[PATCH 01/11] board/freescale: Remove p1023rdb board support
Remove NXP powerpc p1023rdb board support as it is no longer maintained.
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- arch/powerpc/cpu/mpc85xx/Kconfig | 8 - board/freescale/p1023rdb/Kconfig | 12 - board/freescale/p1023rdb/MAINTAINERS | 6 - board/freescale/p1023rdb/Makefile | 8 - board/freescale/p1023rdb/ddr.c | 85 ------- board/freescale/p1023rdb/law.c | 17 -- board/freescale/p1023rdb/p1023rdb.c | 160 ------------- board/freescale/p1023rdb/tlb.c | 98 -------- configs/P1023RDB_defconfig | 50 ---- include/configs/P1023RDB.h | 338 --------------------------- 10 files changed, 782 deletions(-) delete mode 100644 board/freescale/p1023rdb/Kconfig delete mode 100644 board/freescale/p1023rdb/MAINTAINERS delete mode 100644 board/freescale/p1023rdb/Makefile delete mode 100644 board/freescale/p1023rdb/ddr.c delete mode 100644 board/freescale/p1023rdb/law.c delete mode 100644 board/freescale/p1023rdb/p1023rdb.c delete mode 100644 board/freescale/p1023rdb/tlb.c delete mode 100644 configs/P1023RDB_defconfig delete mode 100644 include/configs/P1023RDB.h
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 753d0750b2..0707beebf8 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -109,13 +109,6 @@ config TARGET_P1010RDB_PB imply CMD_SATA imply PANIC_HANG
-config TARGET_P1023RDB - bool "Support P1023RDB" - select ARCH_P1023 - select FSL_DDR_INTERACTIVE - imply CMD_EEPROM - imply PANIC_HANG - config TARGET_P1020MBG bool "Support P1020MBG-PC" select SUPPORT_SPL @@ -1506,7 +1499,6 @@ source "board/freescale/mpc8568mds/Kconfig" source "board/freescale/mpc8569mds/Kconfig" source "board/freescale/mpc8572ds/Kconfig" source "board/freescale/p1010rdb/Kconfig" -source "board/freescale/p1023rdb/Kconfig" source "board/freescale/p1_p2_rdb_pc/Kconfig" source "board/freescale/p2041rdb/Kconfig" source "board/freescale/qemu-ppce500/Kconfig" diff --git a/board/freescale/p1023rdb/Kconfig b/board/freescale/p1023rdb/Kconfig deleted file mode 100644 index 1e4cd10c6c..0000000000 --- a/board/freescale/p1023rdb/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_P1023RDB - -config SYS_BOARD - default "p1023rdb" - -config SYS_VENDOR - default "freescale" - -config SYS_CONFIG_NAME - default "P1023RDB" - -endif diff --git a/board/freescale/p1023rdb/MAINTAINERS b/board/freescale/p1023rdb/MAINTAINERS deleted file mode 100644 index c06bac6d0d..0000000000 --- a/board/freescale/p1023rdb/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -P1023RDB BOARD -#M: - -S: Maintained -F: board/freescale/p1023rdb/ -F: include/configs/P1023RDB.h -F: configs/P1023RDB_defconfig diff --git a/board/freescale/p1023rdb/Makefile b/board/freescale/p1023rdb/Makefile deleted file mode 100644 index 78dc5d595a..0000000000 --- a/board/freescale/p1023rdb/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright 2013 Freescale Semiconductor, Inc. - -obj-y += p1023rdb.o -obj-y += ddr.o -obj-y += law.o -obj-y += tlb.o diff --git a/board/freescale/p1023rdb/ddr.c b/board/freescale/p1023rdb/ddr.c deleted file mode 100644 index dc7a909e03..0000000000 --- a/board/freescale/p1023rdb/ddr.c +++ /dev/null @@ -1,85 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <asm/mmu.h> -#include <asm/immap_85xx.h> -#include <asm/processor.h> -#include <fsl_ddr_sdram.h> -#include <fsl_ddr_dimm_params.h> -#include <asm/io.h> -#include <asm/fsl_law.h> - -/* CONFIG_SYS_DDR_RAW_TIMING */ -/* - * Hynix H5TQ1G83TFR-H9C - */ -dimm_params_t ddr_raw_timing = { - .n_ranks = 1, - .rank_density = 536870912u, - .capacity = 536870912u, - .primary_sdram_width = 32, - .ec_sdram_width = 0, - .registered_dimm = 0, - .mirrored_dimm = 0, - .n_row_addr = 14, - .n_col_addr = 10, - .n_banks_per_sdram_device = 8, - .edc_config = 0, - .burst_lengths_bitmask = 0x0c, - - .tckmin_x_ps = 1875, - .caslat_x = 0x1e << 4, /* 5,6,7,8 */ - .taa_ps = 13125, - .twr_ps = 18000, - .trcd_ps = 13125, - .trrd_ps = 7500, - .trp_ps = 13125, - .tras_ps = 37500, - .trc_ps = 50625, - .trfc_ps = 160000, - .twtr_ps = 7500, - .trtp_ps = 7500, - .refresh_rate_ps = 7800000, - .tfaw_ps = 37500, -}; - -int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, - unsigned int controller_number, - unsigned int dimm_number) -{ - const char dimm_model[] = "Fixed DDR on board"; - - if ((controller_number == 0) && (dimm_number == 0)) { - memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); - memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); - memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); - } - - return 0; -} - -void fsl_ddr_board_options(memctl_options_t *popts, - dimm_params_t *pdimm, - unsigned int ctrl_num) -{ - int i; - popts->clk_adjust = 6; - popts->cpo_override = 0x1f; - popts->write_data_delay = 2; - popts->half_strength_driver_enable = 1; - /* Write leveling override */ - popts->wrlvl_en = 1; - popts->wrlvl_override = 1; - popts->wrlvl_sample = 0xf; - popts->wrlvl_start = 0x8; - popts->trwt_override = 1; - popts->trwt = 0; - - for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { - popts->cs_local_opts[i].odt_rd_cfg = FSL_DDR_ODT_NEVER; - popts->cs_local_opts[i].odt_wr_cfg = FSL_DDR_ODT_CS; - } -} diff --git a/board/freescale/p1023rdb/law.c b/board/freescale/p1023rdb/law.c deleted file mode 100644 index 405fcd7b49..0000000000 --- a/board/freescale/p1023rdb/law.c +++ /dev/null @@ -1,17 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <asm/fsl_law.h> -#include <asm/mmu.h> - -struct law_entry law_table[] = { - SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_4M, - LAW_TRGT_IF_DPAA_SWP_SRAM), - SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), -}; - -int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/p1023rdb/p1023rdb.c b/board/freescale/p1023rdb/p1023rdb.c deleted file mode 100644 index b70ff6899a..0000000000 --- a/board/freescale/p1023rdb/p1023rdb.c +++ /dev/null @@ -1,160 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * Authors: Roy Zang tie-fei.zang@freescale.com - * Chunhe Lan Chunhe.Lan@freescale.com - */ - -#include <common.h> -#include <command.h> -#include <env.h> -#include <image.h> -#include <init.h> -#include <net.h> -#include <pci.h> -#include <asm/io.h> -#include <asm/cache.h> -#include <asm/processor.h> -#include <asm/mmu.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_pci.h> -#include <fsl_ddr_sdram.h> -#include <asm/fsl_portals.h> -#include <fsl_qbman.h> -#include <linux/libfdt.h> -#include <fdt_support.h> -#include <netdev.h> -#include <malloc.h> -#include <fm_eth.h> -#include <fsl_mdio.h> -#include <miiphy.h> -#include <phy.h> -#include <fsl_dtsec.h> - -DECLARE_GLOBAL_DATA_PTR; - -int board_early_init_f(void) -{ - fsl_lbc_t *lbc = LBC_BASE_ADDR; - - /* Set ABSWP to implement conversion of addresses in the LBC */ - setbits_be32(&lbc->lbcr, CONFIG_SYS_LBC_LBCR); - - return 0; -} - -int checkboard(void) -{ - printf("Board: P1023 RDB\n"); - - return 0; -} - -#ifdef CONFIG_PCI -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} -#endif - -int board_early_init_r(void) -{ - const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; - int flash_esel = find_tlb_idx((void *)flashbase, 1); - - /* - * Remap Boot flash + PROMJET region to caching-inhibited - * so that flash can be erased properly. - */ - - /* Flush d-cache and invalidate i-cache of any FLASH data */ - flush_dcache(); - invalidate_icache(); - - if (flash_esel == -1) { - /* very unlikely unless something is messed up */ - puts("Error: Could not find TLB for FLASH BASE\n"); - flash_esel = 2; /* give our best effort to continue */ - } else { - /* invalidate existing TLB entry for flash + promjet */ - disable_tlb(flash_esel); - } - - set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, flash_esel, BOOKE_PAGESZ_256M, 1); - - setup_qbman_portals(); - - return 0; -} - -unsigned long get_board_sys_clk(ulong dummy) -{ - return gd->bus_clk; -} - -unsigned long get_board_ddr_clk(ulong dummy) -{ - return gd->mem_clk; -} - -int board_eth_init(struct bd_info *bis) -{ - ccsr_gur_t *gur = (ccsr_gur_t *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - struct fsl_pq_mdio_info dtsec_mdio_info; - - /* - * Need to set dTSEC 1 pin multiplexing to TSEC. The default setting - * is not correct. - */ - setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_TSEC1_1); - - dtsec_mdio_info.regs = - (struct tsec_mii_mng *)CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR; - dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; - - /* Register the 1G MDIO bus */ - fsl_pq_mdio_init(bis, &dtsec_mdio_info); - - fm_info_set_phy_address(FM1_DTSEC1, CONFIG_SYS_FM1_DTSEC1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, CONFIG_SYS_FM1_DTSEC2_PHY_ADDR); - - fm_info_set_mdio(FM1_DTSEC1, - miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); - fm_info_set_mdio(FM1_DTSEC2, - miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); - -#ifdef CONFIG_FMAN_ENET - cpu_eth_init(bis); -#endif - - return pci_eth_init(bis); -} - -#if defined(CONFIG_OF_BOARD_SETUP) -int ft_board_setup(void *blob, struct bd_info *bd) -{ - phys_addr_t base; - phys_size_t size; - - ft_cpu_setup(blob, bd); - - base = env_get_bootm_low(); - size = env_get_bootm_size(); - - fdt_fixup_memory(blob, (u64)base, (u64)size); - -#ifdef CONFIG_HAS_FSL_DR_USB - fsl_fdt_fixup_dr_usb(blob, bd); -#endif - -#ifdef CONFIG_SYS_DPAA_FMAN -#ifndef CONFIG_DM_ETH - fdt_fixup_fman_ethernet(blob); -#endif -#endif - return 0; -} -#endif diff --git a/board/freescale/p1023rdb/tlb.c b/board/freescale/p1023rdb/tlb.c deleted file mode 100644 index 9f0314d190..0000000000 --- a/board/freescale/p1023rdb/tlb.c +++ /dev/null @@ -1,98 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <asm/mmu.h> - -struct fsl_e_tlb_entry tlb_table[] = { - /* TLB 0 - for temp stack in cache */ - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - - /* TLB 1 */ - /* *I*** - Covers boot page */ - SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I, - 0, 0, BOOKE_PAGESZ_4K, 1), - - /* *I*G* - CCSRBAR */ - SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 1, BOOKE_PAGESZ_4M, 1), - - /* W**G* - Flash, localbus */ - /* This will be changed to *I*G* after relocation to RAM. */ - SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, - 0, 2, BOOKE_PAGESZ_256M, 1), - - /* *I*G* - PCI */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT, CONFIG_SYS_PCIE3_MEM_PHYS, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 3, BOOKE_PAGESZ_1G, 1), - - /* *I*G* - PCI */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x40000000, - CONFIG_SYS_PCIE3_MEM_PHYS + 0x40000000, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 4, BOOKE_PAGESZ_256M, 1), - - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x50000000, - CONFIG_SYS_PCIE3_MEM_PHYS + 0x50000000, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 5, BOOKE_PAGESZ_256M, 1), - - /* *I*G* - PCI I/O */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_IO_VIRT, CONFIG_SYS_PCIE3_IO_PHYS, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 6, BOOKE_PAGESZ_256K, 1), - - /* Bman/Qman */ - SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, - MAS3_SW|MAS3_SR, 0, - 0, 7, BOOKE_PAGESZ_1M, 1), - SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x00100000, - CONFIG_SYS_BMAN_MEM_PHYS + 0x00100000, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 8, BOOKE_PAGESZ_1M, 1), - SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, - MAS3_SW|MAS3_SR, MAS2_M, - 0, 9, BOOKE_PAGESZ_1M, 1), - SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x00100000, - CONFIG_SYS_QMAN_MEM_PHYS + 0x00100000, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 10, BOOKE_PAGESZ_1M, 1), - - SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, - MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 11, BOOKE_PAGESZ_16K, 1), - -#ifdef CONFIG_SYS_RAMBOOT - SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, - CONFIG_SYS_DDR_SDRAM_BASE, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, - 0, 12, BOOKE_PAGESZ_256M, 1), - - SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000, - CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, - 0, 13, BOOKE_PAGESZ_256M, 1), -#endif -}; - -int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig deleted file mode 100644 index a8bb5767b7..0000000000 --- a/configs/P1023RDB_defconfig +++ /dev/null @@ -1,50 +0,0 @@ -CONFIG_PPC=y -CONFIG_SYS_TEXT_BASE=0xEFF40000 -CONFIG_ENV_SIZE=0x2000 -CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_MPC85xx=y -# CONFIG_CMD_ERRATA is not set -CONFIG_TARGET_P1023RDB=y -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_BOOTDELAY=-1 -# CONFIG_MISC_INIT_R is not set -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_HUSH_PARSER=y -# CONFIG_AUTO_COMPLETE is not set -CONFIG_CMD_REGINFO=y -CONFIG_CMD_IMLS=y -# CONFIG_CMD_EEPROM is not set -CONFIG_CMD_I2C=y -CONFIG_CMD_NAND=y -CONFIG_CMD_PCI=y -CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_MP=y -# CONFIG_CMD_HASH is not set -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_ADDR=0xEFF20000 -# CONFIG_MMC is not set -CONFIG_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_MTD_RAW_NAND=y -CONFIG_PHYLIB=y -CONFIG_PHY_ATHEROS=y -CONFIG_PHY_GIGE=y -CONFIG_E1000=y -CONFIG_FMAN_ENET=y -CONFIG_MII=y -CONFIG_SYS_QE_FMAN_FW_IN_NOR=y -CONFIG_SYS_NS16550=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h deleted file mode 100644 index 5c29a4f274..0000000000 --- a/include/configs/P1023RDB.h +++ /dev/null @@ -1,338 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * Authors: Roy Zang tie-fei.zang@freescale.com - * Chunhe Lan Chunhe.Lan@freescale.com - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#include <linux/stringify.h> - -#ifndef CONFIG_SYS_MONITOR_BASE -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ -#endif - -#ifndef CONFIG_RESET_VECTOR_ADDRESS -#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc -#endif - -/* High Level Configuration Options */ - -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ -#define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ -#define CONFIG_PCIE3 /* PCIE controller 3 (slot 3) */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ - -#ifndef __ASSEMBLY__ -extern unsigned long get_clock_freq(void); -#endif - -#define CONFIG_SYS_CLK_FREQ 66666666 -#define CONFIG_DDR_CLK_FREQ CONFIG_SYS_CLK_FREQ - -/* - * These can be toggled for performance analysis, otherwise use default. - */ -#define CONFIG_L2_CACHE /* toggle L2 cache */ -#define CONFIG_BTB /* toggle branch predition */ -#define CONFIG_HWCONFIG - -#define CONFIG_ENABLE_36BIT_PHYS - -/* Implement conversion of addresses in the LBC */ -#define CONFIG_SYS_LBC_LBCR 0x00000000 -#define CONFIG_SYS_LBC_LCRR LCRR_CLKDIV_8 - -/* DDR Setup */ -#define CONFIG_VERY_BIG_RAM -#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE - -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL 1 - -#define CONFIG_DDR_SPD -#define CONFIG_SYS_SDRAM_SIZE 512u /* DDR is 512M */ -#define CONFIG_SYS_SPD_BUS_NUM 0 -#define SPD_EEPROM_ADDRESS 0x50 -#define CONFIG_SYS_DDR_RAW_TIMING - -/* - * Memory map - * - * 0x0000_0000 0x1fff_ffff DDR 512M cacheable - * 0x8000_0000 0xbfff_ffff PCI Express Mem 1G non-cacheable - * 0xc000_0000 0xdfff_ffff PCI 512M non-cacheable - * 0xe100_0000 0xe3ff_ffff PCI IO range 4M non-cacheable - * 0xff00_0000 0xff3f_ffff DPAA_QBMAN 4M cacheable - * 0xff60_0000 0xff7f_ffff CCSR 2M non-cacheable - * 0xffd0_0000 0xffd0_3fff L1 for stack 16K cacheable TLB0 - * - * Localbus non-cacheable - * - * 0xec00_0000 0xefff_ffff NOR flash 64M non-cacheable - * 0xffa0_0000 0xffaf_ffff NAND 1M non-cacheable - */ - -/* - * Local Bus Definitions - */ -#define CONFIG_SYS_FLASH_BASE 0xec000000 /* start of FLASH 64M */ -#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE - -#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ - | BR_PS_16 | BR_V) -#define CONFIG_FLASH_OR_PRELIM 0xfc000ff7 - -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_INIT_RAM_LOCK -#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000/* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_LEN (768 * 1024) /* Reserve 512 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (6 * 1024 * 1024) /* Reserved for malloc */ - -#define CONFIG_SYS_NAND_BASE 0xffa00000 -#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE - -#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_NAND_FSL_ELBC -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - -/* NAND flash config */ -#define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM (OR_AM_256KB /* length 256K */ \ - | OR_FCM_PGS \ - | OR_FCM_CSCT \ - | OR_FCM_CST \ - | OR_FCM_CHT \ - | OR_FCM_SCY_1 \ - | OR_FCM_TRLX \ - | OR_FCM_EHTR) - -#define CONFIG_SYS_BR0_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ -#define CONFIG_SYS_OR0_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ -#define CONFIG_SYS_BR1_PRELIM CONFIG_SYS_NAND_BR_PRELIM -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ - -/* Serial Port */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) - -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} - -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600) - -/* I2C */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_FSL -#define CONFIG_SYS_FSL_I2C_SPEED 400000 -#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 -#define CONFIG_SYS_FSL_I2C2_SPEED 400000 -#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 - -/* - * I2C2 EEPROM - */ -#define CONFIG_ID_EEPROM -#ifdef CONFIG_ID_EEPROM -#define CONFIG_SYS_I2C_EEPROM_NXID -#endif -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_BUS_NUM 0 - -/* - * General PCI - * Memory space is mapped 1-1, but I/O space must start from 0. - */ - -/* controller 3, Slot 1, tgtid 3, Base address b000 */ -#define CONFIG_SYS_PCIE3_NAME "Slot 3" -#define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 -#define CONFIG_SYS_PCIE3_MEM_PHYS 0x80000000 -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE3_IO_VIRT 0xffc00000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_PHYS 0xffc00000 -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ - -/* controller 2, direct to uli, tgtid 2, Base address 9000 */ -#define CONFIG_SYS_PCIE2_NAME "Slot 2" -#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_VIRT 0xffc10000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ - -/* controller 1, Slot 2, tgtid 1, Base address a000 */ -#define CONFIG_SYS_PCIE1_NAME "Slot 1" -#define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc0000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc20000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc20000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ - -#if defined(CONFIG_PCI) -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - -/* - * Environment - */ - -#define CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ - -/* - * USB - */ -#define CONFIG_HAS_FSL_DR_USB -#ifdef CONFIG_HAS_FSL_DR_USB -#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_USB_EHCI_FSL -#endif -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 64 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial Memory map for Linux*/ -#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ - -/* - * Environment Configuration - */ -#define CONFIG_BOOTFILE "uImage" -#define CONFIG_UBOOTPATH (u-boot.bin) /* U-Boot image on TFTP server */ - -/* default location for tftp and bootm */ -#define CONFIG_LOADADDR 1000000 - -/* Qman/Bman */ -#define CONFIG_SYS_QMAN_MEM_BASE 0xff000000 -#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE -#define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 -#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x4000 -#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x1000 -#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE -#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) -#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ - CONFIG_SYS_QMAN_CENA_SIZE) -#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) -#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0xE08 -#define CONFIG_SYS_BMAN_MEM_BASE 0xff200000 -#define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE -#define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 -#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 -#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 -#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE -#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) -#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ - CONFIG_SYS_BMAN_CENA_SIZE) -#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) -#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 - -/* For FM */ -#define CONFIG_SYS_DPAA_FMAN - -/* Default address of microcode for the Linux Fman driver */ -/* QE microcode/firmware address */ -#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 -#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 -#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) - -#ifdef CONFIG_FMAN_ENET -#define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x1 -#define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x2 - -#define CONFIG_SYS_TBIPA_VALUE 8 -#define CONFIG_ETHPRIME "FM1@DTSEC1" -#endif - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ - "loadaddr=1000000\0" \ - "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ - "tftpflash=tftpboot $loadaddr $uboot; " \ - "protect off $ubootaddr +$filesize; " \ - "erase $ubootaddr +$filesize; " \ - "cp.b $loadaddr $ubootaddr $filesize; " \ - "protect on $ubootaddr +$filesize; " \ - "cmp.b $loadaddr $ubootaddr $filesize\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=2000000\0" \ - "ramdiskfile=rootfs.ext2.gz.uboot\0" \ - "fdtaddr=1e00000\0" \ - "fdtfile=p1023rdb.dtb\0" \ - "othbootargs=ramdisk_size=600000\0" \ - "bdev=sda1\0" \ - "hwconfig=usb1:dr_mode=host,phy_type=ulpi\0" - -#define CONFIG_HDBOOT \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_BOOTCOMMAND CONFIG_RAMBOOTCOMMAND - -#endif /* __CONFIG_H */
Priyanka Jain
