[U-Boot] [PATCH] Remove malloc_bin_reloc from lib_sh, lib_nios2 and lib_nios.
By "arm/microblaze/nios/nios2/sh: Remove relocation fixups" (commit: 0630535e2d062dd73c1ceca5c6125c86d1127a49", doesn't need malloc_bin_reloc function. This commit remove this.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- lib_nios/board.c | 2 -- lib_nios2/board.c | 2 -- lib_sh/board.c | 2 -- 3 files changed, 0 insertions(+), 6 deletions(-)
diff --git a/lib_nios/board.c b/lib_nios/board.c index 72713a8..5d2fb2e 100644 --- a/lib_nios/board.c +++ b/lib_nios/board.c @@ -49,7 +49,6 @@ DECLARE_GLOBAL_DATA_PTR; */
-extern void malloc_bin_reloc (void); typedef int (init_fnc_t) (void);
@@ -115,7 +114,6 @@ void board_init (void)
/* The Malloc area is immediately below the monitor copy in RAM */ mem_malloc_init(CONFIG_SYS_MALLOC_BASE, CONFIG_SYS_MALLOC_LEN); - malloc_bin_reloc();
WATCHDOG_RESET (); bd->bi_flashsize = flash_init(); diff --git a/lib_nios2/board.c b/lib_nios2/board.c index c6b36f4..008f04f 100644 --- a/lib_nios2/board.c +++ b/lib_nios2/board.c @@ -52,7 +52,6 @@ DECLARE_GLOBAL_DATA_PTR; */
@@ -121,7 +120,6 @@ void board_init (void)
WATCHDOG_RESET (); bd->bi_flashsize = flash_init(); diff --git a/lib_sh/board.c b/lib_sh/board.c index 5ed40e9..c97e20c 100644 --- a/lib_sh/board.c +++ b/lib_sh/board.c @@ -32,7 +32,6 @@ #include <miiphy.h> #endif
-extern void malloc_bin_reloc (void); extern int cpu_init(void); extern int board_init(void); extern int dram_init(void); @@ -92,7 +91,6 @@ static int sh_mem_env_init(void) { mem_malloc_init(TEXT_BASE - CONFIG_SYS_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN, CONFIG_SYS_MALLOC_LEN - 16); - malloc_bin_reloc(); env_relocate(); jumptable_init(); return 0;
Nobuhiro Iwamatsu
