[PATCH] lib: strto: Fix parsing MTD partition size
Commit 0486497e2b5f ("lib: Improve _parse_integer_fixup_radix base 16 detection") broke parsing MTD partition sizes specified in decimal base.
E.g. "128k(bootloader)" is parsed by drivers/mtd/mtdpart.c as hexadecimal number (0x128 << 10) because character 'a' in substring "bootloader" caused parsing whole number as hexadecimal.
This patch stop doing hexadecimal base heuristic on first non-valid hexadecimal number, so "128k(bootloader)" is parsed as decimal number 128.
Fixes: 0486497e2b5f ("lib: Improve _parse_integer_fixup_radix base 16...") Signed-off-by: Pali Rohár pali@kernel.org --- lib/strto.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/lib/strto.c b/lib/strto.c index 1ac2b09c72..060b66b915 100644 --- a/lib/strto.c +++ b/lib/strto.c @@ -30,6 +30,9 @@ static const char *_parse_integer_fixup_radix(const char *s, unsigned int *base)
do { var = tolower(s[i++]); + if (!(var >= '0' && var <= '9') && + !(var >= 'a' && var <= 'f')) + break; if (var >= 'a' && var <= 'f') { *base = 16; break;
-- 2.20.1
CC Tom, this problem was detected by my in-progress Travis Nokia N900 test which tries to boot kernel from the OneNAND. Build log is there: https://travis-ci.org/github/u-boot/u-boot/jobs/679007310
-- 2.20.1
This is the same as: http://patchwork.ozlabs.org/project/uboot/patch/1a681dbefac4c353ad53d7f6cd1a... yes? Thanks!
-- 2.20.1
Yes, this is the same problem.
-- 2.20.1
Can you please test (and Tested-by) that one? Thanks!
-- 2.20.1
It is basically same patch as mine... but ok I'm going to run that my automated Nokia N900 test locally with above patch.
-- 2.20.1
That patch is working fine, you can add my Tested-by: Pali Rohár pali@kernel.org for it
Pali Rohár
