[U-Boot] [PATCH] mvsata_ide: adjust port init sequence
mvsata_ide_initialize_port(): adjust init sequence (SStatus should be checked only after all writes to SControl) and return success/failure to ide_preinit().
Also, as some tests showed init durations in the hundreds of us, raise the time-out to 01 ms to be on the safe side. --- drivers/block/mvsata_ide.c | 22 ++++++++++++++-------- 1 files changed, 14 insertions(+), 8 deletions(-)
diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index 077b278..2b6b706 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -97,23 +97,27 @@ struct mvsata_port_registers { * DET back to "no action". */
-static void mvsata_ide_initialize_port(struct mvsata_port_registers *port) +static int mvsata_ide_initialize_port(struct mvsata_port_registers *port) { u32 control; u32 status; - u32 tout = 50; /* wait at most 50 us for SATA reset to complete */ + u32 tout = 10000; /* wait at most 10 ms for SATA reset to complete */
+ /* Set control IPM to 3 (no low power) and DET to 1 (initialize) */ control = readl(&port->scontrol); control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_INIT; + /* Toggle control DET back to 0 (normal operation) */ writel(control, &port->scontrol); + control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_USE; + writel(control, &port->scontrol); + /* wait for status DET to become 3 (device and communication OK) */ while (--tout) { status = readl(&port->sstatus) & MVSATA_SSTATUS_DET_MASK; if (status == MVSATA_SSTATUS_DET_DEVCOMM) break; udelay(1); } - control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_USE; - writel(control, &port->scontrol); + return (tout? 0: 1); }
/* @@ -125,15 +129,17 @@ int ide_preinit(void) { /* Enable ATA port 0 (could be SATA port 0 or 1) if declared */ #if defined(CONFIG_SYS_ATA_IDE0_OFFSET) - mvsata_ide_initialize_port( + if (mvsata_ide_initialize_port( (struct mvsata_port_registers *) - (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_IDE0_OFFSET)); + (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_IDE0_OFFSET))) + return 1; #endif /* Enable ATA port 1 (could be SATA port 0 or 1) if declared */ #if defined(CONFIG_SYS_ATA_IDE1_OFFSET) - mvsata_ide_initialize_port( + if (mvsata_ide_initialize_port( (struct mvsata_port_registers *) - (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_IDE1_OFFSET)); + (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_IDE1_OFFSET))) + return 1; #endif /* return 0 as we always succeed */ return 0;
Hello.
- DET back to "no action".
But you haven't set it to 1 yet. Maybe the comment is misplaced?
- /* wait for status DET to become 3 (device and communication OK) */ while (--tout) { status = readl(&port->sstatus)& MVSATA_SSTATUS_DET_MASK; if (status == MVSATA_SSTATUS_DET_DEVCOMM) break; udelay(1); }
- control = (control& ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_USE;
- writel(control,&port->scontrol);
- return (tout? 0: 1);
Why not !tout? (And you forgot a space before colon. :-)
WBR, Sergei
Hi Sergei,
Le 05/09/2010 12:54, Sergei Shtylyov a écrit :
- /* Set control IPM to 3 (no low power) and DET to 1 (initialize) */
- /* Toggle control DET back to 0 (normal operation) */
Look at the comment above, which said DET was set to 1, and at MVSATA_PORT_INIT, which combines IPM=3 and DET=1.
Why not indeed? I'll fix this in the next version.
WBR, Sergei
Thanks!
Amicalement,
Hello.
But you didn't write that value yet before your comment saying that you're resetting DET back to 0.
WBR, Sergei
Le 06/09/2010 11:18, Sergei Shtylyov a écrit :
Hello.
Yes, I did:
#define MVSATA_PORT_INIT \ (MVSATA_SCONTROL_DET_INIT|MVSATA_SCONTROL_IPM_NO_LP_ALLOWED)
MVSATA_PORT_INIT has both IPM = 3 (no low power allowed) and DET = 1 (initialize).
Amicalement,
Hello.
Yes, I did:
Sigh. Your "resetting DET" comment is before the first writel().
Amicalement,
WBR, Sergei
Le 06/09/2010 14:45, Sergei Shtylyov a écrit :
Hello.
Yes, I did:
Amicalement,
WBR, Sergei
Oh, I see! I'll push a new version with the comment moved down one notch. Thanks for your patience. :)
Amicalement,
Albert ARIBAUD
Albert Aribaud
Sergei Shtylyov
