[PATCH v2 1/4] phy: atheros: ar8035: Fix clock output calculation
The clock ouput frequency is calculated incorrectly for AR8035 due to wrong masking of priv->clk_25m_reg and priv->clk_25m_mask.
This same issue has been already fixed in the kernel by:
commit b1f4c209d84057b6d40b939b6e4404854271d797 Author: Oleksij Rempel o.rempel@pengutronix.de Date: Wed Apr 1 11:57:32 2020 +0200
net: phy: at803x: fix clock sink configuration on ATH8030 and ATH8035
The masks in priv->clk_25m_reg and priv->clk_25m_mask are one-bits-set for the values that comprise the fields, not zero-bits-set.
This patch fixes the clock frequency configuration for ATH8030 and ATH8035 Atheros PHYs by removing the erroneous "~".
To reproduce this bug, configure the PHY with the device tree binding "qca,clk-out-frequency" and remove the machine specific PHY fixups.
Fixes: 2f664823a47021 ("net: phy: at803x: add device tree binding") Signed-off-by: Oleksij Rempel o.rempel@pengutronix.de Reported-by: Russell King rmk+kernel@armlinux.org.uk Reviewed-by: Russell King rmk+kernel@armlinux.org.uk Tested-by: Russell King rmk+kernel@armlinux.org.uk Signed-off-by: David S. Miller davem@davemloft.net
Apply the same fix in the U-Boot driver.
Tested on a i.MX6 Hummingboard.
Signed-off-by: Fabio Estevam festevam@gmail.com Reviewed-by: Michael Walle michael@walle.cc Tested-by: Tom Rini trini@konsulko.com --- Changes since v1: - None
drivers/net/phy/atheros.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 13f7275d17..f922fecd6b 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -275,11 +275,10 @@ static int ar803x_of_init(struct phy_device *phydev) * Fixup for the AR8035 which only has two bits. The two * remaining bits map to the same frequencies. */ - if (phydev->drv->uid == AR8035_PHY_ID) { - u16 clear = AR803x_CLK_25M_MASK & AR8035_CLK_25M_MASK;
- priv->clk_25m_mask &= ~clear; - priv->clk_25m_reg &= ~clear; + if (phydev->drv->uid == AR8035_PHY_ID) { + priv->clk_25m_reg &= AR8035_CLK_25M_MASK; + priv->clk_25m_mask &= AR8035_CLK_25M_MASK; } }
As we move towards driver model, it is required to let the FEC driver know how to properly deal with an Ethernet PHY subnode in the device tree.
For example:
&fec { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_microsom_enet_ar8035>; phy-handle = <&phy>; phy-mode = "rgmii-id"; phy-reset-duration = <2>; phy-reset-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; status = "okay";
mdio { #address-cells = <1>; #size-cells = <0>;
phy: ethernet-phy@0 { reg = <0>; qca,clk-out-frequency = <125000000>; }; }; };
Currently the PHY node pointer is incorrectly associated with the Ethernel controller instead of the PHY node itself.
This causes the PHY properties, such as "qca,clk-out-frequency" in the example above to not get parsed.
Fix this problem by populating the phy_of_node node.
Suggested-by: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Fabio Estevam festevam@gmail.com Tested-by: Tom Rini trini@konsulko.com --- Changes since v1: - None
drivers/net/fec_mxc.c | 7 +++++-- drivers/net/fec_mxc.h | 1 + 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 9ae2db033e..992180df86 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1294,7 +1294,7 @@ static const struct eth_ops fecmxc_ops = { .read_rom_hwaddr = fecmxc_read_rom_hwaddr, };
-static int device_get_phy_addr(struct udevice *dev) +static int device_get_phy_addr(struct fec_priv *priv, struct udevice *dev) { struct ofnode_phandle_args phandle_args; int reg; @@ -1305,6 +1305,8 @@ static int device_get_phy_addr(struct udevice *dev) return -ENODEV; }
+ priv->phy_of_node = phandle_args.node; + reg = ofnode_read_u32_default(phandle_args.node, "reg", 0);
return reg; @@ -1315,7 +1317,7 @@ static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) struct phy_device *phydev; int addr;
- addr = device_get_phy_addr(dev); + addr = device_get_phy_addr(priv, dev); #ifdef CONFIG_FEC_MXC_PHYADDR addr = CONFIG_FEC_MXC_PHYADDR; #endif @@ -1325,6 +1327,7 @@ static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) return -ENODEV;
priv->phydev = phydev; + priv->phydev->node = priv->phy_of_node; phy_config(phydev);
return 0; diff --git a/drivers/net/fec_mxc.h b/drivers/net/fec_mxc.h index 0e8f08a51a..659d62646f 100644 --- a/drivers/net/fec_mxc.h +++ b/drivers/net/fec_mxc.h @@ -250,6 +250,7 @@ struct fec_priv { struct mii_dev *bus; #ifdef CONFIG_PHYLIB struct phy_device *phydev; + ofnode phy_of_node; #else int phy_id; int (*mii_postcall)(int);
Sync the device tree with 5.8-rc1.
It basically contains the following extra kernel commit:
commit 86b08bd5b99480b79a25343f24c1b8c4ddcb5c09 Author: Russell King rmk+kernel@armlinux.org.uk Date: Wed Apr 15 16:44:17 2020 +0100
ARM: dts: imx6-sr-som: add ethernet PHY configuration
Add ethernet PHY configuration ahead of removing the quirk that configures the clocking mode for the PHY. The RGMII delay is already set correctly.
Signed-off-by: Russell King rmk+kernel@armlinux.org.uk Reviewed-by: Fabio Estevam festevam@gmail.com Signed-off-by: Shawn Guo shawnguo@kernel.org
, which passes the 'qca,clk-out-frequency' property and it is important to specify the correct frequency generated by the AR8031.
arch/arm/dts/imx6qdl-sr-som.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-sr-som.dtsi b/arch/arm/dts/imx6qdl-sr-som.dtsi index 6d7f6b9035..b06577808f 100644 --- a/arch/arm/dts/imx6qdl-sr-som.dtsi +++ b/arch/arm/dts/imx6qdl-sr-som.dtsi @@ -53,10 +53,21 @@ &fec { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_microsom_enet_ar8035>; + phy-handle = <&phy>; phy-mode = "rgmii-id"; phy-reset-duration = <2>; phy-reset-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + phy: ethernet-phy@0 { + reg = <0>; + qca,clk-out-frequency = <125000000>; + }; + }; };
&iomuxc {
Migration to DM_ETH is mandatory, so convert mx6cuboxi to Ethernet Driver Model.
This also brings the benefit of restoring Ethernet functionality.
Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Fabio Estevam festevam@gmail.com
Signed-off-by: Fabio Estevam festevam@gmail.com Tested-by: Tom Rini trini@konsulko.com --- Changes since v1: - Remove <miiphy.h> header - Baruch - Remove ENET_PAD_CTRL definitions - Baruch - Remove DM_MDIO- Vladimir
board/solidrun/mx6cuboxi/mx6cuboxi.c | 134 ++++----------------------- configs/mx6cuboxi_defconfig | 3 + include/configs/mx6cuboxi.h | 6 -- 3 files changed, 20 insertions(+), 123 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 94707bccb2..59e8b1dca1 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -17,7 +17,6 @@ #include <image.h> #include <init.h> #include <log.h> -#include <net.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> @@ -33,8 +32,6 @@ #include <mmc.h> #include <fsl_esdhc_imx.h> #include <malloc.h> -#include <miiphy.h> -#include <netdev.h> #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> @@ -52,16 +49,6 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define ENET_PAD_CTRL_PD (PAD_CTL_PUS_100K_DOWN | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define ENET_PAD_CTRL_CLK ((PAD_CTL_PUS_100K_UP & ~PAD_CTL_PKE) | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) - -#define ETH_PHY_RESET IMX_GPIO_NR(4, 15) #define USB_H1_VBUS IMX_GPIO_NR(1, 0)
enum board_type { @@ -237,110 +224,6 @@ int board_mmc_init(bd_t *bis) return 0; }
-static iomux_v3_cfg_t const enet_pads[] = { - IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - /* AR8035 reset */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD)), - /* AR8035 interrupt */ - IOMUX_PADS(PAD_DI0_PIN2__GPIO4_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL)), - /* GPIO16 -> AR8035 25MHz */ - IOMUX_PADS(PAD_GPIO_16__ENET_REF_CLK | MUX_PAD_CTRL(NO_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(NO_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), - /* AR8035 CLK_25M --> ENET_REF_CLK (V22) */ - IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL_CLK)), - IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD)), - IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD)), - IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL_PD)), - IOMUX_PADS(PAD_ENET_RXD0__GPIO1_IO27 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD)), - IOMUX_PADS(PAD_ENET_RXD1__GPIO1_IO26 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD)), -}; - -static void setup_iomux_enet(void) -{ - struct gpio_desc desc; - int ret; - - SETUP_IOMUX_PADS(enet_pads); - - ret = dm_gpio_lookup_name("GPIO4_15", &desc); - if (ret) { - printf("%s: phy reset lookup failed\n", __func__); - return; - } - - ret = dm_gpio_request(&desc, "phy-reset"); - if (ret) { - printf("%s: phy reset request failed\n", __func__); - return; - } - - gpio_direction_output(ETH_PHY_RESET, 0); - mdelay(10); - gpio_set_value(ETH_PHY_RESET, 1); - udelay(100); - - gpio_free_list_nodev(&desc, 1); -} - -int board_phy_config(struct phy_device *phydev) -{ - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} - -/* On Cuboxi Ethernet PHY can be located at addresses 0x0 or 0x4 */ -#define ETH_PHY_MASK ((1 << 0x0) | (1 << 0x4)) - -int board_eth_init(bd_t *bis) -{ - struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; - struct mii_dev *bus; - struct phy_device *phydev; - - int ret = enable_fec_anatop_clock(0, ENET_25MHZ); - if (ret) - return ret; - - /* set gpr1[ENET_CLK_SEL] */ - setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK); - - setup_iomux_enet(); - - bus = fec_get_miibus(IMX_FEC_BASE, -1); - if (!bus) - return -EINVAL; - - phydev = phy_find_by_mask(bus, ETH_PHY_MASK, PHY_INTERFACE_MODE_RGMII); - if (!phydev) { - ret = -EINVAL; - goto free_bus; - } - - debug("using phy at address %d\n", phydev->addr); - ret = fec_probe(bis, -1, IMX_FEC_BASE, bus, phydev); - if (ret) - goto free_phydev; - - return 0; - -free_phydev: - free(phydev); -free_bus: - free(bus); - return ret; -} - #ifdef CONFIG_VIDEO_IPUV3 static void do_enable_hdmi(struct display_info_t const *dev) { @@ -433,6 +316,21 @@ static int setup_display(void) } #endif /* CONFIG_VIDEO_IPUV3 */
+static int setup_fec(void) +{ + struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + int ret; + + ret = enable_fec_anatop_clock(0, ENET_25MHZ); + if (ret) + return ret; + + /* set gpr1[ENET_CLK_SEL] */ + setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK); + + return 0; +} + int board_early_init_f(void) { setup_iomux_uart(); @@ -440,6 +338,8 @@ int board_early_init_f(void) #ifdef CONFIG_CMD_SATA setup_sata(); #endif + setup_fec(); + return 0; }
diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index df7e4611a0..568cfce4c0 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -50,6 +50,9 @@ CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 2ccf44e573..96f79e6b58 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -29,12 +29,6 @@ #define CONFIG_LBA48 #endif
-/* Ethernet Configuration */ -#define CONFIG_FEC_MXC -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RGMII -#define CONFIG_FEC_MXC_PHYADDR 0 - /* Framebuffer */ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN
Sorry, there are two Signed-off-by's from me and an extra blank line.
Maybe Stefano could fix it while applying it?
If not, I can send a v3.
Not needed, I fix by merging.
Stefano
Fabio Estevam
Stefano Babic
