[PATCH] board: gateworks: venice: add fixup for GW73xx-C+
The GW73xx-C revision and onward replaced the 5-port PCIe switch with a 4-port (dropping PCIe to one of the miniPCIe sockets) due to part availability. This moved the PCI bus of the GbE eth1 device. Use a fixup to adjust the dt accordingly so that local-mac-address assigned from dt works on new revision boards.
While we are at it, rename 'blob' to 'fdt' for clarity.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/venice/eeprom.c | 7 ++++++ board/gateworks/venice/eeprom.h | 3 +++ board/gateworks/venice/venice.c | 43 +++++++++++++++++++++++++++------ 3 files changed, 46 insertions(+), 7 deletions(-)
diff --git a/board/gateworks/venice/eeprom.c b/board/gateworks/venice/eeprom.c index 7a46f44828ce..b754ef95903f 100644 --- a/board/gateworks/venice/eeprom.c +++ b/board/gateworks/venice/eeprom.c @@ -20,6 +20,7 @@ struct venice_board_info som_info; struct venice_board_info base_info; char venice_model[32]; +char venice_baseboard_model[32]; u32 venice_serial;
/* return a mac address from EEPROM info */ @@ -321,6 +322,7 @@ int eeprom_init(int quiet) base_info.model[3], /* baseboard */ base_info.model[4], base_info.model[5], /* subload of baseboard */ som_info.model[4], som_info.model[5]); /* last 2digits of SOM */ + strncpy(venice_baseboard_model, base_info.model, sizeof(venice_baseboard_model));
/* baseboard revision */ rev_pcb = get_pcb_rev(base_info.model); @@ -357,6 +359,11 @@ const char *eeprom_get_model(void) return venice_model; }
+const char *eeprom_get_baseboard_model(void) +{ + return venice_baseboard_model; +} + u32 eeprom_get_serial(void) { return venice_serial; diff --git a/board/gateworks/venice/eeprom.h b/board/gateworks/venice/eeprom.h index 37bfe76ad81e..8ea7318d7dfc 100644 --- a/board/gateworks/venice/eeprom.h +++ b/board/gateworks/venice/eeprom.h @@ -26,8 +26,11 @@ struct venice_board_info {
int eeprom_init(int quiet); const char *eeprom_get_model(void); +const char *eeprom_get_baseboard_model(void); const char *eeprom_get_dtb_name(int level, char *buf, int len); int eeprom_getmac(int index, uint8_t *enetaddr); uint32_t eeprom_get_serial(void); +int get_bom_rev(const char *str); +char get_pcb_rev(const char *str);
#endif diff --git a/board/gateworks/venice/venice.c b/board/gateworks/venice/venice.c index 4290a6980771..976b0c70f128 100644 --- a/board/gateworks/venice/venice.c +++ b/board/gateworks/venice/venice.c @@ -3,6 +3,7 @@ * Copyright 2021 Gateworks Corporation */
+#include <fdt_support.h> #include <init.h> #include <led.h> #include <miiphy.h> @@ -171,26 +172,54 @@ int board_mmc_get_env_dev(int devno) return devno; }
-int ft_board_setup(void *blob, struct bd_info *bd) +int ft_board_setup(void *fdt, struct bd_info *bd) { + const char *base_model = eeprom_get_baseboard_model(); + char pcbrev; int off;
/* set board model dt prop */ - fdt_setprop_string(blob, 0, "board", eeprom_get_model()); + fdt_setprop_string(fdt, 0, "board", eeprom_get_model());
/* update temp thresholds */ - off = fdt_path_offset(blob, "/thermal-zones/cpu-thermal/trips"); + off = fdt_path_offset(fdt, "/thermal-zones/cpu-thermal/trips"); if (off >= 0) { int minc, maxc, prop;
get_cpu_temp_grade(&minc, &maxc); - fdt_for_each_subnode(prop, blob, off) { - const char *type = fdt_getprop(blob, prop, "type", NULL); + fdt_for_each_subnode(prop, fdt, off) { + const char *type = fdt_getprop(fdt, prop, "type", NULL);
if (type && (!strcmp("critical", type))) - fdt_setprop_u32(blob, prop, "temperature", maxc * 1000); + fdt_setprop_u32(fdt, prop, "temperature", maxc * 1000); else if (type && (!strcmp("passive", type))) - fdt_setprop_u32(blob, prop, "temperature", (maxc - 10) * 1000); + fdt_setprop_u32(fdt, prop, "temperature", (maxc - 10) * 1000); + } + } + + if (!strncmp(base_model, "GW73", 4)) { + pcbrev = get_pcb_rev(base_model); + + if (pcbrev > 'B') { + printf("adjusting dt for %s\n", base_model); + + /* + * revC replaced PCIe 5-port switch with 4-port + * which changed ethernet1 PCIe GbE + * from: pcie@0,0/pcie@1,0/pcie@2,4/pcie@6.0 + * to: pcie@0,0/pcie@1,0/pcie@2,3/pcie@5.0 + */ + off = fdt_path_offset(fdt, "ethernet1"); + if (off > 0) { + uint32_t reg[5]; + + fdt_set_name(fdt, off, "pcie@5,0"); + off = fdt_parent_offset(fdt, off); + fdt_set_name(fdt, off, "pcie@2,3"); + memset(reg, 0, sizeof(reg)); + reg[0] = cpu_to_fdt32(PCI_DEVFN(3, 0)); + fdt_setprop(fdt, off, "reg", reg, sizeof(reg)); + } } }
Tim Harvey
