[U-Boot] DM9161BMSR must be read twice ?
I'm developing a custom board based on the AT91RM9200dk. In u-boot prompt, every time a enter a network command such as tftp or ping I get a message like this:
"MAC: error during MII initialization"
Although the command actually seems to work I was a little concerned. After taking a look at cpu/arm920t/at91rm9200/ether.c and cpu/arm920t/at91rm9200/dm9161.c I realized the problem was at the function UCHAR dm9161_GetLinkSpeed (AT91PS_EMAC p_mac) in dm9161.c. Apparently, the link status bit at BMSR register is indicating link down even when it's not.
I googled for it and found at http://www.davicom.com.tw/page1.aspx?no=149749 a FAQ for dm9000A-8 related to a similar register as follows:
"(...) Q1: There are two methods for checking Link status as below: 1) NSR: 01H bit 6 2) PHY BMSR: 01 bit 2 Could you explain what difference is between 1) and 2)? A1: 1) NSR: 01H bit: PHY link status now 2) PHY BMSR: 01 bit 2: the register will read two times. You can see below table for the meaning
Read first times Read second time meaning 0 0 Link fail 0 1 Link fail before and link ok now 1 0 No any meaning 1 1 Link ok (...)"
So I tried reading the BMSR register twice and it got the job done. Did anybody notice this issue ?
--- a/cpu/arm920t/at91rm9200/dm9161.c 2008-08-12 11:08:38.000000000 -0300 +++ b/cpu/arm920t/at91rm9200/dm9161.c 2008-09-02 16:26:05.000000000 -0300 @@ -70,13 +70,16 @@ */ UCHAR dm9161_GetLinkSpeed (AT91PS_EMAC p_mac) { - unsigned short stat1, stat2; - - if (!at91rm9200_EmacReadPhy (p_mac, DM9161_BMSR, &stat1)) - return FALSE; + unsigned short stat1, stat2, i; + + for (i = 2; i; --i) + if (!at91rm9200_EmacReadPhy (p_mac, DM9161_BMSR, &stat1)) + return FALSE;
- if (!(stat1 & DM9161_LINK_STATUS)) /* link status up? */ + if (!(stat1 & DM9161_LINK_STATUS)) { /* link status up? */ + printf("Link down\n"); return FALSE; + }
if (!at91rm9200_EmacReadPhy (p_mac, DM9161_DSCSR, &stat2)) return FALSE;
Regards
Nícolas
On Tue, Sep 2, 2008 at 2:37 PM, Nícolas Carneiro Lebedenco nicolas.lebedenco@tasksistemas.com.br wrote:
This is part of the 802.3 standard for PHYs. If the link status bit is 1, it means the link is up. However, when the link goes down, the status bit will stay 0 until read. This allows temporary link drops to be detected. In practice, few drivers bother to take advantage of this. So if the first read indicates the link is down, it is necessary to read the status again.
Andy
Andy Fleming
