[U-Boot] [PATCH v2] test/py: only check for SPL signature if SPL uses serial output
check for U-Boot SPL signature only if SPL really has a serial output. So check if CONFIG_SPL_SERIAL_SUPPORT is active in board config.
Signed-off-by: Heiko Schocher hs@denx.de --- found this while trying test/py on the smartweb board, which has SPL but no SPL serial output.
Changes in v2: - add comments from Stephen Warren: - introduce some variables to shorten text - do not use nested if, instead use "if a and b" - use wrapping of 72-74 chars in commit message - add Michal Simek to Cc
test/py/u_boot_console_base.py | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index bc2bd76..79b8dc6 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -303,8 +303,13 @@ class ConsoleBase(object): if not self.config.gdbserver: self.p.timeout = 30000 self.p.logfile_read = self.logstream - if self.config.buildconfig.get('config_spl', False) == 'y': - m = self.p.expect([pattern_u_boot_spl_signon] + self.bad_patterns) + bcfg = u_boot_console.config.buildconfig + config_spl = bcfg.get('config_spl', 'n') == 'y' + config_spl_serial_support = bcfg.get('config_spl_serial_support', + 'n') == 'y' + if config_spl and config_spl_serial_support: + m = self.p.expect([pattern_u_boot_spl_signon] + + self.bad_patterns) if m != 0: raise Exception('Bad pattern found on console: ' + self.bad_pattern_ids[m - 1])
I suspect you didn't test this; it causes all tests to fail on all platforms...
I think that should be self.config.buildconfig instead; there is no u_boot_console variable at this point in the code.
Hello Stephen,
Am 17.02.2016 um 17:45 schrieb Stephen Warren:
Damn, yes, seems I overlooked this issue, while trying to get test/py running for the smartweb board.
fixed.
bye, Heiko
Heiko Schocher
Stephen Warren
