[U-Boot] sunxi configs break with CONFIG_API in v2015.10-rc4
For at least Bananapi, Cubieboard, Cubieboard2, Cubietruck, Mele_A1000, A10-OLinuXino-Lime, A13-OLinuXino, A20-OLinuXino-Lime2 and probably other sunxi boards, enabling CONFIG_API in the distro defaults header leads to build failures like this one:
[ 105s] CC api/api_net.o [ 105s] api/api_net.c: In function 'dev_enum_net': [ 105s] api/api_net.c:61:35: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] [ 105s] struct eth_device *eth_current = eth_get_dev(); [ 105s] ^ [ 105s] api/api_net.c:68:39: error: dereferencing pointer to incomplete type 'struct eth_device' [ 105s] memcpy(di->di_net.hwaddr, eth_current->enetaddr, 6); [ 105s] ^ [ 105s] scripts/Makefile.build:277: recipe for target 'api/api_net.o' failed [ 105s] make[1]: *** [api/api_net.o] Error 1 [ 105s] Makefile:1191: recipe for target 'api' failed [ 105s] make: *** [api] Error 2
Could you please check on why that is?
By comparison, this is working fine for jetson-tk1; arndale, snow and possibly others are lacking a define for the maximum number of MMCs (preparing a patch).
Thanks, Andreas
It looks like this is caused by the api code not supporting the driver-model for ethernet, whereas sunxi uses that.
Regards,
Hans
Andreas Färber
Hans de Goede
