[U-Boot] [PATCH V3 03/11] MX51: Add register definitions
The patch add header files to support the Freescale i.MX51 processor, setting definitions for internal registers.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Fred Fan fanyefeng@gmail.com --- include/asm-arm/arch-mx51/asm-offsets.h | 50 ++++++ include/asm-arm/arch-mx51/crm_regs.h | 192 +++++++++++++++++++++ include/asm-arm/arch-mx51/imx-regs.h | 282 +++++++++++++++++++++++++++++++ 3 files changed, 524 insertions(+), 0 deletions(-) create mode 100644 include/asm-arm/arch-mx51/asm-offsets.h create mode 100644 include/asm-arm/arch-mx51/crm_regs.h create mode 100644 include/asm-arm/arch-mx51/imx-regs.h
diff --git a/include/asm-arm/arch-mx51/asm-offsets.h b/include/asm-arm/arch-mx51/asm-offsets.h new file mode 100644 index 0000000..3a83fa0 --- /dev/null +++ b/include/asm-arm/arch-mx51/asm-offsets.h @@ -0,0 +1,50 @@ +/* + * needed for cpu/arm_cortexa8/mx51/lowlevel_init.S + * + * These should be auto-generated + */ +/* CCM */ +#define CLKCTL_CCR 0x00 +#define CLKCTL_CCDR 0x04 +#define CLKCTL_CSR 0x08 +#define CLKCTL_CCSR 0x0C +#define CLKCTL_CACRR 0x10 +#define CLKCTL_CBCDR 0x14 +#define CLKCTL_CBCMR 0x18 +#define CLKCTL_CSCMR1 0x1C +#define CLKCTL_CSCMR2 0x20 +#define CLKCTL_CSCDR1 0x24 +#define CLKCTL_CS1CDR 0x28 +#define CLKCTL_CS2CDR 0x2C +#define CLKCTL_CDCDR 0x30 +#define CLKCTL_CHSCCDR 0x34 +#define CLKCTL_CSCDR2 0x38 +#define CLKCTL_CSCDR3 0x3C +#define CLKCTL_CSCDR4 0x40 +#define CLKCTL_CWDR 0x44 +#define CLKCTL_CDHIPR 0x48 +#define CLKCTL_CDCR 0x4C +#define CLKCTL_CTOR 0x50 +#define CLKCTL_CLPCR 0x54 +#define CLKCTL_CISR 0x58 +#define CLKCTL_CIMR 0x5C +#define CLKCTL_CCOSR 0x60 +#define CLKCTL_CGPR 0x64 +#define CLKCTL_CCGR0 0x68 +#define CLKCTL_CCGR1 0x6C +#define CLKCTL_CCGR2 0x70 +#define CLKCTL_CCGR3 0x74 +#define CLKCTL_CCGR4 0x78 +#define CLKCTL_CCGR5 0x7C +#define CLKCTL_CCGR6 0x80 +#define CLKCTL_CMEOR 0x84 + +/* DPLL */ +#define PLL_DP_CTL 0x00 +#define PLL_DP_CONFIG 0x04 +#define PLL_DP_OP 0x08 +#define PLL_DP_MFD 0x0C +#define PLL_DP_MFN 0x10 +#define PLL_DP_HFS_OP 0x1C +#define PLL_DP_HFS_MFD 0x20 +#define PLL_DP_HFS_MFN 0x24 diff --git a/include/asm-arm/arch-mx51/crm_regs.h b/include/asm-arm/arch-mx51/crm_regs.h new file mode 100644 index 0000000..14aa231 --- /dev/null +++ b/include/asm-arm/arch-mx51/crm_regs.h @@ -0,0 +1,192 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ARCH_ARM_MACH_MX51_CRM_REGS_H__ +#define __ARCH_ARM_MACH_MX51_CRM_REGS_H__ + +#define MXC_CCM_BASE CCM_BASE_ADDR + +/* DPLL register mapping structure */ +struct mxc_pll_reg { + u32 ctrl; + u32 config; + u32 op; + u32 mfd; + u32 mfn; + u32 mfn_minus; + u32 mfn_plus; + u32 hfs_op; + u32 hfs_mfd; + u32 hfs_mfn; + u32 mfn_togc; + u32 destat; +}; + +/* Register maping of CCM*/ +struct mxc_ccm_reg { + u32 ccr; /* 0x0000 */ + u32 ccdr; + u32 csr; + u32 ccsr; + u32 cacrr; /* 0x0010*/ + u32 cbcdr; + u32 cbcmr; + u32 cscmr1; + u32 cscmr2; /* 0x0020 */ + u32 cscdr1; + u32 cs1cdr; + u32 cs2cdr; + u32 cdcdr; /* 0x0030 */ + u32 chscdr; + u32 cscdr2; + u32 cscdr3; + u32 cscdr4; /* 0x0040 */ + u32 cwdr; + u32 cdhipr; + u32 cdcr; + u32 ctor; /* 0x0050 */ + u32 clpcr; + u32 cisr; + u32 cimr; + u32 ccosr; /* 0x0060 */ + u32 cgpr; + u32 CCGR0; + u32 CCGR1; + u32 CCGR2; /* 0x0070 */ + u32 CCGR3; + u32 CCGR4; + u32 CCGR5; + u32 CCGR6; /* 0x0080 */ + u32 cmeor; +}; + +/* Define the bits in register CACRR */ +#define MXC_CCM_CACRR_ARM_PODF_OFFSET 0 +#define MXC_CCM_CACRR_ARM_PODF_MASK 0x7 + +/* Define the bits in register CBCDR */ +#define MXC_CCM_CBCDR_EMI_CLK_SEL (0x1 << 26) +#define MXC_CCM_CBCDR_PERIPH_CLK_SEL (0x1 << 25) +#define MXC_CCM_CBCDR_EMI_PODF_OFFSET 22 +#define MXC_CCM_CBCDR_EMI_PODF_MASK (0x7 << 22) +#define MXC_CCM_CBCDR_AXI_B_PODF_OFFSET 19 +#define MXC_CCM_CBCDR_AXI_B_PODF_MASK (0x7 << 19) +#define MXC_CCM_CBCDR_AXI_A_PODF_OFFSET 16 +#define MXC_CCM_CBCDR_AXI_A_PODF_MASK (0x7 << 16) +#define MXC_CCM_CBCDR_NFC_PODF_OFFSET 13 +#define MXC_CCM_CBCDR_NFC_PODF_MASK (0x7 << 13) +#define MXC_CCM_CBCDR_AHB_PODF_OFFSET 10 +#define MXC_CCM_CBCDR_AHB_PODF_MASK (0x7 << 10) +#define MXC_CCM_CBCDR_IPG_PODF_OFFSET 8 +#define MXC_CCM_CBCDR_IPG_PODF_MASK (0x3 << 8) +#define MXC_CCM_CBCDR_PERCLK_PRED1_OFFSET 6 +#define MXC_CCM_CBCDR_PERCLK_PRED1_MASK (0x3 << 6) +#define MXC_CCM_CBCDR_PERCLK_PRED2_OFFSET 3 +#define MXC_CCM_CBCDR_PERCLK_PRED2_MASK (0x7 << 3) +#define MXC_CCM_CBCDR_PERCLK_PODF_OFFSET 0 +#define MXC_CCM_CBCDR_PERCLK_PODF_MASK 0x7 + +/* Define the bits in register CSCMR1 */ +#define MXC_CCM_CSCMR1_SSI_EXT2_CLK_SEL_OFFSET 30 +#define MXC_CCM_CSCMR1_SSI_EXT2_CLK_SEL_MASK (0x3 << 30) +#define MXC_CCM_CSCMR1_SSI_EXT1_CLK_SEL_OFFSET 28 +#define MXC_CCM_CSCMR1_SSI_EXT1_CLK_SEL_MASK (0x3 << 28) +#define MXC_CCM_CSCMR1_USB_PHY_CLK_SEL_OFFSET 26 +#define MXC_CCM_CSCMR1_USB_PHY_CLK_SEL (0x1 << 26) +#define MXC_CCM_CSCMR1_UART_CLK_SEL_OFFSET 24 +#define MXC_CCM_CSCMR1_UART_CLK_SEL_MASK (0x3 << 24) +#define MXC_CCM_CSCMR1_USBOH3_CLK_SEL_OFFSET 22 +#define MXC_CCM_CSCMR1_USBOH3_CLK_SEL_MASK (0x3 << 22) +#define MXC_CCM_CSCMR1_ESDHC1_MSHC1_CLK_SEL_OFFSET 20 +#define MXC_CCM_CSCMR1_ESDHC1_MSHC1_CLK_SEL_MASK (0x3 << 20) +#define MXC_CCM_CSCMR1_ESDHC3_CLK_SEL (0x1 << 19) +#define MXC_CCM_CSCMR1_ESDHC4_CLK_SEL (0x1 << 18) +#define MXC_CCM_CSCMR1_ESDHC2_MSHC2_CLK_SEL_OFFSET 16 +#define MXC_CCM_CSCMR1_ESDHC2_MSHC2_CLK_SEL_MASK (0x3 << 16) +#define MXC_CCM_CSCMR1_SSI1_CLK_SEL_OFFSET 14 +#define MXC_CCM_CSCMR1_SSI1_CLK_SEL_MASK (0x3 << 14) +#define MXC_CCM_CSCMR1_SSI2_CLK_SEL_OFFSET 12 +#define MXC_CCM_CSCMR1_SSI2_CLK_SEL_MASK (0x3 << 12) +#define MXC_CCM_CSCMR1_SSI3_CLK_SEL (0x1 << 11) +#define MXC_CCM_CSCMR1_VPU_RCLK_SEL (0x1 << 10) +#define MXC_CCM_CSCMR1_SSI_APM_CLK_SEL_OFFSET 8 +#define MXC_CCM_CSCMR1_SSI_APM_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CSCMR1_TVE_CLK_SEL (0x1 << 7) +#define MXC_CCM_CSCMR1_TVE_EXT_CLK_SEL (0x1 << 6) +#define MXC_CCM_CSCMR1_CSPI_CLK_SEL_OFFSET 4 +#define MXC_CCM_CSCMR1_CSPI_CLK_SEL_MASK (0x3 << 4) +#define MXC_CCM_CSCMR1_SPDIF_CLK_SEL_OFFSET 2 +#define MXC_CCM_CSCMR1_SPDIF_CLK_SEL_MASK (0x3 << 2) +#define MXC_CCM_CSCMR1_SSI_EXT2_COM_CLK_SEL (0x1 << 1) +#define MXC_CCM_CSCMR1_SSI_EXT1_COM_CLK_SEL 0x1 + +/* Define the bits in register CSCDR2 */ +#define MXC_CCM_CSCDR2_CSPI_CLK_PRED_OFFSET 25 +#define MXC_CCM_CSCDR2_CSPI_CLK_PRED_MASK (0x7 << 25) +#define MXC_CCM_CSCDR2_CSPI_CLK_PODF_OFFSET 19 +#define MXC_CCM_CSCDR2_CSPI_CLK_PODF_MASK (0x3F << 19) +#define MXC_CCM_CSCDR2_SIM_CLK_PRED_OFFSET 16 +#define MXC_CCM_CSCDR2_SIM_CLK_PRED_MASK (0x7 << 16) +#define MXC_CCM_CSCDR2_SIM_CLK_PODF_OFFSET 9 +#define MXC_CCM_CSCDR2_SIM_CLK_PODF_MASK (0x3F << 9) +#define MXC_CCM_CSCDR2_SLIMBUS_CLK_PRED_OFFSET 6 +#define MXC_CCM_CSCDR2_SLIMBUS_PRED_MASK (0x7 << 6) +#define MXC_CCM_CSCDR2_SLIMBUS_PODF_OFFSET 0 +#define MXC_CCM_CSCDR2_SLIMBUS_PODF_MASK 0x3F + +/* Define the bits in register CBCMR */ +#define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_OFFSET 14 +#define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_MASK (0x3 << 14) +#define MXC_CCM_CBCMR_PERIPH_CLK_SEL_OFFSET 12 +#define MXC_CCM_CBCMR_PERIPH_CLK_SEL_MASK (0x3 << 12) +#define MXC_CCM_CBCMR_DDR_CLK_SEL_OFFSET 10 +#define MXC_CCM_CBCMR_DDR_CLK_SEL_MASK (0x3 << 10) +#define MXC_CCM_CBCMR_ARM_AXI_CLK_SEL_OFFSET 8 +#define MXC_CCM_CBCMR_ARM_AXI_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CBCMR_IPU_HSP_CLK_SEL_OFFSET 6 +#define MXC_CCM_CBCMR_IPU_HSP_CLK_SEL_MASK (0x3 << 6) +#define MXC_CCM_CBCMR_GPU_CLK_SEL_OFFSET 4 +#define MXC_CCM_CBCMR_GPU_CLK_SEL_MASK (0x3 << 4) +#define MXC_CCM_CBCMR_PERCLK_LP_APM_CLK_SEL (0x1 << 1) +#define MXC_CCM_CBCMR_PERCLK_IPG_CLK_SEL (0x1 << 0) + +/* Define the bits in register CSCDR1 */ +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PRED_OFFSET 22 +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PRED_MASK (0x7 << 22) +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PODF_OFFSET 19 +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PODF_MASK (0x7 << 19) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PRED_OFFSET 16 +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PRED_MASK (0x7 << 16) +#define MXC_CCM_CSCDR1_PGC_CLK_PODF_OFFSET 14 +#define MXC_CCM_CSCDR1_PGC_CLK_PODF_MASK (0x3 << 14) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PODF_OFFSET 11 +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PODF_MASK (0x7 << 11) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_OFFSET 8 +#define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_MASK (0x7 << 8) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_OFFSET 6 +#define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_MASK (0x3 << 6) +#define MXC_CCM_CSCDR1_UART_CLK_PRED_OFFSET 3 +#define MXC_CCM_CSCDR1_UART_CLK_PRED_MASK (0x7 << 3) +#define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0 +#define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x7 + +#endif /* __ARCH_ARM_MACH_MX51_CRM_REGS_H__ */ diff --git a/include/asm-arm/arch-mx51/imx-regs.h b/include/asm-arm/arch-mx51/imx-regs.h new file mode 100644 index 0000000..927eda3 --- /dev/null +++ b/include/asm-arm/arch-mx51/imx-regs.h @@ -0,0 +1,282 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_MXC_MX51_H__ +#define __ASM_ARCH_MXC_MX51_H__ + +#define __REG(x) (*((volatile u32 *)(x))) +#define __REG16(x) (*((volatile u16 *)(x))) +#define __REG8(x) (*((volatile u8 *)(x))) +/* + * IRAM + */ +#define IRAM_BASE_ADDR 0x1FFE8000 /* internal ram */ +/* + * Graphics Memory of GPU + */ +#define GPU_BASE_ADDR 0x20000000 +#define GPU_CTRL_BASE_ADDR 0x30000000 +#define IPU_CTRL_BASE_ADDR 0x40000000 +/* + * Debug + */ +#define DEBUG_BASE_ADDR 0x60000000 +#define ETB_BASE_ADDR (DEBUG_BASE_ADDR + 0x00001000) +#define ETM_BASE_ADDR (DEBUG_BASE_ADDR + 0x00002000) +#define TPIU_BASE_ADDR (DEBUG_BASE_ADDR + 0x00003000) +#define CTI0_BASE_ADDR (DEBUG_BASE_ADDR + 0x00004000) +#define CTI1_BASE_ADDR (DEBUG_BASE_ADDR + 0x00005000) +#define CTI2_BASE_ADDR (DEBUG_BASE_ADDR + 0x00006000) +#define CTI3_BASE_ADDR (DEBUG_BASE_ADDR + 0x00007000) +#define CORTEX_DBG_BASE_ADDR (DEBUG_BASE_ADDR + 0x00008000) + +/* + * SPBA global module enabled #0 + */ +#define SPBA0_BASE_ADDR 0x70000000 + +#define MMC_SDHC1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00004000) +#define MMC_SDHC2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00008000) +#define UART3_BASE_ADDR (SPBA0_BASE_ADDR + 0x0000C000) +#define CSPI1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00010000) +#define SSI2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00014000) +#define MMC_SDHC3_BASE_ADDR (SPBA0_BASE_ADDR + 0x00020000) +#define MMC_SDHC4_BASE_ADDR (SPBA0_BASE_ADDR + 0x00024000) +#define SPDIF_BASE_ADDR (SPBA0_BASE_ADDR + 0x00028000) +#define ATA_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00030000) +#define SLIM_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00034000) +#define HSI2C_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00038000) +#define SPBA_CTRL_BASE_ADDR (SPBA0_BASE_ADDR + 0x0003C000) + +/* + * AIPS 1 + */ +#define AIPS1_BASE_ADDR 0x73F00000 + +#define OTG_BASE_ADDR (AIPS1_BASE_ADDR + 0x00080000) +#define GPIO1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00084000) +#define GPIO2_BASE_ADDR (AIPS1_BASE_ADDR + 0x00088000) +#define GPIO3_BASE_ADDR (AIPS1_BASE_ADDR + 0x0008C000) +#define GPIO4_BASE_ADDR (AIPS1_BASE_ADDR + 0x00090000) +#define KPP_BASE_ADDR (AIPS1_BASE_ADDR + 0x00094000) +#define WDOG1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00098000) +#define WDOG2_BASE_ADDR (AIPS1_BASE_ADDR + 0x0009C000) +#define GPT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A0000) +#define SRTC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A4000) +#define IOMUXC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A8000) +#define EPIT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000AC000) +#define EPIT2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B0000) +#define PWM1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B4000) +#define PWM2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B8000) +#define UART1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000BC000) +#define UART2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000C0000) +#define SRC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D0000) +#define CCM_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D4000) +#define GPC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D8000) + +/* + * AIPS 2 + */ +#define AIPS2_BASE_ADDR 0x83F00000 + +#define PLL1_BASE_ADDR (AIPS2_BASE_ADDR + 0x00080000) +#define PLL2_BASE_ADDR (AIPS2_BASE_ADDR + 0x00084000) +#define PLL3_BASE_ADDR (AIPS2_BASE_ADDR + 0x00088000) +#define AHBMAX_BASE_ADDR (AIPS2_BASE_ADDR + 0x00094000) +#define IIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x00098000) +#define CSU_BASE_ADDR (AIPS2_BASE_ADDR + 0x0009C000) +#define ARM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A0000) +#define OWIRE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A4000) +#define FIRI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A8000) +#define CSPI2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000AC000) +#define SDMA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B0000) +#define SCC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B4000) +#define ROMCP_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B8000) +#define RTIC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000BC000) +#define CSPI3_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C0000) +#define I2C2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C4000) +#define I2C1_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C8000) +#define SSI1_BASE_ADDR (AIPS2_BASE_ADDR + 0x000CC000) +#define AUDMUX_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D0000) +#define M4IF_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D8000) +#define ESDCTL_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D9000) +#define WEIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DA000) +#define NFC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DB000) +#define EMI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DBF00) +#define MIPI_HSC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DC000) +#define ATA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000E0000) +#define SIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000E4000) +#define SSI3BASE_ADDR (AIPS2_BASE_ADDR + 0x000E8000) +#define FEC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000EC000) +#define TVE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F0000) +#define VPU_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F4000) +#define SAHARA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F8000) + +#define TZIC_BASE_ADDR 0x8FFFC000 + +/* + * Memory regions and CS + */ +#define CSD0_BASE_ADDR 0x90000000 +#define CSD1_BASE_ADDR 0xA0000000 +#define CS0_BASE_ADDR 0xB0000000 +#define CS1_BASE_ADDR 0xB8000000 +#define CS2_BASE_ADDR 0xC0000000 +#define CS3_BASE_ADDR 0xC8000000 +#define CS4_BASE_ADDR 0xCC000000 +#define CS5_BASE_ADDR 0xCE000000 + +/* + * NFC + */ +#define NFC_BASE_ADDR_AXI 0xCFFF0000 /* NAND flash AXI */ + +/*! + * Number of GPIO port as defined in the IC Spec + */ +#define GPIO_PORT_NUM 4 +/*! + * Number of GPIO pins per port + */ +#define GPIO_NUM_PIN 32 + +#define IIM_SREV 0x24 +#define ROM_SI_REV 0x48 + +#define NFC_BUF_SIZE 0x1000 + +/* M4IF */ +#define M4IF_FBPM0 0x40 +#define M4IF_FIDBP 0x48 + +/* Assuming 24MHz input clock with doubler ON */ +/* MFI PDF */ +#define DP_OP_850 ((8 << 4) + ((1 - 1) << 0)) +#define DP_MFD_850 (48 - 1) +#define DP_MFN_850 41 + +#define DP_OP_800 ((8 << 4) + ((1 - 1) << 0)) +#define DP_MFD_800 (3 - 1) +#define DP_MFN_800 1 + +#define DP_OP_700 ((7 << 4) + ((1 - 1) << 0)) +#define DP_MFD_700 (24 - 1) +#define DP_MFN_700 7 + +#define DP_OP_665 ((6 << 4) + ((1 - 1) << 0)) +#define DP_MFD_665 (96 - 1) +#define DP_MFN_665 89 + +#define DP_OP_532 ((5 << 4) + ((1 - 1) << 0)) +#define DP_MFD_532 (24 - 1) +#define DP_MFN_532 13 + +#define DP_OP_400 ((8 << 4) + ((2 - 1) << 0)) +#define DP_MFD_400 (3 - 1) +#define DP_MFN_400 1 + +#define DP_OP_216 ((6 << 4) + ((3 - 1) << 0)) +#define DP_MFD_216 (4 - 1) +#define DP_MFN_216 3 + +#define CHIP_REV_1_0 0x10 +#define CHIP_REV_1_1 0x11 +#define CHIP_REV_2_0 0x20 +#define CHIP_REV_2_5 0x25 +#define CHIP_REV_3_0 0x30 + +#define BOARD_REV_1_0 0x0 +#define BOARD_REV_2_0 0x1 + +#ifndef __ASSEMBLY__ + +enum mxc_clock { + MXC_ARM_CLK = 0, + MXC_AHB_CLK, + MXC_IPG_CLK, + MXC_IPG_PERCLK, + MXC_UART_CLK, + MXC_CSPI_CLK, + MXC_FEC_CLK, +}; + +struct clkctl { + u32 ccr; + u32 ccdr; + u32 csr; + u32 ccsr; + u32 cacrr; + u32 cbcdr; + u32 cbcmr; + u32 cscmr1; + u32 cscmr2; + u32 cscdr1; + u32 cs1cdr; + u32 cs2cdr; + u32 cdcdr; + u32 chsccdr; + u32 cscdr2; + u32 cscdr3; + u32 cscdr4; + u32 cwdr; + u32 cdhipr; + u32 cdcr; + u32 ctor; + u32 clpcr; + u32 cisr; + u32 cimr; + u32 ccosr; + u32 cgpr; + u32 ccgr0; + u32 ccgr1; + u32 ccgr2; + u32 ccgr3; + u32 ccgr4; + u32 ccgr5; + u32 ccgr6; + u32 cmeor; +}; + +/* WEIM registers */ +struct weim { + u32 csgcr1; + u32 csgcr2; + u32 csrcr1; + u32 csrcr2; + u32 cswcr1; + u32 cswcr2; +}; + +/*! + * NFMS bit in RCSR register for pagesize of nandflash + */ +#define NFMS (*((volatile u32 *)(CCM_BASE_ADDR+0x18))) +#define NFMS_BIT 8 +#define NFMS_NF_DWIDTH 14 +#define NFMS_NF_PG_SZ 8 + +extern unsigned int get_board_rev(void); +extern int is_soc_rev(int rev); + +#endif /* __ASSEMBLER__*/ + +#endif /* __ASM_ARCH_MXC_MX51_H__ */
Changes since last version:
Removed enum mxc_clock (moved in clock.h) from imx-regs.h (required to remove warnings during compilation).
include/asm-arm/arch-mx51/asm-offsets.h | 50 ++++++ include/asm-arm/arch-mx51/crm_regs.h | 192 ++++++++++++++++++++++ include/asm-arm/arch-mx51/imx-regs.h | 272 +++++++++++++++++++++++++++++++ 3 files changed, 514 insertions(+), 0 deletions(-) create mode 100644 include/asm-arm/arch-mx51/asm-offsets.h create mode 100644 include/asm-arm/arch-mx51/crm_regs.h create mode 100644 include/asm-arm/arch-mx51/imx-regs.h
diff --git a/include/asm-arm/arch-mx51/asm-offsets.h b/include/asm-arm/arch-mx51/asm-offsets.h new file mode 100644 index 0000000..3a83fa0 --- /dev/null +++ b/include/asm-arm/arch-mx51/asm-offsets.h @@ -0,0 +1,50 @@ +/* + * needed for cpu/arm_cortexa8/mx51/lowlevel_init.S + * + * These should be auto-generated + */ +/* CCM */ +#define CLKCTL_CCR 0x00 +#define CLKCTL_CCDR 0x04 +#define CLKCTL_CSR 0x08 +#define CLKCTL_CCSR 0x0C +#define CLKCTL_CACRR 0x10 +#define CLKCTL_CBCDR 0x14 +#define CLKCTL_CBCMR 0x18 +#define CLKCTL_CSCMR1 0x1C +#define CLKCTL_CSCMR2 0x20 +#define CLKCTL_CSCDR1 0x24 +#define CLKCTL_CS1CDR 0x28 +#define CLKCTL_CS2CDR 0x2C +#define CLKCTL_CDCDR 0x30 +#define CLKCTL_CHSCCDR 0x34 +#define CLKCTL_CSCDR2 0x38 +#define CLKCTL_CSCDR3 0x3C +#define CLKCTL_CSCDR4 0x40 +#define CLKCTL_CWDR 0x44 +#define CLKCTL_CDHIPR 0x48 +#define CLKCTL_CDCR 0x4C +#define CLKCTL_CTOR 0x50 +#define CLKCTL_CLPCR 0x54 +#define CLKCTL_CISR 0x58 +#define CLKCTL_CIMR 0x5C +#define CLKCTL_CCOSR 0x60 +#define CLKCTL_CGPR 0x64 +#define CLKCTL_CCGR0 0x68 +#define CLKCTL_CCGR1 0x6C +#define CLKCTL_CCGR2 0x70 +#define CLKCTL_CCGR3 0x74 +#define CLKCTL_CCGR4 0x78 +#define CLKCTL_CCGR5 0x7C +#define CLKCTL_CCGR6 0x80 +#define CLKCTL_CMEOR 0x84 + +/* DPLL */ +#define PLL_DP_CTL 0x00 +#define PLL_DP_CONFIG 0x04 +#define PLL_DP_OP 0x08 +#define PLL_DP_MFD 0x0C +#define PLL_DP_MFN 0x10 +#define PLL_DP_HFS_OP 0x1C +#define PLL_DP_HFS_MFD 0x20 +#define PLL_DP_HFS_MFN 0x24 diff --git a/include/asm-arm/arch-mx51/crm_regs.h b/include/asm-arm/arch-mx51/crm_regs.h new file mode 100644 index 0000000..14aa231 --- /dev/null +++ b/include/asm-arm/arch-mx51/crm_regs.h @@ -0,0 +1,192 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ARCH_ARM_MACH_MX51_CRM_REGS_H__ +#define __ARCH_ARM_MACH_MX51_CRM_REGS_H__ + +#define MXC_CCM_BASE CCM_BASE_ADDR + +/* DPLL register mapping structure */ +struct mxc_pll_reg { + u32 ctrl; + u32 config; + u32 op; + u32 mfd; + u32 mfn; + u32 mfn_minus; + u32 mfn_plus; + u32 hfs_op; + u32 hfs_mfd; + u32 hfs_mfn; + u32 mfn_togc; + u32 destat; +}; + +/* Register maping of CCM*/ +struct mxc_ccm_reg { + u32 ccr; /* 0x0000 */ + u32 ccdr; + u32 csr; + u32 ccsr; + u32 cacrr; /* 0x0010*/ + u32 cbcdr; + u32 cbcmr; + u32 cscmr1; + u32 cscmr2; /* 0x0020 */ + u32 cscdr1; + u32 cs1cdr; + u32 cs2cdr; + u32 cdcdr; /* 0x0030 */ + u32 chscdr; + u32 cscdr2; + u32 cscdr3; + u32 cscdr4; /* 0x0040 */ + u32 cwdr; + u32 cdhipr; + u32 cdcr; + u32 ctor; /* 0x0050 */ + u32 clpcr; + u32 cisr; + u32 cimr; + u32 ccosr; /* 0x0060 */ + u32 cgpr; + u32 CCGR0; + u32 CCGR1; + u32 CCGR2; /* 0x0070 */ + u32 CCGR3; + u32 CCGR4; + u32 CCGR5; + u32 CCGR6; /* 0x0080 */ + u32 cmeor; +}; + +/* Define the bits in register CACRR */ +#define MXC_CCM_CACRR_ARM_PODF_OFFSET 0 +#define MXC_CCM_CACRR_ARM_PODF_MASK 0x7 + +/* Define the bits in register CBCDR */ +#define MXC_CCM_CBCDR_EMI_CLK_SEL (0x1 << 26) +#define MXC_CCM_CBCDR_PERIPH_CLK_SEL (0x1 << 25) +#define MXC_CCM_CBCDR_EMI_PODF_OFFSET 22 +#define MXC_CCM_CBCDR_EMI_PODF_MASK (0x7 << 22) +#define MXC_CCM_CBCDR_AXI_B_PODF_OFFSET 19 +#define MXC_CCM_CBCDR_AXI_B_PODF_MASK (0x7 << 19) +#define MXC_CCM_CBCDR_AXI_A_PODF_OFFSET 16 +#define MXC_CCM_CBCDR_AXI_A_PODF_MASK (0x7 << 16) +#define MXC_CCM_CBCDR_NFC_PODF_OFFSET 13 +#define MXC_CCM_CBCDR_NFC_PODF_MASK (0x7 << 13) +#define MXC_CCM_CBCDR_AHB_PODF_OFFSET 10 +#define MXC_CCM_CBCDR_AHB_PODF_MASK (0x7 << 10) +#define MXC_CCM_CBCDR_IPG_PODF_OFFSET 8 +#define MXC_CCM_CBCDR_IPG_PODF_MASK (0x3 << 8) +#define MXC_CCM_CBCDR_PERCLK_PRED1_OFFSET 6 +#define MXC_CCM_CBCDR_PERCLK_PRED1_MASK (0x3 << 6) +#define MXC_CCM_CBCDR_PERCLK_PRED2_OFFSET 3 +#define MXC_CCM_CBCDR_PERCLK_PRED2_MASK (0x7 << 3) +#define MXC_CCM_CBCDR_PERCLK_PODF_OFFSET 0 +#define MXC_CCM_CBCDR_PERCLK_PODF_MASK 0x7 + +/* Define the bits in register CSCMR1 */ +#define MXC_CCM_CSCMR1_SSI_EXT2_CLK_SEL_OFFSET 30 +#define MXC_CCM_CSCMR1_SSI_EXT2_CLK_SEL_MASK (0x3 << 30) +#define MXC_CCM_CSCMR1_SSI_EXT1_CLK_SEL_OFFSET 28 +#define MXC_CCM_CSCMR1_SSI_EXT1_CLK_SEL_MASK (0x3 << 28) +#define MXC_CCM_CSCMR1_USB_PHY_CLK_SEL_OFFSET 26 +#define MXC_CCM_CSCMR1_USB_PHY_CLK_SEL (0x1 << 26) +#define MXC_CCM_CSCMR1_UART_CLK_SEL_OFFSET 24 +#define MXC_CCM_CSCMR1_UART_CLK_SEL_MASK (0x3 << 24) +#define MXC_CCM_CSCMR1_USBOH3_CLK_SEL_OFFSET 22 +#define MXC_CCM_CSCMR1_USBOH3_CLK_SEL_MASK (0x3 << 22) +#define MXC_CCM_CSCMR1_ESDHC1_MSHC1_CLK_SEL_OFFSET 20 +#define MXC_CCM_CSCMR1_ESDHC1_MSHC1_CLK_SEL_MASK (0x3 << 20) +#define MXC_CCM_CSCMR1_ESDHC3_CLK_SEL (0x1 << 19) +#define MXC_CCM_CSCMR1_ESDHC4_CLK_SEL (0x1 << 18) +#define MXC_CCM_CSCMR1_ESDHC2_MSHC2_CLK_SEL_OFFSET 16 +#define MXC_CCM_CSCMR1_ESDHC2_MSHC2_CLK_SEL_MASK (0x3 << 16) +#define MXC_CCM_CSCMR1_SSI1_CLK_SEL_OFFSET 14 +#define MXC_CCM_CSCMR1_SSI1_CLK_SEL_MASK (0x3 << 14) +#define MXC_CCM_CSCMR1_SSI2_CLK_SEL_OFFSET 12 +#define MXC_CCM_CSCMR1_SSI2_CLK_SEL_MASK (0x3 << 12) +#define MXC_CCM_CSCMR1_SSI3_CLK_SEL (0x1 << 11) +#define MXC_CCM_CSCMR1_VPU_RCLK_SEL (0x1 << 10) +#define MXC_CCM_CSCMR1_SSI_APM_CLK_SEL_OFFSET 8 +#define MXC_CCM_CSCMR1_SSI_APM_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CSCMR1_TVE_CLK_SEL (0x1 << 7) +#define MXC_CCM_CSCMR1_TVE_EXT_CLK_SEL (0x1 << 6) +#define MXC_CCM_CSCMR1_CSPI_CLK_SEL_OFFSET 4 +#define MXC_CCM_CSCMR1_CSPI_CLK_SEL_MASK (0x3 << 4) +#define MXC_CCM_CSCMR1_SPDIF_CLK_SEL_OFFSET 2 +#define MXC_CCM_CSCMR1_SPDIF_CLK_SEL_MASK (0x3 << 2) +#define MXC_CCM_CSCMR1_SSI_EXT2_COM_CLK_SEL (0x1 << 1) +#define MXC_CCM_CSCMR1_SSI_EXT1_COM_CLK_SEL 0x1 + +/* Define the bits in register CSCDR2 */ +#define MXC_CCM_CSCDR2_CSPI_CLK_PRED_OFFSET 25 +#define MXC_CCM_CSCDR2_CSPI_CLK_PRED_MASK (0x7 << 25) +#define MXC_CCM_CSCDR2_CSPI_CLK_PODF_OFFSET 19 +#define MXC_CCM_CSCDR2_CSPI_CLK_PODF_MASK (0x3F << 19) +#define MXC_CCM_CSCDR2_SIM_CLK_PRED_OFFSET 16 +#define MXC_CCM_CSCDR2_SIM_CLK_PRED_MASK (0x7 << 16) +#define MXC_CCM_CSCDR2_SIM_CLK_PODF_OFFSET 9 +#define MXC_CCM_CSCDR2_SIM_CLK_PODF_MASK (0x3F << 9) +#define MXC_CCM_CSCDR2_SLIMBUS_CLK_PRED_OFFSET 6 +#define MXC_CCM_CSCDR2_SLIMBUS_PRED_MASK (0x7 << 6) +#define MXC_CCM_CSCDR2_SLIMBUS_PODF_OFFSET 0 +#define MXC_CCM_CSCDR2_SLIMBUS_PODF_MASK 0x3F + +/* Define the bits in register CBCMR */ +#define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_OFFSET 14 +#define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_MASK (0x3 << 14) +#define MXC_CCM_CBCMR_PERIPH_CLK_SEL_OFFSET 12 +#define MXC_CCM_CBCMR_PERIPH_CLK_SEL_MASK (0x3 << 12) +#define MXC_CCM_CBCMR_DDR_CLK_SEL_OFFSET 10 +#define MXC_CCM_CBCMR_DDR_CLK_SEL_MASK (0x3 << 10) +#define MXC_CCM_CBCMR_ARM_AXI_CLK_SEL_OFFSET 8 +#define MXC_CCM_CBCMR_ARM_AXI_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CBCMR_IPU_HSP_CLK_SEL_OFFSET 6 +#define MXC_CCM_CBCMR_IPU_HSP_CLK_SEL_MASK (0x3 << 6) +#define MXC_CCM_CBCMR_GPU_CLK_SEL_OFFSET 4 +#define MXC_CCM_CBCMR_GPU_CLK_SEL_MASK (0x3 << 4) +#define MXC_CCM_CBCMR_PERCLK_LP_APM_CLK_SEL (0x1 << 1) +#define MXC_CCM_CBCMR_PERCLK_IPG_CLK_SEL (0x1 << 0) + +/* Define the bits in register CSCDR1 */ +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PRED_OFFSET 22 +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PRED_MASK (0x7 << 22) +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PODF_OFFSET 19 +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PODF_MASK (0x7 << 19) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PRED_OFFSET 16 +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PRED_MASK (0x7 << 16) +#define MXC_CCM_CSCDR1_PGC_CLK_PODF_OFFSET 14 +#define MXC_CCM_CSCDR1_PGC_CLK_PODF_MASK (0x3 << 14) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PODF_OFFSET 11 +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PODF_MASK (0x7 << 11) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_OFFSET 8 +#define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_MASK (0x7 << 8) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_OFFSET 6 +#define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_MASK (0x3 << 6) +#define MXC_CCM_CSCDR1_UART_CLK_PRED_OFFSET 3 +#define MXC_CCM_CSCDR1_UART_CLK_PRED_MASK (0x7 << 3) +#define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0 +#define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x7 + +#endif /* __ARCH_ARM_MACH_MX51_CRM_REGS_H__ */ diff --git a/include/asm-arm/arch-mx51/imx-regs.h b/include/asm-arm/arch-mx51/imx-regs.h new file mode 100644 index 0000000..ca8cab4 --- /dev/null +++ b/include/asm-arm/arch-mx51/imx-regs.h @@ -0,0 +1,272 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_MXC_MX51_H__ +#define __ASM_ARCH_MXC_MX51_H__ + +#define __REG(x) (*((volatile u32 *)(x))) +#define __REG16(x) (*((volatile u16 *)(x))) +#define __REG8(x) (*((volatile u8 *)(x))) +/* + * IRAM + */ +#define IRAM_BASE_ADDR 0x1FFE8000 /* internal ram */ +/* + * Graphics Memory of GPU + */ +#define GPU_BASE_ADDR 0x20000000 +#define GPU_CTRL_BASE_ADDR 0x30000000 +#define IPU_CTRL_BASE_ADDR 0x40000000 +/* + * Debug + */ +#define DEBUG_BASE_ADDR 0x60000000 +#define ETB_BASE_ADDR (DEBUG_BASE_ADDR + 0x00001000) +#define ETM_BASE_ADDR (DEBUG_BASE_ADDR + 0x00002000) +#define TPIU_BASE_ADDR (DEBUG_BASE_ADDR + 0x00003000) +#define CTI0_BASE_ADDR (DEBUG_BASE_ADDR + 0x00004000) +#define CTI1_BASE_ADDR (DEBUG_BASE_ADDR + 0x00005000) +#define CTI2_BASE_ADDR (DEBUG_BASE_ADDR + 0x00006000) +#define CTI3_BASE_ADDR (DEBUG_BASE_ADDR + 0x00007000) +#define CORTEX_DBG_BASE_ADDR (DEBUG_BASE_ADDR + 0x00008000) + +/* + * SPBA global module enabled #0 + */ +#define SPBA0_BASE_ADDR 0x70000000 + +#define MMC_SDHC1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00004000) +#define MMC_SDHC2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00008000) +#define UART3_BASE_ADDR (SPBA0_BASE_ADDR + 0x0000C000) +#define CSPI1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00010000) +#define SSI2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00014000) +#define MMC_SDHC3_BASE_ADDR (SPBA0_BASE_ADDR + 0x00020000) +#define MMC_SDHC4_BASE_ADDR (SPBA0_BASE_ADDR + 0x00024000) +#define SPDIF_BASE_ADDR (SPBA0_BASE_ADDR + 0x00028000) +#define ATA_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00030000) +#define SLIM_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00034000) +#define HSI2C_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00038000) +#define SPBA_CTRL_BASE_ADDR (SPBA0_BASE_ADDR + 0x0003C000) + +/* + * AIPS 1 + */ +#define AIPS1_BASE_ADDR 0x73F00000 + +#define OTG_BASE_ADDR (AIPS1_BASE_ADDR + 0x00080000) +#define GPIO1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00084000) +#define GPIO2_BASE_ADDR (AIPS1_BASE_ADDR + 0x00088000) +#define GPIO3_BASE_ADDR (AIPS1_BASE_ADDR + 0x0008C000) +#define GPIO4_BASE_ADDR (AIPS1_BASE_ADDR + 0x00090000) +#define KPP_BASE_ADDR (AIPS1_BASE_ADDR + 0x00094000) +#define WDOG1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00098000) +#define WDOG2_BASE_ADDR (AIPS1_BASE_ADDR + 0x0009C000) +#define GPT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A0000) +#define SRTC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A4000) +#define IOMUXC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A8000) +#define EPIT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000AC000) +#define EPIT2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B0000) +#define PWM1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B4000) +#define PWM2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B8000) +#define UART1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000BC000) +#define UART2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000C0000) +#define SRC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D0000) +#define CCM_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D4000) +#define GPC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D8000) + +/* + * AIPS 2 + */ +#define AIPS2_BASE_ADDR 0x83F00000 + +#define PLL1_BASE_ADDR (AIPS2_BASE_ADDR + 0x00080000) +#define PLL2_BASE_ADDR (AIPS2_BASE_ADDR + 0x00084000) +#define PLL3_BASE_ADDR (AIPS2_BASE_ADDR + 0x00088000) +#define AHBMAX_BASE_ADDR (AIPS2_BASE_ADDR + 0x00094000) +#define IIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x00098000) +#define CSU_BASE_ADDR (AIPS2_BASE_ADDR + 0x0009C000) +#define ARM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A0000) +#define OWIRE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A4000) +#define FIRI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A8000) +#define CSPI2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000AC000) +#define SDMA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B0000) +#define SCC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B4000) +#define ROMCP_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B8000) +#define RTIC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000BC000) +#define CSPI3_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C0000) +#define I2C2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C4000) +#define I2C1_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C8000) +#define SSI1_BASE_ADDR (AIPS2_BASE_ADDR + 0x000CC000) +#define AUDMUX_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D0000) +#define M4IF_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D8000) +#define ESDCTL_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D9000) +#define WEIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DA000) +#define NFC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DB000) +#define EMI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DBF00) +#define MIPI_HSC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DC000) +#define ATA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000E0000) +#define SIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000E4000) +#define SSI3BASE_ADDR (AIPS2_BASE_ADDR + 0x000E8000) +#define FEC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000EC000) +#define TVE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F0000) +#define VPU_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F4000) +#define SAHARA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F8000) + +#define TZIC_BASE_ADDR 0x8FFFC000 + +/* + * Memory regions and CS + */ +#define CSD0_BASE_ADDR 0x90000000 +#define CSD1_BASE_ADDR 0xA0000000 +#define CS0_BASE_ADDR 0xB0000000 +#define CS1_BASE_ADDR 0xB8000000 +#define CS2_BASE_ADDR 0xC0000000 +#define CS3_BASE_ADDR 0xC8000000 +#define CS4_BASE_ADDR 0xCC000000 +#define CS5_BASE_ADDR 0xCE000000 + +/* + * NFC + */ +#define NFC_BASE_ADDR_AXI 0xCFFF0000 /* NAND flash AXI */ + +/*! + * Number of GPIO port as defined in the IC Spec + */ +#define GPIO_PORT_NUM 4 +/*! + * Number of GPIO pins per port + */ +#define GPIO_NUM_PIN 32 + +#define IIM_SREV 0x24 +#define ROM_SI_REV 0x48 + +#define NFC_BUF_SIZE 0x1000 + +/* M4IF */ +#define M4IF_FBPM0 0x40 +#define M4IF_FIDBP 0x48 + +/* Assuming 24MHz input clock with doubler ON */ +/* MFI PDF */ +#define DP_OP_850 ((8 << 4) + ((1 - 1) << 0)) +#define DP_MFD_850 (48 - 1) +#define DP_MFN_850 41 + +#define DP_OP_800 ((8 << 4) + ((1 - 1) << 0)) +#define DP_MFD_800 (3 - 1) +#define DP_MFN_800 1 + +#define DP_OP_700 ((7 << 4) + ((1 - 1) << 0)) +#define DP_MFD_700 (24 - 1) +#define DP_MFN_700 7 + +#define DP_OP_665 ((6 << 4) + ((1 - 1) << 0)) +#define DP_MFD_665 (96 - 1) +#define DP_MFN_665 89 + +#define DP_OP_532 ((5 << 4) + ((1 - 1) << 0)) +#define DP_MFD_532 (24 - 1) +#define DP_MFN_532 13 + +#define DP_OP_400 ((8 << 4) + ((2 - 1) << 0)) +#define DP_MFD_400 (3 - 1) +#define DP_MFN_400 1 + +#define DP_OP_216 ((6 << 4) + ((3 - 1) << 0)) +#define DP_MFD_216 (4 - 1) +#define DP_MFN_216 3 + +#define CHIP_REV_1_0 0x10 +#define CHIP_REV_1_1 0x11 +#define CHIP_REV_2_0 0x20 +#define CHIP_REV_2_5 0x25 +#define CHIP_REV_3_0 0x30 + +#define BOARD_REV_1_0 0x0 +#define BOARD_REV_2_0 0x1 + +#ifndef __ASSEMBLY__ + +struct clkctl { + u32 ccr; + u32 ccdr; + u32 csr; + u32 ccsr; + u32 cacrr; + u32 cbcdr; + u32 cbcmr; + u32 cscmr1; + u32 cscmr2; + u32 cscdr1; + u32 cs1cdr; + u32 cs2cdr; + u32 cdcdr; + u32 chsccdr; + u32 cscdr2; + u32 cscdr3; + u32 cscdr4; + u32 cwdr; + u32 cdhipr; + u32 cdcr; + u32 ctor; + u32 clpcr; + u32 cisr; + u32 cimr; + u32 ccosr; + u32 cgpr; + u32 ccgr0; + u32 ccgr1; + u32 ccgr2; + u32 ccgr3; + u32 ccgr4; + u32 ccgr5; + u32 ccgr6; + u32 cmeor; +}; + +/* WEIM registers */ +struct weim { + u32 csgcr1; + u32 csgcr2; + u32 csrcr1; + u32 csrcr2; + u32 cswcr1; + u32 cswcr2; +}; + +/*! + * NFMS bit in RCSR register for pagesize of nandflash + */ +#define NFMS (*((volatile u32 *)(CCM_BASE_ADDR+0x18))) +#define NFMS_BIT 8 +#define NFMS_NF_DWIDTH 14 +#define NFMS_NF_PG_SZ 8 + +extern unsigned int get_board_rev(void); +extern int is_soc_rev(int rev); + +#endif /* __ASSEMBLER__*/ + +#endif /* __ASM_ARCH_MXC_MX51_H__ */
Hi, Babic
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Stefano Babic Sent: 2010年3月5日 3:22 To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V5 03/11] MX51: Add register definitions
- NFMS bit in RCSR register for pagesize of nandflash */
This NFMS register definion is wrong and more MX51 does not have such kind of NFMS register. Which is in I.MX25/35. Please remove it to avoid confusion.
+extern unsigned int get_board_rev(void); extern int is_soc_rev(int +rev);
1.6.3.3
Agree, removed.
Regards, Stefano
Changes since last version(V5): Comments by Liu Hui: Removed NFMS bit definition from imx-regs.h The bit is only related to MX.25/35 and can lead to confusion
include/asm-arm/arch-mx51/asm-offsets.h | 50 ++++++ include/asm-arm/arch-mx51/crm_regs.h | 192 +++++++++++++++++++++++ include/asm-arm/arch-mx51/imx-regs.h | 261 +++++++++++++++++++++++++++++++ 3 files changed, 503 insertions(+), 0 deletions(-) create mode 100644 include/asm-arm/arch-mx51/asm-offsets.h create mode 100644 include/asm-arm/arch-mx51/crm_regs.h create mode 100644 include/asm-arm/arch-mx51/imx-regs.h
diff --git a/include/asm-arm/arch-mx51/asm-offsets.h b/include/asm-arm/arch-mx51/asm-offsets.h new file mode 100644 index 0000000..3a83fa0 --- /dev/null +++ b/include/asm-arm/arch-mx51/asm-offsets.h @@ -0,0 +1,50 @@ +/* + * needed for cpu/arm_cortexa8/mx51/lowlevel_init.S + * + * These should be auto-generated + */ +/* CCM */ +#define CLKCTL_CCR 0x00 +#define CLKCTL_CCDR 0x04 +#define CLKCTL_CSR 0x08 +#define CLKCTL_CCSR 0x0C +#define CLKCTL_CACRR 0x10 +#define CLKCTL_CBCDR 0x14 +#define CLKCTL_CBCMR 0x18 +#define CLKCTL_CSCMR1 0x1C +#define CLKCTL_CSCMR2 0x20 +#define CLKCTL_CSCDR1 0x24 +#define CLKCTL_CS1CDR 0x28 +#define CLKCTL_CS2CDR 0x2C +#define CLKCTL_CDCDR 0x30 +#define CLKCTL_CHSCCDR 0x34 +#define CLKCTL_CSCDR2 0x38 +#define CLKCTL_CSCDR3 0x3C +#define CLKCTL_CSCDR4 0x40 +#define CLKCTL_CWDR 0x44 +#define CLKCTL_CDHIPR 0x48 +#define CLKCTL_CDCR 0x4C +#define CLKCTL_CTOR 0x50 +#define CLKCTL_CLPCR 0x54 +#define CLKCTL_CISR 0x58 +#define CLKCTL_CIMR 0x5C +#define CLKCTL_CCOSR 0x60 +#define CLKCTL_CGPR 0x64 +#define CLKCTL_CCGR0 0x68 +#define CLKCTL_CCGR1 0x6C +#define CLKCTL_CCGR2 0x70 +#define CLKCTL_CCGR3 0x74 +#define CLKCTL_CCGR4 0x78 +#define CLKCTL_CCGR5 0x7C +#define CLKCTL_CCGR6 0x80 +#define CLKCTL_CMEOR 0x84 + +/* DPLL */ +#define PLL_DP_CTL 0x00 +#define PLL_DP_CONFIG 0x04 +#define PLL_DP_OP 0x08 +#define PLL_DP_MFD 0x0C +#define PLL_DP_MFN 0x10 +#define PLL_DP_HFS_OP 0x1C +#define PLL_DP_HFS_MFD 0x20 +#define PLL_DP_HFS_MFN 0x24 diff --git a/include/asm-arm/arch-mx51/crm_regs.h b/include/asm-arm/arch-mx51/crm_regs.h new file mode 100644 index 0000000..14aa231 --- /dev/null +++ b/include/asm-arm/arch-mx51/crm_regs.h @@ -0,0 +1,192 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ARCH_ARM_MACH_MX51_CRM_REGS_H__ +#define __ARCH_ARM_MACH_MX51_CRM_REGS_H__ + +#define MXC_CCM_BASE CCM_BASE_ADDR + +/* DPLL register mapping structure */ +struct mxc_pll_reg { + u32 ctrl; + u32 config; + u32 op; + u32 mfd; + u32 mfn; + u32 mfn_minus; + u32 mfn_plus; + u32 hfs_op; + u32 hfs_mfd; + u32 hfs_mfn; + u32 mfn_togc; + u32 destat; +}; + +/* Register maping of CCM*/ +struct mxc_ccm_reg { + u32 ccr; /* 0x0000 */ + u32 ccdr; + u32 csr; + u32 ccsr; + u32 cacrr; /* 0x0010*/ + u32 cbcdr; + u32 cbcmr; + u32 cscmr1; + u32 cscmr2; /* 0x0020 */ + u32 cscdr1; + u32 cs1cdr; + u32 cs2cdr; + u32 cdcdr; /* 0x0030 */ + u32 chscdr; + u32 cscdr2; + u32 cscdr3; + u32 cscdr4; /* 0x0040 */ + u32 cwdr; + u32 cdhipr; + u32 cdcr; + u32 ctor; /* 0x0050 */ + u32 clpcr; + u32 cisr; + u32 cimr; + u32 ccosr; /* 0x0060 */ + u32 cgpr; + u32 CCGR0; + u32 CCGR1; + u32 CCGR2; /* 0x0070 */ + u32 CCGR3; + u32 CCGR4; + u32 CCGR5; + u32 CCGR6; /* 0x0080 */ + u32 cmeor; +}; + +/* Define the bits in register CACRR */ +#define MXC_CCM_CACRR_ARM_PODF_OFFSET 0 +#define MXC_CCM_CACRR_ARM_PODF_MASK 0x7 + +/* Define the bits in register CBCDR */ +#define MXC_CCM_CBCDR_EMI_CLK_SEL (0x1 << 26) +#define MXC_CCM_CBCDR_PERIPH_CLK_SEL (0x1 << 25) +#define MXC_CCM_CBCDR_EMI_PODF_OFFSET 22 +#define MXC_CCM_CBCDR_EMI_PODF_MASK (0x7 << 22) +#define MXC_CCM_CBCDR_AXI_B_PODF_OFFSET 19 +#define MXC_CCM_CBCDR_AXI_B_PODF_MASK (0x7 << 19) +#define MXC_CCM_CBCDR_AXI_A_PODF_OFFSET 16 +#define MXC_CCM_CBCDR_AXI_A_PODF_MASK (0x7 << 16) +#define MXC_CCM_CBCDR_NFC_PODF_OFFSET 13 +#define MXC_CCM_CBCDR_NFC_PODF_MASK (0x7 << 13) +#define MXC_CCM_CBCDR_AHB_PODF_OFFSET 10 +#define MXC_CCM_CBCDR_AHB_PODF_MASK (0x7 << 10) +#define MXC_CCM_CBCDR_IPG_PODF_OFFSET 8 +#define MXC_CCM_CBCDR_IPG_PODF_MASK (0x3 << 8) +#define MXC_CCM_CBCDR_PERCLK_PRED1_OFFSET 6 +#define MXC_CCM_CBCDR_PERCLK_PRED1_MASK (0x3 << 6) +#define MXC_CCM_CBCDR_PERCLK_PRED2_OFFSET 3 +#define MXC_CCM_CBCDR_PERCLK_PRED2_MASK (0x7 << 3) +#define MXC_CCM_CBCDR_PERCLK_PODF_OFFSET 0 +#define MXC_CCM_CBCDR_PERCLK_PODF_MASK 0x7 + +/* Define the bits in register CSCMR1 */ +#define MXC_CCM_CSCMR1_SSI_EXT2_CLK_SEL_OFFSET 30 +#define MXC_CCM_CSCMR1_SSI_EXT2_CLK_SEL_MASK (0x3 << 30) +#define MXC_CCM_CSCMR1_SSI_EXT1_CLK_SEL_OFFSET 28 +#define MXC_CCM_CSCMR1_SSI_EXT1_CLK_SEL_MASK (0x3 << 28) +#define MXC_CCM_CSCMR1_USB_PHY_CLK_SEL_OFFSET 26 +#define MXC_CCM_CSCMR1_USB_PHY_CLK_SEL (0x1 << 26) +#define MXC_CCM_CSCMR1_UART_CLK_SEL_OFFSET 24 +#define MXC_CCM_CSCMR1_UART_CLK_SEL_MASK (0x3 << 24) +#define MXC_CCM_CSCMR1_USBOH3_CLK_SEL_OFFSET 22 +#define MXC_CCM_CSCMR1_USBOH3_CLK_SEL_MASK (0x3 << 22) +#define MXC_CCM_CSCMR1_ESDHC1_MSHC1_CLK_SEL_OFFSET 20 +#define MXC_CCM_CSCMR1_ESDHC1_MSHC1_CLK_SEL_MASK (0x3 << 20) +#define MXC_CCM_CSCMR1_ESDHC3_CLK_SEL (0x1 << 19) +#define MXC_CCM_CSCMR1_ESDHC4_CLK_SEL (0x1 << 18) +#define MXC_CCM_CSCMR1_ESDHC2_MSHC2_CLK_SEL_OFFSET 16 +#define MXC_CCM_CSCMR1_ESDHC2_MSHC2_CLK_SEL_MASK (0x3 << 16) +#define MXC_CCM_CSCMR1_SSI1_CLK_SEL_OFFSET 14 +#define MXC_CCM_CSCMR1_SSI1_CLK_SEL_MASK (0x3 << 14) +#define MXC_CCM_CSCMR1_SSI2_CLK_SEL_OFFSET 12 +#define MXC_CCM_CSCMR1_SSI2_CLK_SEL_MASK (0x3 << 12) +#define MXC_CCM_CSCMR1_SSI3_CLK_SEL (0x1 << 11) +#define MXC_CCM_CSCMR1_VPU_RCLK_SEL (0x1 << 10) +#define MXC_CCM_CSCMR1_SSI_APM_CLK_SEL_OFFSET 8 +#define MXC_CCM_CSCMR1_SSI_APM_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CSCMR1_TVE_CLK_SEL (0x1 << 7) +#define MXC_CCM_CSCMR1_TVE_EXT_CLK_SEL (0x1 << 6) +#define MXC_CCM_CSCMR1_CSPI_CLK_SEL_OFFSET 4 +#define MXC_CCM_CSCMR1_CSPI_CLK_SEL_MASK (0x3 << 4) +#define MXC_CCM_CSCMR1_SPDIF_CLK_SEL_OFFSET 2 +#define MXC_CCM_CSCMR1_SPDIF_CLK_SEL_MASK (0x3 << 2) +#define MXC_CCM_CSCMR1_SSI_EXT2_COM_CLK_SEL (0x1 << 1) +#define MXC_CCM_CSCMR1_SSI_EXT1_COM_CLK_SEL 0x1 + +/* Define the bits in register CSCDR2 */ +#define MXC_CCM_CSCDR2_CSPI_CLK_PRED_OFFSET 25 +#define MXC_CCM_CSCDR2_CSPI_CLK_PRED_MASK (0x7 << 25) +#define MXC_CCM_CSCDR2_CSPI_CLK_PODF_OFFSET 19 +#define MXC_CCM_CSCDR2_CSPI_CLK_PODF_MASK (0x3F << 19) +#define MXC_CCM_CSCDR2_SIM_CLK_PRED_OFFSET 16 +#define MXC_CCM_CSCDR2_SIM_CLK_PRED_MASK (0x7 << 16) +#define MXC_CCM_CSCDR2_SIM_CLK_PODF_OFFSET 9 +#define MXC_CCM_CSCDR2_SIM_CLK_PODF_MASK (0x3F << 9) +#define MXC_CCM_CSCDR2_SLIMBUS_CLK_PRED_OFFSET 6 +#define MXC_CCM_CSCDR2_SLIMBUS_PRED_MASK (0x7 << 6) +#define MXC_CCM_CSCDR2_SLIMBUS_PODF_OFFSET 0 +#define MXC_CCM_CSCDR2_SLIMBUS_PODF_MASK 0x3F + +/* Define the bits in register CBCMR */ +#define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_OFFSET 14 +#define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_MASK (0x3 << 14) +#define MXC_CCM_CBCMR_PERIPH_CLK_SEL_OFFSET 12 +#define MXC_CCM_CBCMR_PERIPH_CLK_SEL_MASK (0x3 << 12) +#define MXC_CCM_CBCMR_DDR_CLK_SEL_OFFSET 10 +#define MXC_CCM_CBCMR_DDR_CLK_SEL_MASK (0x3 << 10) +#define MXC_CCM_CBCMR_ARM_AXI_CLK_SEL_OFFSET 8 +#define MXC_CCM_CBCMR_ARM_AXI_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CBCMR_IPU_HSP_CLK_SEL_OFFSET 6 +#define MXC_CCM_CBCMR_IPU_HSP_CLK_SEL_MASK (0x3 << 6) +#define MXC_CCM_CBCMR_GPU_CLK_SEL_OFFSET 4 +#define MXC_CCM_CBCMR_GPU_CLK_SEL_MASK (0x3 << 4) +#define MXC_CCM_CBCMR_PERCLK_LP_APM_CLK_SEL (0x1 << 1) +#define MXC_CCM_CBCMR_PERCLK_IPG_CLK_SEL (0x1 << 0) + +/* Define the bits in register CSCDR1 */ +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PRED_OFFSET 22 +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PRED_MASK (0x7 << 22) +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PODF_OFFSET 19 +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PODF_MASK (0x7 << 19) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PRED_OFFSET 16 +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PRED_MASK (0x7 << 16) +#define MXC_CCM_CSCDR1_PGC_CLK_PODF_OFFSET 14 +#define MXC_CCM_CSCDR1_PGC_CLK_PODF_MASK (0x3 << 14) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PODF_OFFSET 11 +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PODF_MASK (0x7 << 11) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_OFFSET 8 +#define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_MASK (0x7 << 8) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_OFFSET 6 +#define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_MASK (0x3 << 6) +#define MXC_CCM_CSCDR1_UART_CLK_PRED_OFFSET 3 +#define MXC_CCM_CSCDR1_UART_CLK_PRED_MASK (0x7 << 3) +#define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0 +#define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x7 + +#endif /* __ARCH_ARM_MACH_MX51_CRM_REGS_H__ */ diff --git a/include/asm-arm/arch-mx51/imx-regs.h b/include/asm-arm/arch-mx51/imx-regs.h new file mode 100644 index 0000000..3887d3c --- /dev/null +++ b/include/asm-arm/arch-mx51/imx-regs.h @@ -0,0 +1,261 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_MXC_MX51_H__ +#define __ASM_ARCH_MXC_MX51_H__ + +#define __REG(x) (*((volatile u32 *)(x))) +#define __REG16(x) (*((volatile u16 *)(x))) +#define __REG8(x) (*((volatile u8 *)(x))) +/* + * IRAM + */ +#define IRAM_BASE_ADDR 0x1FFE8000 /* internal ram */ +/* + * Graphics Memory of GPU + */ +#define GPU_BASE_ADDR 0x20000000 +#define GPU_CTRL_BASE_ADDR 0x30000000 +#define IPU_CTRL_BASE_ADDR 0x40000000 +/* + * Debug + */ +#define DEBUG_BASE_ADDR 0x60000000 +#define ETB_BASE_ADDR (DEBUG_BASE_ADDR + 0x00001000) +#define ETM_BASE_ADDR (DEBUG_BASE_ADDR + 0x00002000) +#define TPIU_BASE_ADDR (DEBUG_BASE_ADDR + 0x00003000) +#define CTI0_BASE_ADDR (DEBUG_BASE_ADDR + 0x00004000) +#define CTI1_BASE_ADDR (DEBUG_BASE_ADDR + 0x00005000) +#define CTI2_BASE_ADDR (DEBUG_BASE_ADDR + 0x00006000) +#define CTI3_BASE_ADDR (DEBUG_BASE_ADDR + 0x00007000) +#define CORTEX_DBG_BASE_ADDR (DEBUG_BASE_ADDR + 0x00008000) + +/* + * SPBA global module enabled #0 + */ +#define SPBA0_BASE_ADDR 0x70000000 + +#define MMC_SDHC1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00004000) +#define MMC_SDHC2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00008000) +#define UART3_BASE_ADDR (SPBA0_BASE_ADDR + 0x0000C000) +#define CSPI1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00010000) +#define SSI2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00014000) +#define MMC_SDHC3_BASE_ADDR (SPBA0_BASE_ADDR + 0x00020000) +#define MMC_SDHC4_BASE_ADDR (SPBA0_BASE_ADDR + 0x00024000) +#define SPDIF_BASE_ADDR (SPBA0_BASE_ADDR + 0x00028000) +#define ATA_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00030000) +#define SLIM_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00034000) +#define HSI2C_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00038000) +#define SPBA_CTRL_BASE_ADDR (SPBA0_BASE_ADDR + 0x0003C000) + +/* + * AIPS 1 + */ +#define AIPS1_BASE_ADDR 0x73F00000 + +#define OTG_BASE_ADDR (AIPS1_BASE_ADDR + 0x00080000) +#define GPIO1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00084000) +#define GPIO2_BASE_ADDR (AIPS1_BASE_ADDR + 0x00088000) +#define GPIO3_BASE_ADDR (AIPS1_BASE_ADDR + 0x0008C000) +#define GPIO4_BASE_ADDR (AIPS1_BASE_ADDR + 0x00090000) +#define KPP_BASE_ADDR (AIPS1_BASE_ADDR + 0x00094000) +#define WDOG1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00098000) +#define WDOG2_BASE_ADDR (AIPS1_BASE_ADDR + 0x0009C000) +#define GPT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A0000) +#define SRTC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A4000) +#define IOMUXC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A8000) +#define EPIT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000AC000) +#define EPIT2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B0000) +#define PWM1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B4000) +#define PWM2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B8000) +#define UART1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000BC000) +#define UART2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000C0000) +#define SRC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D0000) +#define CCM_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D4000) +#define GPC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D8000) + +/* + * AIPS 2 + */ +#define AIPS2_BASE_ADDR 0x83F00000 + +#define PLL1_BASE_ADDR (AIPS2_BASE_ADDR + 0x00080000) +#define PLL2_BASE_ADDR (AIPS2_BASE_ADDR + 0x00084000) +#define PLL3_BASE_ADDR (AIPS2_BASE_ADDR + 0x00088000) +#define AHBMAX_BASE_ADDR (AIPS2_BASE_ADDR + 0x00094000) +#define IIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x00098000) +#define CSU_BASE_ADDR (AIPS2_BASE_ADDR + 0x0009C000) +#define ARM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A0000) +#define OWIRE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A4000) +#define FIRI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A8000) +#define CSPI2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000AC000) +#define SDMA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B0000) +#define SCC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B4000) +#define ROMCP_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B8000) +#define RTIC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000BC000) +#define CSPI3_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C0000) +#define I2C2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C4000) +#define I2C1_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C8000) +#define SSI1_BASE_ADDR (AIPS2_BASE_ADDR + 0x000CC000) +#define AUDMUX_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D0000) +#define M4IF_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D8000) +#define ESDCTL_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D9000) +#define WEIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DA000) +#define NFC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DB000) +#define EMI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DBF00) +#define MIPI_HSC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DC000) +#define ATA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000E0000) +#define SIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000E4000) +#define SSI3BASE_ADDR (AIPS2_BASE_ADDR + 0x000E8000) +#define FEC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000EC000) +#define TVE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F0000) +#define VPU_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F4000) +#define SAHARA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F8000) + +#define TZIC_BASE_ADDR 0x8FFFC000 + +/* + * Memory regions and CS + */ +#define CSD0_BASE_ADDR 0x90000000 +#define CSD1_BASE_ADDR 0xA0000000 +#define CS0_BASE_ADDR 0xB0000000 +#define CS1_BASE_ADDR 0xB8000000 +#define CS2_BASE_ADDR 0xC0000000 +#define CS3_BASE_ADDR 0xC8000000 +#define CS4_BASE_ADDR 0xCC000000 +#define CS5_BASE_ADDR 0xCE000000 + +/* + * NFC + */ +#define NFC_BASE_ADDR_AXI 0xCFFF0000 /* NAND flash AXI */ + +/*! + * Number of GPIO port as defined in the IC Spec + */ +#define GPIO_PORT_NUM 4 +/*! + * Number of GPIO pins per port + */ +#define GPIO_NUM_PIN 32 + +#define IIM_SREV 0x24 +#define ROM_SI_REV 0x48 + +#define NFC_BUF_SIZE 0x1000 + +/* M4IF */ +#define M4IF_FBPM0 0x40 +#define M4IF_FIDBP 0x48 + +/* Assuming 24MHz input clock with doubler ON */ +/* MFI PDF */ +#define DP_OP_850 ((8 << 4) + ((1 - 1) << 0)) +#define DP_MFD_850 (48 - 1) +#define DP_MFN_850 41 + +#define DP_OP_800 ((8 << 4) + ((1 - 1) << 0)) +#define DP_MFD_800 (3 - 1) +#define DP_MFN_800 1 + +#define DP_OP_700 ((7 << 4) + ((1 - 1) << 0)) +#define DP_MFD_700 (24 - 1) +#define DP_MFN_700 7 + +#define DP_OP_665 ((6 << 4) + ((1 - 1) << 0)) +#define DP_MFD_665 (96 - 1) +#define DP_MFN_665 89 + +#define DP_OP_532 ((5 << 4) + ((1 - 1) << 0)) +#define DP_MFD_532 (24 - 1) +#define DP_MFN_532 13 + +#define DP_OP_400 ((8 << 4) + ((2 - 1) << 0)) +#define DP_MFD_400 (3 - 1) +#define DP_MFN_400 1 + +#define DP_OP_216 ((6 << 4) + ((3 - 1) << 0)) +#define DP_MFD_216 (4 - 1) +#define DP_MFN_216 3 + +#define CHIP_REV_1_0 0x10 +#define CHIP_REV_1_1 0x11 +#define CHIP_REV_2_0 0x20 +#define CHIP_REV_2_5 0x25 +#define CHIP_REV_3_0 0x30 + +#define BOARD_REV_1_0 0x0 +#define BOARD_REV_2_0 0x1 + +#ifndef __ASSEMBLY__ + +struct clkctl { + u32 ccr; + u32 ccdr; + u32 csr; + u32 ccsr; + u32 cacrr; + u32 cbcdr; + u32 cbcmr; + u32 cscmr1; + u32 cscmr2; + u32 cscdr1; + u32 cs1cdr; + u32 cs2cdr; + u32 cdcdr; + u32 chsccdr; + u32 cscdr2; + u32 cscdr3; + u32 cscdr4; + u32 cwdr; + u32 cdhipr; + u32 cdcr; + u32 ctor; + u32 clpcr; + u32 cisr; + u32 cimr; + u32 ccosr; + u32 cgpr; + u32 ccgr0; + u32 ccgr1; + u32 ccgr2; + u32 ccgr3; + u32 ccgr4; + u32 ccgr5; + u32 ccgr6; + u32 cmeor; +}; + +/* WEIM registers */ +struct weim { + u32 csgcr1; + u32 csgcr2; + u32 csrcr1; + u32 csrcr2; + u32 cswcr1; + u32 cswcr2; +}; + +#endif /* __ASSEMBLER__*/ + +#endif /* __ASM_ARCH_MXC_MX51_H__ */
Liu Hui-R64343
Stefano Babic
