[U-Boot] [PATCH] ARM: ATMEL: eb_cpux9k2: fix TEXT_BASE for ramboot target
From: "Jens Scharsig (BuS Elektronik)" esw@bus-elektronik.de
Since more functions are enabled, the eb_cpux9k2_ram target does not boot. This patch changed the TEXT_BASE, that the code fits between TEXT_BASE and ram end.
Signed-off-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de --- include/configs/eb_cpux9k2.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index b8e672f..883bbfc 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -36,7 +36,7 @@ #define CONFIG_SYS_TEXT_BASE 0x00000000 #else #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_SYS_TEXT_BASE 0x21f00000 +#define CONFIG_SYS_TEXT_BASE 0x21800000 #endif #define CONFIG_SYS_LOAD_ADDR 0x21000000 /* default load address */ #define CONFIG_STANDALONE_LOAD_ADDR 0x21000000 @@ -133,6 +133,7 @@ #define CONFIG_CMD_UBI #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_UBIFS + #define CONFIG_SYS_LONGHELP
Dear Esw@Bus-Elektronik.De,
Esw@Bus-Elektronik.De esw@bus-elektronik.de writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
