[PATCH 1/4] arm64: dts: imx8mp: Adjust FEC PHY address on i.MX8MP DHCOM
The current variant of the SoM has LAN8740Ai PHY connected to FEC strapped to MDIO address 0 , adjust the MDIO address to match the hardware.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- arch/arm/dts/imx8mp-dhcom-som.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/imx8mp-dhcom-som.dtsi b/arch/arm/dts/imx8mp-dhcom-som.dtsi index 0f13ee36277..304c94557ed 100644 --- a/arch/arm/dts/imx8mp-dhcom-som.dtsi +++ b/arch/arm/dts/imx8mp-dhcom-som.dtsi @@ -94,14 +94,14 @@ #size-cells = <0>;
/* Up to one of these two PHYs may be populated. */ - ethphy0f: ethernet-phy@1 { /* SMSC LAN8740Ai */ + ethphy0f: ethernet-phy@0 { /* SMSC LAN8740Ai */ compatible = "ethernet-phy-id0007.c110", "ethernet-phy-ieee802.3-c22"; interrupt-parent = <&gpio3>; interrupts = <19 IRQ_TYPE_LEVEL_LOW>; pinctrl-0 = <&pinctrl_ethphy0>; pinctrl-names = "default"; - reg = <1>; + reg = <0>; reset-assert-us = <1000>; reset-deassert-us = <1000>; reset-gpios = <&gpio3 20 GPIO_ACTIVE_LOW>;
The i.MX8MP DHCOM SoM may come with either KSZ9131RNXI RGMII PHY or LAN8740Ai RMII PHY on the SoM attached to EQoS MAC. Add pin mux settings for both options, so that DT overlay can override these settings on SoM variant with the LAN8740Ai PHY.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- arch/arm/dts/imx8mp-dhcom-som.dtsi | 20 ++++++++++++++++++-- 1 file changed, 18 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/imx8mp-dhcom-som.dtsi b/arch/arm/dts/imx8mp-dhcom-som.dtsi index 304c94557ed..b56607dfb39 100644 --- a/arch/arm/dts/imx8mp-dhcom-som.dtsi +++ b/arch/arm/dts/imx8mp-dhcom-som.dtsi @@ -83,7 +83,7 @@
&eqos { /* First ethernet */ pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_eqos>; + pinctrl-0 = <&pinctrl_eqos_rgmii>; phy-handle = <ðphy0g>; phy-mode = "rgmii-id"; status = "okay"; @@ -664,7 +664,7 @@ >; };
- pinctrl_eqos: dhcom-eqos-grp { /* RGMII */ + pinctrl_eqos_rgmii: dhcom-eqos-rgmii-grp { /* RGMII */ fsl,pins = < MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3 MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3 @@ -683,6 +683,22 @@ >; };
+ pinctrl_eqos_rmii: dhcom-eqos-rmii-grp { /* RMII */ + fsl,pins = < + MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3 + MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3 + MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x1f + MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x1f + MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x1f + MX8MP_IOMUXC_ENET_RXC__ENET_QOS_RX_ER 0x1f + MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x91 + MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x91 + MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x91 + /* Clock */ + MX8MP_IOMUXC_ENET_TD2__CCM_ENET_QOS_CLOCK_GENERATE_REF_CLK 0x4000001f + >; + }; + pinctrl_enet_vio: dhcom-enet-vio-grp { fsl,pins = < MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10 0x22
The i.MX8MP DHCOM SoM may come with either external RGMII PHY or LAN8740Ai RMII PHY on the SoM attached to FEC MAC. Add pin mux settings for both options, so that DT overlay can override these settings on SoM variant with the LAN8740Ai PHY.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- arch/arm/dts/imx8mp-dhcom-pdk2.dts | 2 ++ arch/arm/dts/imx8mp-dhcom-som.dtsi | 22 +++++++++++++++++++--- 2 files changed, 21 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/imx8mp-dhcom-pdk2.dts b/arch/arm/dts/imx8mp-dhcom-pdk2.dts index 382fbedaf6b..ac104cd3e62 100644 --- a/arch/arm/dts/imx8mp-dhcom-pdk2.dts +++ b/arch/arm/dts/imx8mp-dhcom-pdk2.dts @@ -117,7 +117,9 @@ /delete-node/ ðphy1f;
&fec { /* Second ethernet */ + pinctrl-0 = <&pinctrl_fec_rgmii>; phy-handle = <ðphypdk>; + phy-mode = "rgmii";
mdio { ethphypdk: ethernet-phy@7 { /* KSZ 9021 */ diff --git a/arch/arm/dts/imx8mp-dhcom-som.dtsi b/arch/arm/dts/imx8mp-dhcom-som.dtsi index b56607dfb39..9fd8bce8065 100644 --- a/arch/arm/dts/imx8mp-dhcom-som.dtsi +++ b/arch/arm/dts/imx8mp-dhcom-som.dtsi @@ -129,9 +129,9 @@
&fec { /* Second ethernet */ pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; + pinctrl-0 = <&pinctrl_fec_rmii>; phy-handle = <ðphy1f>; - phy-mode = "rgmii"; + phy-mode = "rmii"; fsl,magic-packet; status = "okay";
@@ -723,7 +723,7 @@ >; };
- pinctrl_fec: dhcom-fec-grp { + pinctrl_fec_rgmii: dhcom-fec-rgmii-grp { /* RGMII */ fsl,pins = < MX8MP_IOMUXC_SAI1_MCLK__ENET1_TX_CLK 0x1f MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x3 @@ -744,6 +744,22 @@ >; };
+ pinctrl_fec_rmii: dhcom-fec-rmii-grp { /* RMII */ + fsl,pins = < + MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x3 + MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x3 + MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x91 + MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x91 + MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x91 + MX8MP_IOMUXC_SAI1_TXD6__ENET1_RX_ER 0x91 + MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x1f + MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x1f + MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x1f + /* Clock */ + MX8MP_IOMUXC_SAI1_MCLK__ENET1_TX_CLK 0x4000001f + >; + }; + pinctrl_flexcan1: dhcom-flexcan1-grp { fsl,pins = < MX8MP_IOMUXC_SPDIF_RX__CAN1_RX 0x154
The PHY nodes may be activated via DTO in case another SoM variant is populated into the development kit. Do not delete the nodes.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- arch/arm/dts/imx8mp-dhcom-pdk2.dts | 12 ------------ 1 file changed, 12 deletions(-)
diff --git a/arch/arm/dts/imx8mp-dhcom-pdk2.dts b/arch/arm/dts/imx8mp-dhcom-pdk2.dts index ac104cd3e62..8f4eff37c40 100644 --- a/arch/arm/dts/imx8mp-dhcom-pdk2.dts +++ b/arch/arm/dts/imx8mp-dhcom-pdk2.dts @@ -104,18 +104,6 @@ }; };
-/* - * PDK2 carrier board uses SoM with KSZ9131 populated and connected to - * SoM EQoS ethernet RGMII interface. Remove the other SoM PHY DT node. - */ -/delete-node/ ðphy0f; - -/* - * PDK2 carrier board has KSZ9021 PHY populated and connected to SoM FEC - * ethernet RGMII interface. The SoM is not populated with second FEC PHY. - */ -/delete-node/ ðphy1f; - &fec { /* Second ethernet */ pinctrl-0 = <&pinctrl_fec_rgmii>; phy-handle = <ðphypdk>;
