[U-Boot] [PATCH] sparc: consolidate CONFIG_{LEON, LEON2, LEON3} definition
CONFIG_LEON is already defined in arch/sparc/cpu/{leon2,leon3}/config.mk. Remove the redundant definition in board header files.
All leon3 boards define CONFIG_LEON3 in board header files. Move the definition to arch/sparc/cpu/leon3/config.mk.
CONFIG_LEON2 can be move to arch/sparc/cpu/leon2/config.mk as well.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Daniel Hellstrom daniel@gaisler.com --- arch/sparc/cpu/leon2/config.mk | 2 +- arch/sparc/cpu/leon3/config.mk | 2 +- include/configs/gr_cpci_ax2000.h | 2 -- include/configs/gr_ep2s60.h | 2 -- include/configs/gr_xc3s_1500.h | 2 -- include/configs/grsim.h | 2 -- include/configs/grsim_leon2.h | 2 -- 7 files changed, 2 insertions(+), 12 deletions(-)
diff --git a/arch/sparc/cpu/leon2/config.mk b/arch/sparc/cpu/leon2/config.mk index f9b0d34..c44b093 100644 --- a/arch/sparc/cpu/leon2/config.mk +++ b/arch/sparc/cpu/leon2/config.mk @@ -7,4 +7,4 @@
PLATFORM_RELFLAGS += -fPIC
-PLATFORM_CPPFLAGS += -DCONFIG_LEON +PLATFORM_CPPFLAGS += -DCONFIG_LEON -DCONFIG_LEON2 diff --git a/arch/sparc/cpu/leon3/config.mk b/arch/sparc/cpu/leon3/config.mk index f9b0d34..ca6c9b1 100644 --- a/arch/sparc/cpu/leon3/config.mk +++ b/arch/sparc/cpu/leon3/config.mk @@ -7,4 +7,4 @@
-PLATFORM_CPPFLAGS += -DCONFIG_LEON +PLATFORM_CPPFLAGS += -DCONFIG_LEON -DCONFIG_LEON3 diff --git a/include/configs/gr_cpci_ax2000.h b/include/configs/gr_cpci_ax2000.h index 8f4b85b..a4b5eb3 100644 --- a/include/configs/gr_cpci_ax2000.h +++ b/include/configs/gr_cpci_ax2000.h @@ -22,8 +22,6 @@ * (easy to change) */
-#define CONFIG_LEON3 /* This is an LEON3 CPU */ -#define CONFIG_LEON 1 /* This is an LEON CPU */ #define CONFIG_CPCI_AX2000 1 /* ... on GR-CPCI-AX2000 board */
#define CONFIG_LEON_RAM_SRAM 1 diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index 1e829aa..b7f094f 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -23,8 +23,6 @@ * (easy to change) */
-#define CONFIG_LEON3 /* This is an LEON3 CPU */ -#define CONFIG_LEON 1 /* This is an LEON CPU */ /* Altera NIOS Development board, Stratix II board */ #define CONFIG_GR_EP2S60 1
diff --git a/include/configs/gr_xc3s_1500.h b/include/configs/gr_xc3s_1500.h index e9e64f1..789b3ed 100644 --- a/include/configs/gr_xc3s_1500.h +++ b/include/configs/gr_xc3s_1500.h @@ -21,8 +21,6 @@ * (easy to change) */
-#define CONFIG_LEON3 /* This is an LEON3 CPU */ -#define CONFIG_LEON 1 /* This is an LEON CPU */ #define CONFIG_GRXC3S1500 1 /* ... on GR-XC3S-1500 board */
/* CPU / AMBA BUS configuration */ diff --git a/include/configs/grsim.h b/include/configs/grsim.h index f50dd54..82b7a4e 100644 --- a/include/configs/grsim.h +++ b/include/configs/grsim.h @@ -27,8 +27,6 @@ * */
-#define CONFIG_LEON3 /* This is an LEON3 CPU */ -#define CONFIG_LEON 1 /* This is an LEON CPU */ #define CONFIG_GRSIM 0 /* ... not running on GRSIM */ #define CONFIG_TSIM 1 /* ... running on TSIM */
diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index 9ea6d9b..8cb077c 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -26,8 +26,6 @@ * */
-#define CONFIG_LEON2 /* This is an LEON2 CPU */ -#define CONFIG_LEON 1 /* This is an LEON CPU */ #define CONFIG_GRSIM 0 /* ... not running on GRSIM */ #define CONFIG_TSIM 1 /* ... running on TSIM */
Hi Tom,
Why did today's updates go to u-boot/next, not u-boot/master?
Best Regards Masahiro Yamada
On Fri, Mar 28, 2014 at 11:34:49AM +0900, Masahiro Yamada wrote:
Hi Tom,
I'm trying to slow down what's pulled in and since sparc doesn't build for me today (unrelated to Kbuild), I figured I'd hold this one off for the next release, while I was adding other stuff to /next anyhow.
Hi Tom,
Hi Tom,
Thanks. I just wanted to be sure because u-boot/next was touched for the first time in the last one year.
BTW, all Sparc boards are broken because of undefined reference to `get_tbclk'. OK. I will shout in another thread.
I am using a simple way to work around this link error: Adding #define CONFIG_SYS_TIMER_RATE 0 to include/configs/gr_cpci_ax2000.h include/configs/gr_ep2s60.h include/configs/gr_xc3s_1500.h include/configs/grsim.h include/configs/grsim_leon2.h
Masahiro Yamada
