[U-Boot] [PATCH v2] dm: tpm: Drop CONFIG_DM_TPM
Now that all TPM drivers use driver model, we can drop the special driver model CONFIG option.
Changes in v2: - Fix missing 'depends on DM' left out of the v1 patch
drivers/tpm/Kconfig | 15 +++------------ drivers/tpm/Makefile | 2 +- lib/Kconfig | 1 + 3 files changed, 5 insertions(+), 13 deletions(-)
diff --git a/drivers/tpm/Kconfig b/drivers/tpm/Kconfig index 3ab652c..31b35f7 100644 --- a/drivers/tpm/Kconfig +++ b/drivers/tpm/Kconfig @@ -4,15 +4,6 @@
menu "TPM support"
-config DM_TPM - bool "Enable driver model for Trusted Platform Module drivers" - depends on DM && TPM - help - Enable driver model for TPMs. The TIS interface (tis_open(), - tis_sendrecv(), etc.) is then implemented by the TPM uclass. Note - that even with driver model only a single TPM is currently - supported, since the tpm library assumes this. - config TPM_TIS_SANDBOX bool "Enable sandbox TPM driver" depends on SANDBOX @@ -24,7 +15,7 @@ config TPM_TIS_SANDBOX
config TPM_ATMEL_TWI bool "Enable Atmel TWI TPM device driver" - depends on DM_TPM && DM_I2C + depends on TPM && DM_I2C help This driver supports an Atmel TPM device connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk @@ -33,7 +24,7 @@ config TPM_ATMEL_TWI
config TPM_TIS_INFINEON bool "Enable support for Infineon SLB9635/45 TPMs on I2C" - depends on DM_TPM && DM_I2C + depends on TPM && DM_I2C help This driver supports Infineon TPM devices connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk @@ -57,7 +48,7 @@ config TPM_TIS_I2C_BURST_LIMITATION_LEN
config TPM_TIS_LPC bool "Enable support for Infineon SLB9635/45 TPMs on LPC" - depends on DM_TPM && X86 + depends on TPM && X86 help This driver supports Infineon TPM devices connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index 5748145..1d49e95 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -3,7 +3,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_DM_TPM) += tpm-uclass.o +obj-$(CONFIG_TPM) += tpm-uclass.o
obj-$(CONFIG_TPM_ATMEL_TWI) += tpm_atmel_twi.o obj-$(CONFIG_TPM_TIS_INFINEON) += tpm_tis_infineon.o diff --git a/lib/Kconfig b/lib/Kconfig index 0673072..70ed20d 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -56,6 +56,7 @@ source lib/rsa/Kconfig
config TPM bool "Trusted Platform Module (TPM) Support" + depends on DM help This enables support for TPMs which can be used to provide security features for your board. The TPM can be connected via LPC or I2C
Hi Simon,
Acked-by: Christophe Ricardchristophe-h.ricard@st.com
Best Regards Christophe
Changes in v2:
menu "TPM support"
-config DM_TPM
- help
- depends on TPM && DM_I2C help This driver supports an Atmel TPM device connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk
- depends on TPM && DM_I2C help This driver supports Infineon TPM devices connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk
- depends on TPM && X86 help This driver supports Infineon TPM devices connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk
- depends on DM help This enables support for TPMs which can be used to provide security features for your board. The TPM can be connected via LPC or I2C
On 4 October 2015 at 02:46, Christophe Ricard christophe.ricard@gmail.com wrote:
Hi Simon,
Applied to u-boot-dm
Christophe Ricard
