[PATCH] efi_loader: Allow also empty capsule to be process
Empty capsule are also allowed to be process. Without it updated images can't change their Image Acceptance state from no to yes.
Signed-off-by: Michal Simek michal.simek@amd.com ---
lib/efi_loader/efi_capsule.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index 7a6f195cbc02..93e83e5f04c3 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -752,7 +752,8 @@ efi_status_t EFIAPI efi_update_capsule( log_debug("Capsule[%d] (guid:%pUs)\n", i, &capsule->capsule_guid); if (!guidcmp(&capsule->capsule_guid, - &efi_guid_firmware_management_capsule_id)) { + &efi_guid_firmware_management_capsule_id) || + fwu_empty_capsule(capsule)) { ret = efi_capsule_update_firmware(capsule); } else { log_err("Unsupported capsule type: %pUs\n",
Is there any documentation describing the usage of empty capsule to set the image acceptance state?
Best regards
Heinrich
} else { log_err("Unsupported capsule type: %pUs\n",fwu_empty_capsule(capsule)) { ret = efi_capsule_update_firmware(capsule);
I actually don't know about documentation. I was talking to Ilias to make sure that documentation is up2date because there are missing couple of things there.
I am testing A/B update and if you setup oemflags to 0x8000 then capsules are not automatically accepted and waiting for acceptance capsule to be passed. When I tested it I found out that they are not process that's why I created this patch. But definitely someone should check that logic that the patch is right based on intention how these empty capsules should be used. I am actually not quite sure how revert capsules should be used and how to revert only certain image if you use multiple images in the same bank.
Thanks, Michal
Sughosh should have more to say here about A/B update.
The path you tried to modify is only executed by "efidebug capsule update" or more specifically via the runtime service, UPDATE_CAPSULE.
But this API is NOT officially supported in the current capsule implementation (at least, in my initial intention). The only way to invoke capsule updates is to reboot the system. If you want to test A/B update, please do the reboot.
-Takahiro Akashi
Thanks, Michal
I realized that to get full flow you need to use capsule update on disk to get all functionalities. But it is very impractical. Actually I would expect via efidebug you should be able to perform all steps as capsule update performs when you do reboot. I would also understand that via efidebug you are not able to apply any capsule but I don't think it is right that you can apply just update capsules but not empty capsules. I would understand none or all but not something in the middle.
Thanks, Michal
The A/B update functionality requires using the capsule-on-disk functionality for performing the updates. This is also mentioned in the fwu_updates.rst document. You should be able to apply empty capsules even with the 'efidebug disk-update' command. I have never used the 'efidebug capsule update' command, so I'm not sure if that is supported. Like Takahiro mentioned, if you place the capsules(genuine or empty) under the /EFI/UpdateCapsule/ directory, the update should happen automatically, since the fwu update feature also enables the EFI_CAPSULE_ON_DISK_EARLY config.
-sughosh
Thanks, Michal
Yes this is working fine.
ZynqMP> efidebug capsule disk-update ##### Applying capsule capsule1.bin succeeded. ######################### Applying capsule capsule2.bin succeeded. Reboot after firmware update.
I tested it also with empty capsules which are also process properly.
Yes that's work fine on production systems. But from my point of view there shouldn't be really a problem to also apply empty capsule via efidebug capsule update to be able to see that steps and changes in mdata structure without performing reset.
Again I have no issue with code which is using capsule-on-disk feature but I think that pretty much all these steps which are done automatically should be possible to do through steps to see them. That's what you can do with bootm start and simply stepping through it.
I am testing 2 images per bank and I can simply load other partition by simple commands tftpboot 0x100000 192.168.0.105:capsule1.bin && efidebug capsule update -v 0x100000 tftpboot 0x100000 192.168.0.105:capsule2.bin && efidebug capsule update -v 0x100000
And then perform reset to them. I would expect that the same should work also for empty capsules. I am not able to get in this to trial state but I expect this is simply because I am not creating TrialStateCtr variable by hand.
Take a look at log below.
Thanks, Michal
U-Boot 2023.07-00693-g41137e2e3970 (Jul 20 2023 - 08:46:56 +0200)
CPU: ZynqMP Silicon: v3 Chip: xck26 Detected name: zynqmp-sm-k26-xcl2gc-ed-revB-sck-kv-g-revB Model: ZynqMP KV260 revB Board: Xilinx ZynqMP DRAM: 2 GiB (effective 4 GiB) PMUFW: v1.1 Xilinx I2C FRU format at nvmem0: Manufacturer Name: XILINX Product Name: SM-K26-XCL2GC-ED Serial No: 50572B111F2H Part Number: 5057-02ED File ID: 0x0 Revision Number: B Xilinx I2C FRU format at nvmem1: Manufacturer Name: XILINX Product Name: SCK-KV-G Serial No: 50582B112M07 Part Number: 5058-02 File ID: 0x0 Revision Number: B EL Level: EL2 Secure Boot: not authenticated, not encrypted Core: 90 devices, 33 uclasses, devicetree: fit NAND: 0 MiB MMC: mmc@ff160000: 0, mmc@ff170000: 1 Loading Environment from SPIFlash... SF: Detected mt25qu512a with page size 256 Bytes, erase size 64 KiB, total 64 MiB OK In: serial Out: serial Err: serial Net: PHY reset timed out
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 1, interface rgmii-id eth0: ethernet@ff0e0000 fwu_plat_get_bootidx: boot_idx: 1, active_idx: 1 tpm_tis_spi_probe: missing reset GPIO System booting in Trial State Trial State count: attempt 1 out of 3 gpio: pin gpio@ff0a000038 (gpio 38) value is 0 gpio: pin gpio@ff0a000038 (gpio 38) value is 1 starting USB... No working controllers found
Reset SCSI scanning bus for devices... Hit any key to stop autoboot: 0 ZynqMP> ZynqMP> fwu FWU Metadata crc32: 0xe1ea1858 version: 0x1 active_index: 0x1 previous_active_index: 0x0 Image Info
Image Type Guid: DE6066E8-0256-4FAD-8238-E406E274C4CF Location Guid: D7CE8A58-CE2C-11ED-81CD-D324E93AC223 Image Guid: F64A0548-2CCE-ED11-8F66-7BC4531CFE6B Image Acceptance: yes Image Guid: 3E9C814B-2CCE-ED11-BEC8-23DE4C6D2CF2 Image Acceptance: no
Image Type Guid: CF9ECFD4-938B-41C5-8551-1F883AB7DC18 Location Guid: D7CE8A58-CE2C-11ED-81CD-D324E93AC223 Image Guid: 52DA04FB-9D0E-EE11-A57F-637805837C3F Image Acceptance: yes Image Guid: 46926007-9E0E-EE11-A23A-A38980B779A1 Image Acceptance: no ZynqMP> dhcp BOOTP broadcast 1 DHCP client bound to address 192.168.0.155 (10 ms) ZynqMP> tftpboot 0x100000 192.168.0.105:capsule1-accept.bin && efidebug capsule update -v 0x100000 Using ethernet@ff0e0000 device TFTP from server 192.168.0.105; our IP address is 192.168.0.155 Filename 'capsule1-accept.bin'. Load address: 0x100000 Loading: # 6.8 KiB/s done Bytes transferred = 44 (2c hex) Capsule guid: 0c996046-bcc0-4d04-85ec-e1fcedf1c6f8 Capsule flags: 0x0 Capsule header size: 0x1c Capsule image size: 0x2c Unsupported capsule type: 0c996046-bcc0-4d04-85ec-e1fcedf1c6f8 Cannot handle a capsule at 0000000000100000 ZynqMP> tftpboot 0x100000 192.168.0.105:capsule1-accept.bin && save mmc 1 0x100000 /EFI/UpdateCapsule/capsule2.bin ${filesize} Using ethernet@ff0e0000 device TFTP from server 192.168.0.105; our IP address is 192.168.0.155 Filename 'capsule1-accept.bin'. Load address: 0x100000 Loading: # 43 KiB/s done Bytes transferred = 44 (2c hex) 44 bytes written in 726 ms (0 Bytes/s) ZynqMP> efidebug capsule disk-update Applying capsule capsule2.bin succeeded. Reboot after firmware update. Rebooting to index 1 <debug_uart> PMUFW: v1.1 U-Boot SPL 2023.07-00693-g41137e2e3970 (Jul 20 2023 - 08:46:56 +0200) Loading new PMUFW cfg obj (2032 bytes) Silicon version: 3 EL Level: EL3 Secure Boot: not authenticated, not encrypted Multiboot: 496 Trying to boot from SPI spl_spi_get_uboot_offs: Offset of u-boot.itb should be at 0x1000000 NOTICE: BL31: Non secure code at 0x8000000 NOTICE: BL31: v2.9(debug):v2.9.0-337-g37561ae1e640 NOTICE: BL31: Built : 13:08:28, Jul 13 2023 INFO: ARM GICv2 driver initialized INFO: BL31: Initializing runtime services INFO: BL31: PM Service Init Complete: API v1.1 INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: cortex_a53: CPU workaround for 1530924 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x8000000 INFO: SPSR = 0x3c9
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 1, interface rgmii-id eth0: ethernet@ff0e0000 fwu_plat_get_bootidx: boot_idx: 1, active_idx: 1 tpm_tis_spi_probe: missing reset GPIO System booting in Trial State Trial State count: attempt 2 out of 3 gpio: pin gpio@ff0a000038 (gpio 38) value is 0 gpio: pin gpio@ff0a000038 (gpio 38) value is 1 starting USB... No working controllers found
Reset SCSI scanning bus for devices... Hit any key to stop autoboot: 0 ZynqMP> ZynqMP> ZynqMP> ZynqMP> fwu FWU Metadata crc32: 0xb62f5041 version: 0x1 active_index: 0x1 previous_active_index: 0x0 Image Info
Image Type Guid: DE6066E8-0256-4FAD-8238-E406E274C4CF Location Guid: D7CE8A58-CE2C-11ED-81CD-D324E93AC223 Image Guid: F64A0548-2CCE-ED11-8F66-7BC4531CFE6B Image Acceptance: yes Image Guid: 3E9C814B-2CCE-ED11-BEC8-23DE4C6D2CF2 Image Acceptance: yes
On 13.07.23 16:35, Michal Simek wrote: > Empty capsule are also allowed to be process. Without it updated images > can't change their Image Acceptance state from no to yes.
The 'efidebug capsule update' command calls the efi_update_capsule function, which implements the UpdateCapsule runtime service call. The initial versions of my fwu patches were indeed adding support for this path, but one of the review comments was to restrict support only for the capsule-on-disk path when performing the update in u-boot, since we are not using the runtime call in u-boot.
-sughosh
Thanks, Michal
On 7/18/23 17:41, Heinrich Schuchardt wrote: > On 13.07.23 16:35, Michal Simek wrote: >> Empty capsule are also allowed to be process. Without it updated images >> can't change their Image Acceptance state from no to yes. > > Is there any documentation describing the usage of empty capsule to set > the image acceptance state?
I don't think this is a valid argument. As I said I would understand if there is no interface for any capsule. It means having support for both or none is IMHO the way we should support. Can you please point me to that discussion?
Thanks, Michal
On Wed, Jul 19, 2023 at 08:28:41AM +0200, Michal Simek wrote: > > > On 7/18/23 17:41, Heinrich Schuchardt wrote: >> On 13.07.23 16:35, Michal Simek wrote: >>> Empty capsule are also allowed to be process. Without it updated images >>> can't change their Image Acceptance state from no to yes. >> >> Is there any documentation describing the usage of empty capsule to set >> the image acceptance state? > > I actually don't know about documentation. I was talking to Ilias to make > sure that documentation is up2date because there are missing couple of > things there.
> I am testing A/B update and if you setup oemflags to 0x8000 then capsules > are not automatically accepted and waiting for acceptance capsule to be > passed. > When I tested it I found out that they are not process that's why I created > this patch.
There is mention of the point in this discussion [1]. Even this thread has Takahiro mention the point he is making above, that maybe there shouldn't be the efi_update_capsule function.
-sughosh
[1] - https://lists.denx.de/pipermail/u-boot/2022-February/473891.html
On 7/20/23 07:49, AKASHI Takahiro wrote: > Hi, > > On Wed, Jul 19, 2023 at 08:28:41AM +0200, Michal Simek wrote: >> >> >> On 7/18/23 17:41, Heinrich Schuchardt wrote: >>> On 13.07.23 16:35, Michal Simek wrote: >>>> Empty capsule are also allowed to be process. Without it updated images >>>> can't change their Image Acceptance state from no to yes. >>> >>> Is there any documentation describing the usage of empty capsule to set >>> the image acceptance state? >> >> I actually don't know about documentation. I was talking to Ilias to make >> sure that documentation is up2date because there are missing couple of >> things there. > > Sughosh should have more to say here about A/B update. > >> I am testing A/B update and if you setup oemflags to 0x8000 then capsules >> are not automatically accepted and waiting for acceptance capsule to be >> passed. >> When I tested it I found out that they are not process that's why I created >> this patch. > > The path you tried to modify is only executed by "efidebug capsule update" > or more specifically via the runtime service, UPDATE_CAPSULE. > > But this API is NOT officially supported in the current capsule implementation > (at least, in my initial intention). > The only way to invoke capsule updates is to reboot the system. > If you want to test A/B update, please do the reboot.
-sughosh
Hello Sugosh,
fwu_empty_capsule() detects an empty capsule as one with a GUID fwu_guid_os_request_fw_revert or fwu_guid_os_request_fw_accept.
I am not aware of a requirement in the UEFI specification to treat capsules read from file in a different way than capsules passed via UpdateCapsule(). Is there any reason why UpdateCapsule() should not process an empty capsule when called from a boot-time EFI application?
Best regards
Heinrich
On Thu, 20 Jul 2023 at 11:37, Michal Simek michal.simek@amd.com wrote: > > Hi, > > On 7/20/23 07:49, AKASHI Takahiro wrote: > > Hi, > > > > On Wed, Jul 19, 2023 at 08:28:41AM +0200, Michal Simek wrote: > > > > > > > > > On 7/18/23 17:41, Heinrich Schuchardt wrote: > > > > On 13.07.23 16:35, Michal Simek wrote: > > > > > Empty capsule are also allowed to be process. Without it updated images > > > > > can't change their Image Acceptance state from no to yes. > > > > > > > > Is there any documentation describing the usage of empty capsule to set > > > > the image acceptance state? > > > > > > I actually don't know about documentation. I was talking to Ilias to make > > > sure that documentation is up2date because there are missing couple of > > > things there. > > > > Sughosh should have more to say here about A/B update. > > > > > I am testing A/B update and if you setup oemflags to 0x8000 then capsules > > > are not automatically accepted and waiting for acceptance capsule to be > > > passed. > > > When I tested it I found out that they are not process that's why I created > > > this patch. > > > > The path you tried to modify is only executed by "efidebug capsule update" > > or more specifically via the runtime service, UPDATE_CAPSULE. > > > > But this API is NOT officially supported in the current capsule implementation > > (at least, in my initial intention). > > The only way to invoke capsule updates is to reboot the system. > > If you want to test A/B update, please do the reboot. > > I realized that to get full flow you need to use capsule update on disk to get > all functionalities. But it is very impractical. Actually I would expect via > efidebug you should be able to perform all steps as capsule update performs when > you do reboot. > I would also understand that via efidebug you are not able to apply any capsule > but I don't think it is right that you can apply just update capsules but not > empty capsules. I would understand none or all but not something in the middle.
-sughosh
Hello Sugosh,
Here is a story behind efi_update_capsule(): === commit a6aafce494ab Author: Masami Hiramatsu masami.hiramatsu@linaro.org Date: Wed Feb 16 15:15:42 2022 +0900
efi_loader: use efi_update_capsule_firmware() for capsule on disk ===
I still believe that this is a valid change, but we should have moved 'capsule->capsule_guid' check into efi_update_capsule_firmware() at the same time.
-Takahiro Akashi
Best regards
Heinrich
Hi all
Hello Sugosh,
I agree with Akashi-san here. I am also fine with this patchset since running the A/B update from an EFI app should work. But can we do a v2 with 2 patches? #1 move the capsule check along with the empty capsule checks in efi_update_capsule_firmware() #2 fix the a/b updates via the runtime calls and adjust the commit message accordingly, explaining why this change is needed?
Thanks /Ilias
-Takahiro Akashi
Best regards
Heinrich
On 7/26/23 15:07, Ilias Apalodimas wrote:
Hi all
Hello Sugosh,
Can someone from Linaro create v2 on this? I just wanted to pointed to it.
Thanks, Michal
Hi Michal, Sughosh,
Hi all
Hello Sugosh,
Yes, I posted "efi_loader: capsule: enforce guid check in api and capsule_on_disk". Since I didn't run any test against A/B update, can you please confirm that this patch works in your environment?
Unlike Ilias suggested, I made a single patch because an empty capsule will be handled any way at the beginning of efi_capsule_update_firmware() and we process only normal capsules after that.
-Takahiro Akashi
Thanks, Michal
Hi Heinirch,
Yes, there is. It's described here along with the relevant uuids
[0] https://gitlab.com/Linaro/trustedsubstrate/mbfw/uploads/3d0d7d11ca9874dc9115... "2.3.3 OS directed FW image acceptance"
Regards /Ilias
Best regards
Heinrich
participants (5)
AKASHI Takahiro
Ilias Apalodimas
Michal Simek
Sughosh Ganu
