[U-Boot] [PATCH] armv7, beagle: Second SDRAM bank don;t work
since commit 3667cbeed5e3c4067e624e52a916b1ebb02c8f05 on beagle board the second sdram bank didn;t longer work. Since this patch sdram settings just get copied from bank a, but CMD_NOP, CMD_PRECHARGE, CMD_AUTOREFRESH are not executed and after that mr register is also not updated. This patch adds this for the bank b.
Signed-off-by: Heiko Schocher hs@denx.de cc: Steve Sakoman steve@sakoman.com cc: Sandeep Paulraj s-paulraj@ti.com cc: Wolfgang Denk wd@denx.de --- Wolfgang, this patch should also be added to u-boot-arm elf_reloc
arch/arm/cpu/armv7/omap3/sdrc.c | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/sdrc.c b/arch/arm/cpu/armv7/omap3/sdrc.c index 2719bb5..3087096 100644 --- a/arch/arm/cpu/armv7/omap3/sdrc.c +++ b/arch/arm/cpu/armv7/omap3/sdrc.c @@ -149,6 +149,13 @@ void do_sdrc_init(u32 cs, u32 early) &sdrc_actim_base1->ctrla); writel(readl(&sdrc_actim_base0->ctrlb), &sdrc_actim_base1->ctrlb); + + writel(CMD_NOP, &sdrc_base->cs[cs].manual); + writel(CMD_PRECHARGE, &sdrc_base->cs[cs].manual); + writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); + writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); + writel(readl(&sdrc_base->cs[CS0].mr), + &sdrc_base->cs[CS1].mr); }
Dear Heiko Schocher,
I would like to see Steve's ACK for the original Beagle board, and it's several versions.
Steve, what Heiko forgets to mention here is that this problem happened on a EBV-Beagle, so there are certrain hardware differences.
I suspect that his using an EVB-Beagle (with associated EVB x-load) is what is causing the issue for him.
With the introduction of the Beagle xM came the need to deal with several types of POP memory, and the resulting need for customized setup for the SDRC.
This is best handled in x-load while running from SRAM, since timings and mux setup are different for each memory type.
The code in Beagle x-load currently looks like this:
void config_3430sdram_ddr(void) { /* reset sdrc controller */ __raw_writel(SOFTRESET, SDRC_SYSCONFIG); wait_on_value(BIT0, BIT0, SDRC_STATUS, 12000000); __raw_writel(0, SDRC_SYSCONFIG);
/* setup sdrc to ball mux */ __raw_writel(SDP_SDRC_SHARING, SDRC_SHARING);
if (beagle_revision() == REVISION_XM) { if (identify_xm_ddr() == MICRON_DDR) { __raw_writel(0x2, SDRC_CS_CFG); /* 256MB/bank */ __raw_writel(SDP_SDRC_MDCFG_0_DDR_MICRON_XM, SDRC_MCFG_0); __raw_writel(SDP_SDRC_MDCFG_0_DDR_MICRON_XM, SDRC_MCFG_1); __raw_writel(MICRON_V_ACTIMA_200, SDRC_ACTIM_CTRLA_0); __raw_writel(MICRON_V_ACTIMB_200, SDRC_ACTIM_CTRLB_0); __raw_writel(MICRON_V_ACTIMA_200, SDRC_ACTIM_CTRLA_1); __raw_writel(MICRON_V_ACTIMB_200, SDRC_ACTIM_CTRLB_1); __raw_writel(SDP_3430_SDRC_RFR_CTRL_200MHz, SDRC_RFR_CTRL_0); __raw_writel(SDP_3430_SDRC_RFR_CTRL_200MHz, SDRC_RFR_CTRL_1); } else { __raw_writel(0x4, SDRC_CS_CFG); /* 512MB/bank */ __raw_writel(SDP_SDRC_MDCFG_0_DDR_NUMONYX_XM, SDRC_MCFG_0); __raw_writel(SDP_SDRC_MDCFG_0_DDR_NUMONYX_XM, SDRC_MCFG_1); __raw_writel(NUMONYX_V_ACTIMA_165, SDRC_ACTIM_CTRLA_0); __raw_writel(NUMONYX_V_ACTIMB_165, SDRC_ACTIM_CTRLB_0); __raw_writel(NUMONYX_V_ACTIMA_165, SDRC_ACTIM_CTRLA_1); __raw_writel(NUMONYX_V_ACTIMB_165, SDRC_ACTIM_CTRLB_1); __raw_writel(SDP_3430_SDRC_RFR_CTRL_165MHz, SDRC_RFR_CTRL_0); __raw_writel(SDP_3430_SDRC_RFR_CTRL_165MHz, SDRC_RFR_CTRL_1); } } else { __raw_writel(0x1, SDRC_CS_CFG); /* 128MB/bank */ __raw_writel(SDP_SDRC_MDCFG_0_DDR, SDRC_MCFG_0); __raw_writel(SDP_SDRC_MDCFG_0_DDR, SDRC_MCFG_1); __raw_writel(MICRON_V_ACTIMA_165, SDRC_ACTIM_CTRLA_0); __raw_writel(MICRON_V_ACTIMB_165, SDRC_ACTIM_CTRLB_0); __raw_writel(MICRON_V_ACTIMA_165, SDRC_ACTIM_CTRLA_1); __raw_writel(MICRON_V_ACTIMB_165, SDRC_ACTIM_CTRLB_1); __raw_writel(SDP_3430_SDRC_RFR_CTRL_165MHz, SDRC_RFR_CTRL_0); __raw_writel(SDP_3430_SDRC_RFR_CTRL_165MHz, SDRC_RFR_CTRL_1); }
__raw_writel(SDP_SDRC_POWER_POP, SDRC_POWER);
/* init sequence for mDDR/mSDR using manual commands (DDR is different) */ __raw_writel(CMD_NOP, SDRC_MANUAL_0); __raw_writel(CMD_NOP, SDRC_MANUAL_1);
delay(5000);
__raw_writel(CMD_PRECHARGE, SDRC_MANUAL_0); __raw_writel(CMD_PRECHARGE, SDRC_MANUAL_1);
__raw_writel(CMD_AUTOREFRESH, SDRC_MANUAL_0); __raw_writel(CMD_AUTOREFRESH, SDRC_MANUAL_1);
/* set mr0 */ __raw_writel(SDP_SDRC_MR_0_DDR, SDRC_MR_0); __raw_writel(SDP_SDRC_MR_0_DDR, SDRC_MR_1);
/* set up dll */ __raw_writel(SDP_SDRC_DLLAB_CTRL, SDRC_DLLA_CTRL); delay(0x2000); /* give time to lock */
The code in u-boot to copy bank 1 settings to bank 2 was a workaround so that Beagle users who didn't update x-load immediately would at least have a functioning system.
I don't think that Heiko's patch will do any harm and it might be a good idea so that EVB Beagle users can use the standard Beagle u-boot. I will have to verify that it does no harm on all the various Beagle versions first though.
I will Ack or Nack after I do some testing.
Regards,
Steve
Hello Steve,
Yep, seems so.
Yep, so I think too ...
Thanks!
bye, Heiko
Dear Steve Sakoman,
I still wonder why x-load was foprked out of the U-Boot tree; I guess a number of problems would simply not exist at all if the code was maintained together.
Do let me know the results of your testing
Regards, Sandeep
- writel(CMD_NOP, &sdrc_base->cs[cs].manual);
- writel(CMD_PRECHARGE, &sdrc_base->cs[cs].manual);
- writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual);
- writel(readl(&sdrc_base->cs[CS0].mr),
- &sdrc_base->cs[CS1].mr);
1.7.2.3
I tested this on Overos with 3 brands of POP memory and both 35XX and 37XX processors. Seemed to do no harm on any combination, so:
Acked-by: Steve Sakoman steve.sakoman@linaro.org Tested-by: Steve Sakoman steve.sakoman@linaro.org
Heiko Schocher
Paulraj, Sandeep
Steve Sakoman
