[U-Boot] [PATCH 0/6] ti: dwc3: Enable USB clocks on-demand
Patch series adds APIs to enable/disable USB clocks and then uses these APIs to enable clocks when dwc3 is used and disable clocks when it is inactive.
This patch series is split from [1] to contain only enabling and disabling clocks.
[1] -> http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/229188
Kishon Vijay Abraham I (6): ARM: OMAP5: Add support for disabling clocks in uboot ARM: OMAP5: Add functions to enable and disable USB clocks ARM: AM43xx: Add support for disabling clocks in uboot ARM: AM43xx: Add functions to enable and disable USB clocks board: ti: invoke clock API to enable and disable clocks ARM: OMAP5/AM43xx: remove enabling USB clocks from enable_basic_clocks()
arch/arm/cpu/armv7/am33xx/clock.c | 53 ++++++++++ arch/arm/cpu/armv7/am33xx/clock_am43xx.c | 82 ++++++++++++--- arch/arm/cpu/armv7/omap-common/clocks-common.c | 53 ++++++++++ arch/arm/cpu/armv7/omap5/hw_data.c | 127 ++++++++++++++++++------ arch/arm/include/asm/arch-am33xx/clock.h | 1 + arch/arm/include/asm/arch-am33xx/sys_proto.h | 5 + arch/arm/include/asm/omap_common.h | 10 ++ board/ti/am43xx/board.c | 2 + board/ti/beagle_x15/board.c | 4 + board/ti/dra7xx/evm.c | 2 + board/ti/omap5_uevm/evm.c | 2 + 11 files changed, 299 insertions(+), 42 deletions(-)
Add do_disable_clocks() to disable clock domains and module clocks. These clocks are enabled using do_enable_clocks().
Cc: Roger Quadros rogerq@ti.com Cc: Tero Kristo t-kristo@ti.com Cc: Nishanth Menon nm@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- arch/arm/cpu/armv7/omap-common/clocks-common.c | 53 ++++++++++++++++++++++++ arch/arm/include/asm/omap_common.h | 4 ++ 2 files changed, 57 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/clocks-common.c b/arch/arm/cpu/armv7/omap-common/clocks-common.c index c94a807..e28b795 100644 --- a/arch/arm/cpu/armv7/omap-common/clocks-common.c +++ b/arch/arm/cpu/armv7/omap-common/clocks-common.c @@ -648,6 +648,14 @@ static inline void enable_clock_domain(u32 const clkctrl_reg, u32 enable_mode) debug("Enable clock domain - %x\n", clkctrl_reg); }
+static inline void disable_clock_domain(u32 const clkctrl_reg) +{ + clrsetbits_le32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_MASK, + CD_CLKCTRL_CLKTRCTRL_SW_SLEEP << + CD_CLKCTRL_CLKTRCTRL_SHIFT); + debug("Disable clock domain - %x\n", clkctrl_reg); +} + static inline void wait_for_clk_enable(u32 clkctrl_addr) { u32 clkctrl, idlest = MODULE_CLKCTRL_IDLEST_DISABLED; @@ -677,6 +685,34 @@ static inline void enable_clock_module(u32 const clkctrl_addr, u32 enable_mode, wait_for_clk_enable(clkctrl_addr); }
+static inline void wait_for_clk_disable(u32 clkctrl_addr) +{ + u32 clkctrl, idlest = MODULE_CLKCTRL_IDLEST_FULLY_FUNCTIONAL; + u32 bound = LDELAY; + + while ((idlest != MODULE_CLKCTRL_IDLEST_DISABLED)) { + clkctrl = readl(clkctrl_addr); + idlest = (clkctrl & MODULE_CLKCTRL_IDLEST_MASK) >> + MODULE_CLKCTRL_IDLEST_SHIFT; + if (--bound == 0) { + printf("Clock disable failed for 0x%x idlest 0x%x\n", + clkctrl_addr, clkctrl); + return; + } + } +} + +static inline void disable_clock_module(u32 const clkctrl_addr, + u32 wait_for_disable) +{ + clrsetbits_le32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_DISABLE << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + debug("Disable clock module - %x\n", clkctrl_addr); + if (wait_for_disable) + wait_for_clk_disable(clkctrl_addr); +} + void freq_update_core(void) { u32 freq_config1 = 0; @@ -800,6 +836,23 @@ void do_enable_clocks(u32 const *clk_domains, } }
+void do_disable_clocks(u32 const *clk_domains, + u32 const *clk_modules_disable, + u8 wait_for_disable) +{ + u32 i, max = 100; + + + /* Clock modules that need to be put in SW_DISABLE */ + for (i = 0; (i < max) && clk_modules_disable[i]; i++) + disable_clock_module(clk_modules_disable[i], + wait_for_disable); + + /* Put the clock domains in SW_SLEEP mode */ + for (i = 0; (i < max) && clk_domains[i]; i++) + disable_clock_domain(clk_domains[i]); +} + void prcm_init(void) { switch (omap_hw_init_context()) { diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 462a9ee..224fbf0 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -577,6 +577,10 @@ void do_enable_clocks(u32 const *clk_domains, u32 const *clk_modules_explicit_en, u8 wait_for_enable);
+void do_disable_clocks(u32 const *clk_domains, + u32 const *clk_modules_disable, + u8 wait_for_disable); + void setup_post_dividers(u32 const base, const struct dpll_params *params); u32 omap_ddr_clk(void);
Cc: Roger Quadros rogerq@ti.com Cc: Tero Kristo t-kristo@ti.com Cc: Nishanth Menon nm@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Please note that this has come in via u-boot-spi and is now applied, thanks!
Added functions to enable and disable USB clocks which can be invoked during USB init and USB exit respectively.
Cc: Roger Quadros rogerq@ti.com Cc: Tero Kristo t-kristo@ti.com Cc: Nishanth Menon nm@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- arch/arm/cpu/armv7/omap5/hw_data.c | 97 ++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/omap_common.h | 6 +++ 2 files changed, 103 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index 11440ac..1085bb3 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -581,6 +581,103 @@ void enable_basic_uboot_clocks(void) 1); }
+#ifdef CONFIG_USB_DWC3 +void enable_usb_clocks(int index) +{ + u32 cm_l3init_usb_otg_ss_clkctrl = 0; + + if (index == 0) { + cm_l3init_usb_otg_ss_clkctrl = + (*prcm)->cm_l3init_usb_otg_ss1_clkctrl; + /* Enable 960 MHz clock for dwc3 */ + setbits_le32((*prcm)->cm_l3init_usb_otg_ss1_clkctrl, + OPTFCLKEN_REFCLK960M); + + /* Enable 32 KHz clock for dwc3 */ + setbits_le32((*prcm)->cm_coreaon_usb_phy1_core_clkctrl, + USBPHY_CORE_CLKCTRL_OPTFCLKEN_CLK32K); + } else if (index == 1) { + cm_l3init_usb_otg_ss_clkctrl = + (*prcm)->cm_l3init_usb_otg_ss2_clkctrl; + /* Enable 960 MHz clock for dwc3 */ + setbits_le32((*prcm)->cm_l3init_usb_otg_ss2_clkctrl, + OPTFCLKEN_REFCLK960M); + + /* Enable 32 KHz clock for dwc3 */ + setbits_le32((*prcm)->cm_coreaon_usb_phy2_core_clkctrl, + USBPHY_CORE_CLKCTRL_OPTFCLKEN_CLK32K); + + /* Enable 60 MHz clock for USB2PHY2 */ + setbits_le32((*prcm)->cm_coreaon_l3init_60m_gfclk_clkctrl, + L3INIT_CLKCTRL_OPTFCLKEN_60M_GFCLK); + } + + u32 const clk_domains_usb[] = { + 0 + }; + + u32 const clk_modules_hw_auto_usb[] = { + (*prcm)->cm_l3init_ocp2scp1_clkctrl, + cm_l3init_usb_otg_ss_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_usb[] = { + 0 + }; + + do_enable_clocks(clk_domains_usb, + clk_modules_hw_auto_usb, + clk_modules_explicit_en_usb, + 1); +} + +void disable_usb_clocks(int index) +{ + u32 cm_l3init_usb_otg_ss_clkctrl = 0; + + if (index == 0) { + cm_l3init_usb_otg_ss_clkctrl = + (*prcm)->cm_l3init_usb_otg_ss1_clkctrl; + /* Disable 960 MHz clock for dwc3 */ + clrbits_le32((*prcm)->cm_l3init_usb_otg_ss1_clkctrl, + OPTFCLKEN_REFCLK960M); + + /* Disable 32 KHz clock for dwc3 */ + clrbits_le32((*prcm)->cm_coreaon_usb_phy1_core_clkctrl, + USBPHY_CORE_CLKCTRL_OPTFCLKEN_CLK32K); + } else if (index == 1) { + cm_l3init_usb_otg_ss_clkctrl = + (*prcm)->cm_l3init_usb_otg_ss2_clkctrl; + /* Disable 960 MHz clock for dwc3 */ + clrbits_le32((*prcm)->cm_l3init_usb_otg_ss2_clkctrl, + OPTFCLKEN_REFCLK960M); + + /* Disable 32 KHz clock for dwc3 */ + clrbits_le32((*prcm)->cm_coreaon_usb_phy2_core_clkctrl, + USBPHY_CORE_CLKCTRL_OPTFCLKEN_CLK32K); + + /* Disable 60 MHz clock for USB2PHY2 */ + clrbits_le32((*prcm)->cm_coreaon_l3init_60m_gfclk_clkctrl, + L3INIT_CLKCTRL_OPTFCLKEN_60M_GFCLK); + } + + u32 const clk_domains_usb[] = { + 0 + }; + + u32 const clk_modules_disable[] = { + (*prcm)->cm_l3init_ocp2scp1_clkctrl, + cm_l3init_usb_otg_ss_clkctrl, + 0 + }; + + do_disable_clocks(clk_domains_usb, + clk_modules_disable, + 1); +} +#endif + const struct ctrl_ioregs ioregs_omap5430 = { .ctrl_ddrch = DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, .ctrl_lpddr2ch = DDR_IO_I_34OHM_SR_FASTEST_WD_CK_CKE_NCS_CA_PULL_DOWN, diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 224fbf0..527e143 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -587,6 +587,12 @@ u32 omap_ddr_clk(void); u32 get_sys_clk_index(void); void enable_basic_clocks(void); void enable_basic_uboot_clocks(void); + +#ifdef CONFIG_USB_DWC3 +void enable_usb_clocks(int index); +void disable_usb_clocks(int index); +#endif + void scale_vcores(struct vcores_data const *); u32 get_offset_code(u32 volt_offset, struct pmic_data *pmic); void do_scale_vcore(u32 vcore_reg, u32 volt_mv, struct pmic_data *pmic);
No #ifdef/#endif in headers, thanks.
Hi Tom,
sure, I'll fix and send.
Thanks Kishon
Cc: Roger Quadros rogerq@ti.com Cc: Tero Kristo t-kristo@ti.com Cc: Nishanth Menon nm@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- arch/arm/cpu/armv7/am33xx/clock.c | 53 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-am33xx/clock.h | 1 + 2 files changed, 54 insertions(+)
diff --git a/arch/arm/cpu/armv7/am33xx/clock.c b/arch/arm/cpu/armv7/am33xx/clock.c index ec7d468..f6a4cee 100644 --- a/arch/arm/cpu/armv7/am33xx/clock.c +++ b/arch/arm/cpu/armv7/am33xx/clock.c @@ -144,6 +144,34 @@ static inline void enable_clock_module(u32 *const clkctrl_addr, u32 enable_mode, wait_for_clk_enable(clkctrl_addr); }
+static inline void wait_for_clk_disable(u32 *clkctrl_addr) +{ + u32 clkctrl, idlest = MODULE_CLKCTRL_IDLEST_FULLY_FUNCTIONAL; + u32 bound = LDELAY; + + while ((idlest != MODULE_CLKCTRL_IDLEST_DISABLED)) { + clkctrl = readl(clkctrl_addr); + idlest = (clkctrl & MODULE_CLKCTRL_IDLEST_MASK) >> + MODULE_CLKCTRL_IDLEST_SHIFT; + if (--bound == 0) { + printf("Clock disable failed for 0x%p idlest 0x%x\n", + clkctrl_addr, clkctrl); + return; + } + } +} + +static inline void disable_clock_module(u32 *const clkctrl_addr, + u32 wait_for_disable) +{ + clrsetbits_le32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_DISABLE << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + debug("Disable clock module - %p\n", clkctrl_addr); + if (wait_for_disable) + wait_for_clk_disable(clkctrl_addr); +} + static inline void enable_clock_domain(u32 *const clkctrl_reg, u32 enable_mode) { clrsetbits_le32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_MASK, @@ -151,6 +179,14 @@ static inline void enable_clock_domain(u32 *const clkctrl_reg, u32 enable_mode) debug("Enable clock domain - %p\n", clkctrl_reg); }
+static inline void disable_clock_domain(u32 *const clkctrl_reg) +{ + clrsetbits_le32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_MASK, + CD_CLKCTRL_CLKTRCTRL_SW_SLEEP << + CD_CLKCTRL_CLKTRCTRL_SHIFT); + debug("Disable clock domain - %p\n", clkctrl_reg); +} + void do_enable_clocks(u32 *const *clk_domains, u32 *const *clk_modules_explicit_en, u8 wait_for_enable) { @@ -170,6 +206,23 @@ void do_enable_clocks(u32 *const *clk_domains, }; }
+void do_disable_clocks(u32 *const *clk_domains, + u32 *const *clk_modules_disable, + u8 wait_for_disable) +{ + u32 i, max = 100; + + + /* Clock modules that need to be put in SW_DISABLE */ + for (i = 0; (i < max) && clk_modules_disable[i]; i++) + disable_clock_module(clk_modules_disable[i], + wait_for_disable); + + /* Put the clock domains in SW_SLEEP mode */ + for (i = 0; (i < max) && clk_domains[i]; i++) + disable_clock_domain(clk_domains[i]); +} + /* * Before scaling up the clocks we need to have the PMIC scale up the * voltages first. This will be dependent on which PMIC is in use diff --git a/arch/arm/include/asm/arch-am33xx/clock.h b/arch/arm/include/asm/arch-am33xx/clock.h index 4af6b57..a6d2419 100644 --- a/arch/arm/include/asm/arch-am33xx/clock.h +++ b/arch/arm/include/asm/arch-am33xx/clock.h @@ -112,5 +112,6 @@ void do_setup_dpll(const struct dpll_regs *, const struct dpll_params *); void prcm_init(void); void enable_basic_clocks(void); void do_enable_clocks(u32 *const *, u32 *const *, u8); +void do_disable_clocks(u32 *const *, u32 *const *, u8);
#endif
Hi Kishon,
Please correct the message subject. As fair as I can tell you are changing clocks on am33xx SoC, not AM43xx.
- u32 clkctrl, idlest = MODULE_CLKCTRL_IDLEST_FULLY_FUNCTIONAL;
- u32 bound = LDELAY;
- while ((idlest != MODULE_CLKCTRL_IDLEST_DISABLED)) {
if (--bound == 0) {
0x%x\n",
return;
- clrsetbits_le32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_MASK,
- debug("Disable clock module - %p\n", clkctrl_addr);
- if (wait_for_disable)
- clrsetbits_le32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_MASK,
- debug("Disable clock domain - %p\n", clkctrl_reg);
- u32 i, max = 100;
Remove one blank line here.
- /* Clock modules that need to be put in SW_DISABLE */
- for (i = 0; (i < max) && clk_modules_disable[i]; i++)
wait_for_disable);
- /* Put the clock domains in SW_SLEEP mode */
- for (i = 0; (i < max) && clk_domains[i]; i++)
- Before scaling up the clocks we need to have the PMIC scale up the
- voltages first. This will be dependent on which PMIC is in use
#endif
On Tuesday 11 August 2015 12:31 PM, Lukasz Majewski wrote:
Hi Kishon,
The same file is used by both am33xx and am43xx. Maybe I can change that to am33xx/am43xx.
if (--bound == 0) {
0x%x\n",
return;
- u32 i, max = 100;
sure.
Thanks Kishon
Cc: Roger Quadros rogerq@ti.com Cc: Tero Kristo t-kristo@ti.com Cc: Nishanth Menon nm@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- arch/arm/cpu/armv7/am33xx/clock_am43xx.c | 70 ++++++++++++++++++++++++++ arch/arm/include/asm/arch-am33xx/sys_proto.h | 5 ++ 2 files changed, 75 insertions(+)
diff --git a/arch/arm/cpu/armv7/am33xx/clock_am43xx.c b/arch/arm/cpu/armv7/am33xx/clock_am43xx.c index b1c0025..cd8931e 100644 --- a/arch/arm/cpu/armv7/am33xx/clock_am43xx.c +++ b/arch/arm/cpu/armv7/am33xx/clock_am43xx.c @@ -134,3 +134,73 @@ void enable_basic_clocks(void) /* For OPP100 the mac clock should be /5. */ writel(0x4, &cmdpll->clkselmacclk); } + +#ifdef CONFIG_USB_DWC3 +void enable_usb_clocks(int index) +{ + u32 *usbclkctrl = 0; + u32 *usbphyocp2scpclkctrl = 0; + + if (index == 0) { + usbclkctrl = &cmper->usb0clkctrl; + usbphyocp2scpclkctrl = &cmper->usbphyocp2scp0clkctrl; + setbits_le32(&cmper->usb0clkctrl, + USBOTGSSX_CLKCTRL_OPTFCLKEN_REFCLK960); + setbits_le32(&cmwkup->usbphy0clkctrl, + USBPHY0_CLKCTRL_OPTFCLKEN_CLK32K); + } else if (index == 1) { + usbclkctrl = &cmper->usb1clkctrl; + usbphyocp2scpclkctrl = &cmper->usbphyocp2scp1clkctrl; + setbits_le32(&cmper->usb1clkctrl, + USBOTGSSX_CLKCTRL_OPTFCLKEN_REFCLK960); + setbits_le32(&cmwkup->usbphy1clkctrl, + USBPHY0_CLKCTRL_OPTFCLKEN_CLK32K); + } + + u32 *const clk_domains_usb[] = { + 0 + }; + + u32 *const clk_modules_explicit_en_usb[] = { + usbclkctrl, + usbphyocp2scpclkctrl, + 0 + }; + + do_enable_clocks(clk_domains_usb, clk_modules_explicit_en_usb, 1); +} + +void disable_usb_clocks(int index) +{ + u32 *usbclkctrl = 0; + u32 *usbphyocp2scpclkctrl = 0; + + if (index == 0) { + usbclkctrl = &cmper->usb0clkctrl; + usbphyocp2scpclkctrl = &cmper->usbphyocp2scp0clkctrl; + clrbits_le32(&cmper->usb0clkctrl, + USBOTGSSX_CLKCTRL_OPTFCLKEN_REFCLK960); + clrbits_le32(&cmwkup->usbphy0clkctrl, + USBPHY0_CLKCTRL_OPTFCLKEN_CLK32K); + } else if (index == 1) { + usbclkctrl = &cmper->usb1clkctrl; + usbphyocp2scpclkctrl = &cmper->usbphyocp2scp1clkctrl; + clrbits_le32(&cmper->usb1clkctrl, + USBOTGSSX_CLKCTRL_OPTFCLKEN_REFCLK960); + clrbits_le32(&cmwkup->usbphy1clkctrl, + USBPHY0_CLKCTRL_OPTFCLKEN_CLK32K); + } + + u32 *const clk_domains_usb[] = { + 0 + }; + + u32 *const clk_modules_disable_usb[] = { + usbclkctrl, + usbphyocp2scpclkctrl, + 0 + }; + + do_disable_clocks(clk_domains_usb, clk_modules_disable_usb, 1); +} +#endif diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h b/arch/arm/include/asm/arch-am33xx/sys_proto.h index 91b614a..275cf7b 100644 --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h @@ -42,3 +42,8 @@ void am33xx_spl_board_init(void); int am335x_get_efuse_mpu_max_freq(struct ctrl_dev *cdev); int am335x_get_tps65910_mpu_vdd(int sil_rev, int frequency); #endif + +#ifdef CONFIG_USB_DWC3 +void enable_usb_clocks(int index); +void disable_usb_clocks(int index); +#endif
No #ifdef/#endif in header files.
Thanks Kishon
invoke enable_usb_clocks during board_usb_init and disable_usb_clocks during board_usb_exit to enable and disable clocks respectively.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- board/ti/am43xx/board.c | 2 ++ board/ti/beagle_x15/board.c | 4 ++++ board/ti/dra7xx/evm.c | 2 ++ board/ti/omap5_uevm/evm.c | 2 ++ 4 files changed, 10 insertions(+)
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 1454976..770726c 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -713,6 +713,7 @@ static struct ti_usb_phy_device usb_phy2_device = {
int board_usb_init(int index, enum usb_init_type init) { + enable_usb_clocks(index); switch (index) { case 0: if (init == USB_INIT_DEVICE) { @@ -759,6 +760,7 @@ int board_usb_cleanup(int index, enum usb_init_type init) default: printf("Invalid Controller Index\n"); } + disable_usb_clocks(index);
return 0; } diff --git a/board/ti/beagle_x15/board.c b/board/ti/beagle_x15/board.c index bcf8cf2..042f9ab 100644 --- a/board/ti/beagle_x15/board.c +++ b/board/ti/beagle_x15/board.c @@ -356,10 +356,12 @@ static struct ti_usb_phy_device usb_phy2_device = {
int board_usb_init(int index, enum usb_init_type init) { + enable_usb_clocks(index); switch (index) { case 0: if (init == USB_INIT_DEVICE) { printf("port %d can't be used as device\n", index); + disable_usb_clocks(index); return -EINVAL; } else { usb_otg_ss1.dr_mode = USB_DR_MODE_HOST; @@ -379,6 +381,7 @@ int board_usb_init(int index, enum usb_init_type init) usb_otg_ss2_glue.vbus_id_status = OMAP_DWC3_VBUS_VALID; } else { printf("port %d can't be used as host\n", index); + disable_usb_clocks(index); return -EINVAL; }
@@ -405,6 +408,7 @@ int board_usb_cleanup(int index, enum usb_init_type init) default: printf("Invalid Controller Index\n"); } + disable_usb_clocks(index); return 0; }
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 4849694..04fc8ed 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -144,6 +144,7 @@ static struct ti_usb_phy_device usb_phy2_device = {
int board_usb_init(int index, enum usb_init_type init) { + enable_usb_clocks(index); switch (index) { case 0: if (init == USB_INIT_DEVICE) { @@ -190,6 +191,7 @@ int board_usb_cleanup(int index, enum usb_init_type init) default: printf("Invalid Controller Index\n"); } + disable_usb_clocks(index); return 0; }
diff --git a/board/ti/omap5_uevm/evm.c b/board/ti/omap5_uevm/evm.c index d0d0e0e..659877c 100644 --- a/board/ti/omap5_uevm/evm.c +++ b/board/ti/omap5_uevm/evm.c @@ -95,6 +95,7 @@ int board_usb_init(int index, enum usb_init_type init) usb_otg_ss_glue.vbus_id_status = OMAP_DWC3_ID_GROUND; }
+ enable_usb_clocks(index); ti_usb_phy_uboot_init(&usb_phy_device); dwc3_omap_uboot_init(&usb_otg_ss_glue); dwc3_uboot_init(&usb_otg_ss); @@ -112,6 +113,7 @@ int board_usb_cleanup(int index, enum usb_init_type init) ti_usb_phy_uboot_exit(index); dwc3_uboot_exit(index); dwc3_omap_uboot_exit(index); + disable_usb_clocks(index);
return 0; }
Now that we have separate function to enable USB clocks, remove enabling USB clocks from enable_basic_clocks(). Now board_usb_init() should take care to invoke enable_usb_clocks() for enabling USB clocks.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- arch/arm/cpu/armv7/am33xx/clock_am43xx.c | 12 ------------ arch/arm/cpu/armv7/omap5/hw_data.c | 30 ------------------------------ 2 files changed, 42 deletions(-)
diff --git a/arch/arm/cpu/armv7/am33xx/clock_am43xx.c b/arch/arm/cpu/armv7/am33xx/clock_am43xx.c index cd8931e..30b4867 100644 --- a/arch/arm/cpu/armv7/am33xx/clock_am43xx.c +++ b/arch/arm/cpu/armv7/am33xx/clock_am43xx.c @@ -111,21 +111,9 @@ void enable_basic_clocks(void) &cmper->emifclkctrl, &cmper->otfaemifclkctrl, &cmper->qspiclkctrl, - &cmper->usb0clkctrl, - &cmper->usbphyocp2scp0clkctrl, - &cmper->usb1clkctrl, - &cmper->usbphyocp2scp1clkctrl, 0 };
- setbits_le32(&cmper->usb0clkctrl, - USBOTGSSX_CLKCTRL_OPTFCLKEN_REFCLK960); - setbits_le32(&cmwkup->usbphy0clkctrl, - USBPHY0_CLKCTRL_OPTFCLKEN_CLK32K); - setbits_le32(&cmper->usb1clkctrl, - USBOTGSSX_CLKCTRL_OPTFCLKEN_REFCLK960); - setbits_le32(&cmwkup->usbphy1clkctrl, - USBPHY0_CLKCTRL_OPTFCLKEN_CLK32K); do_enable_clocks(clk_domains, clk_modules_explicit_en, 1);
/* Select the Master osc clk as Timer2 clock source */ diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index 1085bb3..19f2c43 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -460,13 +460,6 @@ void enable_basic_clocks(void) (*prcm)->cm_l4per_gpio6_clkctrl, (*prcm)->cm_l4per_gpio7_clkctrl, (*prcm)->cm_l4per_gpio8_clkctrl, -#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP) - (*prcm)->cm_l3init_ocp2scp1_clkctrl, - (*prcm)->cm_l3init_usb_otg_ss1_clkctrl, -#if defined(CONFIG_DRA7XX) || defined(CONFIG_AM57XX) - (*prcm)->cm_l3init_usb_otg_ss2_clkctrl, -#endif -#endif 0 };
@@ -498,29 +491,6 @@ void enable_basic_clocks(void) setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, HSMMC_CLKCTRL_CLKSEL_MASK);
-#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP) - /* Enable 960 MHz clock for dwc3 */ - setbits_le32((*prcm)->cm_l3init_usb_otg_ss1_clkctrl, - OPTFCLKEN_REFCLK960M); - - /* Enable 32 KHz clock for dwc3 */ - setbits_le32((*prcm)->cm_coreaon_usb_phy1_core_clkctrl, - USBPHY_CORE_CLKCTRL_OPTFCLKEN_CLK32K); -#if defined(CONFIG_DRA7XX) || defined(CONFIG_AM57XX) - /* Enable 960 MHz clock for dwc3 */ - setbits_le32((*prcm)->cm_l3init_usb_otg_ss2_clkctrl, - OPTFCLKEN_REFCLK960M); - - /* Enable 32 KHz clock for dwc3 */ - setbits_le32((*prcm)->cm_coreaon_usb_phy2_core_clkctrl, - USBPHY_CORE_CLKCTRL_OPTFCLKEN_CLK32K); - - /* Enable 60 MHz clock for USB2PHY2 */ - setbits_le32((*prcm)->cm_coreaon_l3init_60m_gfclk_clkctrl, - L3INIT_CLKCTRL_OPTFCLKEN_60M_GFCLK); -#endif -#endif - /* Set the correct clock dividers for mmc */ setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, HSMMC_CLKCTRL_CLKSEL_DIV_MASK);
Lukasz Majewski
