[U-Boot] [GIT PULL] Xilinx changes for v2017.05
Hi Tom,
please pull these changes to your tree.
Thanks, Michal
The following changes since commit 85d0bea153c76f4a3912b5683222885bfd37c769:
Prepare v2017.03-rc2 (2017-02-13 11:47:45 -0500)
git://www.denx.de/git/u-boot-microblaze.git tags/xilinx-for-v2017.05
for you to fetch changes up to 61e745d1311532a90de537cc470da12d306ee193:
mmc: zynq: Add fdt max-frequency support (2017-02-17 10:22:47 +0100)
---------------------------------------------------------------- Xilinx changes for v2017.05
- Move to DM clk driver - Add clk support for zynq_sdhci
---------------------------------------------------------------- Stefan Herbrechtsmeier (10): net: zynq: Don't overwrite gem_rclk_ctrl with default value net: zynq: Add clk framework support to zynq ethernet driver zynq: Add clk framework support to zynq timer zynq: Move static clock names into separate array zynq: Remove zynq_clk_get_name function clk: zynq: Add zynq clock framework driver zynq: Move zynq to clock framework clk: zynq: Add optional ethernet emio clock source support mmc: zynq: Determine base clock frequency via clock framework mmc: zynq: Add fdt max-frequency support
arch/arm/Kconfig | 3 + arch/arm/dts/zynq-7000.dtsi | 2 + arch/arm/include/asm/arch-zynqmp/sys_proto.h | 7 -- arch/arm/mach-zynq/clk.c | 690 ++++++++++++++++------------------------------------------------------------------------------------------------------------------------------------------------ arch/arm/mach-zynq/cpu.c | 1 - arch/arm/mach-zynq/include/mach/clk.h | 6 -- arch/arm/mach-zynq/include/mach/sys_proto.h | 1 - arch/arm/mach-zynq/slcr.c | 29 ------- arch/arm/mach-zynq/timer.c | 23 ++++++ drivers/clk/Kconfig | 8 ++ drivers/clk/Makefile | 1 + drivers/clk/clk_zynq.c | 488 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/zynq_sdhci.c | 33 +++++++- drivers/net/zynq_gem.c | 29 +++---- drivers/serial/serial_zynq.c | 6 +- include/configs/topic_miami.h | 2 - include/configs/zynq_zybo.h | 3 - scripts/config_whitelist.txt | 1 - 18 files changed, 634 insertions(+), 699 deletions(-) create mode 100644 drivers/clk/clk_zynq.c
On Thu, Mar 16, 2017 at 10:24:42AM +0100, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
