[PATCH] arm: socfpga: soc64: Add support for board_boot_order()
Add board_boot_order() to retrieve the list of boot devices from spl-boot-order property in device tree. This board_boot_order() will use for all Intel SOC64 device for single SPL binary.
Signed-off-by: Sin Hui Kho sin.hui.kho@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- arch/arm/mach-socfpga/spl_soc64.c | 93 +++++++++++++++++++++++++++++++ 1 file changed, 93 insertions(+)
diff --git a/arch/arm/mach-socfpga/spl_soc64.c b/arch/arm/mach-socfpga/spl_soc64.c index ba6efc1d86..2b2377da69 100644 --- a/arch/arm/mach-socfpga/spl_soc64.c +++ b/arch/arm/mach-socfpga/spl_soc64.c @@ -23,3 +23,96 @@ u32 spl_boot_mode(const u32 boot_device) return MMCSD_MODE_RAW; } #endif + +/* This function is to map specified node onto SPL boot devices */ +static int spl_node_to_boot_device(int node) +{ + struct udevice *parent; + + if (!uclass_get_device_by_of_offset(UCLASS_MMC, node, &parent)) + return BOOT_DEVICE_MMC1; + else if (!uclass_get_device_by_of_offset(UCLASS_SPI_FLASH, node, &parent)) + return BOOT_DEVICE_SPI; + else if (!uclass_get_device_by_of_offset(UCLASS_MTD, node, &parent)) + return BOOT_DEVICE_NAND; + else + return -1; +} + +static void default_spl_boot_list(u32 *spl_boot_list, int length) +{ + spl_boot_list[0] = BOOT_DEVICE_MMC1; + + if (length > 1) + spl_boot_list[1] = BOOT_DEVICE_SPI; + + if (length > 2) + spl_boot_list[2] = BOOT_DEVICE_NAND; +} + +void board_boot_order(u32 *spl_boot_list) +{ + int idx = 0; + const void *blob = gd->fdt_blob; + int chosen_node = fdt_path_offset(blob, "/chosen"); + const char *conf; + int elem; + int boot_device; + int node; + int length; + + /* expect valid initialized spl_boot_list */ + if (!spl_boot_list) + return; + + length = 1; + while (spl_boot_list[length] == spl_boot_list[length - 1]) + length++; + + debug("%s: chosen_node is %d\n", __func__, chosen_node); + if (chosen_node < 0) { + printf("%s: /chosen not found, using default\n", __func__); + default_spl_boot_list(spl_boot_list, length); + return; + } + + for (elem = 0; + (conf = fdt_stringlist_get(blob, chosen_node, + "u-boot,spl-boot-order", elem, NULL)); + elem++) { + if (idx >= length) { + printf("%s: limit %d to spl_boot_list exceeded\n", __func__, + length); + break; + } + + /* Resolve conf item as a path in device tree */ + node = fdt_path_offset(blob, conf); + if (node < 0) { + debug("%s: could not find %s in FDT\n", __func__, conf); + continue; + } + + /* Try to map spl node back onto SPL boot devices */ + boot_device = spl_node_to_boot_device(node); + if (boot_device < 0) { + debug("%s: could not map node @%x to a boot-device\n", + __func__, node); + continue; + } + + spl_boot_list[idx] = boot_device; + debug("%s: spl_boot_list[%d] = %u\n", __func__, idx, + spl_boot_list[idx]); + idx++; + } + + if (idx == 0) { + if (!conf && !elem) { + printf("%s: spl-boot-order invalid, using default\n", __func__); + default_spl_boot_list(spl_boot_list, length); + } else { + printf("%s: no valid element spl-boot-order list\n", __func__); + } + } +} \ No newline at end of file
Jit Loon Lim
