[U-Boot] [PATCH] avr32:portmux: fix setup for macb1
Use portd_mask instead of portc_mask to setup the pins for port D.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- arch/avr32/cpu/at32ap700x/portmux.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/avr32/cpu/at32ap700x/portmux.c b/arch/avr32/cpu/at32ap700x/portmux.c index e3e38a2..7eb42de 100644 --- a/arch/avr32/cpu/at32ap700x/portmux.c +++ b/arch/avr32/cpu/at32ap700x/portmux.c @@ -122,7 +122,7 @@ void portmux_enable_macb1(unsigned long flags, unsigned long drive_strength) portd_mask |= (1 << 15);/* SPD */
/* REVISIT: Some pins are probably pure outputs */ - portmux_select_peripheral(PORTMUX_PORT_D, portc_mask, + portmux_select_peripheral(PORTMUX_PORT_D, portd_mask, PORTMUX_FUNC_B, PORTMUX_BUSKEEPER); portmux_select_peripheral(PORTMUX_PORT_C, portc_mask, PORTMUX_FUNC_B, PORTMUX_BUSKEEPER);
Andreas Bießmann
