[U-Boot] [PATCH] cmd: Make CMD_LZMA / CMD_UNZIP default y if CMD_BOOTI
In the Linux Kernel on ARM64, the Image.COMPRESSION file is not self-extracting in the way that x86 and ARM images are. So when CMD_BOOTI is enabled we should also default to enabling CMD_UNZIP and CONFIG_LZMA in order for the user to be able to decompress many of the common compressions that will be done to an Image file.
Signed-off-by: Tom Rini trini@konsulko.com --- cmd/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index d6d130edfa91..f923b0e421f7 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -526,6 +526,7 @@ menu "Compression commands"
config CMD_LZMADEC bool "lzmadec" + default y if CMD_BOOTI select LZMA help Support decompressing an LZMA (Lempel-Ziv-Markov chain algorithm) @@ -533,6 +534,7 @@ config CMD_LZMADEC
config CMD_UNZIP bool "unzip" + default y if CMD_BOOTI help Uncompress a zip-compressed memory region.
