[U-Boot] [PATCH] driver/ddr/fsl: Remove duplicate inclusion of header file
The fsl_immap.h header file had been included in common.h header file. So remove duplicated header.
Signed-off-by: Chunhe Lan Chunhe.Lan@freescale.com --- drivers/ddr/fsl/ctrl_regs.c | 1 - drivers/ddr/fsl/fsl_ddr_gen4.c | 1 - drivers/ddr/fsl/util.c | 1 - 3 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index 03d7ff1..325bf06 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -14,7 +14,6 @@ #include <fsl_ddr_sdram.h>
#include <fsl_ddr.h> -#include <fsl_immap.h> #include <asm/io.h>
unsigned int picos_to_mclk(unsigned int picos); diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index a3c01e7..8b78652 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -8,7 +8,6 @@ #include <asm/io.h> #include <fsl_ddr_sdram.h> #include <asm/processor.h> -#include <fsl_immap.h> #include <fsl_ddr.h>
#if (CONFIG_CHIP_SELECTS_PER_CTRL > 4) diff --git a/drivers/ddr/fsl/util.c b/drivers/ddr/fsl/util.c index 58b519b..a66f1ea 100644 --- a/drivers/ddr/fsl/util.c +++ b/drivers/ddr/fsl/util.c @@ -13,7 +13,6 @@ #include <div64.h>
/* To avoid 64-bit full-divides, we factor this here */
Did you test this patch? Please rebase and compile for powerpc and arm platforms.
York
Chunhe Lan
York Sun
