[U-Boot] Please pull u-boot-ti/next
Hello,
The following changes since commit 0d32389f2c8cb967dde2d3f89abdbe5fab5b0788: David Purdy (1): kirkwood: add support for Cloud Engines Pogoplug E02
git://git.denx.de/u-boot-ti next
Aneesh V (6): arm: adapt asm/linkage.h from Linux armv7: add appropriate headers for assembly functions ARM: enable Thumb build armv7: Use -march=armv7-a and thereby enable Thumb-2 omap4+: Avoid using __attribute__ ((__packed__)) OMAP4: enable Thumb build
Balaji T K (3): arm: omap5: correct boot device mode7 for eMMC omap5: pbias ldo9 turn on mmc: omap5evm: Add eMMC saveenv support
Enric Balletbò i Serra (1): OMAP3: igep00x0: Reduce lines of code for IGEP-based boards.
Grazvydas Ignotas (3): OMAP3: pandora: pin mux updates for DM3730 board variant OMAP3: pandora: revise GPIO configuration OMAP3: pandora: drop console kernel argument
Jonathan Solnit (1): ARM:OMAP+:MMC: Add parameters to MMC init
Nishanth Menon (3): OMAP3+: Introduce generic logic for OMAP voltage controller OMAP4460: TPS Ensure SET1 is selected after voltage configuration OMAP4: scale voltage of core before MPU scales
SRICHARAN R (16): OMAP5: clocks: Change clock settings as required for ES1.0 silicon. OMAP5: board: Add pinmux data for omap5_evm board. OMAP5: io: Configure the io settings for omap5430 sevm board. OMAP5: emif/ddr: Change emif settings as required for ES1.0 silicon. OMAP5: palmas: Configure nominal opp vdd values OMAP5: hwinit: Add the missing break statement OMAP4/5: Make the silicon revision variable common. OMAP5: SRAM: Change the SRAM base address. OMAP4/5: Make the sysctrl structure common OMAP4/5: device: Add support to get the device type. OMAP5: defconfig: Align the defconfig for 5430 ES1.0 OMAP5: ddr: Change the ddr device name. OMAP4/5: emif: Correct the emif power mgt shadow register bit fields. power: twl6035: add palmas PMIC support OMAP3+: reset: Create a common reset layer. OMAP5: reset: Use cold reset in case of 5430ES1.0
Tom Rini (9): tools, config.mk: Add gcc-version.sh, cc-version test from Linux Makefile: Add a 'checkthumb' rule omap4: Remove CONFIG_SYS_MMC_SET_DEV omap4+: Remove CONFIG_ARCH_CPU_INIT omap5912osk: Remove empty misc_init_r omap730p2: Remove empty misc_init_r omap3: Introduce weak misc_init_r include/configs: Remove CONFIG_SYS_64BIT_VSPRINTF include/configs: Remove CONFIG_SYS_64BIT_STRTOUL
Makefile | 7 + README | 8 + arch/arm/config.mk | 27 +- arch/arm/cpu/armv7/am33xx/board.c | 2 +- arch/arm/cpu/armv7/config.mk | 7 +- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 5 +- arch/arm/cpu/armv7/mx6/lowlevel_init.S | 5 +- arch/arm/cpu/armv7/omap-common/Makefile | 1 + arch/arm/cpu/armv7/omap-common/clocks-common.c | 99 ++--- arch/arm/cpu/armv7/omap-common/emif-common.c | 41 ++- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 16 +- arch/arm/cpu/armv7/omap-common/lowlevel_init.S | 14 +- .../arm/cpu/armv7/omap-common/{reset.S => reset.c} | 30 +- arch/arm/cpu/armv7/omap-common/spl.c | 1 + arch/arm/cpu/armv7/omap-common/spl_mmc.c | 5 +- arch/arm/cpu/armv7/omap-common/vc.c | 138 ++++++ arch/arm/cpu/armv7/omap3/board.c | 12 + arch/arm/cpu/armv7/omap3/lowlevel_init.S | 41 +- arch/arm/cpu/armv7/omap4/clocks.c | 77 ++- arch/arm/cpu/armv7/omap4/hwinit.c | 24 +- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 4 + arch/arm/cpu/armv7/omap5/Makefile | 2 +- arch/arm/cpu/armv7/omap5/clocks.c | 143 ++++-- arch/arm/cpu/armv7/omap5/hwinit.c | 104 ++++- .../cpu/armv7/omap5/{sdram_elpida.c => sdram.c} | 101 +++-- arch/arm/cpu/armv7/s5pc1xx/cache.S | 10 +- arch/arm/cpu/armv7/s5pc1xx/reset.S | 5 +- arch/arm/cpu/armv7/start.S | 13 +- arch/arm/cpu/armv7/tegra2/lowlevel_init.S | 5 +- arch/arm/cpu/armv7/u8500/lowlevel.S | 9 +- arch/arm/include/asm/arch-am33xx/mmc_host_def.h | 2 +- arch/arm/include/asm/arch-omap3/cpu.h | 5 +- arch/arm/include/asm/arch-omap3/mmc_host_def.h | 8 +- arch/arm/include/asm/arch-omap3/mux.h | 6 + arch/arm/include/asm/arch-omap4/clocks.h | 18 +- arch/arm/include/asm/arch-omap4/cpu.h | 11 + arch/arm/include/asm/arch-omap4/mmc_host_def.h | 2 +- arch/arm/include/asm/arch-omap4/mux_omap4.h | 2 +- arch/arm/include/asm/arch-omap4/omap.h | 25 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 8 +- arch/arm/include/asm/arch-omap5/clocks.h | 52 ++- arch/arm/include/asm/arch-omap5/cpu.h | 11 + arch/arm/include/asm/arch-omap5/mmc_host_def.h | 2 +- arch/arm/include/asm/arch-omap5/mux_omap5.h | 504 ++++++++++---------- arch/arm/include/asm/arch-omap5/omap.h | 153 +++++-- arch/arm/include/asm/arch-omap5/sys_proto.h | 8 +- arch/arm/include/asm/emif.h | 76 +++- arch/arm/include/asm/linkage.h | 7 + arch/arm/include/asm/omap_common.h | 11 +- board/cm_t35/cm_t35.c | 13 +- board/comelit/dig297/dig297.c | 2 +- board/corscience/tricorder/tricorder.c | 2 +- board/htkw/mcx/mcx.c | 13 +- board/isee/igep0020/igep0020.c | 4 +- board/isee/igep0030/igep0030.c | 4 +- board/logicpd/am3517evm/am3517evm.c | 2 +- board/logicpd/omap3som/omap3logic.c | 13 +- board/logicpd/zoom1/zoom1.c | 2 +- board/logicpd/zoom2/zoom2.c | 2 +- board/matrix_vision/mvblx/mvblx.c | 4 +- board/overo/overo.c | 2 +- board/pandora/pandora.c | 59 ++- board/pandora/pandora.h | 6 + board/technexion/twister/twister.c | 2 +- board/teejet/mt_ventoux/mt_ventoux.c | 9 +- board/ti/am3517crane/am3517crane.c | 2 +- board/ti/beagle/beagle.c | 2 +- board/ti/evm/evm.c | 2 +- board/ti/omap5912osk/omap5912osk.c | 7 - board/ti/omap5_evm/evm.c | 10 +- board/ti/omap5_evm/mux_data.h | 489 ++++++++++--------- board/ti/omap730p2/omap730p2.c | 6 - board/ti/panda/panda.c | 2 +- board/ti/panda/panda_mux_data.h | 2 +- board/ti/sdp3430/sdp.c | 2 +- board/ti/sdp4430/sdp.c | 4 +- board/ti/sdp4430/sdp4430_mux_data.h | 2 +- board/timll/devkit8000/devkit8000.c | 2 +- boards.cfg | 4 +- config.mk | 6 +- drivers/mmc/omap_hsmmc.c | 61 +++- drivers/power/Makefile | 1 + drivers/power/twl6035.c | 65 +++ include/configs/P1023RDS.h | 3 - include/configs/P2020COME.h | 2 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 2 - include/configs/at91sam9263ek.h | 2 - include/configs/da830evm.h | 1 - include/configs/ea20.h | 1 - include/configs/eb_cpux9k2.h | 2 - include/configs/flea3.h | 2 - include/configs/hawkboard.h | 1 - include/configs/igep0030.h | 261 ---------- include/configs/{igep0020.h => igep00x0.h} | 15 +- include/configs/imx27lite-common.h | 1 - include/configs/mcx.h | 2 - include/configs/meesc.h | 1 - include/configs/mv-common.h | 1 - include/configs/mx25pdk.h | 1 - include/configs/mx35pdk.h | 2 - include/configs/omap3_pandora.h | 3 +- include/configs/omap4_common.h | 4 +- include/configs/omap5912osk.h | 2 - include/configs/omap5_evm.h | 26 +- include/configs/omap730p2.h | 2 - include/configs/otc570.h | 1 - include/configs/p1_p2_rdb_pc.h | 3 - include/configs/spear-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/tx25.h | 2 - include/configs/zmx25.h | 2 - include/linux/linkage.h | 7 +- .../armv7/omap-common/reset.S => include/twl6035.h | 38 +- tools/gcc-version.sh | 32 ++ 115 files changed, 1779 insertions(+), 1321 deletions(-) copy arch/arm/cpu/armv7/omap-common/{reset.S => reset.c} (70%) create mode 100644 arch/arm/cpu/armv7/omap-common/vc.c rename arch/arm/cpu/armv7/omap5/{sdram_elpida.c => sdram.c} (64%) create mode 100644 arch/arm/include/asm/linkage.h create mode 100644 drivers/power/twl6035.c delete mode 100644 include/configs/igep0030.h rename include/configs/{igep0020.h => igep00x0.h} (97%) rename arch/arm/cpu/armv7/omap-common/reset.S => include/twl6035.h (53%) create mode 100755 tools/gcc-version.sh
Hi Tom,
Le 20/04/2012 18:26, Tom Rini a écrit :
Hello,
Applied to u-boot-arm/next, thanks!
Amicalement,
Albert ARIBAUD
