[PATCH V3 1/2] mtd: allow getting MTD device associated with a specific DT node
MTD subsystem API allows interacting with MTD devices (e.g. reading, writing, handling bad blocks). So far a random driver could get MTD device only by its name (get_mtd_device_nm()). This change allows getting them also by a DT node.
This API is required for drivers handling DT defined MTD partitions in a specific way (e.g. U-Boot (sub)partition with environment variables).
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- V3: First introduction of of_get_mtd_device_by_node()
mtd maintainers: please let know how would you like this patch processed. Would that be OK for you to Review/Ack it and let it go through NVMEM tree? --- drivers/mtd/mtdcore.c | 28 ++++++++++++++++++++++++++++ include/linux/mtd/mtd.h | 1 + 2 files changed, 29 insertions(+)
diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index 9eb0680db312..7dc214271c85 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -1154,6 +1154,34 @@ int __get_mtd_device(struct mtd_info *mtd) } EXPORT_SYMBOL_GPL(__get_mtd_device);
+/** + * of_get_mtd_device_by_node - obtain an MTD device associated with a given node + * + * @np: device tree node + */ +struct mtd_info *of_get_mtd_device_by_node(struct device_node *np) +{ + struct mtd_info *mtd = NULL; + struct mtd_info *tmp; + int err; + + mutex_lock(&mtd_table_mutex); + + err = -ENODEV; + mtd_for_each_device(tmp) { + if (mtd_get_of_node(tmp) == np) { + mtd = tmp; + err = __get_mtd_device(mtd); + break; + } + } + + mutex_unlock(&mtd_table_mutex); + + return err ? ERR_PTR(err) : mtd; +} +EXPORT_SYMBOL_GPL(of_get_mtd_device_by_node); + /** * get_mtd_device_nm - obtain a validated handle for an MTD device by * device name diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 955aee14b0f7..6fc841ceef31 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -677,6 +677,7 @@ extern int mtd_device_unregister(struct mtd_info *master); extern struct mtd_info *get_mtd_device(struct mtd_info *mtd, int num); extern int __get_mtd_device(struct mtd_info *mtd); extern void __put_mtd_device(struct mtd_info *mtd); +extern struct mtd_info *of_get_mtd_device_by_node(struct device_node *np); extern struct mtd_info *get_mtd_device_nm(const char *name); extern void put_mtd_device(struct mtd_info *mtd);
U-Boot stores its setup as environment variables. It's a list of key-value pairs stored on flash device with a custom header.
This commit adds an NVMEM driver that: 1. Provides NVMEM access to environment vars binary data 2. Extracts variables as NVMEM cells
Current Linux's NVMEM sysfs API allows reading whole NVMEM data block. It can be used by user-space tools for reading U-Boot env vars block without the hassle of finding its location. Parsing will still need to be re-done there.
Kernel-parsed NVMEM cells can be read however by Linux drivers. This may be uesful for Ethernet drivers for reading device MAC address which is often stored as U-Boot env variable.
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- V3: Use of_get_mtd_device_by_node() (thanks Ahmad) & update description V2: Drop ARCH_BCM4908 dependency as there are plenty architectures using U-Boot bootloader. Thanks Srinivas.
As noticed by Ahmad a missing NVMEM subsystem feature is user-space access to parsed NVMEM cells. That is something I started working on some time ago and I'm planning to get back to at some point, please check: [PATCH 2/2] nvmem: expose NVMEM cells in sysfs https://lore.kernel.org/lkml/20211220064730.28806-2-zajec5@gmail.com/ --- MAINTAINERS | 1 + drivers/nvmem/Kconfig | 11 ++ drivers/nvmem/Makefile | 2 + drivers/nvmem/u-boot-env.c | 231 +++++++++++++++++++++++++++++++++++++ 4 files changed, 245 insertions(+) create mode 100644 drivers/nvmem/u-boot-env.c
diff --git a/MAINTAINERS b/MAINTAINERS index 475e28365385..43b427fa76b0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -20411,6 +20411,7 @@ U-BOOT ENVIRONMENT VARIABLES M: Rafał Miłecki rafal@milecki.pl S: Maintained F: Documentation/devicetree/bindings/nvmem/u-boot,env.yaml +F: drivers/nvmem/u-boot-env.c
UACCE ACCELERATOR FRAMEWORK M: Zhangfei Gao zhangfei.gao@linaro.org diff --git a/drivers/nvmem/Kconfig b/drivers/nvmem/Kconfig index d72d879a6d34..5f1b32b953b9 100644 --- a/drivers/nvmem/Kconfig +++ b/drivers/nvmem/Kconfig @@ -344,4 +344,15 @@ config NVMEM_APPLE_EFUSES This driver can also be built as a module. If so, the module will be called nvmem-apple-efuses.
+config NVMEM_U_BOOT_ENV + tristate "U-Boot environment variables support" + depends on OF && MTD + select CRC32 + help + U-Boot stores its setup as environment variables. This driver adds + support for verifying & exporting such data. It also exposes variables + as NVMEM cells so they can be referenced by other drivers. + + If compiled as module it will be called nvmem_u-boot-env. + endif diff --git a/drivers/nvmem/Makefile b/drivers/nvmem/Makefile index c710b64f9fe4..399f9972d45b 100644 --- a/drivers/nvmem/Makefile +++ b/drivers/nvmem/Makefile @@ -69,3 +69,5 @@ obj-$(CONFIG_NVMEM_APPLE_EFUSES) += nvmem-apple-efuses.o nvmem-apple-efuses-y := apple-efuses.o obj-$(CONFIG_MICROCHIP_OTPC) += nvmem-microchip-otpc.o nvmem-microchip-otpc-y := microchip-otpc.o +obj-$(CONFIG_NVMEM_U_BOOT_ENV) += nvmem_u-boot-env.o +nvmem_u-boot-env-y := u-boot-env.o diff --git a/drivers/nvmem/u-boot-env.c b/drivers/nvmem/u-boot-env.c new file mode 100644 index 000000000000..92c2dd11d99f --- /dev/null +++ b/drivers/nvmem/u-boot-env.c @@ -0,0 +1,231 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2022 Rafał Miłecki rafal@milecki.pl + */ + +#include <linux/crc32.h> +#include <linux/mod_devicetable.h> +#include <linux/module.h> +#include <linux/mtd/mtd.h> +#include <linux/nvmem-consumer.h> +#include <linux/nvmem-provider.h> +#include <linux/of_device.h> +#include <linux/platform_device.h> +#include <linux/slab.h> + +enum u_boot_env_format { + U_BOOT_FORMAT_SINGLE, + U_BOOT_FORMAT_REDUNDANT, +}; + +struct u_boot_env { + struct device *dev; + enum u_boot_env_format format; + + /* Parent device */ + struct mtd_info *mtd; + size_t offset; + size_t size; + + /* Cells */ + struct nvmem_cell_info *cells; + int ncells; +}; + +struct u_boot_env_image_single { + __le32 crc32; + uint8_t data[0]; +} __packed; + +struct u_boot_env_image_redundant { + __le32 crc32; + u8 mark; + uint8_t data[0]; +} __packed; + +static int u_boot_env_read(void *context, unsigned int offset, void *val, + size_t bytes) +{ + struct u_boot_env *priv = context; + struct device *dev = priv->dev; + size_t bytes_read; + int err; + + err = mtd_read(priv->mtd, priv->offset + offset, bytes, &bytes_read, val); + if (err && !mtd_is_bitflip(err)) { + dev_err(dev, "Failed to read from mtd: %d\n", err); + return err; + } + + if (bytes_read != bytes) { + dev_err(dev, "Failed to read %zd bytes\n", bytes); + return -EIO; + } + + return 0; +} + +static int u_boot_env_add_cells(struct u_boot_env *priv, uint8_t *buf, + size_t data_offset, size_t data_len) +{ + struct device *dev = priv->dev; + char *data = buf + data_offset; + char *var, *value, *eq; + int idx; + + priv->ncells = 0; + for (var = data; var < data + data_len && *var; var += strlen(var) + 1) + priv->ncells++; + + priv->cells = devm_kcalloc(dev, priv->ncells, sizeof(*priv->cells), GFP_KERNEL); + if (!priv->cells) + return -ENOMEM; + + for (var = data, idx = 0; + var < data + data_len && *var; + var = value + strlen(value) + 1, idx++) { + eq = strchr(var, '='); + if (!eq) + break; + *eq = '\0'; + value = eq + 1; + + priv->cells[idx].name = devm_kstrdup(dev, var, GFP_KERNEL); + if (!priv->cells[idx].name) + return -ENOMEM; + priv->cells[idx].offset = data_offset + value - data; + priv->cells[idx].bytes = strlen(value); + } + + if (WARN_ON(idx != priv->ncells)) + priv->ncells = idx; + + return 0; +} + +static int u_boot_env_parse(struct u_boot_env *priv) +{ + struct device *dev = priv->dev; + size_t crc32_data_offset; + size_t crc32_data_len; + size_t crc32_offset; + size_t data_offset; + size_t data_len; + uint32_t crc32; + uint32_t calc; + size_t bytes; + uint8_t *buf; + int err; + + buf = kcalloc(1, priv->size, GFP_KERNEL); + if (!buf) { + err = -ENOMEM; + goto err_out; + } + + err = mtd_read(priv->mtd, priv->offset, priv->size, &bytes, buf); + if ((err && !mtd_is_bitflip(err)) || bytes != priv->size) { + dev_err(dev, "Failed to read from mtd: %d\n", err); + goto err_kfree; + } + + switch (priv->format) { + case U_BOOT_FORMAT_SINGLE: + crc32_offset = offsetof(struct u_boot_env_image_single, crc32); + crc32_data_offset = offsetof(struct u_boot_env_image_single, data); + data_offset = offsetof(struct u_boot_env_image_single, data); + break; + case U_BOOT_FORMAT_REDUNDANT: + crc32_offset = offsetof(struct u_boot_env_image_redundant, crc32); + crc32_data_offset = offsetof(struct u_boot_env_image_redundant, mark); + data_offset = offsetof(struct u_boot_env_image_redundant, data); + break; + } + crc32 = le32_to_cpu(*(uint32_t *)(buf + crc32_offset)); + crc32_data_len = priv->size - crc32_data_offset; + data_len = priv->size - data_offset; + + calc = crc32(~0, buf + crc32_data_offset, crc32_data_len) ^ ~0L; + if (calc != crc32) { + dev_err(dev, "Invalid calculated CRC32: 0x%08x (expected: 0x%08x)\n", calc, crc32); + err = -EINVAL; + goto err_kfree; + } + + buf[priv->size - 1] = '\0'; + err = u_boot_env_add_cells(priv, buf, data_offset, data_len); + if (err) + dev_err(dev, "Failed to add cells: %d\n", err); + +err_kfree: + kfree(buf); +err_out: + return err; +} + +static const struct of_device_id u_boot_env_of_match_table[] = { + { .compatible = "u-boot,env", .data = (void *)U_BOOT_FORMAT_SINGLE, }, + { .compatible = "u-boot,env-redundant-bool", .data = (void *)U_BOOT_FORMAT_REDUNDANT, }, + { .compatible = "u-boot,env-redundant-count", .data = (void *)U_BOOT_FORMAT_REDUNDANT, }, + {}, +}; + +static int u_boot_env_probe(struct platform_device *pdev) +{ + struct nvmem_config config = { + .name = "u-boot-env", + .reg_read = u_boot_env_read, + }; + struct device *dev = &pdev->dev; + struct device_node *np = dev->of_node; + const struct of_device_id *of_id; + struct u_boot_env *priv; + int err; + + priv = devm_kzalloc(dev, sizeof(*priv), GFP_KERNEL); + if (!priv) + return -ENOMEM; + priv->dev = dev; + + of_id = of_match_device(u_boot_env_of_match_table, dev); + if (!of_id) + return -EINVAL; + priv->format = (uintptr_t)of_id->data; + + if (of_property_read_u32(np, "reg", (u32 *)&priv->offset) || + of_property_read_u32_index(np, "reg", 1, (u32 *)&priv->size)) { + dev_err(dev, "Failed to read "reg" property\n"); + return -EINVAL; + } + + priv->mtd = of_get_mtd_device_by_node(np->parent); + if (IS_ERR(priv->mtd)) { + dev_err(dev, "Failed to get %pOF MTD: %ld\n", np->parent, PTR_ERR(priv->mtd)); + return PTR_ERR(priv->mtd); + } + + err = u_boot_env_parse(priv); + if (err) + return err; + + config.dev = dev; + config.cells = priv->cells; + config.ncells = priv->ncells; + config.priv = priv; + config.size = priv->size; + + return PTR_ERR_OR_ZERO(devm_nvmem_register(dev, &config)); +} + +static struct platform_driver u_boot_env_driver = { + .probe = u_boot_env_probe, + .driver = { + .name = "u_boot_env", + .of_match_table = u_boot_env_of_match_table, + }, +}; +module_platform_driver(u_boot_env_driver); + +MODULE_AUTHOR("Rafał Miłecki"); +MODULE_LICENSE("GPL"); +MODULE_DEVICE_TABLE(of, u_boot_env_of_match_table);
Hello Rafał,
- Provides NVMEM access to environment vars binary data
- Extracts variables as NVMEM cells
useful.
Looks better now!
Thanks for the link.
- tristate "U-Boot environment variables support"
- depends on OF && MTD
- select CRC32
- help
You should probably mention that this is tied to MTD somewhere in the help text as u-boot env on EEPROM/raw eMMC is not covered by this.
- Copyright (C) 2022 Rafał Miłecki rafal@milecki.pl
- U_BOOT_FORMAT_SINGLE,
- U_BOOT_FORMAT_REDUNDANT,
- struct device *dev;
- enum u_boot_env_format format;
- /* Parent device */
- struct mtd_info *mtd;
- size_t offset;
- size_t size;
- /* Cells */
- struct nvmem_cell_info *cells;
- int ncells;
- __le32 crc32;
- uint8_t data[0];
GCC zero-length arrays are being phased out in favor of flexible array members. Just replace the [0] with []. See Documentation/process/deprecated.rst for more information.
+} __packed;
- __le32 crc32;
- u8 mark;
- uint8_t data[0];
Same here
+} __packed;
size_t bytes)
- struct u_boot_env *priv = context;
- struct device *dev = priv->dev;
- size_t bytes_read;
- int err;
- err = mtd_read(priv->mtd, priv->offset + offset, bytes, &bytes_read, val);
Nitpick: if you called u_boot_env::offset u_boot_env::start instead, code would be more readable IMO.
- if (err && !mtd_is_bitflip(err)) {
Nitpick: %pe
return err;
- if (bytes_read != bytes) {
%zu
return -EIO;
- char *data = buf + data_offset;
- char *var, *value, *eq;
- int idx;
- priv->ncells = 0;
- for (var = data; var < data + data_len && *var; var += strlen(var) + 1)
priv->ncells++;
- priv->cells = devm_kcalloc(dev, priv->ncells, sizeof(*priv->cells), GFP_KERNEL);
- if (!priv->cells)
return -ENOMEM;
- for (var = data, idx = 0;
if (!eq)
break;
*eq = '\0';
value = eq + 1;
return -ENOMEM;
U-Boot environment can't hold binary values?
- if (WARN_ON(idx != priv->ncells))
priv->ncells = idx;
- size_t crc32_data_offset;
- size_t crc32_data_len;
- size_t crc32_offset;
- size_t data_offset;
- size_t data_len;
- uint32_t crc32;
- uint32_t calc;
- size_t bytes;
- uint8_t *buf;
- int err;
- buf = kcalloc(1, priv->size, GFP_KERNEL);
- if (!buf) {
err = -ENOMEM;
goto err_out;
- err = mtd_read(priv->mtd, priv->offset, priv->size, &bytes, buf);
- if ((err && !mtd_is_bitflip(err)) || bytes != priv->size) {
goto err_kfree;
- switch (priv->format) {
- case U_BOOT_FORMAT_SINGLE:
break;
- case U_BOOT_FORMAT_REDUNDANT:
break;
- crc32 = le32_to_cpu(*(uint32_t *)(buf + crc32_offset));
- crc32_data_len = priv->size - crc32_data_offset;
- data_len = priv->size - data_offset;
- calc = crc32(~0, buf + crc32_data_offset, crc32_data_len) ^ ~0L;
- if (calc != crc32) {
err = -EINVAL;
goto err_kfree;
- buf[priv->size - 1] = '\0';
- err = u_boot_env_add_cells(priv, buf, data_offset, data_len);
- if (err)
+err_kfree:
- kfree(buf);
+err_out:
- return err;
- { .compatible = "u-boot,env", .data = (void *)U_BOOT_FORMAT_SINGLE, },
- { .compatible = "u-boot,env-redundant-bool", .data = (void *)U_BOOT_FORMAT_REDUNDANT, },
- { .compatible = "u-boot,env-redundant-count", .data = (void *)U_BOOT_FORMAT_REDUNDANT, },
- struct nvmem_config config = {
- struct device *dev = &pdev->dev;
- struct device_node *np = dev->of_node;
- const struct of_device_id *of_id;
- struct u_boot_env *priv;
- int err;
- priv = devm_kzalloc(dev, sizeof(*priv), GFP_KERNEL);
- if (!priv)
return -ENOMEM;
- priv->dev = dev;
- of_id = of_match_device(u_boot_env_of_match_table, dev);
- if (!of_id)
return -EINVAL;
No need for the check.
- priv->format = (uintptr_t)of_id->data;
of_device_get_match_data() can be used instead and compatible list moved to the bottom.
- if (of_property_read_u32(np, "reg", (u32 *)&priv->offset) ||
bad idea. Not 64-bit safe.
Likewise.
Also you don't take #address-cells, #size-cells into account. There's of_translate_address() for that, not sure if there's something more specific. But parsing reg like this is not the right way.
dev_err(dev, "Failed to read \"reg\" property\n");
return -EINVAL;
- priv->mtd = of_get_mtd_device_by_node(np->parent);
- if (IS_ERR(priv->mtd)) {
dev_err -> dev_err_probe. To take care of EPROBE_DEFER.
- err = u_boot_env_parse(priv);
- if (err)
return err;
- config.dev = dev;
- config.cells = priv->cells;
- config.ncells = priv->ncells;
- config.priv = priv;
- config.size = priv->size;
- return PTR_ERR_OR_ZERO(devm_nvmem_register(dev, &config));
- .probe = u_boot_env_probe,
- .driver = {
Cheers, Ahmad
Nitpick: %pe
My "err" variable in int, not a pointer (I don't use PTR_ERR()).
- int idx;
- priv->ncells = 0;
priv->ncells++;
- if (!priv->cells)
return -ENOMEM;
if (!eq)
break;
*eq = '\0';
value = eq + 1;
return -ENOMEM;
I believe it can't. In any case \0 is a always a separator.
priv->ncells = idx;
- select CRC32
- help
- size_t offset;
- size_t size;
- /* Cells */
- int ncells;
- __le32 crc32;
- uint8_t data[0];
+} __packed;
- __le32 crc32;
- u8 mark;
- uint8_t data[0];
+} __packed;
size_t bytes)
- int err;
return err;
return -EIO;
- int idx;
- priv->ncells = 0;
priv->ncells++;
- if (!priv->cells)
return -ENOMEM;
if (!eq)
break;
*eq = '\0';
value = eq + 1;
return -ENOMEM;
priv->ncells = idx;
- size_t data_len;
- uint32_t crc32;
- uint32_t calc;
- size_t bytes;
- uint8_t *buf;
- int err;
- if (!buf) {
err = -ENOMEM;
goto err_out;
goto err_kfree;
break;
break;
err = -EINVAL;
goto err_kfree;
- if (err)
+err_kfree:
- kfree(buf);
+err_out:
- return err;
- int err;
- if (!priv)
return -ENOMEM;
- priv->dev = dev;
- if (!of_id)
return -EINVAL;
return -EINVAL;
Partitions are mtd devices themselves and the mtd layer directly associates these devices to their OF node, so it should be possible to do a of_get_mtd_device_by_node(np) which gets you the partition. You can use the whole mtd device then and do not have to fiddle with reg properties, offsets and sizes in your driver yourself.
Sascha
Hello,
- int err;
- if (!priv)
return -ENOMEM;
- priv->dev = dev;
- if (!of_id)
return -EINVAL;
return -EINVAL;
Just for the record, there will be one mtd device per partition, but the "full" mtd device will only exist if the configuration contains CONFIG_MTD_PARTITIONED_MASTER.
Thanks, Miquèl
Hi Rafał,
zajec5@gmail.com wrote on Sat, 11 Jun 2022 22:46:50 +0200:
Yes
- of_get_mtd_device_by_node - obtain an MTD device associated with a given node
- @np: device tree node
Shall we try to use a more of-agnostic syntax or is it too complex here?
- struct mtd_info *mtd = NULL;
- struct mtd_info *tmp;
- int err;
- mutex_lock(&mtd_table_mutex);
- err = -ENODEV;
- mtd_for_each_device(tmp) {
mtd = tmp;
break;
- mutex_unlock(&mtd_table_mutex);
- return err ? ERR_PTR(err) : mtd;
- get_mtd_device_nm - obtain a validated handle for an MTD device by
- device name
Thanks, Miquèl
I need some extra hint, please. This is how many similar functions look like:
$ grep -E -r "(get|find).*_by_node" ./include/* ./include/drm/drm_mipi_dsi.h:struct mipi_dsi_host *of_find_mipi_dsi_host_by_node(struct device_node *node); ./include/drm/drm_mipi_dsi.h:struct mipi_dsi_device *of_find_mipi_dsi_device_by_node(struct device_node *np); ./include/linux/usb/phy.h:extern struct usb_phy *devm_usb_get_phy_by_node(struct device *dev, ./include/linux/usb/phy.h:static inline struct usb_phy *devm_usb_get_phy_by_node(struct device *dev, ./include/linux/extcon.h:struct extcon_dev *extcon_find_edev_by_node(struct device_node *node); ./include/linux/extcon.h:static inline struct extcon_dev *extcon_find_edev_by_node(struct device_node *node) ./include/linux/of_net.h:extern struct net_device *of_find_net_device_by_node(struct device_node *np); ./include/linux/of_net.h:static inline struct net_device *of_find_net_device_by_node(struct device_node *np) ./include/linux/devfreq.h:struct devfreq *devfreq_get_devfreq_by_node(struct device_node *node); ./include/linux/devfreq.h:static inline struct devfreq *devfreq_get_devfreq_by_node(struct device_node *node) ./include/linux/of_platform.h:extern struct platform_device *of_find_device_by_node(struct device_node *np); ./include/linux/of_platform.h:static inline struct platform_device *of_find_device_by_node(struct device_node *np) ./include/linux/backlight.h:struct backlight_device *of_find_backlight_by_node(struct device_node *node); ./include/linux/backlight.h:of_find_backlight_by_node(struct device_node *node) ./include/linux/i2c.h:struct i2c_client *of_find_i2c_device_by_node(struct device_node *node); ./include/linux/i2c.h:struct i2c_adapter *of_find_i2c_adapter_by_node(struct device_node *node); ./include/linux/i2c.h:struct i2c_adapter *of_get_i2c_adapter_by_node(struct device_node *node); ./include/linux/i2c.h:static inline struct i2c_client *of_find_i2c_device_by_node(struct device_node *node) ./include/linux/i2c.h:static inline struct i2c_adapter *of_find_i2c_adapter_by_node(struct device_node *node) ./include/linux/i2c.h:static inline struct i2c_adapter *of_get_i2c_adapter_by_node(struct device_node *node)
- int err;
- err = -ENODEV;
mtd = tmp;
break;
- device name
Hi Rafał,
zajec5@gmail.com wrote on Mon, 13 Jun 2022 16:15:34 +0200:
I know most implementation today use of_ functions directly but it seems like there is a global move towards fwnodes now, and I was wondering if using those instead (which might also apply to other types of "nodes" than DT ones) could be possible.
But looking into existing implementations, I came across the pwm implem which features: - of_pwm_get() - acpi_pwm_get()
And finally a fwnode_pwm_get() which does:
if (is_of_node()) of_pwm_get(): else if (is_acpi_node()) acpi_pwm_get();
So actually my suggestion is meaningless. I'm fine with the current approach.
Acked-by: Miquel Raynal miquel.raynal@bootlin.com
- int err;
- err = -ENODEV;
mtd = tmp;
break;
- device name
Thanks, Miquèl
Hello Rafał,
- int err;
- err = -ENODEV;
Shouldn't this be -EPROBE_DEFER? That way drivers making use of this function can defer probe until the device is probed.
mtd = tmp;
break;
- device name
Ahmad Fatoum
Miquel Raynal
Rafał Miłecki
Sascha Hauer
