[U-Boot] Pull request: u-boot-sunxi/master
Hi Tom,
Please pull this PR.
thanks, Jagan.
The following changes since commit f58e779513be36e30ce46838fb467e12ac6a5539:
Merge tag 'arc-updates-for-2018.07-rc2' of git://git.denx.de/u-boot-arc (2018-06-15 09:38:16 -0400)
git://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to be0d217952222b2bd3ed071de9bb0c66d8cc80d9:
arm: timer: sunxi: add Allwinner timer erratum workaround (2018-07-03 22:00:00 +0530)
---------------------------------------------------------------- Andre Przywara (2): arm: timer: factor out FSL arch timer erratum workaround arm: timer: sunxi: add Allwinner timer erratum workaround
Hauke Mehrtens (2): sun8i: h2: Add initial Orange Pi R1 support sun50i: h5: Add initial Orange Pi Zero Plus support
arch/arm/cpu/armv8/generic_timer.c | 55 ++++++++-- arch/arm/dts/Makefile | 2 + arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts | 145 ++++++++++++++++++++++++++ arch/arm/dts/sun8i-h2-plus-orangepi-r1.dts | 101 ++++++++++++++++++ arch/arm/mach-sunxi/Kconfig | 4 + board/sunxi/MAINTAINERS | 10 ++ configs/orangepi_r1_defconfig | 16 +++ configs/orangepi_zero_plus_defconfig | 16 +++ 8 files changed, 343 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts create mode 100644 arch/arm/dts/sun8i-h2-plus-orangepi-r1.dts create mode 100644 configs/orangepi_r1_defconfig create mode 100644 configs/orangepi_zero_plus_defconfig
On Tue, Jul 03, 2018 at 10:09:09PM +0530, Jagan Teki wrote:
Hi Tom,
thanks, Jagan.
Jagan Teki
