[RESEND PATCH v4 00/10] mtd: spinand: initial support of ecc engines
This patch series: * sync spinand driver code with linux-6.10 * sync spinand flash support with linux-6.10 * add initial support of ecc engines
Up to now only software ecc is supported, but other engines can be add quite easily
Changes v2 * update description of some patches
Changes v3: * split some patches to a smaller one for more easy checking/verification * sync spinand flash support with linux-6.10 * add some ecc engine comments (taken from linux driver) * slightly change patch order
Changes v4: * avoid double increments of error counters
Mikhail Kshevetskiy (10): mtd: spinand: Use the spi-mem dirmap API mtd: spinand: Add a NAND page I/O request type mtd: spinand: add missed add missed MODULE_DEVICE_TABLE() mtd: spinand: simulate behavior of linux's function spinand_wait() mtd: spinand: more use of spinand_to_{something} helpers mtd: spinand: replace enable_ecc variable with disable_ecc and update corresponding logic mtd: spinand: minor refactoring mtd: spinand: more refactoring mtd: spinand: sync supported flashes with linux-6.10 mtd: nand: add initial ecc engine support
drivers/mtd/nand/Makefile | 2 +- drivers/mtd/nand/core.c | 130 +++++- drivers/mtd/nand/ecc.c | 249 ++++++++++ drivers/mtd/nand/spi/Makefile | 4 +- drivers/mtd/nand/spi/alliancememory.c | 155 ++++++ drivers/mtd/nand/spi/ato.c | 84 ++++ drivers/mtd/nand/spi/core.c | 649 ++++++++++++++++---------- drivers/mtd/nand/spi/esmt.c | 16 +- drivers/mtd/nand/spi/foresee.c | 97 ++++ drivers/mtd/nand/spi/gigadevice.c | 194 +++++++- drivers/mtd/nand/spi/macronix.c | 32 +- drivers/mtd/nand/spi/micron.c | 2 +- drivers/mtd/nand/spi/toshiba.c | 43 +- drivers/mtd/nand/spi/winbond.c | 67 ++- include/linux/mtd/nand.h | 279 ++++++++++- include/linux/mtd/spinand.h | 47 +- include/spi-mem.h | 2 + 17 files changed, 1778 insertions(+), 274 deletions(-) create mode 100644 drivers/mtd/nand/ecc.c create mode 100644 drivers/mtd/nand/spi/alliancememory.c create mode 100644 drivers/mtd/nand/spi/ato.c create mode 100644 drivers/mtd/nand/spi/foresee.c
Make use of the spi-mem direct mapping API to let advanced controllers optimize read/write operations when they support direct mapping.
This is a port of linux patch 981d1aa0697ce1393e00933f154d181e965703d0 created by Boris Brezillon bbrezillon@kernel.org.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/core.c | 185 +++++++++++++++++------------------- include/linux/mtd/spinand.h | 7 ++ 2 files changed, 95 insertions(+), 97 deletions(-)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index f5ddfbf4b83..ea00cd7dcf0 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -41,21 +41,6 @@ struct spinand_plat { /* SPI NAND index visible in MTD names */ static int spi_nand_idx;
-static void spinand_cache_op_adjust_colum(struct spinand_device *spinand, - const struct nand_page_io_req *req, - u16 *column) -{ - struct nand_device *nand = spinand_to_nand(spinand); - unsigned int shift; - - if (nand->memorg.planes_per_lun < 2) - return; - - /* The plane number is passed in MSB just above the column address */ - shift = fls(nand->memorg.pagesize); - *column |= req->pos.plane << shift; -} - static int spinand_read_reg_op(struct spinand_device *spinand, u8 reg, u8 *val) { struct spi_mem_op op = SPINAND_GET_FEATURE_OP(reg, @@ -249,27 +234,21 @@ static int spinand_load_page_op(struct spinand_device *spinand, static int spinand_read_from_cache_op(struct spinand_device *spinand, const struct nand_page_io_req *req) { - struct spi_mem_op op = *spinand->op_templates.read_cache; struct nand_device *nand = spinand_to_nand(spinand); struct mtd_info *mtd = nanddev_to_mtd(nand); - struct nand_page_io_req adjreq = *req; + struct spi_mem_dirmap_desc *rdesc; unsigned int nbytes = 0; void *buf = NULL; u16 column = 0; - int ret; + ssize_t ret;
if (req->datalen) { - adjreq.datalen = nanddev_page_size(nand); - adjreq.dataoffs = 0; - adjreq.databuf.in = spinand->databuf; buf = spinand->databuf; - nbytes = adjreq.datalen; + nbytes = nanddev_page_size(nand); + column = 0; }
if (req->ooblen) { - adjreq.ooblen = nanddev_per_page_oobsize(nand); - adjreq.ooboffs = 0; - adjreq.oobbuf.in = spinand->oobbuf; nbytes += nanddev_per_page_oobsize(nand); if (!buf) { buf = spinand->oobbuf; @@ -277,28 +256,19 @@ static int spinand_read_from_cache_op(struct spinand_device *spinand, } }
- spinand_cache_op_adjust_colum(spinand, &adjreq, &column); - op.addr.val = column; + rdesc = spinand->dirmaps[req->pos.plane].rdesc;
- /* - * Some controllers are limited in term of max RX data size. In this - * case, just repeat the READ_CACHE operation after updating the - * column. - */ while (nbytes) { - op.data.buf.in = buf; - op.data.nbytes = nbytes; - ret = spi_mem_adjust_op_size(spinand->slave, &op); - if (ret) + ret = spi_mem_dirmap_read(rdesc, column, nbytes, buf); + if (ret < 0) return ret;
- ret = spi_mem_exec_op(spinand->slave, &op); - if (ret) - return ret; + if (!ret || ret > nbytes) + return -EIO;
- buf += op.data.nbytes; - nbytes -= op.data.nbytes; - op.addr.val += op.data.nbytes; + nbytes -= ret; + column += ret; + buf += ret; }
if (req->datalen) @@ -322,14 +292,12 @@ static int spinand_read_from_cache_op(struct spinand_device *spinand, static int spinand_write_to_cache_op(struct spinand_device *spinand, const struct nand_page_io_req *req) { - struct spi_mem_op op = *spinand->op_templates.write_cache; struct nand_device *nand = spinand_to_nand(spinand); struct mtd_info *mtd = nanddev_to_mtd(nand); - struct nand_page_io_req adjreq = *req; - unsigned int nbytes = 0; - void *buf = NULL; - u16 column = 0; - int ret; + struct spi_mem_dirmap_desc *wdesc; + unsigned int nbytes, column = 0; + void *buf = spinand->databuf; + ssize_t ret;
/* * Looks like PROGRAM LOAD (AKA write cache) does not necessarily reset @@ -338,19 +306,12 @@ static int spinand_write_to_cache_op(struct spinand_device *spinand, * the data portion of the page, otherwise we might corrupt the BBM or * user data previously programmed in OOB area. */ - memset(spinand->databuf, 0xff, - nanddev_page_size(nand) + - nanddev_per_page_oobsize(nand)); + nbytes = nanddev_page_size(nand) + nanddev_per_page_oobsize(nand); + memset(spinand->databuf, 0xff, nbytes);
- if (req->datalen) { + if (req->datalen) memcpy(spinand->databuf + req->dataoffs, req->databuf.out, req->datalen); - adjreq.dataoffs = 0; - adjreq.datalen = nanddev_page_size(nand); - adjreq.databuf.out = spinand->databuf; - nbytes = adjreq.datalen; - buf = spinand->databuf; - }
if (req->ooblen) { if (req->mode == MTD_OPS_AUTO_OOB) @@ -361,52 +322,21 @@ static int spinand_write_to_cache_op(struct spinand_device *spinand, else memcpy(spinand->oobbuf + req->ooboffs, req->oobbuf.out, req->ooblen); - - adjreq.ooblen = nanddev_per_page_oobsize(nand); - adjreq.ooboffs = 0; - nbytes += nanddev_per_page_oobsize(nand); - if (!buf) { - buf = spinand->oobbuf; - column = nanddev_page_size(nand); - } }
- spinand_cache_op_adjust_colum(spinand, &adjreq, &column); - - op = *spinand->op_templates.write_cache; - op.addr.val = column; + wdesc = spinand->dirmaps[req->pos.plane].wdesc;
- /* - * Some controllers are limited in term of max TX data size. In this - * case, split the operation into one LOAD CACHE and one or more - * LOAD RANDOM CACHE. - */ while (nbytes) { - op.data.buf.out = buf; - op.data.nbytes = nbytes; - - ret = spi_mem_adjust_op_size(spinand->slave, &op); - if (ret) - return ret; - - ret = spi_mem_exec_op(spinand->slave, &op); - if (ret) + ret = spi_mem_dirmap_write(wdesc, column, nbytes, buf); + if (ret < 0) return ret;
- buf += op.data.nbytes; - nbytes -= op.data.nbytes; - op.addr.val += op.data.nbytes; + if (!ret || ret > nbytes) + return -EIO;
- /* - * We need to use the RANDOM LOAD CACHE operation if there's - * more than one iteration, because the LOAD operation resets - * the cache to 0xff. - */ - if (nbytes) { - column = op.addr.val; - op = *spinand->op_templates.update_cache; - op.addr.val = column; - } + nbytes -= ret; + column += ret; + buf += ret; }
return 0; @@ -819,6 +749,59 @@ static int spinand_mtd_block_isreserved(struct mtd_info *mtd, loff_t offs) return ret; }
+static int spinand_create_dirmap(struct spinand_device *spinand, + unsigned int plane) +{ + struct nand_device *nand = spinand_to_nand(spinand); + struct spi_mem_dirmap_info info = { + .length = nanddev_page_size(nand) + + nanddev_per_page_oobsize(nand), + }; + struct spi_mem_dirmap_desc *desc; + + /* The plane number is passed in MSB just above the column address */ + info.offset = plane << fls(nand->memorg.pagesize); + + info.op_tmpl = *spinand->op_templates.update_cache; + desc = spi_mem_dirmap_create(spinand->slave, &info); + if (IS_ERR(desc)) + return PTR_ERR(desc); + + spinand->dirmaps[plane].wdesc = desc; + + info.op_tmpl = *spinand->op_templates.read_cache; + desc = spi_mem_dirmap_create(spinand->slave, &info); + if (IS_ERR(desc)) { + spi_mem_dirmap_destroy(spinand->dirmaps[plane].wdesc); + return PTR_ERR(desc); + } + + spinand->dirmaps[plane].rdesc = desc; + + return 0; +} + +static int spinand_create_dirmaps(struct spinand_device *spinand) +{ + struct nand_device *nand = spinand_to_nand(spinand); + int i, ret; + + spinand->dirmaps = devm_kzalloc(spinand->slave->dev, + sizeof(*spinand->dirmaps) * + nand->memorg.planes_per_lun, + GFP_KERNEL); + if (!spinand->dirmaps) + return -ENOMEM; + + for (i = 0; i < nand->memorg.planes_per_lun; i++) { + ret = spinand_create_dirmap(spinand, i); + if (ret) + return ret; + } + + return 0; +} + static const struct nand_ops spinand_ops = { .erase = spinand_erase, .markbad = spinand_markbad, @@ -1116,6 +1099,14 @@ static int spinand_init(struct spinand_device *spinand) goto err_free_bufs; }
+ ret = spinand_create_dirmaps(spinand); + if (ret) { + dev_err(spinand->slave->dev, + "Failed to create direct mappings for read/write operations (err = %d)\n", + ret); + goto err_manuf_cleanup; + } + /* After power up, all blocks are locked, so unlock them here. */ for (i = 0; i < nand->memorg.ntargets; i++) { ret = spinand_select_target(spinand, i); diff --git a/include/linux/mtd/spinand.h b/include/linux/mtd/spinand.h index 13b5a52f8b9..5934b7604cc 100644 --- a/include/linux/mtd/spinand.h +++ b/include/linux/mtd/spinand.h @@ -363,6 +363,11 @@ struct spinand_info { __VA_ARGS__ \ }
+struct spinand_dirmap { + struct spi_mem_dirmap_desc *wdesc; + struct spi_mem_dirmap_desc *rdesc; +}; + /** * struct spinand_device - SPI NAND device instance * @base: NAND device instance @@ -406,6 +411,8 @@ struct spinand_device { const struct spi_mem_op *update_cache; } op_templates;
+ struct spinand_dirmap *dirmaps; + int (*select_target)(struct spinand_device *spinand, unsigned int target); unsigned int cur_target;
Use an enum to differentiate the type of I/O (reading or writing a page). Also update the request iterator.
This is a port of linux patch 701981cab01696584a12e5f0e7c2ad931a326059 created by Miquel Raynal miquel.raynal@bootlin.com
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/core.c | 4 ++-- include/linux/mtd/nand.h | 18 ++++++++++++++++-- 2 files changed, 18 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index ea00cd7dcf0..8f227ce81fa 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -523,7 +523,7 @@ static int spinand_mtd_read(struct mtd_info *mtd, loff_t from, mutex_lock(&spinand->lock); #endif
- nanddev_io_for_each_page(nand, from, ops, &iter) { + nanddev_io_for_each_page(nand, NAND_PAGE_READ, from, ops, &iter) { schedule(); ret = spinand_select_target(spinand, iter.req.pos.target); if (ret) @@ -575,7 +575,7 @@ static int spinand_mtd_write(struct mtd_info *mtd, loff_t to, mutex_lock(&spinand->lock); #endif
- nanddev_io_for_each_page(nand, to, ops, &iter) { + nanddev_io_for_each_page(nand, NAND_PAGE_WRITE, to, ops, &iter) { schedule(); ret = spinand_select_target(spinand, iter.req.pos.target); if (ret) diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 651f8706df5..0afdaed5715 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -80,8 +80,19 @@ struct nand_pos { unsigned int page; };
+/** + * enum nand_page_io_req_type - Direction of an I/O request + * @NAND_PAGE_READ: from the chip, to the controller + * @NAND_PAGE_WRITE: from the controller, to the chip + */ +enum nand_page_io_req_type { + NAND_PAGE_READ = 0, + NAND_PAGE_WRITE, +}; + /** * struct nand_page_io_req - NAND I/O request object + * @type: the type of page I/O: read or write * @pos: the position this I/O request is targeting * @dataoffs: the offset within the page * @datalen: number of data bytes to read from/write to this page @@ -97,6 +108,7 @@ struct nand_pos { * specific commands/operations. */ struct nand_page_io_req { + enum nand_page_io_req_type type; struct nand_pos pos; unsigned int dataoffs; unsigned int datalen; @@ -613,11 +625,13 @@ static inline void nanddev_pos_next_page(struct nand_device *nand, * layer. */ static inline void nanddev_io_iter_init(struct nand_device *nand, + enum nand_page_io_req_type reqtype, loff_t offs, struct mtd_oob_ops *req, struct nand_io_iter *iter) { struct mtd_info *mtd = nanddev_to_mtd(nand);
+ iter->req.type = reqtype; iter->req.mode = req->mode; iter->req.dataoffs = nanddev_offs_to_pos(nand, offs, &iter->req.pos); iter->req.ooboffs = req->ooboffs; @@ -687,8 +701,8 @@ static inline bool nanddev_io_iter_end(struct nand_device *nand, * * Should be used for iterate over pages that are contained in an MTD request. */ -#define nanddev_io_for_each_page(nand, start, req, iter) \ - for (nanddev_io_iter_init(nand, start, req, iter); \ +#define nanddev_io_for_each_page(nand, type, start, req, iter) \ + for (nanddev_io_iter_init(nand, type, start, req, iter); \ !nanddev_io_iter_end(nand, iter); \ nanddev_io_iter_next_page(nand, iter))
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/core.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 8f227ce81fa..62779dd3e51 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -1267,12 +1267,14 @@ static const struct spi_device_id spinand_ids[] = { { .name = "spi-nand" }, { /* sentinel */ }, }; +MODULE_DEVICE_TABLE(spi, spinand_ids);
#ifdef CONFIG_OF static const struct of_device_id spinand_of_ids[] = { { .compatible = "spi-nand" }, { /* sentinel */ }, }; +MODULE_DEVICE_TABLE(of, spinand_of_ids); #endif
static struct spi_mem_driver spinand_drv = {
also call schedule() to allow periodic actions
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/core.c | 35 ++++++++++++++++++++++++++++------- include/linux/mtd/spinand.h | 22 ++++++++++++++++++++++ 2 files changed, 50 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 62779dd3e51..a10605487f3 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -32,6 +32,7 @@ #include <linux/bug.h> #include <linux/mtd/spinand.h> #include <linux/printk.h> +#include <linux/delay.h> #endif
struct spinand_plat { @@ -362,21 +363,29 @@ static int spinand_erase_op(struct spinand_device *spinand, return spi_mem_exec_op(spinand->slave, &op); }
-static int spinand_wait(struct spinand_device *spinand, u8 *s) +static int spinand_wait(struct spinand_device *spinand, + unsigned long initial_delay_us, + unsigned long poll_delay_us, + u8 *s) { unsigned long start, stop; u8 status; int ret;
+ udelay(initial_delay_us); start = get_timer(0); - stop = 400; + stop = SPINAND_WAITRDY_TIMEOUT_MS; do { + schedule(); + ret = spinand_read_status(spinand, &status); if (ret) return ret;
if (!(status & STATUS_BUSY)) goto out; + + udelay(poll_delay_us); } while (get_timer(start) < stop);
/* @@ -418,7 +427,10 @@ static int spinand_reset_op(struct spinand_device *spinand) if (ret) return ret;
- return spinand_wait(spinand, NULL); + return spinand_wait(spinand, + SPINAND_RESET_INITIAL_DELAY_US, + SPINAND_RESET_POLL_DELAY_US, + NULL); }
static int spinand_lock_block(struct spinand_device *spinand, u8 lock) @@ -466,7 +478,10 @@ static int spinand_read_page(struct spinand_device *spinand, if (ret) return ret;
- ret = spinand_wait(spinand, &status); + ret = spinand_wait(spinand, + SPINAND_READ_INITIAL_DELAY_US, + SPINAND_READ_POLL_DELAY_US, + &status); if (ret < 0) return ret;
@@ -498,9 +513,12 @@ static int spinand_write_page(struct spinand_device *spinand, if (ret) return ret;
- ret = spinand_wait(spinand, &status); + ret = spinand_wait(spinand, + SPINAND_WRITE_INITIAL_DELAY_US, + SPINAND_WRITE_POLL_DELAY_US, + &status); if (!ret && (status & STATUS_PROG_FAILED)) - ret = -EIO; + return -EIO;
return ret; } @@ -702,7 +720,10 @@ static int spinand_erase(struct nand_device *nand, const struct nand_pos *pos) if (ret) return ret;
- ret = spinand_wait(spinand, &status); + ret = spinand_wait(spinand, + SPINAND_ERASE_INITIAL_DELAY_US, + SPINAND_ERASE_POLL_DELAY_US, + &status); if (!ret && (status & STATUS_ERASE_FAILED)) ret = -EIO;
diff --git a/include/linux/mtd/spinand.h b/include/linux/mtd/spinand.h index 5934b7604cc..b701d25f73d 100644 --- a/include/linux/mtd/spinand.h +++ b/include/linux/mtd/spinand.h @@ -176,6 +176,28 @@ struct spinand_op; struct spinand_device;
#define SPINAND_MAX_ID_LEN 4 +/* + * For erase, write and read operation, we got the following timings : + * tBERS (erase) 1ms to 4ms + * tPROG 300us to 400us + * tREAD 25us to 100us + * In order to minimize latency, the min value is divided by 4 for the + * initial delay, and dividing by 20 for the poll delay. + * For reset, 5us/10us/500us if the device is respectively + * reading/programming/erasing when the RESET occurs. Since we always + * issue a RESET when the device is IDLE, 5us is selected for both initial + * and poll delay. + */ +#define SPINAND_READ_INITIAL_DELAY_US 6 +#define SPINAND_READ_POLL_DELAY_US 5 +#define SPINAND_RESET_INITIAL_DELAY_US 5 +#define SPINAND_RESET_POLL_DELAY_US 5 +#define SPINAND_WRITE_INITIAL_DELAY_US 75 +#define SPINAND_WRITE_POLL_DELAY_US 15 +#define SPINAND_ERASE_INITIAL_DELAY_US 250 +#define SPINAND_ERASE_POLL_DELAY_US 50 + +#define SPINAND_WAITRDY_TIMEOUT_MS 400
/** * struct spinand_id - SPI NAND id structure
Use spinand_to_nand() and spinand_to_mtd() helpers instead of nanddev_to_mtd() and direct access to spinand structure fields.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/core.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index a10605487f3..b58d9e00907 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -236,7 +236,7 @@ static int spinand_read_from_cache_op(struct spinand_device *spinand, const struct nand_page_io_req *req) { struct nand_device *nand = spinand_to_nand(spinand); - struct mtd_info *mtd = nanddev_to_mtd(nand); + struct mtd_info *mtd = spinand_to_mtd(spinand); struct spi_mem_dirmap_desc *rdesc; unsigned int nbytes = 0; void *buf = NULL; @@ -294,7 +294,7 @@ static int spinand_write_to_cache_op(struct spinand_device *spinand, const struct nand_page_io_req *req) { struct nand_device *nand = spinand_to_nand(spinand); - struct mtd_info *mtd = nanddev_to_mtd(nand); + struct mtd_info *mtd = spinand_to_mtd(spinand); struct spi_mem_dirmap_desc *wdesc; unsigned int nbytes, column = 0; void *buf = spinand->databuf; @@ -356,7 +356,7 @@ static int spinand_program_op(struct spinand_device *spinand, static int spinand_erase_op(struct spinand_device *spinand, const struct nand_pos *pos) { - struct nand_device *nand = &spinand->base; + struct nand_device *nand = spinand_to_nand(spinand); unsigned int row = nanddev_pos_to_row(nand, pos); struct spi_mem_op op = SPINAND_BLK_ERASE_OP(row);
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/core.c | 24 +++++++++++++++--------- 1 file changed, 15 insertions(+), 9 deletions(-)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index b58d9e00907..9629fac3388 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -530,12 +530,12 @@ static int spinand_mtd_read(struct mtd_info *mtd, loff_t from, struct nand_device *nand = mtd_to_nanddev(mtd); unsigned int max_bitflips = 0; struct nand_io_iter iter; - bool enable_ecc = false; + bool disable_ecc = false; bool ecc_failed = false; int ret = 0;
- if (ops->mode != MTD_OPS_RAW && spinand->eccinfo.ooblayout) - enable_ecc = true; + if (ops->mode == MTD_OPS_RAW || !spinand->eccinfo.ooblayout) + disable_ecc = true;
#ifndef __UBOOT__ mutex_lock(&spinand->lock); @@ -543,15 +543,18 @@ static int spinand_mtd_read(struct mtd_info *mtd, loff_t from,
nanddev_io_for_each_page(nand, NAND_PAGE_READ, from, ops, &iter) { schedule(); + if (disable_ecc) + iter.req.mode = MTD_OPS_RAW; + ret = spinand_select_target(spinand, iter.req.pos.target); if (ret) break;
- ret = spinand_ecc_enable(spinand, enable_ecc); + ret = spinand_ecc_enable(spinand, !disable_ecc); if (ret) break;
- ret = spinand_read_page(spinand, &iter.req, enable_ecc); + ret = spinand_read_page(spinand, &iter.req, !disable_ecc); if (ret < 0 && ret != -EBADMSG) break;
@@ -583,11 +586,11 @@ static int spinand_mtd_write(struct mtd_info *mtd, loff_t to, struct spinand_device *spinand = mtd_to_spinand(mtd); struct nand_device *nand = mtd_to_nanddev(mtd); struct nand_io_iter iter; - bool enable_ecc = false; + bool disable_ecc = false; int ret = 0;
- if (ops->mode != MTD_OPS_RAW && mtd->ooblayout) - enable_ecc = true; + if (ops->mode == MTD_OPS_RAW || !mtd->ooblayout) + disable_ecc = true;
#ifndef __UBOOT__ mutex_lock(&spinand->lock); @@ -595,11 +598,14 @@ static int spinand_mtd_write(struct mtd_info *mtd, loff_t to,
nanddev_io_for_each_page(nand, NAND_PAGE_WRITE, to, ops, &iter) { schedule(); + if (disable_ecc) + iter.req.mode = MTD_OPS_RAW; + ret = spinand_select_target(spinand, iter.req.pos.target); if (ret) break;
No functional changes, just some refactoring to match better linux kernel driver.
changes: * move spinand configuration reading out from spinand_init_cfg_cache() to separate function spinand_read_cfg() * move spinand flash initialization to separate function spinand_init_flash() * move direct mapping initialization to the end of spinand_init()
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/core.c | 112 ++++++++++++++++++++++-------------- 1 file changed, 70 insertions(+), 42 deletions(-)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 9629fac3388..6ca8b7c80cc 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -160,20 +160,12 @@ int spinand_select_target(struct spinand_device *spinand, unsigned int target) return 0; }
-static int spinand_init_cfg_cache(struct spinand_device *spinand) +static int spinand_read_cfg(struct spinand_device *spinand) { struct nand_device *nand = spinand_to_nand(spinand); - struct udevice *dev = spinand->slave->dev; unsigned int target; int ret;
- spinand->cfg_cache = devm_kzalloc(dev, - sizeof(*spinand->cfg_cache) * - nand->memorg.ntargets, - GFP_KERNEL); - if (!spinand->cfg_cache) - return -ENOMEM; - for (target = 0; target < nand->memorg.ntargets; target++) { ret = spinand_select_target(spinand, target); if (ret) @@ -192,6 +184,21 @@ static int spinand_init_cfg_cache(struct spinand_device *spinand) return 0; }
+static int spinand_init_cfg_cache(struct spinand_device *spinand) +{ + struct nand_device *nand = spinand_to_nand(spinand); + struct udevice *dev = spinand->slave->dev; + + spinand->cfg_cache = devm_kcalloc(dev, + nand->memorg.ntargets, + sizeof(*spinand->cfg_cache), + GFP_KERNEL); + if (!spinand->cfg_cache) + return -ENOMEM; + + return 0; +} + static int spinand_init_quad_enable(struct spinand_device *spinand) { bool enable = false; @@ -1073,11 +1080,55 @@ static const struct mtd_ooblayout_ops spinand_noecc_ooblayout = { .rfree = spinand_noecc_ooblayout_free, };
+static int spinand_init_flash(struct spinand_device *spinand) +{ + struct udevice *dev = spinand->slave->dev; + struct nand_device *nand = spinand_to_nand(spinand); + int ret, i; + + ret = spinand_read_cfg(spinand); + if (ret) + return ret; + + ret = spinand_init_quad_enable(spinand); + if (ret) + return ret; + + ret = spinand_upd_cfg(spinand, CFG_OTP_ENABLE, 0); + if (ret) + return ret; + + ret = spinand_manufacturer_init(spinand); + if (ret) { + dev_err(dev, + "Failed to initialize the SPI NAND chip (err = %d)\n", + ret); + return ret; + } + + /* After power up, all blocks are locked, so unlock them here. */ + for (i = 0; i < nand->memorg.ntargets; i++) { + ret = spinand_select_target(spinand, i); + if (ret) + break; + + ret = spinand_lock_block(spinand, BL_ALL_UNLOCKED); + if (ret) + break; + } + + if (ret) + spinand_manufacturer_cleanup(spinand); + + return ret; +} + static int spinand_init(struct spinand_device *spinand) { + struct udevice *dev = spinand->slave->dev; struct mtd_info *mtd = spinand_to_mtd(spinand); struct nand_device *nand = mtd_to_nanddev(mtd); - int ret, i; + int ret;
/* * We need a scratch buffer because the spi_mem interface requires that @@ -1110,41 +1161,10 @@ static int spinand_init(struct spinand_device *spinand) if (ret) goto err_free_bufs;
- ret = spinand_init_quad_enable(spinand); + ret = spinand_init_flash(spinand); if (ret) goto err_free_bufs;
- ret = spinand_upd_cfg(spinand, CFG_OTP_ENABLE, 0); - if (ret) - goto err_free_bufs; - - ret = spinand_manufacturer_init(spinand); - if (ret) { - dev_err(spinand->slave->dev, - "Failed to initialize the SPI NAND chip (err = %d)\n", - ret); - goto err_free_bufs; - } - - ret = spinand_create_dirmaps(spinand); - if (ret) { - dev_err(spinand->slave->dev, - "Failed to create direct mappings for read/write operations (err = %d)\n", - ret); - goto err_manuf_cleanup; - } - - /* After power up, all blocks are locked, so unlock them here. */ - for (i = 0; i < nand->memorg.ntargets; i++) { - ret = spinand_select_target(spinand, i); - if (ret) - goto err_manuf_cleanup; - - ret = spinand_lock_block(spinand, BL_ALL_UNLOCKED); - if (ret) - goto err_manuf_cleanup; - } - ret = nanddev_init(nand, &spinand_ops, THIS_MODULE); if (ret) goto err_manuf_cleanup; @@ -1171,6 +1191,14 @@ static int spinand_init(struct spinand_device *spinand)
mtd->oobavail = ret;
+ ret = spinand_create_dirmaps(spinand); + if (ret) { + dev_err(dev, + "Failed to create direct mappings for read/write operations (err = %d)\n", + ret); + goto err_cleanup_nanddev; + } + return 0;
err_cleanup_nanddev:
changes: * Move spinand_check_ecc_status(), spinand_noecc_ooblayout_ecc(), spinand_noecc_ooblayout_free() and spinand_noecc_ooblayout close to each other. * some code formatting * remove comments not present in linux driver
This make code more close to linux-6.10 kernel driver
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/core.c | 115 +++++++++++++++++------------------- 1 file changed, 55 insertions(+), 60 deletions(-)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 6ca8b7c80cc..548a7144ee3 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -222,6 +222,59 @@ static int spinand_ecc_enable(struct spinand_device *spinand, enable ? CFG_ECC_ENABLE : 0); }
+static int spinand_check_ecc_status(struct spinand_device *spinand, u8 status) +{ + struct nand_device *nand = spinand_to_nand(spinand); + + if (spinand->eccinfo.get_status) + return spinand->eccinfo.get_status(spinand, status); + + switch (status & STATUS_ECC_MASK) { + case STATUS_ECC_NO_BITFLIPS: + return 0; + + case STATUS_ECC_HAS_BITFLIPS: + /* + * We have no way to know exactly how many bitflips have been + * fixed, so let's return the maximum possible value so that + * wear-leveling layers move the data immediately. + */ + return nand->eccreq.strength; + + case STATUS_ECC_UNCOR_ERROR: + return -EBADMSG; + + default: + break; + } + + return -EINVAL; +} + +static int spinand_noecc_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + return -ERANGE; +} + +static int spinand_noecc_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + if (section) + return -ERANGE; + + /* Reserve 2 bytes for the BBM. */ + region->offset = 2; + region->length = 62; + + return 0; +} + +static const struct mtd_ooblayout_ops spinand_noecc_ooblayout = { + .ecc = spinand_noecc_ooblayout_ecc, + .rfree = spinand_noecc_ooblayout_free, +}; + static int spinand_write_enable_op(struct spinand_device *spinand) { struct spi_mem_op op = SPINAND_WR_EN_DIS_OP(true); @@ -413,9 +466,8 @@ out: static int spinand_read_id_op(struct spinand_device *spinand, u8 naddr, u8 ndummy, u8 *buf) { - struct spi_mem_op op = SPINAND_READID_OP(naddr, ndummy, - spinand->scratchbuf, - SPINAND_MAX_ID_LEN); + struct spi_mem_op op = SPINAND_READID_OP( + naddr, ndummy, spinand->scratchbuf, SPINAND_MAX_ID_LEN); int ret;
ret = spi_mem_exec_op(spinand->slave, &op); @@ -445,35 +497,6 @@ static int spinand_lock_block(struct spinand_device *spinand, u8 lock) return spinand_write_reg_op(spinand, REG_BLOCK_LOCK, lock); }
-static int spinand_check_ecc_status(struct spinand_device *spinand, u8 status) -{ - struct nand_device *nand = spinand_to_nand(spinand); - - if (spinand->eccinfo.get_status) - return spinand->eccinfo.get_status(spinand, status); - - switch (status & STATUS_ECC_MASK) { - case STATUS_ECC_NO_BITFLIPS: - return 0; - - case STATUS_ECC_HAS_BITFLIPS: - /* - * We have no way to know exactly how many bitflips have been - * fixed, so let's return the maximum possible value so that - * wear-leveling layers move the data immediately. - */ - return nand->eccreq.strength; - - case STATUS_ECC_UNCOR_ERROR: - return -EBADMSG; - - default: - break; - } - - return -EINVAL; -} - static int spinand_read_page(struct spinand_device *spinand, const struct nand_page_io_req *req, bool ecc_enabled) @@ -1056,30 +1079,6 @@ static int spinand_detect(struct spinand_device *spinand) return 0; }
-static int spinand_noecc_ooblayout_ecc(struct mtd_info *mtd, int section, - struct mtd_oob_region *region) -{ - return -ERANGE; -} - -static int spinand_noecc_ooblayout_free(struct mtd_info *mtd, int section, - struct mtd_oob_region *region) -{ - if (section) - return -ERANGE; - - /* Reserve 2 bytes for the BBM. */ - region->offset = 2; - region->length = 62; - - return 0; -} - -static const struct mtd_ooblayout_ops spinand_noecc_ooblayout = { - .ecc = spinand_noecc_ooblayout_ecc, - .rfree = spinand_noecc_ooblayout_free, -}; - static int spinand_init_flash(struct spinand_device *spinand) { struct udevice *dev = spinand->slave->dev; @@ -1169,10 +1168,6 @@ static int spinand_init(struct spinand_device *spinand) if (ret) goto err_manuf_cleanup;
- /* - * Right now, we don't support ECC, so let the whole oob - * area is available for user. - */ mtd->_read_oob = spinand_mtd_read; mtd->_write_oob = spinand_mtd_write; mtd->_block_isbad = spinand_mtd_block_isbad;
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/spi/Makefile | 4 +- drivers/mtd/nand/spi/alliancememory.c | 155 ++++++++++++++++++++ drivers/mtd/nand/spi/ato.c | 84 +++++++++++ drivers/mtd/nand/spi/core.c | 5 +- drivers/mtd/nand/spi/esmt.c | 16 ++- drivers/mtd/nand/spi/foresee.c | 97 +++++++++++++ drivers/mtd/nand/spi/gigadevice.c | 194 +++++++++++++++++++++++++- drivers/mtd/nand/spi/macronix.c | 25 +++- drivers/mtd/nand/spi/toshiba.c | 33 +++++ drivers/mtd/nand/spi/winbond.c | 57 ++++++++ include/linux/mtd/spinand.h | 5 +- 11 files changed, 664 insertions(+), 11 deletions(-) create mode 100644 drivers/mtd/nand/spi/alliancememory.c create mode 100644 drivers/mtd/nand/spi/ato.c create mode 100644 drivers/mtd/nand/spi/foresee.c
diff --git a/drivers/mtd/nand/spi/Makefile b/drivers/mtd/nand/spi/Makefile index 65b836b34ca..d438747cf37 100644 --- a/drivers/mtd/nand/spi/Makefile +++ b/drivers/mtd/nand/spi/Makefile @@ -1,5 +1,5 @@ # SPDX-License-Identifier: GPL-2.0
-spinand-objs := core.o esmt.o gigadevice.o macronix.o micron.o paragon.o -spinand-objs += toshiba.o winbond.o xtx.o +spinand-objs := core.o alliancememory.o ato.o esmt.o foresee.o gigadevice.o macronix.o +spinand-objs += micron.o paragon.o toshiba.o winbond.o xtx.o obj-$(CONFIG_MTD_SPI_NAND) += spinand.o diff --git a/drivers/mtd/nand/spi/alliancememory.c b/drivers/mtd/nand/spi/alliancememory.c new file mode 100644 index 00000000000..e29e4cc77ec --- /dev/null +++ b/drivers/mtd/nand/spi/alliancememory.c @@ -0,0 +1,155 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Author: Mario Kicherer dev@kicherer.org + */ + +#ifndef __UBOOT__ +#include <linux/device.h> +#include <linux/kernel.h> +#endif +#include <linux/mtd/spinand.h> + +#define SPINAND_MFR_ALLIANCEMEMORY 0x52 + +#define AM_STATUS_ECC_BITMASK (3 << 4) + +#define AM_STATUS_ECC_NONE_DETECTED (0 << 4) +#define AM_STATUS_ECC_CORRECTED (1 << 4) +#define AM_STATUS_ECC_ERRORED (2 << 4) +#define AM_STATUS_ECC_MAX_CORRECTED (3 << 4) + +static SPINAND_OP_VARIANTS(read_cache_variants, + SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_DUALIO_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0)); + +static SPINAND_OP_VARIANTS(write_cache_variants, + SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), + SPINAND_PROG_LOAD(true, 0, NULL, 0)); + +static SPINAND_OP_VARIANTS(update_cache_variants, + SPINAND_PROG_LOAD_X4(false, 0, NULL, 0), + SPINAND_PROG_LOAD(false, 0, NULL, 0)); + +static int am_get_eccsize(struct mtd_info *mtd) +{ + if (mtd->oobsize == 64) + return 0x20; + else if (mtd->oobsize == 128) + return 0x38; + else if (mtd->oobsize == 256) + return 0x70; + else + return -EINVAL; +} + +static int am_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + int ecc_bytes; + + ecc_bytes = am_get_eccsize(mtd); + if (ecc_bytes < 0) + return ecc_bytes; + + region->offset = mtd->oobsize - ecc_bytes; + region->length = ecc_bytes; + + return 0; +} + +static int am_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + int ecc_bytes; + + if (section) + return -ERANGE; + + ecc_bytes = am_get_eccsize(mtd); + if (ecc_bytes < 0) + return ecc_bytes; + + /* + * It is unclear how many bytes are used for the bad block marker. We + * reserve the common two bytes here. + * + * The free area in this kind of flash is divided into chunks where the + * first 4 bytes of each chunk are unprotected. The number of chunks + * depends on the specific model. The models with 4096+256 bytes pages + * have 8 chunks, the others 4 chunks. + */ + + region->offset = 2; + region->length = mtd->oobsize - 2 - ecc_bytes; + + return 0; +} + +static const struct mtd_ooblayout_ops am_ooblayout = { + .ecc = am_ooblayout_ecc, + .rfree = am_ooblayout_free, +}; + +static int am_ecc_get_status(struct spinand_device *spinand, u8 status) +{ + switch (status & AM_STATUS_ECC_BITMASK) { + case AM_STATUS_ECC_NONE_DETECTED: + return 0; + + case AM_STATUS_ECC_CORRECTED: + /* + * use oobsize to determine the flash model and the maximum of + * correctable errors and return maximum - 1 by convention + */ + if (spinand->base.mtd->oobsize == 64) + return 3; + else + return 7; + + case AM_STATUS_ECC_ERRORED: + return -EBADMSG; + + case AM_STATUS_ECC_MAX_CORRECTED: + /* + * use oobsize to determine the flash model and the maximum of + * correctable errors + */ + if (spinand->base.mtd->oobsize == 64) + return 4; + else + return 8; + + default: + break; + } + + return -EINVAL; +} + +static const struct spinand_info alliancememory_spinand_table[] = { + SPINAND_INFO("AS5F34G04SND", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x2f), + NAND_MEMORG(1, 2048, 128, 64, 4096, 80, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&am_ooblayout, + am_ecc_get_status)), +}; + +static const struct spinand_manufacturer_ops alliancememory_spinand_manuf_ops = { +}; + +const struct spinand_manufacturer alliancememory_spinand_manufacturer = { + .id = SPINAND_MFR_ALLIANCEMEMORY, + .name = "AllianceMemory", + .chips = alliancememory_spinand_table, + .nchips = ARRAY_SIZE(alliancememory_spinand_table), + .ops = &alliancememory_spinand_manuf_ops, +}; diff --git a/drivers/mtd/nand/spi/ato.c b/drivers/mtd/nand/spi/ato.c new file mode 100644 index 00000000000..f0d4436cf45 --- /dev/null +++ b/drivers/mtd/nand/spi/ato.c @@ -0,0 +1,84 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Aidan MacDonald + * + * Author: Aidan MacDonald aidanmacdonald.0x0@gmail.com + */ + +#ifndef __UBOOT__ +#include <linux/device.h> +#include <linux/kernel.h> +#endif +#include <linux/mtd/spinand.h> + +#define SPINAND_MFR_ATO 0x9b + +static SPINAND_OP_VARIANTS(read_cache_variants, + SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0)); + +static SPINAND_OP_VARIANTS(write_cache_variants, + SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), + SPINAND_PROG_LOAD(true, 0, NULL, 0)); + +static SPINAND_OP_VARIANTS(update_cache_variants, + SPINAND_PROG_LOAD_X4(false, 0, NULL, 0), + SPINAND_PROG_LOAD(false, 0, NULL, 0)); + +static int ato25d1ga_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + if (section > 3) + return -ERANGE; + + region->offset = (16 * section) + 8; + region->length = 8; + return 0; +} + +static int ato25d1ga_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + if (section > 3) + return -ERANGE; + + if (section) { + region->offset = (16 * section); + region->length = 8; + } else { + /* first byte of section 0 is reserved for the BBM */ + region->offset = 1; + region->length = 7; + } + + return 0; +} + +static const struct mtd_ooblayout_ops ato25d1ga_ooblayout = { + .ecc = ato25d1ga_ooblayout_ecc, + .rfree = ato25d1ga_ooblayout_free, +}; + +static const struct spinand_info ato_spinand_table[] = { + SPINAND_INFO("ATO25D1GA", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x12), + NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(1, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&ato25d1ga_ooblayout, NULL)), +}; + +static const struct spinand_manufacturer_ops ato_spinand_manuf_ops = { +}; + +const struct spinand_manufacturer ato_spinand_manufacturer = { + .id = SPINAND_MFR_ATO, + .name = "ATO", + .chips = ato_spinand_table, + .nchips = ARRAY_SIZE(ato_spinand_table), + .ops = &ato_spinand_manuf_ops, +}; diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 548a7144ee3..d5cb9026246 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -866,13 +866,16 @@ static const struct nand_ops spinand_ops = { };
static const struct spinand_manufacturer *spinand_manufacturers[] = { + &alliancememory_spinand_manufacturer, + &ato_spinand_manufacturer, + &esmt_c8_spinand_manufacturer, + &foresee_spinand_manufacturer, &gigadevice_spinand_manufacturer, ¯onix_spinand_manufacturer, µn_spinand_manufacturer, ¶gon_spinand_manufacturer, &toshiba_spinand_manufacturer, &winbond_spinand_manufacturer, - &esmt_c8_spinand_manufacturer, &xtx_spinand_manufacturer, };
diff --git a/drivers/mtd/nand/spi/esmt.c b/drivers/mtd/nand/spi/esmt.c index 7e07b26827a..23be098b885 100644 --- a/drivers/mtd/nand/spi/esmt.c +++ b/drivers/mtd/nand/spi/esmt.c @@ -106,7 +106,8 @@ static const struct mtd_ooblayout_ops f50l1g41lb_ooblayout = {
static const struct spinand_info esmt_c8_spinand_table[] = { SPINAND_INFO("F50L1G41LB", - SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x01), + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x01, 0x7f, + 0x7f, 0x7f), NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 1, 1), NAND_ECCREQ(1, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -115,7 +116,8 @@ static const struct spinand_info esmt_c8_spinand_table[] = { 0, SPINAND_ECCINFO(&f50l1g41lb_ooblayout, NULL)), SPINAND_INFO("F50D1G41LB", - SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x11), + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x11, 0x7f, + 0x7f, 0x7f), NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 1, 1), NAND_ECCREQ(1, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -123,6 +125,16 @@ static const struct spinand_info esmt_c8_spinand_table[] = { &update_cache_variants), 0, SPINAND_ECCINFO(&f50l1g41lb_ooblayout, NULL)), + SPINAND_INFO("F50D2G41KA", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x51, 0x7f, + 0x7f, 0x7f), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&f50l1g41lb_ooblayout, NULL)), };
static const struct spinand_manufacturer_ops esmt_spinand_manuf_ops = { diff --git a/drivers/mtd/nand/spi/foresee.c b/drivers/mtd/nand/spi/foresee.c new file mode 100644 index 00000000000..7d141cdd658 --- /dev/null +++ b/drivers/mtd/nand/spi/foresee.c @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023, SberDevices. All Rights Reserved. + * + * Author: Martin Kurbanov mmkurbanov@salutedevices.com + */ + +#ifndef __UBOOT__ +#include <linux/device.h> +#include <linux/kernel.h> +#endif +#include <linux/mtd/spinand.h> + +#define SPINAND_MFR_FORESEE 0xCD + +static SPINAND_OP_VARIANTS(read_cache_variants, + SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0)); + +static SPINAND_OP_VARIANTS(write_cache_variants, + SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), + SPINAND_PROG_LOAD(true, 0, NULL, 0)); + +static SPINAND_OP_VARIANTS(update_cache_variants, + SPINAND_PROG_LOAD_X4(false, 0, NULL, 0), + SPINAND_PROG_LOAD(false, 0, NULL, 0)); + +static int f35sqa002g_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + return -ERANGE; +} + +static int f35sqa002g_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + if (section) + return -ERANGE; + + /* Reserve 2 bytes for the BBM. */ + region->offset = 2; + region->length = 62; + + return 0; +} + +static const struct mtd_ooblayout_ops f35sqa002g_ooblayout = { + .ecc = f35sqa002g_ooblayout_ecc, + .rfree = f35sqa002g_ooblayout_free, +}; + +static int f35sqa002g_ecc_get_status(struct spinand_device *spinand, u8 status) +{ + struct nand_device *nand = spinand_to_nand(spinand); + + switch (status & STATUS_ECC_MASK) { + case STATUS_ECC_NO_BITFLIPS: + return 0; + + case STATUS_ECC_HAS_BITFLIPS: + return nand->eccreq.strength; + + default: + break; + } + + /* More than 1-bit error was detected in one or more sectors and + * cannot be corrected. + */ + return -EBADMSG; +} + +static const struct spinand_info foresee_spinand_table[] = { + SPINAND_INFO("F35SQA002G", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x72, 0x72), + NAND_MEMORG(1, 2048, 64, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(1, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&f35sqa002g_ooblayout, + f35sqa002g_ecc_get_status)), +}; + +static const struct spinand_manufacturer_ops foresee_spinand_manuf_ops = { +}; + +const struct spinand_manufacturer foresee_spinand_manufacturer = { + .id = SPINAND_MFR_FORESEE, + .name = "FORESEE", + .chips = foresee_spinand_table, + .nchips = ARRAY_SIZE(foresee_spinand_table), + .ops = &foresee_spinand_manuf_ops, +}; diff --git a/drivers/mtd/nand/spi/gigadevice.c b/drivers/mtd/nand/spi/gigadevice.c index f2ecf47f8d4..f3608a13d8e 100644 --- a/drivers/mtd/nand/spi/gigadevice.c +++ b/drivers/mtd/nand/spi/gigadevice.c @@ -43,6 +43,22 @@ static SPINAND_OP_VARIANTS(read_cache_variants_f, SPINAND_PAGE_READ_FROM_CACHE_OP_3A(true, 0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_OP_3A(false, 0, 0, NULL, 0));
+static SPINAND_OP_VARIANTS(read_cache_variants_1gq5, + SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 2, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_DUALIO_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0)); + +static SPINAND_OP_VARIANTS(read_cache_variants_2gq5, + SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 4, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_DUALIO_OP(0, 2, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0)); + static SPINAND_OP_VARIANTS(write_cache_variants, SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), SPINAND_PROG_LOAD(true, 0, NULL, 0)); @@ -174,7 +190,7 @@ static int gd5fxgq4uexxg_ecc_get_status(struct spinand_device *spinand, { u8 status2; struct spi_mem_op op = SPINAND_GET_FEATURE_OP(GD5FXGQXXEXXG_REG_STATUS2, - &status2); + spinand->scratchbuf); int ret;
switch (status & STATUS_ECC_MASK) { @@ -195,6 +211,7 @@ static int gd5fxgq4uexxg_ecc_get_status(struct spinand_device *spinand, * report the maximum of 4 in this case */ /* bits sorted this way (3...0): ECCS1,ECCS0,ECCSE1,ECCSE0 */ + status2 = *(spinand->scratchbuf); return ((status & STATUS_ECC_MASK) >> 2) | ((status2 & STATUS_ECC_MASK) >> 4);
@@ -216,7 +233,7 @@ static int gd5fxgq5xexxg_ecc_get_status(struct spinand_device *spinand, { u8 status2; struct spi_mem_op op = SPINAND_GET_FEATURE_OP(GD5FXGQXXEXXG_REG_STATUS2, - &status2); + spinand->scratchbuf); int ret;
switch (status & STATUS_ECC_MASK) { @@ -236,6 +253,7 @@ static int gd5fxgq5xexxg_ecc_get_status(struct spinand_device *spinand, * 1 ... 4 bits are flipped (and corrected) */ /* bits sorted this way (1...0): ECCSE1, ECCSE0 */ + status2 = *(spinand->scratchbuf); return ((status2 & STATUS_ECC_MASK) >> 4) + 1;
case STATUS_ECC_UNCOR_ERROR: @@ -329,6 +347,36 @@ static const struct spinand_info gigadevice_spinand_table[] = { SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F1GQ4RExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0xc1), + NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F2GQ4UExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0xd2), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F2GQ4RExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0xc2), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), SPINAND_INFO("GD5F1GQ4UFxxG", SPINAND_ID(SPINAND_READID_METHOD_OPCODE, 0xb1, 0x48), NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), @@ -343,12 +391,152 @@ static const struct spinand_info gigadevice_spinand_table[] = { SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x51), NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), NAND_ECCREQ(4, 512), - SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq5xexxg_ecc_get_status)), + SPINAND_INFO("GD5F1GQ5RExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x41), + NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq5xexxg_ecc_get_status)), + SPINAND_INFO("GD5F2GQ5UExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x52), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_2gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq5xexxg_ecc_get_status)), + SPINAND_INFO("GD5F2GQ5RExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x42), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_2gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq5xexxg_ecc_get_status)), + SPINAND_INFO("GD5F4GQ6UExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x55), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 2, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_2gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq5xexxg_ecc_get_status)), + SPINAND_INFO("GD5F4GQ6RExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x45), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 2, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_2gq5, &write_cache_variants, &update_cache_variants), SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, gd5fxgq5xexxg_ecc_get_status)), + SPINAND_INFO("GD5F1GM7UExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x91), + NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F1GM7RExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x81), + NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F2GM7UExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x92), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F2GM7RExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x82), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F4GM8UExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x95), + NAND_MEMORG(1, 2048, 128, 64, 4096, 80, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F4GM8RExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x85), + NAND_MEMORG(1, 2048, 128, 64, 4096, 80, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F2GQ5xExxH", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x22), + NAND_MEMORG(1, 2048, 64, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_2gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F1GQ5RExxH", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x21), + NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), + SPINAND_INFO("GD5F1GQ4RExxH", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xc9), + NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants_1gq5, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&gd5fxgqx_variant2_ooblayout, + gd5fxgq4uexxg_ecc_get_status)), };
static const struct spinand_manufacturer_ops gigadevice_spinand_manuf_ops = { diff --git a/drivers/mtd/nand/spi/macronix.c b/drivers/mtd/nand/spi/macronix.c index 86bffc2800b..3d4a7f0c3cb 100644 --- a/drivers/mtd/nand/spi/macronix.c +++ b/drivers/mtd/nand/spi/macronix.c @@ -23,7 +23,7 @@ static SPINAND_OP_VARIANTS(read_cache_variants,
static SPINAND_OP_VARIANTS(write_cache_variants, SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), - SPINAND_PROG_LOAD(true, 0, NULL, 0)); + SPINAND_PROG_LOAD(false, 0, NULL, 0));
static SPINAND_OP_VARIANTS(update_cache_variants, SPINAND_PROG_LOAD_X4(false, 0, NULL, 0), @@ -86,9 +86,10 @@ static int mx35lf1ge4ab_ecc_get_status(struct spinand_device *spinand, * in order to avoid forcing the wear-leveling layer to move * data around if it's not necessary. */ - if (mx35lf1ge4ab_get_eccsr(spinand, &eccsr)) + if (mx35lf1ge4ab_get_eccsr(spinand, spinand->scratchbuf)) return nand->eccreq.strength;
+ eccsr = *spinand->scratchbuf; if (WARN_ON(eccsr > nand->eccreq.strength || !eccsr)) return nand->eccreq.strength;
@@ -300,6 +301,26 @@ static const struct spinand_info macronix_spinand_table[] = { SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, mx35lf1ge4ab_ecc_get_status)),
+ SPINAND_INFO("MX31LF2GE4BC", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x2e), + NAND_MEMORG(1, 2048, 64, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, + mx35lf1ge4ab_ecc_get_status)), + SPINAND_INFO("MX3UF2GE4BC", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xae), + NAND_MEMORG(1, 2048, 64, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, + mx35lf1ge4ab_ecc_get_status)), };
static const struct spinand_manufacturer_ops macronix_spinand_manuf_ops = { diff --git a/drivers/mtd/nand/spi/toshiba.c b/drivers/mtd/nand/spi/toshiba.c index b9908e79271..ad48b1c7c8a 100644 --- a/drivers/mtd/nand/spi/toshiba.c +++ b/drivers/mtd/nand/spi/toshiba.c @@ -269,6 +269,39 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), + /* 1.8V 1Gb (1st generation) */ + SPINAND_INFO("TC58NYG0S3HBAI4", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xA1), + NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, + tx58cxgxsxraix_ecc_get_status)), + /* 1.8V 4Gb (1st generation) */ + SPINAND_INFO("TH58NYG2S3HBAI4", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xAC), + NAND_MEMORG(1, 2048, 128, 64, 4096, 80, 1, 2, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_x4_variants, + &update_cache_x4_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, + tx58cxgxsxraix_ecc_get_status)), + /* 1.8V 8Gb (1st generation) */ + SPINAND_INFO("TH58NYG3S0HBAI6", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xA3), + NAND_MEMORG(1, 4096, 256, 64, 4096, 80, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_x4_variants, + &update_cache_x4_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, + tx58cxgxsxraix_ecc_get_status)), };
static const struct spinand_manufacturer_ops toshiba_spinand_manuf_ops = { diff --git a/drivers/mtd/nand/spi/winbond.c b/drivers/mtd/nand/spi/winbond.c index dd4ed257a83..c62096dc2e6 100644 --- a/drivers/mtd/nand/spi/winbond.c +++ b/drivers/mtd/nand/spi/winbond.c @@ -18,6 +18,8 @@
#define WINBOND_CFG_BUF_READ BIT(3)
+#define W25N04KV_STATUS_ECC_5_8_BITFLIPS (3 << 4) + static SPINAND_OP_VARIANTS(read_cache_variants, SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 2, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), @@ -121,6 +123,7 @@ static int w25n02kv_ecc_get_status(struct spinand_device *spinand, return -EBADMSG;
case STATUS_ECC_HAS_BITFLIPS: + case W25N04KV_STATUS_ECC_5_8_BITFLIPS: /* * Let's try to retrieve the real maximum number of bitflips * in order to avoid forcing the wear-leveling layer to move @@ -172,6 +175,60 @@ static const struct spinand_info winbond_spinand_table[] = { &update_cache_variants), 0, SPINAND_ECCINFO(&w25n02kv_ooblayout, w25n02kv_ecc_get_status)), + SPINAND_INFO("W25N01JW", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xbc, 0x21), + NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&w25m02gv_ooblayout, w25n02kv_ecc_get_status)), + SPINAND_INFO("W25N02JWZEIF", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xbf, 0x22), + NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 2, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&w25n02kv_ooblayout, w25n02kv_ecc_get_status)), + SPINAND_INFO("W25N512GW", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xba, 0x20), + NAND_MEMORG(1, 2048, 64, 64, 512, 10, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&w25n02kv_ooblayout, w25n02kv_ecc_get_status)), + SPINAND_INFO("W25N02KWZEIR", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xba, 0x22), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&w25n02kv_ooblayout, w25n02kv_ecc_get_status)), + SPINAND_INFO("W25N01GWZEIG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xba, 0x21), + NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&w25m02gv_ooblayout, w25n02kv_ecc_get_status)), + SPINAND_INFO("W25N04KV", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xaa, 0x23), + NAND_MEMORG(1, 2048, 128, 64, 4096, 40, 2, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&w25n02kv_ooblayout, w25n02kv_ecc_get_status)), };
static int winbond_spinand_init(struct spinand_device *spinand) diff --git a/include/linux/mtd/spinand.h b/include/linux/mtd/spinand.h index b701d25f73d..81a7b0dbbb2 100644 --- a/include/linux/mtd/spinand.h +++ b/include/linux/mtd/spinand.h @@ -266,13 +266,16 @@ struct spinand_manufacturer { };
/* SPI NAND manufacturers */ +extern const struct spinand_manufacturer alliancememory_spinand_manufacturer; +extern const struct spinand_manufacturer ato_spinand_manufacturer; +extern const struct spinand_manufacturer esmt_c8_spinand_manufacturer; +extern const struct spinand_manufacturer foresee_spinand_manufacturer; extern const struct spinand_manufacturer gigadevice_spinand_manufacturer; extern const struct spinand_manufacturer macronix_spinand_manufacturer; extern const struct spinand_manufacturer micron_spinand_manufacturer; extern const struct spinand_manufacturer paragon_spinand_manufacturer; extern const struct spinand_manufacturer toshiba_spinand_manufacturer; extern const struct spinand_manufacturer winbond_spinand_manufacturer; -extern const struct spinand_manufacturer esmt_c8_spinand_manufacturer; extern const struct spinand_manufacturer xtx_spinand_manufacturer;
only spinand on_die ecc is supported for a moment
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/mtd/nand/Makefile | 2 +- drivers/mtd/nand/core.c | 130 +++++++++++++++- drivers/mtd/nand/ecc.c | 249 ++++++++++++++++++++++++++++++ drivers/mtd/nand/spi/core.c | 207 ++++++++++++++++++++----- drivers/mtd/nand/spi/foresee.c | 2 +- drivers/mtd/nand/spi/macronix.c | 7 +- drivers/mtd/nand/spi/micron.c | 2 +- drivers/mtd/nand/spi/toshiba.c | 10 +- drivers/mtd/nand/spi/winbond.c | 10 +- include/linux/mtd/nand.h | 261 ++++++++++++++++++++++++++++++-- include/linux/mtd/spinand.h | 13 +- include/spi-mem.h | 2 + 12 files changed, 830 insertions(+), 65 deletions(-) create mode 100644 drivers/mtd/nand/ecc.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 96e186600a1..56179188e92 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) -nandcore-objs := core.o bbt.o +nandcore-objs := core.o bbt.o ecc.o obj-$(CONFIG_MTD_NAND_CORE) += nandcore.o obj-$(CONFIG_MTD_RAW_NAND) += raw/ obj-$(CONFIG_MTD_SPI_NAND) += spi/ diff --git a/drivers/mtd/nand/core.c b/drivers/mtd/nand/core.c index 472ad0bdefb..6c90d576de3 100644 --- a/drivers/mtd/nand/core.c +++ b/drivers/mtd/nand/core.c @@ -129,7 +129,7 @@ EXPORT_SYMBOL_GPL(nanddev_isreserved); * * Return: 0 in case of success, a negative error code otherwise. */ -static int nanddev_erase(struct nand_device *nand, const struct nand_pos *pos) +int nanddev_erase(struct nand_device *nand, const struct nand_pos *pos) { unsigned int entry;
@@ -187,6 +187,134 @@ int nanddev_mtd_erase(struct mtd_info *mtd, struct erase_info *einfo) } EXPORT_SYMBOL_GPL(nanddev_mtd_erase);
+/** + * nanddev_get_ecc_engine() - Find and get a suitable ECC engine + * @nand: NAND device + */ +static int nanddev_get_ecc_engine(struct nand_device *nand) +{ + int engine_type; + + /* Read the user desires in terms of ECC engine/configuration */ + of_get_nand_ecc_user_config(nand); + + engine_type = nand->ecc.user_conf.engine_type; + if (engine_type == NAND_ECC_ENGINE_TYPE_INVALID) + engine_type = nand->ecc.defaults.engine_type; + + switch (engine_type) { + case NAND_ECC_ENGINE_TYPE_NONE: + return 0; + case NAND_ECC_ENGINE_TYPE_SOFT: + nand->ecc.engine = nand_ecc_get_sw_engine(nand); + break; + case NAND_ECC_ENGINE_TYPE_ON_DIE: + nand->ecc.engine = nand_ecc_get_on_die_hw_engine(nand); + break; + case NAND_ECC_ENGINE_TYPE_ON_HOST: + nand->ecc.engine = nand_ecc_get_on_host_hw_engine(nand); + if (PTR_ERR(nand->ecc.engine) == -EPROBE_DEFER) + return -EPROBE_DEFER; + break; + default: + pr_err("Missing ECC engine type\n"); + } + + if (!nand->ecc.engine) + return -EINVAL; + + return 0; +} + +/** + * nanddev_put_ecc_engine() - Dettach and put the in-use ECC engine + * @nand: NAND device + */ +static int nanddev_put_ecc_engine(struct nand_device *nand) +{ + switch (nand->ecc.ctx.conf.engine_type) { + case NAND_ECC_ENGINE_TYPE_ON_HOST: + nand_ecc_put_on_host_hw_engine(nand); + break; + case NAND_ECC_ENGINE_TYPE_NONE: + case NAND_ECC_ENGINE_TYPE_SOFT: + case NAND_ECC_ENGINE_TYPE_ON_DIE: + default: + break; + } + + return 0; +} + +/** + * nanddev_find_ecc_configuration() - Find a suitable ECC configuration + * @nand: NAND device + */ +static int nanddev_find_ecc_configuration(struct nand_device *nand) +{ + int ret; + + if (!nand->ecc.engine) + return -ENOTSUPP; + + ret = nand_ecc_init_ctx(nand); + if (ret) + return ret; + + if (!nand_ecc_is_strong_enough(nand)) + pr_warn("WARNING: %s: the ECC used on your system is too weak compared to the one required by the NAND chip\n", + nand->mtd->name); + + return 0; +} + +/** + * nanddev_ecc_engine_init() - Initialize an ECC engine for the chip + * @nand: NAND device + */ +int nanddev_ecc_engine_init(struct nand_device *nand) +{ + int ret; + + /* Look for the ECC engine to use */ + ret = nanddev_get_ecc_engine(nand); + if (ret) { + if (ret != -EPROBE_DEFER) + pr_err("No ECC engine found\n"); + + return ret; + } + + /* No ECC engine requested */ + if (!nand->ecc.engine) + return 0; + + /* Configure the engine: balance user input and chip requirements */ + ret = nanddev_find_ecc_configuration(nand); + if (ret) { + pr_err("No suitable ECC configuration\n"); + nanddev_put_ecc_engine(nand); + + return ret; + } + + return 0; +} +EXPORT_SYMBOL_GPL(nanddev_ecc_engine_init); + +/** + * nanddev_ecc_engine_cleanup() - Cleanup ECC engine initializations + * @nand: NAND device + */ +void nanddev_ecc_engine_cleanup(struct nand_device *nand) +{ + if (nand->ecc.engine) + nand_ecc_cleanup_ctx(nand); + + nanddev_put_ecc_engine(nand); +} +EXPORT_SYMBOL_GPL(nanddev_ecc_engine_cleanup); + /** * nanddev_init() - Initialize a NAND device * @nand: NAND device diff --git a/drivers/mtd/nand/ecc.c b/drivers/mtd/nand/ecc.c new file mode 100644 index 00000000000..58cbe7deaac --- /dev/null +++ b/drivers/mtd/nand/ecc.c @@ -0,0 +1,249 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Generic Error-Correcting Code (ECC) engine + * + * Copyright (C) 2019 Macronix + * Author: + * Miquèl RAYNAL miquel.raynal@bootlin.com + * + * + * This file describes the abstraction of any NAND ECC engine. It has been + * designed to fit most cases, including parallel NANDs and SPI-NANDs. + * + * There are three main situations where instantiating this ECC engine makes + * sense: + * - external: The ECC engine is outside the NAND pipeline, typically this + * is a software ECC engine, or an hardware engine that is + * outside the NAND controller pipeline. + * - pipelined: The ECC engine is inside the NAND pipeline, ie. on the + * controller's side. This is the case of most of the raw NAND + * controllers. In the pipeline case, the ECC bytes are + * generated/data corrected on the fly when a page is + * written/read. + * - ondie: The ECC engine is inside the NAND pipeline, on the chip's side. + * Some NAND chips can correct themselves the data. + * + * Besides the initial setup and final cleanups, the interfaces are rather + * simple: + * - prepare: Prepare an I/O request. Enable/disable the ECC engine based on + * the I/O request type. In case of software correction or external + * engine, this step may involve to derive the ECC bytes and place + * them in the OOB area before a write. + * - finish: Finish an I/O request. Correct the data in case of a read + * request and report the number of corrected bits/uncorrectable + * errors. Most likely empty for write operations, unless you have + * hardware specific stuff to do, like shutting down the engine to + * save power. + * + * The I/O request should be enclosed in a prepare()/finish() pair of calls + * and will behave differently depending on the requested I/O type: + * - raw: Correction disabled + * - ecc: Correction enabled + * + * The request direction is impacting the logic as well: + * - read: Load data from the NAND chip + * - write: Store data in the NAND chip + * + * Mixing all this combinations together gives the following behavior. + * Those are just examples, drivers are free to add custom steps in their + * prepare/finish hook. + * + * [external ECC engine] + * - external + prepare + raw + read: do nothing + * - external + finish + raw + read: do nothing + * - external + prepare + raw + write: do nothing + * - external + finish + raw + write: do nothing + * - external + prepare + ecc + read: do nothing + * - external + finish + ecc + read: calculate expected ECC bytes, extract + * ECC bytes from OOB buffer, correct + * and report any bitflip/error + * - external + prepare + ecc + write: calculate ECC bytes and store them at + * the right place in the OOB buffer based + * on the OOB layout + * - external + finish + ecc + write: do nothing + * + * [pipelined ECC engine] + * - pipelined + prepare + raw + read: disable the controller's ECC engine if + * activated + * - pipelined + finish + raw + read: do nothing + * - pipelined + prepare + raw + write: disable the controller's ECC engine if + * activated + * - pipelined + finish + raw + write: do nothing + * - pipelined + prepare + ecc + read: enable the controller's ECC engine if + * deactivated + * - pipelined + finish + ecc + read: check the status, report any + * error/bitflip + * - pipelined + prepare + ecc + write: enable the controller's ECC engine if + * deactivated + * - pipelined + finish + ecc + write: do nothing + * + * [ondie ECC engine] + * - ondie + prepare + raw + read: send commands to disable the on-chip ECC + * engine if activated + * - ondie + finish + raw + read: do nothing + * - ondie + prepare + raw + write: send commands to disable the on-chip ECC + * engine if activated + * - ondie + finish + raw + write: do nothing + * - ondie + prepare + ecc + read: send commands to enable the on-chip ECC + * engine if deactivated + * - ondie + finish + ecc + read: send commands to check the status, report + * any error/bitflip + * - ondie + prepare + ecc + write: send commands to enable the on-chip ECC + * engine if deactivated + * - ondie + finish + ecc + write: do nothing + */ + +#ifndef __UBOOT__ +#include <linux/module.h> +#include <linux/slab.h> +#include <linux/of.h> +#include <linux/of_device.h> +#include <linux/of_platform.h> +#endif +#include <linux/mtd/nand.h> + +/** + * nand_ecc_init_ctx - Init the ECC engine context + * @nand: the NAND device + * + * On success, the caller is responsible of calling @nand_ecc_cleanup_ctx(). + */ +int nand_ecc_init_ctx(struct nand_device *nand) +{ + if (!nand->ecc.engine || !nand->ecc.engine->ops->init_ctx) + return 0; + + return nand->ecc.engine->ops->init_ctx(nand); +} +EXPORT_SYMBOL(nand_ecc_init_ctx); + +/** + * nand_ecc_cleanup_ctx - Cleanup the ECC engine context + * @nand: the NAND device + */ +void nand_ecc_cleanup_ctx(struct nand_device *nand) +{ + if (nand->ecc.engine && nand->ecc.engine->ops->cleanup_ctx) + nand->ecc.engine->ops->cleanup_ctx(nand); +} +EXPORT_SYMBOL(nand_ecc_cleanup_ctx); + +/** + * nand_ecc_prepare_io_req - Prepare an I/O request + * @nand: the NAND device + * @req: the I/O request + */ +int nand_ecc_prepare_io_req(struct nand_device *nand, + struct nand_page_io_req *req) +{ + if (!nand->ecc.engine || !nand->ecc.engine->ops->prepare_io_req) + return 0; + + return nand->ecc.engine->ops->prepare_io_req(nand, req); +} +EXPORT_SYMBOL(nand_ecc_prepare_io_req); + +/** + * nand_ecc_finish_io_req - Finish an I/O request + * @nand: the NAND device + * @req: the I/O request + */ +int nand_ecc_finish_io_req(struct nand_device *nand, + struct nand_page_io_req *req) +{ + if (!nand->ecc.engine || !nand->ecc.engine->ops->finish_io_req) + return 0; + + return nand->ecc.engine->ops->finish_io_req(nand, req); +} +EXPORT_SYMBOL(nand_ecc_finish_io_req); + +void of_get_nand_ecc_user_config(struct nand_device *nand) +{ + nand->ecc.user_conf.engine_type = NAND_ECC_ENGINE_TYPE_ON_DIE; + nand->ecc.user_conf.algo = NAND_ECC_ALGO_UNKNOWN; + nand->ecc.user_conf.placement = NAND_ECC_PLACEMENT_UNKNOWN; +} +EXPORT_SYMBOL(of_get_nand_ecc_user_config); + +/** + * nand_ecc_is_strong_enough - Check if the chip configuration meets the + * datasheet requirements. + * + * @nand: Device to check + * + * If our configuration corrects A bits per B bytes and the minimum + * required correction level is X bits per Y bytes, then we must ensure + * both of the following are true: + * + * (1) A / B >= X / Y + * (2) A >= X + * + * Requirement (1) ensures we can correct for the required bitflip density. + * Requirement (2) ensures we can correct even when all bitflips are clumped + * in the same sector. + */ +bool nand_ecc_is_strong_enough(struct nand_device *nand) +{ + const struct nand_ecc_props *reqs = nanddev_get_ecc_requirements(nand); + const struct nand_ecc_props *conf = nanddev_get_ecc_conf(nand); + struct mtd_info *mtd = nanddev_to_mtd(nand); + int corr, ds_corr; + + if (conf->step_size == 0 || reqs->step_size == 0) + /* Not enough information */ + return true; + + /* + * We get the number of corrected bits per page to compare + * the correction density. + */ + corr = (mtd->writesize * conf->strength) / conf->step_size; + ds_corr = (mtd->writesize * reqs->strength) / reqs->step_size; + + return corr >= ds_corr && conf->strength >= reqs->strength; +} +EXPORT_SYMBOL(nand_ecc_is_strong_enough); + +struct nand_ecc_engine *nand_ecc_get_sw_engine(struct nand_device *nand) +{ + unsigned int algo = nand->ecc.user_conf.algo; + + if (algo == NAND_ECC_ALGO_UNKNOWN) + algo = nand->ecc.defaults.algo; + + switch (algo) { + case NAND_ECC_ALGO_HAMMING: + return nand_ecc_sw_hamming_get_engine(); + case NAND_ECC_ALGO_BCH: + return nand_ecc_sw_bch_get_engine(); + default: + break; + } + + return NULL; +} +EXPORT_SYMBOL(nand_ecc_get_sw_engine); + +struct nand_ecc_engine *nand_ecc_get_on_die_hw_engine(struct nand_device *nand) +{ + return nand->ecc.ondie_engine; +} +EXPORT_SYMBOL(nand_ecc_get_on_die_hw_engine); + +struct nand_ecc_engine *nand_ecc_get_on_host_hw_engine(struct nand_device *nand) +{ + return NULL; +} +EXPORT_SYMBOL(nand_ecc_get_on_host_hw_engine); + +void nand_ecc_put_on_host_hw_engine(struct nand_device *nand) +{ +} +EXPORT_SYMBOL(nand_ecc_put_on_host_hw_engine); + +#ifndef __UBOOT__ +MODULE_LICENSE("GPL"); +MODULE_AUTHOR("Miquel Raynal miquel.raynal@bootlin.com"); +MODULE_DESCRIPTION("Generic ECC engine"); +#endif /* __UBOOT__ */ diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index d5cb9026246..70f07be06b0 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -239,7 +239,7 @@ static int spinand_check_ecc_status(struct spinand_device *spinand, u8 status) * fixed, so let's return the maximum possible value so that * wear-leveling layers move the data immediately. */ - return nand->eccreq.strength; + return nanddev_get_ecc_conf(nand)->strength;
case STATUS_ECC_UNCOR_ERROR: return -EBADMSG; @@ -275,6 +275,92 @@ static const struct mtd_ooblayout_ops spinand_noecc_ooblayout = { .rfree = spinand_noecc_ooblayout_free, };
+static int spinand_ondie_ecc_init_ctx(struct nand_device *nand) +{ + struct spinand_device *spinand = nand_to_spinand(nand); + struct mtd_info *mtd = nanddev_to_mtd(nand); + struct spinand_ondie_ecc_conf *engine_conf; + + nand->ecc.ctx.conf.engine_type = NAND_ECC_ENGINE_TYPE_ON_DIE; + nand->ecc.ctx.conf.step_size = nand->ecc.requirements.step_size; + nand->ecc.ctx.conf.strength = nand->ecc.requirements.strength; + + engine_conf = kzalloc(sizeof(*engine_conf), GFP_KERNEL); + if (!engine_conf) + return -ENOMEM; + + nand->ecc.ctx.priv = engine_conf; + + if (spinand->eccinfo.ooblayout) + mtd_set_ooblayout(mtd, spinand->eccinfo.ooblayout); + else + mtd_set_ooblayout(mtd, &spinand_noecc_ooblayout); + + return 0; +} + +static void spinand_ondie_ecc_cleanup_ctx(struct nand_device *nand) +{ + kfree(nand->ecc.ctx.priv); +} + +static int spinand_ondie_ecc_prepare_io_req(struct nand_device *nand, + struct nand_page_io_req *req) +{ + struct spinand_device *spinand = nand_to_spinand(nand); + bool enable = (req->mode != MTD_OPS_RAW); + + memset(spinand->oobbuf, 0xff, nanddev_per_page_oobsize(nand)); + + /* Only enable or disable the engine */ + return spinand_ecc_enable(spinand, enable); +} + +static int spinand_ondie_ecc_finish_io_req(struct nand_device *nand, + struct nand_page_io_req *req) +{ + struct spinand_ondie_ecc_conf *engine_conf = nand->ecc.ctx.priv; + struct spinand_device *spinand = nand_to_spinand(nand); + struct mtd_info *mtd = spinand_to_mtd(spinand); + int ret; + + if (req->mode == MTD_OPS_RAW) + return 0; + + /* Nothing to do when finishing a page write */ + if (req->type == NAND_PAGE_WRITE) + return 0; + + /* Finish a page read: check the status, report errors/bitflips */ + ret = spinand_check_ecc_status(spinand, engine_conf->status); + if (ret == -EBADMSG) + mtd->ecc_stats.failed++; + else if (ret > 0) + mtd->ecc_stats.corrected += ret; + + return ret; +} + +static struct nand_ecc_engine_ops spinand_ondie_ecc_engine_ops = { + .init_ctx = spinand_ondie_ecc_init_ctx, + .cleanup_ctx = spinand_ondie_ecc_cleanup_ctx, + .prepare_io_req = spinand_ondie_ecc_prepare_io_req, + .finish_io_req = spinand_ondie_ecc_finish_io_req, +}; + +static struct nand_ecc_engine spinand_ondie_ecc_engine = { + .ops = &spinand_ondie_ecc_engine_ops, +}; + +static void spinand_ondie_ecc_save_status(struct nand_device *nand, u8 status) +{ + struct spinand_ondie_ecc_conf *engine_conf = nand->ecc.ctx.priv; + + if (nand->ecc.ctx.conf.engine_type == NAND_ECC_ENGINE_TYPE_ON_DIE && + engine_conf) + engine_conf->status = status; +} + static int spinand_write_enable_op(struct spinand_device *spinand) { struct spi_mem_op op = SPINAND_WR_EN_DIS_OP(true); @@ -317,7 +403,10 @@ static int spinand_read_from_cache_op(struct spinand_device *spinand, } }
- rdesc = spinand->dirmaps[req->pos.plane].rdesc; + if (req->mode == MTD_OPS_RAW) + rdesc = spinand->dirmaps[req->pos.plane].rdesc; + else + rdesc = spinand->dirmaps[req->pos.plane].rdesc_ecc;
while (nbytes) { ret = spi_mem_dirmap_read(rdesc, column, nbytes, buf); @@ -366,9 +455,12 @@ static int spinand_write_to_cache_op(struct spinand_device *spinand, * must fill the page cache entirely even if we only want to program * the data portion of the page, otherwise we might corrupt the BBM or * user data previously programmed in OOB area. + * + * Only reset the data buffer manually, the OOB buffer is prepared by + * ECC engines ->prepare_io_req() callback. */ nbytes = nanddev_page_size(nand) + nanddev_per_page_oobsize(nand); - memset(spinand->databuf, 0xff, nbytes); + memset(spinand->databuf, 0xff, nanddev_page_size(nand));
if (req->datalen) memcpy(spinand->databuf + req->dataoffs, req->databuf.out, @@ -385,7 +477,10 @@ static int spinand_write_to_cache_op(struct spinand_device *spinand, req->ooblen); }
- wdesc = spinand->dirmaps[req->pos.plane].wdesc; + if (req->mode == MTD_OPS_RAW) + wdesc = spinand->dirmaps[req->pos.plane].wdesc; + else + wdesc = spinand->dirmaps[req->pos.plane].wdesc_ecc;
while (nbytes) { ret = spi_mem_dirmap_write(wdesc, column, nbytes, buf); @@ -498,12 +593,16 @@ static int spinand_lock_block(struct spinand_device *spinand, u8 lock) }
static int spinand_read_page(struct spinand_device *spinand, - const struct nand_page_io_req *req, - bool ecc_enabled) + const struct nand_page_io_req *req) { + struct nand_device *nand = spinand_to_nand(spinand); u8 status; int ret;
+ ret = nand_ecc_prepare_io_req(nand, (struct nand_page_io_req *)req); + if (ret) + return ret; + ret = spinand_load_page_op(spinand, req); if (ret) return ret; @@ -515,22 +614,26 @@ static int spinand_read_page(struct spinand_device *spinand, if (ret < 0) return ret;
+ spinand_ondie_ecc_save_status(nand, status); + ret = spinand_read_from_cache_op(spinand, req); if (ret) return ret;
- if (!ecc_enabled) - return 0; - - return spinand_check_ecc_status(spinand, status); + return nand_ecc_finish_io_req(nand, (struct nand_page_io_req *)req); }
static int spinand_write_page(struct spinand_device *spinand, const struct nand_page_io_req *req) { + struct nand_device *nand = spinand_to_nand(spinand); u8 status; int ret;
+ ret = nand_ecc_prepare_io_req(nand, (struct nand_page_io_req *)req); + if (ret) + return ret; + ret = spinand_write_enable_op(spinand); if (ret) return ret; @@ -550,7 +653,7 @@ static int spinand_write_page(struct spinand_device *spinand, if (!ret && (status & STATUS_PROG_FAILED)) return -EIO;
- return ret; + return nand_ecc_finish_io_req(nand, (struct nand_page_io_req *)req); }
static int spinand_mtd_read(struct mtd_info *mtd, loff_t from, @@ -580,21 +683,14 @@ static int spinand_mtd_read(struct mtd_info *mtd, loff_t from, if (ret) break;
- ret = spinand_ecc_enable(spinand, !disable_ecc); - if (ret) - break; - - ret = spinand_read_page(spinand, &iter.req, !disable_ecc); + ret = spinand_read_page(spinand, &iter.req); if (ret < 0 && ret != -EBADMSG) break;
- if (ret == -EBADMSG) { + if (ret == -EBADMSG) ecc_failed = true; - mtd->ecc_stats.failed++; - } else { - mtd->ecc_stats.corrected += ret; + else max_bitflips = max_t(unsigned int, max_bitflips, ret); - }
ret = 0; ops->retlen += iter.req.datalen; @@ -635,10 +731,6 @@ static int spinand_mtd_write(struct mtd_info *mtd, loff_t to, if (ret) break;
- ret = spinand_ecc_enable(spinand, !disable_ecc); - if (ret) - break; - ret = spinand_write_page(spinand, &iter.req); if (ret) break; @@ -667,7 +759,7 @@ static bool spinand_isbad(struct nand_device *nand, const struct nand_pos *pos) };
spinand_select_target(spinand, pos->target); - spinand_read_page(spinand, &req, false); + spinand_read_page(spinand, &req); if (marker[0] != 0xff || marker[1] != 0xff) return true;
@@ -835,6 +927,36 @@ static int spinand_create_dirmap(struct spinand_device *spinand,
spinand->dirmaps[plane].rdesc = desc;
+ if (nand->ecc.engine->integration != NAND_ECC_ENGINE_INTEGRATION_PIPELINED) { + spinand->dirmaps[plane].wdesc_ecc = spinand->dirmaps[plane].wdesc; + spinand->dirmaps[plane].rdesc_ecc = spinand->dirmaps[plane].rdesc; + + return 0; + } + + info.op_tmpl = *spinand->op_templates.update_cache; + info.op_tmpl.data.ecc = true; + desc = spi_mem_dirmap_create(spinand->slave, &info); + if (IS_ERR(desc)) { + spi_mem_dirmap_destroy(spinand->dirmaps[plane].wdesc); + spi_mem_dirmap_destroy(spinand->dirmaps[plane].rdesc); + return PTR_ERR(desc); + } + + spinand->dirmaps[plane].wdesc_ecc = desc; + + info.op_tmpl = *spinand->op_templates.read_cache; + info.op_tmpl.data.ecc = true; + desc = spi_mem_dirmap_create(spinand->slave, &info); + if (IS_ERR(desc)) { + spi_mem_dirmap_destroy(spinand->dirmaps[plane].wdesc); + spi_mem_dirmap_destroy(spinand->dirmaps[plane].rdesc); + spi_mem_dirmap_destroy(spinand->dirmaps[plane].wdesc_ecc); + return PTR_ERR(desc); + } + + spinand->dirmaps[plane].rdesc_ecc = desc; + return 0; }
@@ -1019,7 +1141,7 @@ int spinand_match_and_init(struct spinand_device *spinand, continue;
nand->memorg = table[i].memorg; - nand->eccreq = table[i].eccreq; + nanddev_set_ecc_requirements(nand, &table[i].eccreq); spinand->eccinfo = table[i].eccinfo; spinand->flags = table[i].flags; spinand->id.len = 1 + table[i].devid.len; @@ -1171,6 +1293,15 @@ static int spinand_init(struct spinand_device *spinand) if (ret) goto err_manuf_cleanup;
+ /* SPI-NAND default ECC engine is on-die */ + nand->ecc.defaults.engine_type = NAND_ECC_ENGINE_TYPE_ON_DIE; + nand->ecc.ondie_engine = &spinand_ondie_ecc_engine; + + spinand_ecc_enable(spinand, false); + ret = nanddev_ecc_engine_init(nand); + if (ret) + goto err_cleanup_nanddev; + mtd->_read_oob = spinand_mtd_read; mtd->_write_oob = spinand_mtd_write; mtd->_block_isbad = spinand_mtd_block_isbad; @@ -1178,27 +1309,31 @@ static int spinand_init(struct spinand_device *spinand) mtd->_block_isreserved = spinand_mtd_block_isreserved; mtd->_erase = spinand_mtd_erase;
- if (spinand->eccinfo.ooblayout) - mtd_set_ooblayout(mtd, spinand->eccinfo.ooblayout); - else - mtd_set_ooblayout(mtd, &spinand_noecc_ooblayout); - - ret = mtd_ooblayout_count_freebytes(mtd); - if (ret < 0) - goto err_cleanup_nanddev; + if (nand->ecc.engine) { + ret = mtd_ooblayout_count_freebytes(mtd); + if (ret < 0) + goto err_cleanup_ecc_engine; + }
+ /* Propagate ECC information to mtd_info */ + mtd->ecc_strength = nanddev_get_ecc_conf(nand)->strength; + mtd->ecc_step_size = nanddev_get_ecc_conf(nand)->step_size; + ret = spinand_create_dirmaps(spinand); if (ret) { dev_err(dev, "Failed to create direct mappings for read/write operations (err = %d)\n", ret); - goto err_cleanup_nanddev; + goto err_cleanup_ecc_engine; }
+err_cleanup_ecc_engine: + nanddev_ecc_engine_cleanup(nand); + err_cleanup_nanddev: nanddev_cleanup(nand);
diff --git a/drivers/mtd/nand/spi/foresee.c b/drivers/mtd/nand/spi/foresee.c index 7d141cdd658..6229c959b2c 100644 --- a/drivers/mtd/nand/spi/foresee.c +++ b/drivers/mtd/nand/spi/foresee.c @@ -60,7 +60,7 @@ static int f35sqa002g_ecc_get_status(struct spinand_device *spinand, u8 status) return 0;
case STATUS_ECC_HAS_BITFLIPS: - return nand->eccreq.strength; + return nanddev_get_ecc_conf(nand)->strength;
default: break; diff --git a/drivers/mtd/nand/spi/macronix.c b/drivers/mtd/nand/spi/macronix.c index 3d4a7f0c3cb..c2a7aa2da96 100644 --- a/drivers/mtd/nand/spi/macronix.c +++ b/drivers/mtd/nand/spi/macronix.c @@ -87,11 +87,12 @@ static int mx35lf1ge4ab_ecc_get_status(struct spinand_device *spinand, * data around if it's not necessary. */ if (mx35lf1ge4ab_get_eccsr(spinand, spinand->scratchbuf)) - return nand->eccreq.strength; + return nanddev_get_ecc_conf(nand)->strength;
eccsr = *spinand->scratchbuf; - if (WARN_ON(eccsr > nand->eccreq.strength || !eccsr)) - return nand->eccreq.strength; + if (WARN_ON(eccsr > nanddev_get_ecc_conf(nand)->strength || + !eccsr)) + return nanddev_get_ecc_conf(nand)->strength;
return eccsr;
diff --git a/drivers/mtd/nand/spi/micron.c b/drivers/mtd/nand/spi/micron.c index b538213ed8e..01c177facfb 100644 --- a/drivers/mtd/nand/spi/micron.c +++ b/drivers/mtd/nand/spi/micron.c @@ -14,7 +14,7 @@
#define SPINAND_MFR_MICRON 0x2c
-#define MICRON_STATUS_ECC_MASK GENMASK(7, 4) +#define MICRON_STATUS_ECC_MASK GENMASK(6, 4) #define MICRON_STATUS_ECC_NO_BITFLIPS (0 << 4) #define MICRON_STATUS_ECC_1TO3_BITFLIPS (1 << 4) #define MICRON_STATUS_ECC_4TO6_BITFLIPS (3 << 4) diff --git a/drivers/mtd/nand/spi/toshiba.c b/drivers/mtd/nand/spi/toshiba.c index ad48b1c7c8a..bf7da57de13 100644 --- a/drivers/mtd/nand/spi/toshiba.c +++ b/drivers/mtd/nand/spi/toshiba.c @@ -76,7 +76,7 @@ static int tx58cxgxsxraix_ecc_get_status(struct spinand_device *spinand, { struct nand_device *nand = spinand_to_nand(spinand); u8 mbf = 0; - struct spi_mem_op op = SPINAND_GET_FEATURE_OP(0x30, &mbf); + struct spi_mem_op op = SPINAND_GET_FEATURE_OP(0x30, spinand->scratchbuf);
switch (status & STATUS_ECC_MASK) { case STATUS_ECC_NO_BITFLIPS: @@ -93,12 +93,12 @@ static int tx58cxgxsxraix_ecc_get_status(struct spinand_device *spinand, * data around if it's not necessary. */ if (spi_mem_exec_op(spinand->slave, &op)) - return nand->eccreq.strength; + return nanddev_get_ecc_conf(nand)->strength;
- mbf >>= 4; + mbf = *(spinand->scratchbuf) >> 4;
- if (WARN_ON(mbf > nand->eccreq.strength || !mbf)) - return nand->eccreq.strength; + if (WARN_ON(mbf > nanddev_get_ecc_conf(nand)->strength || !mbf)) + return nanddev_get_ecc_conf(nand)->strength;
return mbf;
diff --git a/drivers/mtd/nand/spi/winbond.c b/drivers/mtd/nand/spi/winbond.c index c62096dc2e6..d7dc1c86494 100644 --- a/drivers/mtd/nand/spi/winbond.c +++ b/drivers/mtd/nand/spi/winbond.c @@ -113,7 +113,7 @@ static int w25n02kv_ecc_get_status(struct spinand_device *spinand, { struct nand_device *nand = spinand_to_nand(spinand); u8 mbf = 0; - struct spi_mem_op op = SPINAND_GET_FEATURE_OP(0x30, &mbf); + struct spi_mem_op op = SPINAND_GET_FEATURE_OP(0x30, spinand->scratchbuf);
switch (status & STATUS_ECC_MASK) { case STATUS_ECC_NO_BITFLIPS: @@ -130,12 +130,12 @@ static int w25n02kv_ecc_get_status(struct spinand_device *spinand, * data around if it's not necessary. */ if (spi_mem_exec_op(spinand->slave, &op)) - return nand->eccreq.strength; + return nanddev_get_ecc_conf(nand)->strength;
return mbf;
diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 0afdaed5715..18b9cf276ac 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -12,6 +12,8 @@
#include <linux/mtd/mtd.h>
+struct nand_device; + /** * struct nand_memory_organization - Memory organization structure * @bits_per_cell: number of bits per NAND cell @@ -126,17 +128,72 @@ struct nand_page_io_req { };
/** - * struct nand_ecc_req - NAND ECC requirements + * enum nand_ecc_engine_type - NAND ECC engine type + * @NAND_ECC_ENGINE_TYPE_INVALID: Invalid value + * @NAND_ECC_ENGINE_TYPE_NONE: No ECC correction + * @NAND_ECC_ENGINE_TYPE_SOFT: Software ECC correction + * @NAND_ECC_ENGINE_TYPE_ON_HOST: On host hardware ECC correction + * @NAND_ECC_ENGINE_TYPE_ON_DIE: On chip hardware ECC correction + */ +enum nand_ecc_engine_type { + NAND_ECC_ENGINE_TYPE_INVALID, + NAND_ECC_ENGINE_TYPE_NONE, + NAND_ECC_ENGINE_TYPE_SOFT, + NAND_ECC_ENGINE_TYPE_ON_HOST, + NAND_ECC_ENGINE_TYPE_ON_DIE, +}; + +/** + * enum nand_ecc_placement - NAND ECC bytes placement + * @NAND_ECC_PLACEMENT_UNKNOWN: The actual position of the ECC bytes is unknown + * @NAND_ECC_PLACEMENT_OOB: The ECC bytes are located in the OOB area + * @NAND_ECC_PLACEMENT_INTERLEAVED: Syndrome layout, there are ECC bytes + * interleaved with regular data in the main + * area + */ +enum nand_ecc_placement { + NAND_ECC_PLACEMENT_UNKNOWN, + NAND_ECC_PLACEMENT_OOB, + NAND_ECC_PLACEMENT_INTERLEAVED, +}; + +/** + * enum nand_ecc_algo - NAND ECC algorithm + * @NAND_ECC_ALGO_UNKNOWN: Unknown algorithm + * @NAND_ECC_ALGO_HAMMING: Hamming algorithm + * @NAND_ECC_ALGO_BCH: Bose-Chaudhuri-Hocquenghem algorithm + * @NAND_ECC_ALGO_RS: Reed-Solomon algorithm + */ +enum nand_ecc_algo { + NAND_ECC_ALGO_UNKNOWN, + NAND_ECC_ALGO_HAMMING, + NAND_ECC_ALGO_BCH, + NAND_ECC_ALGO_RS, +}; + +/** + * struct nand_ecc_props - NAND ECC properties + * @engine_type: ECC engine type + * @placement: OOB placement (if relevant) + * @algo: ECC algorithm (if relevant) * @strength: ECC strength - * @step_size: ECC step/block size + * @step_size: Number of bytes per step + * @flags: Misc properties */ -struct nand_ecc_req { +struct nand_ecc_props { + enum nand_ecc_engine_type engine_type; + enum nand_ecc_placement placement; + enum nand_ecc_algo algo; unsigned int strength; unsigned int step_size; + unsigned int flags; };
#define NAND_ECCREQ(str, stp) { .strength = (str), .step_size = (stp) }
+/* NAND ECC misc flags */ +#define NAND_ECC_MAXIMIZE_STRENGTH BIT(0) + /** * struct nand_bbt - bad block table object * @cache: in memory BBT cache @@ -145,8 +202,6 @@ struct nand_bbt { unsigned long *cache; };
-struct nand_device; - /** * struct nand_ops - NAND operations * @erase: erase a specific block. No need to check if the block is bad before @@ -169,11 +224,130 @@ struct nand_ops { bool (*isbad)(struct nand_device *nand, const struct nand_pos *pos); };
+/** + * struct nand_ecc_context - Context for the ECC engine + * @conf: basic ECC engine parameters + * @nsteps: number of ECC steps + * @total: total number of bytes used for storing ECC codes, this is used by + * generic OOB layouts + * @priv: ECC engine driver private data + */ +struct nand_ecc_context { + struct nand_ecc_props conf; + unsigned int nsteps; + unsigned int total; + void *priv; +}; + +/** + * struct nand_ecc_engine_ops - ECC engine operations + * @init_ctx: given a desired user configuration for the pointed NAND device, + * requests the ECC engine driver to setup a configuration with + * values it supports. + * @cleanup_ctx: clean the context initialized by @init_ctx. + * @prepare_io_req: is called before reading/writing a page to prepare the I/O + * request to be performed with ECC correction. + * @finish_io_req: is called after reading/writing a page to terminate the I/O + * request and ensure proper ECC correction. + */ +struct nand_ecc_engine_ops { + int (*init_ctx)(struct nand_device *nand); + void (*cleanup_ctx)(struct nand_device *nand); + int (*prepare_io_req)(struct nand_device *nand, + struct nand_page_io_req *req); + int (*finish_io_req)(struct nand_device *nand, + struct nand_page_io_req *req); +}; + +/** + * enum nand_ecc_engine_integration - How the NAND ECC engine is integrated + * @NAND_ECC_ENGINE_INTEGRATION_INVALID: Invalid value + * @NAND_ECC_ENGINE_INTEGRATION_PIPELINED: Pipelined engine, performs on-the-fly + * correction, does not need to copy + * data around + * @NAND_ECC_ENGINE_INTEGRATION_EXTERNAL: External engine, needs to bring the + * data into its own area before use + */ +enum nand_ecc_engine_integration { + NAND_ECC_ENGINE_INTEGRATION_INVALID, + NAND_ECC_ENGINE_INTEGRATION_PIPELINED, + NAND_ECC_ENGINE_INTEGRATION_EXTERNAL, +}; + +/** + * struct nand_ecc_engine - ECC engine abstraction for NAND devices + * @dev: Host device + * @node: Private field for registration time + * @ops: ECC engine operations + * @integration: How the engine is integrated with the host + * (only relevant on %NAND_ECC_ENGINE_TYPE_ON_HOST engines) + * @priv: Private data + */ +struct nand_ecc_engine { + struct device *dev; + struct list_head node; + struct nand_ecc_engine_ops *ops; + enum nand_ecc_engine_integration integration; + void *priv; +}; + +void of_get_nand_ecc_user_config(struct nand_device *nand); +int nand_ecc_init_ctx(struct nand_device *nand); +void nand_ecc_cleanup_ctx(struct nand_device *nand); +int nand_ecc_prepare_io_req(struct nand_device *nand, + struct nand_page_io_req *req); +int nand_ecc_finish_io_req(struct nand_device *nand, + struct nand_page_io_req *req); +bool nand_ecc_is_strong_enough(struct nand_device *nand); + +struct nand_ecc_engine *nand_ecc_get_sw_engine(struct nand_device *nand); +struct nand_ecc_engine *nand_ecc_get_on_die_hw_engine(struct nand_device *nand); +struct nand_ecc_engine *nand_ecc_get_on_host_hw_engine(struct nand_device *nand); +void nand_ecc_put_on_host_hw_engine(struct nand_device *nand); +struct device *nand_ecc_get_engine_dev(struct device *host); + +#if defined(CONFIG_MTD_NAND_ECC_SW_HAMMING) +struct nand_ecc_engine *nand_ecc_sw_hamming_get_engine(void); +#else +static inline struct nand_ecc_engine *nand_ecc_sw_hamming_get_engine(void) +{ + return NULL; +} +#endif + +#if defined(CONFIG_MTD_NAND_ECC_SW_BCH) +struct nand_ecc_engine *nand_ecc_sw_bch_get_engine(void); +#else +static inline struct nand_ecc_engine *nand_ecc_sw_bch_get_engine(void) +{ + return NULL; +} +#endif + +/** + * struct nand_ecc - Information relative to the ECC + * @defaults: Default values, depend on the underlying subsystem + * @requirements: ECC requirements from the NAND chip perspective + * @user_conf: User desires in terms of ECC parameters + * @ctx: ECC context for the ECC engine, derived from the device @requirements + * the @user_conf and the @defaults + * @ondie_engine: On-die ECC engine reference, if any + * @engine: ECC engine actually bound + */ +struct nand_ecc { + struct nand_ecc_props defaults; + struct nand_ecc_props requirements; + struct nand_ecc_props user_conf; + struct nand_ecc_context ctx; + struct nand_ecc_engine *ondie_engine; + struct nand_ecc_engine *engine; +}; + /** * struct nand_device - NAND device * @mtd: MTD instance attached to the NAND device * @memorg: memory layout - * @eccreq: ECC requirements + * @ecc: NAND ECC object attached to the NAND device * @rowconv: position to row address converter * @bbt: bad block table info * @ops: NAND operations attached to the NAND device @@ -181,8 +355,8 @@ struct nand_ops { * Generic NAND object. Specialized NAND layers (raw NAND, SPI NAND, OneNAND) * should declare their own NAND object embedding a nand_device struct (that's * how inheritance is done). - * struct_nand_device->memorg and struct_nand_device->eccreq should be filled - * at device detection time to reflect the NAND device + * struct_nand_device->memorg and struct_nand_device->ecc.requirements should + * be filled at device detection time to reflect the NAND device * capabilities/requirements. Once this is done nanddev_init() can be called. * It will take care of converting NAND information into MTD ones, which means * the specialized NAND layers should never manually tweak @@ -191,7 +365,7 @@ struct nand_ops { struct nand_device { struct mtd_info *mtd; struct nand_memory_organization memorg; - struct nand_ecc_req eccreq; + struct nand_ecc ecc; struct nand_row_converter rowconv; struct nand_bbt bbt; const struct nand_ops *ops; @@ -332,7 +506,7 @@ static inline unsigned int nanddev_ntargets(const struct nand_device *nand) }
/** - * nanddev_neraseblocks() - Get the total number of erasablocks + * nanddev_neraseblocks() - Get the total number of eraseblocks * @nand: NAND device * * Return: the total number of eraseblocks exposed by @nand. @@ -370,6 +544,60 @@ nanddev_get_memorg(struct nand_device *nand) return &nand->memorg; }
+/** + * nanddev_get_ecc_conf() - Extract the ECC configuration from a NAND device + * @nand: NAND device + */ +static inline const struct nand_ecc_props * +nanddev_get_ecc_conf(struct nand_device *nand) +{ + return &nand->ecc.ctx.conf; +} + +/** + * nanddev_get_ecc_nsteps() - Extract the number of ECC steps + * @nand: NAND device + */ +static inline unsigned int +nanddev_get_ecc_nsteps(struct nand_device *nand) +{ + return nand->ecc.ctx.nsteps; +} + +/** + * nanddev_get_ecc_bytes_per_step() - Extract the number of ECC bytes per step + * @nand: NAND device + */ +static inline unsigned int +nanddev_get_ecc_bytes_per_step(struct nand_device *nand) +{ + return nand->ecc.ctx.total / nand->ecc.ctx.nsteps; +} + +/** + * nanddev_get_ecc_requirements() - Extract the ECC requirements from a NAND + * device + * @nand: NAND device + */ +static inline const struct nand_ecc_props * +nanddev_get_ecc_requirements(struct nand_device *nand) +{ + return &nand->ecc.requirements; +} + +/** + * nanddev_set_ecc_requirements() - Assign the ECC requirements of a NAND + * device + * @nand: NAND device + * @reqs: Requirements + */ +static inline void +nanddev_set_ecc_requirements(struct nand_device *nand, + const struct nand_ecc_props *reqs) +{ + nand->ecc.requirements = *reqs; +} + int nanddev_init(struct nand_device *nand, const struct nand_ops *ops, struct module *owner); void nanddev_cleanup(struct nand_device *nand); @@ -598,7 +826,7 @@ static inline void nanddev_pos_next_eraseblock(struct nand_device *nand, }
/** - * nanddev_pos_next_eraseblock() - Move a position to the next page + * nanddev_pos_next_page() - Move a position to the next page * @nand: NAND device * @pos: the position to update * @@ -708,8 +936,18 @@ static inline bool nanddev_io_iter_end(struct nand_device *nand,
bool nanddev_isbad(struct nand_device *nand, const struct nand_pos *pos); bool nanddev_isreserved(struct nand_device *nand, const struct nand_pos *pos); +int nanddev_erase(struct nand_device *nand, const struct nand_pos *pos); int nanddev_markbad(struct nand_device *nand, const struct nand_pos *pos);
+/* ECC related functions */ +int nanddev_ecc_engine_init(struct nand_device *nand); +void nanddev_ecc_engine_cleanup(struct nand_device *nand); + +static inline void *nand_to_ecc_ctx(struct nand_device *nand) +{ + return nand->ecc.ctx.priv; +} + /* BBT related functions */ enum nand_bbt_block_status { NAND_BBT_BLOCK_STATUS_UNKNOWN, @@ -760,5 +998,6 @@ static inline bool nanddev_bbt_is_initialized(struct nand_device *nand)
/* MTD -> NAND helper functions. */ int nanddev_mtd_erase(struct mtd_info *mtd, struct erase_info *einfo); +int nanddev_mtd_max_bad_blocks(struct mtd_info *mtd, loff_t offs, size_t len);
#endif /* __LINUX_MTD_NAND_H */ diff --git a/include/linux/mtd/spinand.h b/include/linux/mtd/spinand.h index 81a7b0dbbb2..3bcdbffc34a 100644 --- a/include/linux/mtd/spinand.h +++ b/include/linux/mtd/spinand.h @@ -319,6 +319,15 @@ struct spinand_ecc_info { #define SPINAND_HAS_QE_BIT BIT(0) #define SPINAND_HAS_CR_FEAT_BIT BIT(1)
+/** + * struct spinand_ondie_ecc_conf - private SPI-NAND on-die ECC engine structure + * @status: status of the last wait operation that will be used in case + * ->get_status() is not populated by the spinand device. + */ +struct spinand_ondie_ecc_conf { + u8 status; +}; + /** * struct spinand_info - Structure used to describe SPI NAND chips * @model: model name @@ -342,7 +351,7 @@ struct spinand_info { struct spinand_devid devid; u32 flags; struct nand_memory_organization memorg; - struct nand_ecc_req eccreq; + struct nand_ecc_props eccreq; struct spinand_ecc_info eccinfo; struct { const struct spinand_op_variants *read_cache; @@ -391,6 +400,8 @@ struct spinand_info { struct spinand_dirmap { struct spi_mem_dirmap_desc *wdesc; struct spi_mem_dirmap_desc *rdesc; + struct spi_mem_dirmap_desc *wdesc_ecc; + struct spi_mem_dirmap_desc *rdesc_ecc; };
/** diff --git a/include/spi-mem.h b/include/spi-mem.h index 3c8e95b6f53..82dbe21fd5a 100644 --- a/include/spi-mem.h +++ b/include/spi-mem.h @@ -91,6 +91,7 @@ enum spi_mem_data_dir { * @dummy.dtr: whether the dummy bytes should be sent in DTR mode or not * @data.buswidth: number of IO lanes used to send/receive the data * @data.dtr: whether the data should be sent in DTR mode or not + * @data.ecc: whether error correction is required or not * @data.dir: direction of the transfer * @data.buf.in: input buffer * @data.buf.out: output buffer @@ -119,6 +120,7 @@ struct spi_mem_op { struct { u8 buswidth; u8 dtr : 1; + u8 ecc : 1; enum spi_mem_data_dir dir; unsigned int nbytes; /* buf.{in,out} must be DMA-able. */
Mikhail Kshevetskiy
