[U-Boot] [PATCH] Convert CONFIG_DISABLE_CONSOLE to Kconfig
This converts the following to Kconfig: CONFIG_DISABLE_CONSOLE
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- common/Kconfig | 5 +++++ scripts/config_whitelist.txt | 1 - 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/common/Kconfig b/common/Kconfig index 3030da4fc9..207cb3ae0b 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -259,6 +259,11 @@ config CONSOLE_RECORD_IN_SIZE The buffer is allocated immediately after the malloc() region is ready.
+config DISABLE_CONSOLE + bool "Add functionality to disable console completely" + help + Disable console (in & out). + config IDENT_STRING string "Board specific string to be added to uboot version string" help diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fc37099cbe..27fba1e963 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -366,7 +366,6 @@ CONFIG_DHCP_MIN_EXT_LEN CONFIG_DIALOG_POWER CONFIG_DIMM_SLOTS_PER_CTLR CONFIG_DIRECT_NOR_BOOT -CONFIG_DISABLE_CONSOLE CONFIG_DISCONTIGMEM CONFIG_DISCOVER_PHY CONFIG_DISPLAY_AER_xxxx
ping
Am Mo., 10. Sep. 2018 um 12:43 Uhr schrieb Christian Gmeiner christian.gmeiner@gmail.com:
help
config IDENT_STRING string "Board specific string to be added to uboot version string" help diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fc37099cbe..27fba1e963 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -366,7 +366,6 @@ CONFIG_DHCP_MIN_EXT_LEN CONFIG_DIALOG_POWER CONFIG_DIMM_SLOTS_PER_CTLR CONFIG_DIRECT_NOR_BOOT -CONFIG_DISABLE_CONSOLE CONFIG_DISCONTIGMEM CONFIG_DISCOVER_PHY CONFIG_DISPLAY_AER_xxxx -- 2.17.1
ping..
christian.gmeiner@gmail.com schrieb am Do., 20. Sep. 2018, 17:05:
ping
is
ready.
help
string"
help
-- greets -- Christian Gmeiner, MSc
https://christian-gmeiner.info
Christian Gmeiner
Christian Gmeiner
