[PATCH 1/1] doc: conf.py: correct title and author of generated pdf
Adjust the PDF output options for rst2pdf:
* Set start document to 'index'. * Set title to 'Das U-Boot'. * Set author to 'The U-Boot development community'.
Correct documentation link.
Remove obsolete FIXME.
Link: https://rst2pdf.org/static/manual.html Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/conf.py | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/doc/conf.py b/doc/conf.py index ced3a6723fc..c50daf874a5 100644 --- a/doc/conf.py +++ b/doc/conf.py @@ -560,13 +560,9 @@ epub_exclude_files = ['search.html'] # Grouping the document tree into PDF files. List of tuples # (source start file, target name, title, author, options). # -# See the Sphinx chapter of https://ralsina.me/static/manual.pdf -# -# FIXME: Do not add the index file here; the result will be too big. Adding -# multiple PDF files here actually tries to get the cross-referencing right -# *between* PDF files. +# See https://rst2pdf.org/static/manual.html#sphinx pdf_documents = [ - ('uboot-documentation', u'U-Boot', u'U-Boot', u'J. Random Bozo'), + ('index', u'U-Boot', u'Das U-Boot', u'The U-Boot development community'), ]
# kernel-doc extension configuration for running Sphinx directly (e.g. by Read
