[U-Boot] git fsck errors with u-boot
Hello,
Since git 2.1, there have been a number of new fsck options added which produce issues when I clone & fsck the repository git://git.denx.de/u-boot.git
$ git fsck --full Checking object directories: 100% (256/256), done. error in tag eb394f56db3e05d00891d6dc36a00df0025cf255: unterminated header error in tag 9bf86baaa3b35b25baa2d664e2f7f6cafad689ee: unterminated header error in tag c7071e6d645a8e13adb0d4cea2caad27213fa62f: unterminated header Checking objects: 100% (325719/325719), done. Checking connectivity: 325719, done.
These new tests are enabled by default when using git fsck. I have been testing with git version 2.4.4.409.g5b1d901 and thought you might want to know so the error messages can be corrected.
I think these issues were already reported here: https://www.mail-archive.com/u-boot@lists.denx.de/msg175411.html but were not reproducible. Can you see if they can be reproduced using a newer git (2.4 or 2.3) and git fsck --full ?
Thanks, Liam
Dear "Liam R. Howlett",
Indeed these have been reported before - see the full thread at [1]
[1] http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/223976
To summarize: there is no problem with the U-Boot repository, but a false positive in git; the git folks are working on it, and it will problebly be fixed in later versions of git. There is no need for any action on our side.
* Wolfgang Denk wd@denx.de [150630 07:29]:
Hello Wolfgang,
Thank you very much for the summary and the link. I appreciate your time on this matter.
Cheers, Liam
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de : I've tried (in vi) "g/[a-z]\n[a-z]/s//_/"...but that doesn't : cut it. Any ideas? (I take it that it may be a two-pass sort of solution). In the first pass, install perl. :-) Larry Wall 6849@jpl-devvax.JPL.NASA.GOV
Liam R. Howlett
