[PATCH] tools/mxsimage: Remove fclose on empty FILE pointer
If `sb_load_cmdfile()` fails to open the configuration file it will jump to error handling where the code will try to `fclose()` the FILE pointer which is NULL causing `mkimage` to segfault.
This patch removes the `fclose()` since `fopen()` always returns NULL instead of the file descriptor when failing.
Signed-off-by: Mattias Hansson hansson.mattias@gmail.com --- tools/mxsimage.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/tools/mxsimage.c b/tools/mxsimage.c index 002f4b525a..c7bd86ce52 100644 --- a/tools/mxsimage.c +++ b/tools/mxsimage.c @@ -1618,7 +1618,6 @@ static int sb_load_cmdfile(struct sb_image_ctx *ictx) return 0;
err_file: - fclose(fp); fprintf(stderr, "ERR: Failed to load file "%s"\n", ictx->cfg_filename); return -EINVAL;
Mattias Hansson
