.h +++ b/include/mtd.h @@ -20,5 +20,6 @@ static inline struct mtd_info *mtd_get_info(struct udevice *dev) }
int mtd_probe(struct udevice *dev); +int mtd_probe_devices(void);
On Thu, 6 Sep 2018 09:08:51 +0200 Miquel Raynal miquel.raynal@bootlin.com wrote:
- const char *mtdparts = env_get("mtdparts");
- const char *mtdids = env_get("mtdids");
- bool remaining_partitions = true;
- struct mtd_info *mtd;
- int i;
- mtd_probe_uclass_mtd_devs();
- /* Check if mtdparts/mtdids changed since last call, otherwise: exit */
- if (!strcmp(mtdparts, old_mtdparts) && !strcmp(mtdids, old_mtdids))
- /* Update the local copy of mtdparts */
- free(old_mtdparts);
- free(old_mtdids);
- old_mtdparts = strdup(mtdparts);
- old_mtdids = strdup(mtdids);
- /* If at least one partition is still in use, do not delete anything */
- mtd_for_each_device(mtd) {
printf("Partition \"%s\" already in use, aborting\n",
mtd->name);
- while (remaining_partitions) {
break;
Just a detail, but I think this logic could be moved in moved in the core (mtd_uboot.c).
- /* Start the parsing by ignoring the extra 'mtdparts=' prefix, if any */
- if (strstr(mtdparts, "mtdparts="))
mtdparts += 9;
- /* For each MTD device in mtdparts */
- while (mtdparts[0] != '\0') {
int ret;
if (!colon) {
MTD_NAME_MAX_LEN);
if (!ret)
mtd_name);
if (mtdparts)
mtdparts++;
continue;
Don't know if the refcounting is a nop or not, but shouldn't we keep a reference to mtd until we're done manipulating it (after the call to add_mtd_partitions())?
if (ret) {
if (!len)
continue;
free(parts);
I'd recommend creating an helper for parts deletion:
void mtd_free_partitions(struct mtd_partitions *parts, unsigned int nparts) { for (i = 0; i < len; i++) free(parts[i].name);
free(parts); }
- return CMD_RET_SUCCESS;
Actually, I think the whole mtd_probe_devices() function (and its dependencies) should be moved in the core (mtd_uboot.c?) so that other components (ubi, cmd/mtdparts) can use it without depending/selecting CONFIG_CMD_MTD.
Current implementation of mtdparts command errors out if the desired MTD device is not found. Fallback to the new probe function in this case before erroring out.
This will the save the user the need to call something like 'mtd list' before mtdparts.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Acked-by: Jagan Teki jagan@openedev.com Reviewed-by: Stefan Roese sr@denx.de --- cmd/mtdparts.c | 16 +++++++++++++--- 1 file changed, 13 insertions(+), 3 deletions(-)
diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index f7ed1a0779..a1102c3fc5 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -79,6 +79,10 @@ #include <linux/err.h> #include <linux/mtd/mtd.h>
+#if defined(CONFIG_MTD) +#include <mtd.h> +#endif + #if defined(CONFIG_CMD_NAND) #include <linux/mtd/rawnand.h> #include <nand.h> @@ -307,9 +311,15 @@ static int get_mtd_info(u8 type, u8 num, struct mtd_info **mtd)
sprintf(mtd_dev, "%s%d", MTD_DEV_TYPE(type), num); *mtd = get_mtd_device_nm(mtd_dev); - if (IS_ERR(*mtd)) { - printf("Device %s not found!\n", mtd_dev); - return 1; + if (IS_ERR_OR_NULL(*mtd)) { +#ifdef CONFIG_MTD + mtd_probe_devices(); + *mtd = get_mtd_device_nm(mtd_dev); +#endif + if (IS_ERR_OR_NULL(*mtd)) { + printf("Device %s not found!\n", mtd_dev); + return 1; + } } put_mtd_device(*mtd);
On Thu, 6 Sep 2018 09:08:52 +0200 Miquel Raynal miquel.raynal@bootlin.com wrote:
return 1;
- if (IS_ERR_OR_NULL(*mtd)) {
+#ifdef CONFIG_MTD
In its current state, it should #ifdef CONFIG_CMD_MTD, since mtd_probe_devices() is implemented in cmd/mtd.c. Anyway, as I suggested, I think it's better to just move that in mtd_uboot.c and drop the #ifdef.
BTW, I'm not sure why we need to call mtd_probe_devices() here. If we really want to deprecate this command, then I'd recommend not adding new features to it.
return 1;
} put_mtd_device(*mtd);}
UBI should not mess with MTD partitions, now that the partitions are handled in a clean way, clean the ubi command and avoid using this uneeded extra-glue to reference the devices.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Stefan Roese sr@denx.de --- cmd/Kconfig | 2 ++ cmd/ubi.c | 100 +++++++++++++++------------------------------------- 2 files changed, 31 insertions(+), 71 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index b5bd978f6d..f82addca0a 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1822,6 +1822,8 @@ config CMD_UBI capabilities. Please, consult the MTD web site for more details (www.linux-mtd.infradead.org). Activate this option if you want to use U-Boot UBI commands. + It is also strongly encouraged to also enable CONFIG_MTD to get full + partition support.
config CMD_UBIFS tristate "Enable UBIFS - Unsorted block images filesystem commands" diff --git a/cmd/ubi.c b/cmd/ubi.c index 0a3405a3b1..af0cea2ca5 100644 --- a/cmd/ubi.c +++ b/cmd/ubi.c @@ -15,6 +15,9 @@ #include <command.h> #include <exports.h> #include <memalign.h> +#if defined(CONFIG_MTD) +#include <mtd.h> +#endif #include <nand.h> #include <onenand_uboot.h> #include <linux/mtd/mtd.h> @@ -29,17 +32,6 @@
/* Private own data */ static struct ubi_device *ubi; -static char buffer[80]; -static int ubi_initialized; - -struct selected_dev { - char part_name[80]; - int selected; - int nr; - struct mtd_info *mtd_info; -}; - -static struct selected_dev ubi_dev;
#ifdef CONFIG_CMD_UBIFS int ubifs_is_mounted(void); @@ -404,43 +396,24 @@ int ubi_volume_read(char *volume, char *buf, size_t size) return err; }
-static int ubi_dev_scan(struct mtd_info *info, char *ubidev, - const char *vid_header_offset) +static int ubi_dev_scan(struct mtd_info *info, const char *vid_header_offset) { - struct mtd_device *dev; - struct part_info *part; - struct mtd_partition mtd_part; char ubi_mtd_param_buffer[80]; - u8 pnum; int err;
- if (find_dev_and_part(ubidev, &dev, &pnum, &part) != 0) - return 1; + if (!vid_header_offset) + sprintf(ubi_mtd_param_buffer, "%s", info->name); + else + sprintf(ubi_mtd_param_buffer, "%s,%s", info->name, + vid_header_offset);
- sprintf(buffer, "mtd=%d", pnum); - memset(&mtd_part, 0, sizeof(mtd_part)); - mtd_part.name = buffer; - mtd_part.size = part->size; - mtd_part.offset = part->offset; - add_mtd_partitions(info, &mtd_part, 1); - - strcpy(ubi_mtd_param_buffer, buffer); - if (vid_header_offset) - sprintf(ubi_mtd_param_buffer, "mtd=%d,%s", pnum, - vid_header_offset); err = ubi_mtd_param_parse(ubi_mtd_param_buffer, NULL); - if (err) { - del_mtd_partitions(info); + if (err) return -err; - }
err = ubi_init(); - if (err) { - del_mtd_partitions(info); + if (err) return -err; - } - - ubi_initialized = 1;
return 0; } @@ -465,50 +438,35 @@ int ubi_detach(void) /* * Call ubi_exit() before re-initializing the UBI subsystem */ - if (ubi_initialized) { + if (ubi) ubi_exit(); - del_mtd_partitions(ubi_dev.mtd_info); - ubi_initialized = 0; - }
- ubi_dev.selected = 0; + ubi = NULL; + return 0; }
int ubi_part(char *part_name, const char *vid_header_offset) { + struct mtd_info *mtd; int err = 0; - char mtd_dev[16]; - struct mtd_device *dev; - struct part_info *part; - u8 pnum;
ubi_detach(); - /* - * Search the mtd device number where this partition - * is located - */ - if (find_dev_and_part(part_name, &dev, &pnum, &part)) { + +#ifdef CONFIG_MTD + mtd_probe_devices(); +#endif + mtd = get_mtd_device_nm(part_name); + if (IS_ERR(mtd)) { printf("Partition %s not found!\n", part_name); return 1; } - sprintf(mtd_dev, "%s%d", MTD_DEV_TYPE(dev->id->type), dev->id->num); - ubi_dev.mtd_info = get_mtd_device_nm(mtd_dev); - if (IS_ERR(ubi_dev.mtd_info)) { - printf("Partition %s not found on device %s!\n", part_name, - mtd_dev); - return 1; - } + put_mtd_device(mtd);
- ubi_dev.selected = 1; - - strcpy(ubi_dev.part_name, part_name); - err = ubi_dev_scan(ubi_dev.mtd_info, ubi_dev.part_name, - vid_header_offset); + err = ubi_dev_scan(mtd, vid_header_offset); if (err) { printf("UBI init error %d\n", err); printf("Please check, if the correct MTD partition is used (size big enough?)\n"); - ubi_dev.selected = 0; return err; }
@@ -539,13 +497,13 @@ static int do_ubi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* Print current partition */ if (argc == 2) { - if (!ubi_dev.selected) { - printf("Error, no UBI device/partition selected!\n"); + if (!ubi) { + printf("Error, no UBI device selected!\n"); return 1; }
- printf("Device %d: %s, partition %s\n", - ubi_dev.nr, ubi_dev.mtd_info->name, ubi_dev.part_name); + printf("Device %d: %s, MTD partition %s\n", + ubi->ubi_num, ubi->ubi_name, ubi->mtd->name); return 0; }
@@ -558,8 +516,8 @@ static int do_ubi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return ubi_part(argv[2], vid_header_offset); }
- if ((strcmp(argv[1], "part") != 0) && (!ubi_dev.selected)) { - printf("Error, no UBI device/partition selected!\n"); + if ((strcmp(argv[1], "part") != 0) && !ubi) { + printf("Error, no UBI device selected!\n"); return 1; }
Hi Miquel,
On Thu, 6 Sep 2018 09:08:53 +0200 Miquel Raynal miquel.raynal@bootlin.com wrote:
- struct mtd_info *mtd; int err = 0;
char mtd_dev[16];
u8 pnum;
ubi_detach();
* is located
+#ifdef CONFIG_MTD
- mtd_probe_devices();
Okay, so just like for the mtdparts patch, the #ifdef is incorrect, but more importantly, with you're rework, you're breaking all non-DM platforms, because the UBI layer no longer creates an MTD device on the fly, and the mtd partition creation won't take place if CONFIG_MTD is not activated.
My suggestion would be to make mtd_probe_devices() available to everyone (not only those who have CONFIG_MTD selected, which in turn depends on CONFIG_DM) so that the mtd part creation is done unconditionally, and you can safely get rid of the "dummy MTD device creation" done in UBI.
- mtd = get_mtd_device_nm(part_name);
- if (IS_ERR(mtd)) {
Regards,
Boris
The 'mtdparts' command is not needed anymore. While the environment variable is still valid (and useful, along with the 'mtdids' one), the command has been replaced by 'mtd' which is much more close to the MTD stack and do not add its own specific glue.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com Reviewed-by: Stefan Roese sr@denx.de --- cmd/Kconfig | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index f82addca0a..51dd058128 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1680,7 +1680,11 @@ config CMD_MTDPARTS bool "MTD partition support" select MTD_DEVICE if (CMD_NAND || NAND) help - MTD partition support + MTD partitioning tool support. + It is strongly encouraged to avoid using this command + anymore. One can still declare the partitions in the + mtdparts environment variable but better use the MTD stack + and the mtd command instead than this one.
On Thu, 6 Sep 2018 09:08:54 +0200 Miquel Raynal miquel.raynal@bootlin.com wrote:
Well, that's only working if people stop using nand,onenand,sf,... commands in favor the mtd ones, otherwise they still need mtdparts, unfortunately :-(.
I guess a long term goal could be to define aliases between flash specific commands and the generic mtd ones so that we can get rid of cmd/<flashcmd>.c drivers.
Regards,
Boris
Hello,
I failed the numbering, this is actually the v8. The below changelog is still right though. I don't plan to resend unless I am explicitly told to do so.
Sorry for the mistake.
Thanks, Miquèl
Miquel Raynal miquel.raynal@bootlin.com wrote on Thu, 6 Sep 2018 09:08:42 +0200:
During the last months, Boris Brezillon shared his work to support serial flashes within Linux. First, he delivered (and merged) a new layer called spi-mem. He also initiated in Linux MTD subsystem the move of all 'raw' NAND related code to a raw/ subdirectory, adding at the same time a NAND core that would be shared with all NAND devices. Then, he contributed a generic SPI-NAND driver, making use of this NAND core, as well as some vendor code to drive a few chips.
On top of this work, I made some cleanups in the MTD layer and added an 'mtd' U-Boot command to handle all sort of MTD devices. This should become the default command instead of having one per flash flavor ('sf', 'nand', 'spi-nand' ?).
The series has been tested on an Ocelot board PCB123 (VSC7514), featuring a Macronix SPI NAND chip.
TL;DR: the series contains (stripped version since 23 patches have already been taken):
- Various fixes
- Support for spi-nand devices in mtdparts.
- Generics mtdparts/mtdids parsers.
- A new 'mtd' command.
- A note to set mtdparts command legacy.
To test your SPI-NAND device with U-Boot, you can test someting like:
setenv mtdparts 'spi-nand0:1m(foo),-(bar)' setenv mtdids 'spi-nand0=spi0.0' # spi0.0 is Linux MTD name for this device ubi part bar # create a static UBI volume in the bar partition mtd list # show the current MTD devices/partitions
Thanks, Miquèl
Changes since v7:
- Added Stefan R-b tags.
- Used tolower() as suggested by Stefan in lib/strto.c.
- Added a mention saying that we continue to abuse the kB suffix in lib/strto.c by not making a difference between kB and kiB which both mean "* 1024" for us. This has been added in the commit log.
- Fixed various bugs in the mtd command and in the parsers, they should be pretty stable now (tested with two MTD devices probed and several different partition configurations).
- mtdids is not deprecated at all as opposed at what I wrote in v6. U-Boot still uses its own MTD names (being <type><idx> like nor0 or spi-nand1) and mtdids is still needed to do the glue.
- Removed a useless patch removing a Kconfig entry I added myself since during a rebase someone else also added this symbol.
Changes since v6:
- Squashed Boris' fixes about build issues in Travis.
- Merged Stefan Roese's contributions.
- cmd: mtdparts:
- added fallthrough comments in switch blocks deriving sizes.
- balanced debug messages to compare freed and allocated partitions.
- move mtdparts_init() declaration in mtd/partitions.h to be used in mtd command as well.
- introduced a "compatibility" function to return what the MTD device name could be thanks to the mtdids environment variable (which is useless with the new partitioning logic).
- mtd: mtdpart:
- reworked the way partitions are created/handled.
- cmd: mtd:
- implement a partitioning logic that takes the best out of the MTD layer without re-inventing the wheel. Partitions are all freed correctly when the value of mtdparts changes.
- balance get_mtd_device() by put_mtd_device() calls.
- prevent memory leak by reorganizing the code a bit in do_mtd.
- do not reconstruct partition list when a partition is already in use (complain about that instead).
- add support for the legacy mtdids (not needed anymore if mtdparts directly uses the MTD device names as in Linux.
- cmd: ubi:
- clean and simplify the partition handling a bit to make use the best use of the MTD layer as well and keep the code simple.
Changes since v5:
- Included Boris fixup about the build issues.
- Added Rb/Ab tags from Jagan on patchs 20/21.
Changes since v4:
- Added Jagan's Acked-by tags to every patch related to the SPI-mem/SPI-NAND addition.
- Rebased on top of master.
Changes since v3:
- Fixed the debug messages in spi-mem to print either Rx or Tx data.
- Fixed a Kconfig error that prevented to build mtdparts with plain defconfig.
- Fixed a compilation error due to the above error that prevented one file to be compiled.
- Adapted the mtd command to probe MTD partitions also.
- Declared mtd_probe_devices() in a header so mtdparts or UBI could use it too (to probe all devices and MTD partitions in a clean way).
- As I worked on mtdparts, I found annoying and completely useless the fact that we need to prefix the environment variable with "mtdparts=". Canceled this obligation.
- Added one patch to allow spi-nand devices to be recognized by mtdparts (this is purely useless but needed to be done in order to use this command).
- Removed useless definitions of MTD device types in UBI code.
- Wrote a generic mtdparts environment variable parser, used by the mtd command.
- Used the mtd_probe_devices() function from get_mtd_info() in cmd/mtdparts.c to be sure the desired partition really does not exist (otherwise it will be probed and then found).
Changes since v2:
- Rebased on u-boot master branch.
- Removed extra-parenthesis in "mtd: Fallback to ->_read/write() when ->_read/write_oob() is missing"
- s/fiels/files/ in "mtd: move NAND fiels into a raw/ subdirectory"
- Do not describe generic SPI device properties in SPI NAND bindings.
- Changes in the mtd command:
- Printing more information in 'mtd list' (device type, device characteristics)
- Switch to do_div() instead of '(u32)value64b % value32b' which only worked because value32b was a power of 2.
- Removed erase.chip option.
- By default, erase/read/write happen on the full MTD device while a dump will only work on a single page.
Changes since v1:
- Fixed the nand_memorg structure of the MX35LF2GE4AB chip.
- Added Reviewed-by tags from Jagan.
- Backported and squashed two patches fixing things in the SPI NAND core received on the Linux ML.
- Backported more changes in mtdcore.c from Linux.
- Added a patch to add a fallback on mtd->_read/_write() in mtdcore.c when mtd->_read/write_oob() is not supported.
- Removed the DT changes, useless as the DTs are not available in mainline yet.
- Addressed Boris/Stefan comments on the 'mtd' command.
- Added support for multi-pages OOB read/write.
Miquel Raynal (12): lib: strto: parse all lowercase metric prefixes in ustrtoul[l] lib: strto: fix metric suffix parsing in strtoul[l] cmd: mtdparts: accept spi-nand devices cmd: mtdparts: remove mandatory 'mtdparts=' prefix mtd: uclass: add probe function mtd: uclass: add a generic 'mtdparts' parser mtd: uclass: search for an equivalent MTD name with the mtdids mtd: mtdpart: implement proper partition handling cmd: mtd: add 'mtd' command cmd: mtdparts: try to probe the MTD devices as a fallback cmd: ubi: clean the partition handling cmd: mtdparts: describe as legacy
cmd/Kconfig | 18 +- cmd/Makefile | 1 + cmd/mtd.c | 521 ++++++++++++++++++++++++++ cmd/mtdparts.c | 46 ++- cmd/ubi.c | 100 ++--- drivers/mtd/Makefile | 2 +- drivers/mtd/mtd-uclass.c | 16 + drivers/mtd/mtdcore.c | 2 + drivers/mtd/mtdpart.c | 660 +++++++++++++++++++++------------ include/jffs2/load_kernel.h | 7 +- include/linux/mtd/mtd.h | 31 ++ include/linux/mtd/partitions.h | 5 +- include/mtd.h | 3 + lib/strto.c | 36 +- 14 files changed, 1094 insertions(+), 354 deletions(-) create mode 100644 cmd/mtd.c
Hi Jagan,
I just wanted to ask about the timeline for the SPI-NAND patches. I remember that Tom wanted to have them in 2018.11. Is this going to happen or is there anything preventing this?
Thanks, Frieder
On 06.09.2018 09:15, Miquel Raynal wrote:
Hello,
Thanks, Miquèl
- Various fixes
Thanks, Miquèl
Changes since v7:
Changes since v6:
- cmd: mtdparts:
- mtd: mtdpart:
- cmd: mtd:
- cmd: ubi:
Changes since v5:
Changes since v4:
Changes since v3:
Changes since v2:
Changes since v1:
On Thu, Sep 20, 2018 at 7:36 PM, Frieder Schrempf frieder.schrempf@exceet.de wrote:
Hi Jagan,
Travis[1] for combination of earlier series + this. Will send PR soon I get the results.
Miquel, Let me know if anything miss here?
[1] https://travis-ci.org/openedev/u-boot-amarula/builds/431062285
Hi Jagan, Frieder,
Jagan Teki jagan@amarulasolutions.com wrote on Thu, 20 Sep 2018 20:16:06 +0530:
Hi Jagan,
You can definitely take the earlier series, they are fine and work on their own. About this one, the four first patches are fine and won't be changed, please keep them: lib: strto: parse all lowercase metric prefixes in ustrtoul[l] lib: strto: fix metric suffix parsing in strtoul[l] cmd: mtdparts: accept spi-nand devices cmd: mtdparts: remove mandatory 'mtdparts=' prefix
For the rest, as pointed by Boris, it would break UBI for certain users so I want to make a last version (mostly code moves) next week to fit it. I will resend a v9 only for patches: mtd: uclass: add probe function mtd: uclass: add a generic 'mtdparts' parser mtd: uclass: search for an equivalent MTD name with the mtdids mtd: mtdpart: implement proper partition handling cmd: mtd: add 'mtd' command cmd: mtdparts: try to probe the MTD devices as a fallback cmd: ubi: clean the partition handling cmd: mtdparts: describe as legacy
2018.11 is definitely the target.
Thanks, Miquèl
Hi Miquel,
On 20.09.2018 16:59, Miquel Raynal wrote:
Hi Jagan, Frieder,
Hi Jagan,
Ok, good to know and thanks a lot for the effort you are putting into this.
Thanks, Frieder
Thanks, Miquèl
On Thu, Sep 20, 2018 at 8:29 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Jagan, Frieder,
Hi Jagan,
I shall pick upto this and wait for v8 to send PR together.
Hi Jagan,
Jagan Teki jagan@amarulasolutions.com wrote on Fri, 21 Sep 2018 13:45:56 +0530:
Hi Jagan, Frieder,
Hi Jagan,
Perfect!
Thanks, Miquèl
Hi Jagan,
Hi Jagan, Frieder,
Hi Jagan,
Here you have the v9 in your mailbox (this was the v8 but I messed-up with git-format-patch). For me all the features (both for spi-nand and the 'mtd' command) are available.
I hope this is not too late before the merge window closes, I spent more time than expected testing/fixing small errors. Of course I'm still there and listen for feedback/bug reports.
Thanks, Miquèl
Boris Brezillon
Frieder Schrempf
Jagan Teki
Miquel Raynal
