[PATCH V2 1/2] arm: dts: imx8mm-beacon: Resync dtsi with Kernel 5.17-rc1
Resync the SOM and baseboar files with the device trees that will be included in 5.17-RC1 when it's cut. This will improve pinmuxing for USDHC1 and add USB functionality.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/imx8mm-beacon-baseboard.dtsi b/arch/arm/dts/imx8mm-beacon-baseboard.dtsi index d6b9dedd16..4097a66163 100644 --- a/arch/arm/dts/imx8mm-beacon-baseboard.dtsi +++ b/arch/arm/dts/imx8mm-beacon-baseboard.dtsi @@ -43,6 +43,17 @@ enable-active-high; };
+ reg_usbotg1: regulator-usbotg1 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usb_otg1>; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + reg_usdhc2_vmmc: regulator-usdhc2 { compatible = "regulator-fixed"; regulator-name = "VSD_3V3"; @@ -102,7 +113,6 @@ compatible = "wlf,wm8962"; reg = <0x1a>; clocks = <&clk IMX8MM_CLK_SAI3_ROOT>; - clock-names = "xclk"; DCVDD-supply = <®_audio>; DBVDD-supply = <®_audio>; AVDD-supply = <®_audio>; @@ -170,6 +180,24 @@ status = "okay"; };
+&usbotg1 { + vbus-supply = <®_usbotg1>; + disable-over-current; + dr_mode="otg"; + status = "okay"; +}; + +&usbotg2 { + pinctrl-names = "default"; + disable-over-current; + dr_mode="host"; + status = "okay"; +}; + +&usbphynop2 { + reset-gpios = <&pca6416_1 7 GPIO_ACTIVE_HIGH>; +}; + &usdhc2 { pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; @@ -216,6 +244,12 @@ >; };
+ pinctrl_reg_usb_otg1: usbotg1grp { + fsl,pins = < + MX8MM_IOMUXC_SAI3_RXC_GPIO4_IO29 0x19 + >; + }; + pinctrl_sai3: sai3grp { fsl,pins = < MX8MM_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 diff --git a/arch/arm/dts/imx8mm-beacon-som.dtsi b/arch/arm/dts/imx8mm-beacon-som.dtsi index d897913537..cf07987ccc 100644 --- a/arch/arm/dts/imx8mm-beacon-som.dtsi +++ b/arch/arm/dts/imx8mm-beacon-som.dtsi @@ -91,7 +91,7 @@ #size-cells = <1>; compatible = "jedec,spi-nor"; spi-max-frequency = <80000000>; - spi-tx-bus-width = <4>; + spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; }; }; @@ -256,12 +256,13 @@ &usdhc1 { #address-cells = <1>; #size-cells = <0>; - pinctrl-names = "default"; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; bus-width = <4>; non-removable; cap-power-off-card; - pm-ignore-notify; keep-power-in-suspend; mmc-pwrseq = <&usdhc1_pwrseq>; status = "okay";
With the updated device tree's having USB support, enable in U-Boot. This also requires the addition of the imx8m power domain, since the USB is gated by the power domain controller.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Rebase on master. Change imx8mm-beacon-kit-u-boot to default to host mode, because gadget calls can override it.
diff --git a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi index 73ddfdade6..e33e10ac12 100644 --- a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi @@ -77,6 +77,10 @@ u-boot,dm-spl; };
+&usbotg1 { + dr_mode="host"; +}; + &usdhc2 { u-boot,dm-spl; }; diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index ba9c9a3ee0..14b34e6516 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -45,6 +45,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -96,6 +98,8 @@ CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_BD71837=y CONFIG_SPL_DM_PMIC_BD71837=y @@ -118,4 +122,13 @@ CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y +CONFIG_USB=y +# CONFIG_SPL_DM_USB is not set +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_IMX_WATCHDOG=y
Hi Adam,
I assume this needs your patch below, correct? [PATCH V3] usb: ehci-mx6: Enable OTG detection on imx8mm and imx8mn
Reviewed-by: Fabio Estevam festevam@gmail.com
On Sat, Jan 22, 2022 at 2:14 PM Fabio Estevam festevam@gmail.com wrote:
Hi Adam,
No, I added the change to imx8mm-beacon-kit-u-boot to avoid the necessity of the other patch. They are also not mutually exclusive, so if the OTG auto detection gets added we can remove the customization in imx8mm-beacon-kit-u-boot, but it also shouldn't hurt anything either.
adam
With the updated device tree's having USB support, enable in U-Boot. This also requires the addition of the imx8m power domain, since the USB is gated by the power domain controller. Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Resync the SOM and baseboar files with the device trees that will be included in 5.17-RC1 when it's cut. This will improve pinmuxing for USDHC1 and add USB functionality. Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com diff --git a/arch/arm/dts/imx8mm-beacon-baseboard.dtsi b/arch/arm/dts/imx8mm-beacon-baseboard.dtsi index d6b9dedd16..4097a66163 100644 --- a/arch/arm/dts/imx8mm-beacon-baseboard.dtsi +++ b/arch/arm/dts/imx8mm-beacon-baseboard.dtsi @@ -43,6 +43,17 @@ enable-active-high; };
- reg_usbotg1: regulator-usbotg1 {
enable-active-high;
- reg_usdhc2_vmmc: regulator-usdhc2 { compatible = "regulator-fixed"; regulator-name = "VSD_3V3";
DCVDD-supply = <®_audio>; DBVDD-supply = <®_audio>; AVDD-supply = <®_audio>;clock-names = "xclk";
+&usbotg1 {
- vbus-supply = <®_usbotg1>;
- disable-over-current;
- dr_mode="otg";
- status = "okay";
+&usbotg2 {
- dr_mode="host";
- status = "okay";
+&usbphynop2 {
- reset-gpios = <&pca6416_1 7 GPIO_ACTIVE_HIGH>;
- pinctrl_reg_usb_otg1: usbotg1grp {
fsl,pins = <
- pinctrl_sai3: sai3grp { fsl,pins = < MX8MM_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6
spi-rx-bus-width = <4>; };spi-tx-bus-width = <1>;
- pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc1>;
- pinctrl-1 = <&pinctrl_usdhc1_100mhz>;
- pinctrl-2 = <&pinctrl_usdhc1_200mhz>; bus-width = <4>; non-removable; cap-power-off-card;
Adam Ford
Fabio Estevam
sbabic@denx.de
