[U-Boot] [PATCH 1/2 v2] ARMV7: S5P: make s5p-common for sharing the code between s5pc1xx and s5pc2xx
This patch adds basic support for s5pc210. s5p-common will be used by all of s5p SoCs.
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- v2: no change
Makefile | 7 + arch/arm/cpu/armv7/s5p-common/Makefile | 46 +++++++ arch/arm/cpu/armv7/s5p-common/cpu_info.c | 57 +++++++++ arch/arm/cpu/armv7/s5p-common/timer.c | 192 ++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/s5pc1xx/Makefile | 2 - arch/arm/cpu/armv7/s5pc1xx/cpu_info.c | 57 --------- arch/arm/cpu/armv7/s5pc1xx/timer.c | 192 ------------------------------ 7 files changed, 302 insertions(+), 251 deletions(-) create mode 100644 arch/arm/cpu/armv7/s5p-common/Makefile create mode 100644 arch/arm/cpu/armv7/s5p-common/cpu_info.c create mode 100644 arch/arm/cpu/armv7/s5p-common/timer.c delete mode 100644 arch/arm/cpu/armv7/s5pc1xx/cpu_info.c delete mode 100644 arch/arm/cpu/armv7/s5pc1xx/timer.c
diff --git a/Makefile b/Makefile index 9cea069..47f4e7d 100644 --- a/Makefile +++ b/Makefile @@ -253,6 +253,13 @@ ifeq ($(SOC),omap4) LIBS += $(CPUDIR)/omap-common/libomap-common.a endif
+ifeq ($(SOC),s5pc1xx) +LIBS += $(CPUDIR)/s5p-common/libs5p-common.a +endif +ifeq ($(SOC),s5pc2xx) +LIBS += $(CPUDIR)/s5p-common/libs5p-common.a +endif + LIBS := $(addprefix $(obj),$(LIBS)) .PHONY : $(LIBS) $(TIMESTAMP_FILE) $(VERSION_FILE)
diff --git a/arch/arm/cpu/armv7/s5p-common/Makefile b/arch/arm/cpu/armv7/s5p-common/Makefile new file mode 100644 index 0000000..37371f6 --- /dev/null +++ b/arch/arm/cpu/armv7/s5p-common/Makefile @@ -0,0 +1,46 @@ +# +# Copyright (C) 2009 Samsung Electronics +# Minkyu Kang mk7.kang@samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libs5p-common.a + +COBJS-y += cpu_info.o +COBJS-y += timer.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/armv7/s5p-common/cpu_info.c b/arch/arm/cpu/armv7/s5p-common/cpu_info.c new file mode 100644 index 0000000..454175c --- /dev/null +++ b/arch/arm/cpu/armv7/s5p-common/cpu_info.c @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2009 Samsung Electronics + * Minkyu Kang mk7.kang@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clk.h> + +/* Default is s5pc100 */ +unsigned int s5pc1xx_cpu_id = 0xC100; + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + s5pc1xx_cpu_id = readl(samsung_get_base_pro_id()); + s5pc1xx_cpu_id = 0xC000 | ((s5pc1xx_cpu_id & 0x00FFF000) >> 12); + + s5pc1xx_clock_init(); + + return 0; +} +#endif + +u32 get_device_type(void) +{ + return s5pc1xx_cpu_id; +} + +#ifdef CONFIG_DISPLAY_CPUINFO +int print_cpuinfo(void) +{ + char buf[32]; + + printf("CPU:\tS5P%X@%sMHz\n", + s5pc1xx_cpu_id, strmhz(buf, get_arm_clk())); + + return 0; +} +#endif diff --git a/arch/arm/cpu/armv7/s5p-common/timer.c b/arch/arm/cpu/armv7/s5p-common/timer.c new file mode 100644 index 0000000..6487c0f --- /dev/null +++ b/arch/arm/cpu/armv7/s5p-common/timer.c @@ -0,0 +1,192 @@ +/* + * Copyright (C) 2009 Samsung Electronics + * Heungjun Kim riverful.kim@samsung.com + * Inki Dae inki.dae@samsung.com + * Minkyu Kang mk7.kang@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/pwm.h> +#include <asm/arch/clk.h> + +#define PRESCALER_1 (16 - 1) /* prescaler of timer 2, 3, 4 */ +#define MUX_DIV_2 1 /* 1/2 period */ +#define MUX_DIV_4 2 /* 1/4 period */ +#define MUX_DIV_8 3 /* 1/8 period */ +#define MUX_DIV_16 4 /* 1/16 period */ +#define MUX4_DIV_SHIFT 16 + +#define TCON_TIMER4_SHIFT 20 + +static unsigned long count_value; + +/* Internal tick units */ +static unsigned long long timestamp; /* Monotonic incrementing timer */ +static unsigned long lastdec; /* Last decremneter snapshot */ + +/* macro to read the 16 bit timer */ +static inline struct s5pc1xx_timer *s5pc1xx_get_base_timer(void) +{ + return (struct s5pc1xx_timer *)samsung_get_base_timer(); +} + +int timer_init(void) +{ + struct s5pc1xx_timer *const timer = s5pc1xx_get_base_timer(); + u32 val; + + /* + * @ PWM Timer 4 + * Timer Freq(HZ) = + * PCLK / { (prescaler_value + 1) * (divider_value) } + */ + + /* set prescaler : 16 */ + /* set divider : 2 */ + writel((PRESCALER_1 & 0xff) << 8, &timer->tcfg0); + writel((MUX_DIV_2 & 0xf) << MUX4_DIV_SHIFT, &timer->tcfg1); + + if (count_value == 0) { + /* reset initial value */ + /* count_value = 2085937.5(HZ) (per 1 sec)*/ + count_value = get_pclk() / ((PRESCALER_1 + 1) * + (MUX_DIV_2 + 1)); + + /* count_value / 100 = 20859.375(HZ) (per 10 msec) */ + count_value = count_value / 100; + } + + /* set count value */ + writel(count_value, &timer->tcntb4); + lastdec = count_value; + + val = (readl(&timer->tcon) & ~(0x07 << TCON_TIMER4_SHIFT)) | + S5PC1XX_TCON4_AUTO_RELOAD; + + /* auto reload & manual update */ + writel(val | S5PC1XX_TCON4_UPDATE, &timer->tcon); + + /* start PWM timer 4 */ + writel(val | S5PC1XX_TCON4_START, &timer->tcon); + + timestamp = 0; + + return 0; +} + +/* + * timer without interrupts + */ +void reset_timer(void) +{ + reset_timer_masked(); +} + +unsigned long get_timer(unsigned long base) +{ + return get_timer_masked() - base; +} + +void set_timer(unsigned long t) +{ + timestamp = t; +} + +/* delay x useconds */ +void __udelay(unsigned long usec) +{ + unsigned long tmo, tmp; + + if (usec >= 1000) { + /* + * if "big" number, spread normalization + * to seconds + * 1. start to normalize for usec to ticks per sec + * 2. find number of "ticks" to wait to achieve target + * 3. finish normalize. + */ + tmo = usec / 1000; + tmo *= (CONFIG_SYS_HZ * count_value / 10); + tmo /= 1000; + } else { + /* else small number, don't kill it prior to HZ multiply */ + tmo = usec * CONFIG_SYS_HZ * count_value / 10; + tmo /= (1000 * 1000); + } + + /* get current timestamp */ + tmp = get_timer(0); + + /* if setting this fordward will roll time stamp */ + /* reset "advancing" timestamp to 0, set lastdec value */ + /* else, set advancing stamp wake up time */ + if ((tmo + tmp + 1) < tmp) + reset_timer_masked(); + else + tmo += tmp; + + /* loop till event */ + while (get_timer_masked() < tmo) + ; /* nop */ +} + +void reset_timer_masked(void) +{ + struct s5pc1xx_timer *const timer = s5pc1xx_get_base_timer(); + + /* reset time */ + lastdec = readl(&timer->tcnto4); + timestamp = 0; +} + +unsigned long get_timer_masked(void) +{ + struct s5pc1xx_timer *const timer = s5pc1xx_get_base_timer(); + unsigned long now = readl(&timer->tcnto4); + + if (lastdec >= now) + timestamp += lastdec - now; + else + timestamp += lastdec + count_value - now; + + lastdec = now; + + return timestamp; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +unsigned long get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/arch/arm/cpu/armv7/s5pc1xx/Makefile b/arch/arm/cpu/armv7/s5pc1xx/Makefile index 3785593..263945f 100644 --- a/arch/arm/cpu/armv7/s5pc1xx/Makefile +++ b/arch/arm/cpu/armv7/s5pc1xx/Makefile @@ -32,9 +32,7 @@ SOBJS = cache.o SOBJS += reset.o
COBJS += clock.o -COBJS += cpu_info.o COBJS += sromc.o -COBJS += timer.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/s5pc1xx/cpu_info.c b/arch/arm/cpu/armv7/s5pc1xx/cpu_info.c deleted file mode 100644 index 454175c..0000000 --- a/arch/arm/cpu/armv7/s5pc1xx/cpu_info.c +++ /dev/null @@ -1,57 +0,0 @@ -/* - * Copyright (C) 2009 Samsung Electronics - * Minkyu Kang mk7.kang@samsung.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <asm/io.h> -#include <asm/arch/clk.h> - -/* Default is s5pc100 */ -unsigned int s5pc1xx_cpu_id = 0xC100; - -#ifdef CONFIG_ARCH_CPU_INIT -int arch_cpu_init(void) -{ - s5pc1xx_cpu_id = readl(samsung_get_base_pro_id()); - s5pc1xx_cpu_id = 0xC000 | ((s5pc1xx_cpu_id & 0x00FFF000) >> 12); - - s5pc1xx_clock_init(); - - return 0; -} -#endif - -u32 get_device_type(void) -{ - return s5pc1xx_cpu_id; -} - -#ifdef CONFIG_DISPLAY_CPUINFO -int print_cpuinfo(void) -{ - char buf[32]; - - printf("CPU:\tS5P%X@%sMHz\n", - s5pc1xx_cpu_id, strmhz(buf, get_arm_clk())); - - return 0; -} -#endif diff --git a/arch/arm/cpu/armv7/s5pc1xx/timer.c b/arch/arm/cpu/armv7/s5pc1xx/timer.c deleted file mode 100644 index 6487c0f..0000000 --- a/arch/arm/cpu/armv7/s5pc1xx/timer.c +++ /dev/null @@ -1,192 +0,0 @@ -/* - * Copyright (C) 2009 Samsung Electronics - * Heungjun Kim riverful.kim@samsung.com - * Inki Dae inki.dae@samsung.com - * Minkyu Kang mk7.kang@samsung.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/pwm.h> -#include <asm/arch/clk.h> - -#define PRESCALER_1 (16 - 1) /* prescaler of timer 2, 3, 4 */ -#define MUX_DIV_2 1 /* 1/2 period */ -#define MUX_DIV_4 2 /* 1/4 period */ -#define MUX_DIV_8 3 /* 1/8 period */ -#define MUX_DIV_16 4 /* 1/16 period */ -#define MUX4_DIV_SHIFT 16 - -#define TCON_TIMER4_SHIFT 20 - -static unsigned long count_value; - -/* Internal tick units */ -static unsigned long long timestamp; /* Monotonic incrementing timer */ -static unsigned long lastdec; /* Last decremneter snapshot */ - -/* macro to read the 16 bit timer */ -static inline struct s5pc1xx_timer *s5pc1xx_get_base_timer(void) -{ - return (struct s5pc1xx_timer *)samsung_get_base_timer(); -} - -int timer_init(void) -{ - struct s5pc1xx_timer *const timer = s5pc1xx_get_base_timer(); - u32 val; - - /* - * @ PWM Timer 4 - * Timer Freq(HZ) = - * PCLK / { (prescaler_value + 1) * (divider_value) } - */ - - /* set prescaler : 16 */ - /* set divider : 2 */ - writel((PRESCALER_1 & 0xff) << 8, &timer->tcfg0); - writel((MUX_DIV_2 & 0xf) << MUX4_DIV_SHIFT, &timer->tcfg1); - - if (count_value == 0) { - /* reset initial value */ - /* count_value = 2085937.5(HZ) (per 1 sec)*/ - count_value = get_pclk() / ((PRESCALER_1 + 1) * - (MUX_DIV_2 + 1)); - - /* count_value / 100 = 20859.375(HZ) (per 10 msec) */ - count_value = count_value / 100; - } - - /* set count value */ - writel(count_value, &timer->tcntb4); - lastdec = count_value; - - val = (readl(&timer->tcon) & ~(0x07 << TCON_TIMER4_SHIFT)) | - S5PC1XX_TCON4_AUTO_RELOAD; - - /* auto reload & manual update */ - writel(val | S5PC1XX_TCON4_UPDATE, &timer->tcon); - - /* start PWM timer 4 */ - writel(val | S5PC1XX_TCON4_START, &timer->tcon); - - timestamp = 0; - - return 0; -} - -/* - * timer without interrupts - */ -void reset_timer(void) -{ - reset_timer_masked(); -} - -unsigned long get_timer(unsigned long base) -{ - return get_timer_masked() - base; -} - -void set_timer(unsigned long t) -{ - timestamp = t; -} - -/* delay x useconds */ -void __udelay(unsigned long usec) -{ - unsigned long tmo, tmp; - - if (usec >= 1000) { - /* - * if "big" number, spread normalization - * to seconds - * 1. start to normalize for usec to ticks per sec - * 2. find number of "ticks" to wait to achieve target - * 3. finish normalize. - */ - tmo = usec / 1000; - tmo *= (CONFIG_SYS_HZ * count_value / 10); - tmo /= 1000; - } else { - /* else small number, don't kill it prior to HZ multiply */ - tmo = usec * CONFIG_SYS_HZ * count_value / 10; - tmo /= (1000 * 1000); - } - - /* get current timestamp */ - tmp = get_timer(0); - - /* if setting this fordward will roll time stamp */ - /* reset "advancing" timestamp to 0, set lastdec value */ - /* else, set advancing stamp wake up time */ - if ((tmo + tmp + 1) < tmp) - reset_timer_masked(); - else - tmo += tmp; - - /* loop till event */ - while (get_timer_masked() < tmo) - ; /* nop */ -} - -void reset_timer_masked(void) -{ - struct s5pc1xx_timer *const timer = s5pc1xx_get_base_timer(); - - /* reset time */ - lastdec = readl(&timer->tcnto4); - timestamp = 0; -} - -unsigned long get_timer_masked(void) -{ - struct s5pc1xx_timer *const timer = s5pc1xx_get_base_timer(); - unsigned long now = readl(&timer->tcnto4); - - if (lastdec >= now) - timestamp += lastdec - now; - else - timestamp += lastdec + count_value - now; - - lastdec = now; - - return timestamp; -} - -/* - * This function is derived from PowerPC code (read timebase as long long). - * On ARM it just returns the timer value. - */ -unsigned long long get_ticks(void) -{ - return get_timer(0); -} - -/* - * This function is derived from PowerPC code (timebase clock frequency). - * On ARM it returns the number of timer ticks per second. - */ -unsigned long get_tbclk(void) -{ - return CONFIG_SYS_HZ; -}
v2: no change
applied to u-boot-samsung
Minkyu Kang
Minkyu Kang
