[BUG] sandbox_defconfig u-boot -T crashes
Hello Simon,
I have built sandbox_defconfig using origin/master (b9b83a86f0e8 ("Merge branch 'master' of https://source.denx.de/u-boot/custodians/u-boot-sh")) on Ubuntu 23.10.
Running ./u-boot -T leads to a crash:
#9 0x00007ffff7a28189 in __libc_start_main_impl (main=0x555555591540 <main>, argc=2, argv=0x7fffffffd918, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7fffffffd908) at ../csu/libc-start.c:360 360 in ../csu/libc-start.c (gdb) #8 0x00007ffff7a280d0 in __libc_start_call_main (main=main@entry=0x555555591540 <main>, argc=argc@entry=2, argv=argv@entry=0x7fffffffd918) at ../sysdeps/nptl/libc_start_call_main.h:58 58 ../sysdeps/nptl/libc_start_call_main.h: No such file or directory. (gdb) #7 0x0000555555591e19 in sandbox_main (argc=2, argv=0x7fffffffd918) at arch/sandbox/cpu/start.c:557 557 board_init_r(gd->new_gd, 0); (gdb) #6 board_init_r (new_gd=<optimized out>, dest_addr=dest_addr@entry=0) at common/board_r.c:818 818 if (initcall_run_list(init_sequence_r)) (gdb) #5 0x00005555555d961e in initcall_run_list (init_sequence=0x5555558e1860 <init_sequence_r>) at include/initcall.h:46 46 ret = (*init_fnc_ptr)(); (gdb) #4 0x00005555555e695d in stdio_add_devices () at common/stdio.c:332 332 for (ret = uclass_first_device_check(UCLASS_KEYBOARD, &dev); (gdb) #3 0x00005555555f9e4f in uclass_first_device_check (devp=<optimized out>, id=UCLASS_KEYBOARD) at drivers/core/uclass.c:644 644 return device_probe(*devp); (gdb) #2 0x00005555555f7235 in device_probe (dev=0x1ac9c800) at drivers/core/device.c:583
583 ret = drv->probe(dev); (gdb) #1 0x000055555560ae09 in input_stdio_register (dev=0x1aead870) at drivers/input/input.c:674 674 if (!error && strcmp(env_get("stdin"), dev->name) == 0) { (gdb) #0 strcmp (cs=0x1 <error: Cannot access memory at address 0x1>, ct=0x1aead879 "ros-ec-keyb", ct@entry=0x1aead878 "cros-ec-keyb") at lib/string.c:217 217 ret = a - b;
env_get("stdin") returns NULL here and should not be used without checking.
Best regards
Heinrich
Hi Heinrich,
On Wed, 20 Sept 2023 at 10:01, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hello Simon,
Something else is wrong though, since env_get() should return the correct value here, not NULL.
