[U-Boot] [PATCH] ARM: imx: apalis_imx6: Drop ad-hoc SATA binding
Drop the ad-hoc AHCI binding code, this is superseded by CONFIG_DWC_AHSATA_AHCI=y resp. drivers/ata/dwc_ahsata.c
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Stefan Agner stefan.agner@toradex.com Cc: Stefano Babic sbabic@denx.de --- board/toradex/apalis_imx6/apalis_imx6.c | 49 ------------------------- 1 file changed, 49 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 3e59185438..b502d4ef13 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -1131,52 +1131,3 @@ U_BOOT_DEVICE(mxc_serial) = { .name = "serial_mxc", .platdata = &mxc_serial_plat, }; - -#if CONFIG_IS_ENABLED(AHCI) -static int sata_imx_probe(struct udevice *dev) -{ - int i, err; - - for (i = 0; i < APALIS_IMX6_SATA_INIT_RETRIES; i++) { - err = setup_sata(); - if (err) { - printf("SATA setup failed: %d\n", err); - return err; - } - - udelay(100); - - err = dwc_ahsata_probe(dev); - if (!err) - break; - - /* There is no device on the SATA port */ - if (sata_dm_port_status(0, 0) == 0) - break; - - /* There's a device, but link not established. Retry */ - device_remove(dev, DM_REMOVE_NORMAL); - } - - return 0; -} - -struct ahci_ops sata_imx_ops = { - .port_status = dwc_ahsata_port_status, - .reset = dwc_ahsata_bus_reset, - .scan = dwc_ahsata_scan, -}; - -static const struct udevice_id sata_imx_ids[] = { - { .compatible = "fsl,imx6q-ahci" }, - { } -}; - -U_BOOT_DRIVER(sata_imx) = { - .name = "dwc_ahci", - .id = UCLASS_AHCI, - .of_match = sata_imx_ids, - .ops = &sata_imx_ops, - .probe = sata_imx_probe, -}; -#endif /* AHCI */
Works fine, thanks!
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
- int i, err;
err = setup_sata();
if (err) {
return err;
udelay(100);
if (!err)
break;
break;
Drop the ad-hoc AHCI binding code, this is superseded by CONFIG_DWC_AHSATA_AHCI=y resp. drivers/ata/dwc_ahsata.c Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Stefan Agner stefan.agner@toradex.com Cc: Stefano Babic sbabic@denx.de Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Best regards, Stefano Babic
Marcel Ziswiler
sbabic@denx.de
