[U-Boot] [PATCH v5] arm: omap3: Add SPL support to cm_t35
Add SPL U-Boot support to replace x-loader on the Compulab cm_t35 board. Currently only the 256MiB SDRAM board versions are supported.
Tested by booting via MMC and NAND.
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@ti.com Cc: Igor Grinberg grinberg@compulab.co.il Cc: Nikita Kiryanov nikita@compulab.co.il --- v5: - Added CONFIG_NAND_OMAP_ECCSCHEME to select HW ECC by default - Tested with latest mainline U-Boot 2014.01-rc1, needs fix for 8bit NAND device from Pekon Gupta
v4: - Rebased and retested on current mainline version
v3: - Some instability of this SDRAM setup has been detected while running Linux. Comparison with the x-loader setup showed that mcfg is configured slightly differently here. CM_T35 needs RAS-width of 14 instead of 13. So use the define MICRON_V_MCFG_200 which implements this 14 as RAS width.
v2: - Change CONFIG_SYS_TEXT_BASE back to 0x80008000 for x-loader compatibility - Change CONFIG_SPL_BSS_START_ADDR to 0x80100000 to not overlap with TEXT_BASE now
board/compulab/cm_t35/cm_t35.c | 18 +++++++++++- include/configs/cm_t35.h | 65 ++++++++++++++++++++++++++++++++++++++++-- 2 files changed, 80 insertions(+), 3 deletions(-)
diff --git a/board/compulab/cm_t35/cm_t35.c b/board/compulab/cm_t35/cm_t35.c index bc8e0ca..00bcf41 100644 --- a/board/compulab/cm_t35/cm_t35.c +++ b/board/compulab/cm_t35/cm_t35.c @@ -105,6 +105,22 @@ static inline int splash_load_from_nand(void) } #endif /* CONFIG_CMD_NAND */
+#ifdef CONFIG_SPL_BUILD +/* + * Routine: get_board_mem_timings + * Description: If we use SPL then there is no x-loader nor config header + * so we have to setup the DDR timings ourself on both banks. + */ +void get_board_mem_timings(struct board_sdrc_timings *timings) +{ + timings->mr = MICRON_V_MR_165; + timings->mcfg = MICRON_V_MCFG_200(256 << 20); /* raswidth 14 needed */ + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; +} +#endif + int splash_screen_prepare(void) { char *env_splashimage_value; @@ -440,7 +456,7 @@ void set_muxconf_regs(void) cm_t3730_set_muxconf(); }
-#ifdef CONFIG_GENERIC_MMC +#if defined(CONFIG_GENERIC_MMC) && !defined(CONFIG_SPL_BUILD) int board_mmc_getcd(struct mmc *mmc) { u8 val; diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index f4ecd0d..2e865c0 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -27,8 +27,6 @@ #define CONFIG_CM_T3X /* working with CM-T35 and CM-T3730 */ #define CONFIG_OMAP_COMMON
-#define CONFIG_SYS_TEXT_BASE 0x80008000 - #define CONFIG_SDRC /* The chip has SDRC controller */
#include <asm/arch/cpu.h> /* get chip and board defs */ @@ -329,4 +327,67 @@
#define CONFIG_OMAP3_SPI
+/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_NAND_SIMPLE + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_OMAP3_ID_NAND +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +/* NAND boot config */ +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +/* + * Use the ECC/OOB layout from omap_gpmc.h that matches your chip: + * SP vs LP, 8bit vs 16bit: GPMC_NAND_HW_ECC_LAYOUT + */ +#define CONFIG_SYS_NAND_ECCPOS { 1, 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12 } +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 + +#define CONFIG_SPL_TEXT_BASE 0x40200800 +#define CONFIG_SPL_MAX_SIZE (54 * 1024) /* 8 KB for stack */ +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +/* + * Use 0x80008000 as TEXT_BASE here for compatibility reasons with the + * older x-loader implementations. And move the BSS area so that it + * doesn't overlap with TEXT_BASE. + */ +#define CONFIG_SYS_TEXT_BASE 0x80008000 +#define CONFIG_SPL_BSS_START_ADDR 0x80100000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + #endif /* __CONFIG_H */
Hi Stefan,
Finally, I've found some time to look at the patch... Generally, it is fine... I say generally, because we have found several bugs, but they are not related to your patch... but to Pekon's work on the omap nand driver. Nikita is on them ;-)
One minor comment below...
Apart from the comment below, Acked-by: Igor Grinberg grinberg@compulab.co.il
v5:
v4:
v3:
v2:
- Routine: get_board_mem_timings
- Description: If we use SPL then there is no x-loader nor config header
- so we have to setup the DDR timings ourself on both banks.
- timings->mr = MICRON_V_MR_165;
- timings->mcfg = MICRON_V_MCFG_200(256 << 20); /* raswidth 14 needed */
- timings->ctrla = MICRON_V_ACTIMA_165;
- timings->ctrlb = MICRON_V_ACTIMB_165;
- timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz;
+} +#endif
Our U-Boot binary sizes are beyond 300KiB... This config is not used anywhere besides config files and README... That's why it probably works for you... I think we should either remove it from the README and configs, or set it to 0x300 or even 0x400 instead (in case we still want to use it, although I don't know why, as we have the size from the image header).
- Use the ECC/OOB layout from omap_gpmc.h that matches your chip:
- SP vs LP, 8bit vs 16bit: GPMC_NAND_HW_ECC_LAYOUT
10, 11, 12 }
- Use 0x80008000 as TEXT_BASE here for compatibility reasons with the
- older x-loader implementations. And move the BSS area so that it
- doesn't overlap with TEXT_BASE.
Hi Igor!
Good. :)
<snip>
Good catch. If it is not used/referenced at all, then let's remove it completely. It makes no sense to drag such an unused define along. Could lead only to confusion.
But we can and should remove this in a separate patch.
Thanks, Stefan
On 12/11/13 16:55, Stefan Roese wrote:
Hi Igor!
Good. :)
<snip>
Fare enough!
Tom, can you please apply this one?
Thanks!
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@ti.com Cc: Igor Grinberg grinberg@compulab.co.il Cc: Nikita Kiryanov nikita@compulab.co.il Acked-by: Igor Grinberg grinberg@compulab.co.il
Applied to u-boot-ti/master, thanks!
Igor Grinberg
Stefan Roese
