[v1] disable NFS support by default
While NFS is widely used in data centres, and private networks it's quite a nuanced usecase for device firmware. A lot of devices already disable it.
Various network protocols should really be opt in, not opt out, because they add extra size and are potential attack vectors from a security PoV. In the NFS case it doesn't really make sense for a lot of devices like tables, SBCs etc. It's also something we don't really want for SystemReady-IR due to security concerns.
Signed-off-by: Peter Robinson pbrobinson@gmail.com ---
v1: drop RFC tag
cmd/Kconfig | 1 - configs/10m50_defconfig | 1 - configs/3c120_defconfig | 1 - configs/CMPC885_defconfig | 1 - configs/CMPCPRO_defconfig | 1 - configs/apalis-tk1_defconfig | 1 - configs/apalis_imx6_defconfig | 1 - configs/apalis_t30_defconfig | 1 - configs/bayleybay_defconfig | 1 - configs/beaver_defconfig | 1 - configs/bitmain_antminer_s9_defconfig | 1 - configs/brppt1_mmc_defconfig | 1 - configs/brppt2_defconfig | 1 - configs/brsmarc1_defconfig | 1 - configs/brxre1_defconfig | 1 - configs/cardhu_defconfig | 1 - configs/cei-tk1-som_defconfig | 1 - configs/cherryhill_defconfig | 1 - configs/chromebook_link64_defconfig | 1 - configs/chromebook_link_defconfig | 1 - configs/chromebook_samus_defconfig | 1 - configs/chromebox_panther_defconfig | 1 - configs/cm_t43_defconfig | 1 - configs/colibri_imx6_defconfig | 1 - configs/colibri_t20_defconfig | 1 - configs/colibri_t30_defconfig | 1 - configs/colibri_vf_defconfig | 1 - configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 - configs/conga-qeval20-qa3-e3845_defconfig | 1 - configs/coreboot64_defconfig | 1 - configs/coreboot_defconfig | 1 - configs/corstone1000_defconfig | 1 - configs/cougarcanyon2_defconfig | 1 - configs/crownbay_defconfig | 1 - configs/dalmore_defconfig | 1 - configs/dfi-bt700-q7x-151_defconfig | 1 - configs/edison_defconfig | 1 - configs/efi-x86_payload32_defconfig | 1 - configs/efi-x86_payload64_defconfig | 1 - configs/galileo_defconfig | 1 - configs/gazerbeam_defconfig | 1 - configs/ge_bx50v3_defconfig | 1 - configs/harmony_defconfig | 1 - configs/jetson-tk1_defconfig | 1 - configs/malta64_defconfig | 1 - configs/malta64el_defconfig | 1 - configs/malta_defconfig | 1 - configs/maltael_defconfig | 1 - configs/medcom-wide_defconfig | 1 - configs/minnowmax_defconfig | 1 - configs/mscc_jr2_defconfig | 1 - configs/mscc_luton_defconfig | 1 - configs/mscc_ocelot_defconfig | 1 - configs/mscc_serval_defconfig | 1 - configs/mscc_servalt_defconfig | 1 - configs/mt7620_mt7530_rfb_defconfig | 1 - configs/mt7620_rfb_defconfig | 1 - configs/mt7621_nand_rfb_defconfig | 1 - configs/mt7621_rfb_defconfig | 1 - configs/mt7623a_unielec_u7623_02_defconfig | 1 - configs/mt7623n_bpir2_defconfig | 1 - configs/mt7628_rfb_defconfig | 1 - configs/mt7629_rfb_defconfig | 1 - configs/nyan-big_defconfig | 1 - configs/odroid_defconfig | 1 - configs/omap4_panda_defconfig | 1 - configs/omap4_sdp4430_defconfig | 1 - configs/p2371-0000_defconfig | 1 - configs/p2371-2180_defconfig | 1 - configs/p2571_defconfig | 1 - configs/p2771-0000-000_defconfig | 1 - configs/p2771-0000-500_defconfig | 1 - configs/p3450-0000_defconfig | 1 - configs/paz00_defconfig | 1 - configs/plutux_defconfig | 1 - configs/qemu-x86_64_defconfig | 1 - configs/qemu-x86_defconfig | 1 - configs/seaboard_defconfig | 1 - configs/smdkv310_defconfig | 1 - configs/sniper_defconfig | 1 - configs/socrates_defconfig | 1 - configs/som-db5800-som-6867_defconfig | 1 - configs/tec-ng_defconfig | 1 - configs/tec_defconfig | 1 - configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig | 1 - configs/theadorable-x86-conga-qa3-e3845_defconfig | 1 - configs/theadorable-x86-dfi-bt700_defconfig | 1 - configs/trimslice_defconfig | 1 - configs/venice2_defconfig | 1 - configs/ventana_defconfig | 1 - configs/vexpress_ca9x4_defconfig | 1 - 91 files changed, 91 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 365371fb511..a193929cec4 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1848,7 +1848,6 @@ config CMD_RARP
config CMD_NFS bool "nfs" - default y help Boot image via network using NFS protocol.
diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index 54a67c5aa98..b76f31b009f 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index fc73c0613d0..13da353d7eb 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/CMPC885_defconfig b/configs/CMPC885_defconfig index f5bc6d6c004..54873daa156 100644 --- a/configs/CMPC885_defconfig +++ b/configs/CMPC885_defconfig @@ -51,7 +51,6 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_MTD=y CONFIG_CMD_NAND=y CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_MII_INIT=y CONFIG_CMD_PING=y diff --git a/configs/CMPCPRO_defconfig b/configs/CMPCPRO_defconfig index 80913e653be..d817274a936 100644 --- a/configs/CMPCPRO_defconfig +++ b/configs/CMPCPRO_defconfig @@ -136,7 +136,6 @@ CONFIG_CMD_MTD=y CONFIG_CMD_NAND=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 36d28a249cd..fda85c2d6ae 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -43,7 +43,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index d7342c4968b..eff4039b008 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -65,7 +65,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 516552584c7..83aab2450be 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 4e59d513cdc..a44c9b714be 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 3820a333ecb..0d8a74be7aa 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index c38ba15cd03..3995d41ce1b 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -55,7 +55,6 @@ CONFIG_CMD_PART=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 2c9b0662159..653620263cd 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -64,7 +64,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index 00ef3d9908e..05ee4c5797e 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -56,7 +56,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_CACHE=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 1e55ed7c60d..94943fccf1a 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -73,7 +73,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 1c437e9743c..b50aef0aad9 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -63,7 +63,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 00fea793f92..4fe4621f037 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index c00e6bec5a3..b920ac2ae40 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -41,7 +41,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/cherryhill_defconfig b/configs/cherryhill_defconfig index 4137b1c77e9..00799715e8f 100644 --- a/configs/cherryhill_defconfig +++ b/configs/cherryhill_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 8c75d654290..558609e13d6 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -50,7 +50,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 3098857d6e1..96c26f1c377 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 0d20891d2bc..4019c169a4c 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 96c739cbfbc..f050d066be4 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index a307e83d1d4..12d010ab64b 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -62,7 +62,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index e25cde9e5fa..3e193349e23 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -64,7 +64,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index cdf9e8b1d01..eb2e202f6f2 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index fed867a8eb2..8098ff7abc1 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index c47bfc801a2..4d4d0e4aaf4 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -51,7 +51,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT4=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 14f00b6212e..656d575998c 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 613dcd3ca59..54dc59e8a13 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -40,7 +40,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/coreboot64_defconfig b/configs/coreboot64_defconfig index 60a1924e9e5..8aadaa68c27 100644 --- a/configs/coreboot64_defconfig +++ b/configs/coreboot64_defconfig @@ -30,7 +30,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/coreboot_defconfig b/configs/coreboot_defconfig index 058caf008f9..0f3512d23c6 100644 --- a/configs/coreboot_defconfig +++ b/configs/coreboot_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/corstone1000_defconfig b/configs/corstone1000_defconfig index 2d391048cd6..112d502e91f 100644 --- a/configs/corstone1000_defconfig +++ b/configs/corstone1000_defconfig @@ -30,7 +30,6 @@ CONFIG_CMD_LOADM=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 47834bb6fef..da5ff5573d0 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 69ad017f987..70e1a50a244 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -33,7 +33,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 936787bb39c..92f4436eebd 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 14e6e6c2d84..9313e7fbd12 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/edison_defconfig b/configs/edison_defconfig index 00342aace9a..8692a8a9995 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_DFU=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_TIMER=y CONFIG_CMD_HASH=y CONFIG_CMD_EXT4=y diff --git a/configs/efi-x86_payload32_defconfig b/configs/efi-x86_payload32_defconfig index a5c629b46f3..4149eea6cf6 100644 --- a/configs/efi-x86_payload32_defconfig +++ b/configs/efi-x86_payload32_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/efi-x86_payload64_defconfig b/configs/efi-x86_payload64_defconfig index 5cde04a5ac9..d41f73cccfc 100644 --- a/configs/efi-x86_payload64_defconfig +++ b/configs/efi-x86_payload64_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 0d2ebdab926..c6d989ea6ef 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index c8c8469d8a6..7901a195aa7 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -123,7 +123,6 @@ CONFIG_SYS_LOADS_BAUD_CHANGE=y CONFIG_CMD_MMC=y CONFIG_CMD_AXI=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index f005e91e0bc..2ef560ccaa4 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index b1d9399b860..8b49505a650 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index b2a39e0c844..d8086281582 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -40,7 +40,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index 03de1616840..a69e1934fe8 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index 3ea9fa9857e..21a291d341c 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 317b422a6b6..8c76ebbb155 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 3e4d2beda2f..4abd3b15580 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 47fcf1574e4..e99bb8f5b52 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 6082b8d70d6..8347a9dcecf 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -43,7 +43,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index b30b804dbf2..e3ff906098a 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index 9a1e0c3e064..e811bc97e1f 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -46,7 +46,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index a372b21f66b..f3246f22196 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_MTD=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index 055ed68305a..4ff7933717b 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -41,7 +41,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index 6e225a69389..5f6ed73c2ed 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -40,7 +40,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" diff --git a/configs/mt7620_mt7530_rfb_defconfig b/configs/mt7620_mt7530_rfb_defconfig index 96f10926b13..af9df547d57 100644 --- a/configs/mt7620_mt7530_rfb_defconfig +++ b/configs/mt7620_mt7530_rfb_defconfig @@ -38,7 +38,6 @@ CONFIG_SYS_BOOTM_LEN=0x1000000 CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_SPI=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y # CONFIG_CMD_MDIO is not set CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupts resets reset-names" diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig index d96da91df36..fe57fd1892d 100644 --- a/configs/mt7620_rfb_defconfig +++ b/configs/mt7620_rfb_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y # CONFIG_CMD_MDIO is not set CONFIG_CMD_FAT=y diff --git a/configs/mt7621_nand_rfb_defconfig b/configs/mt7621_nand_rfb_defconfig index 5291bb300e4..368bf800968 100644 --- a/configs/mt7621_nand_rfb_defconfig +++ b/configs/mt7621_nand_rfb_defconfig @@ -49,7 +49,6 @@ CONFIG_CMD_MTD=y CONFIG_CMD_PART=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_USB=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/mt7621_rfb_defconfig b/configs/mt7621_rfb_defconfig index b50fbec92dd..49c9e7411d8 100644 --- a/configs/mt7621_rfb_defconfig +++ b/configs/mt7621_rfb_defconfig @@ -47,7 +47,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PART=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_SPI=y -# CONFIG_CMD_NFS is not set CONFIG_DOS_PARTITION=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set diff --git a/configs/mt7623a_unielec_u7623_02_defconfig b/configs/mt7623a_unielec_u7623_02_defconfig index a7687b54f0c..20c84d65df7 100644 --- a/configs/mt7623a_unielec_u7623_02_defconfig +++ b/configs/mt7623a_unielec_u7623_02_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_READ=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/mt7623n_bpir2_defconfig b/configs/mt7623n_bpir2_defconfig index 62a17f2cbc7..5e7c1fefadb 100644 --- a/configs/mt7623n_bpir2_defconfig +++ b/configs/mt7623n_bpir2_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_READ=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig index 0e100fca498..7e5b76c590a 100644 --- a/configs/mt7628_rfb_defconfig +++ b/configs/mt7628_rfb_defconfig @@ -37,7 +37,6 @@ CONFIG_SYS_BOOTM_LEN=0x1000000 CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_SPI=y -# CONFIG_CMD_NFS is not set CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/mt7629_rfb_defconfig b/configs/mt7629_rfb_defconfig index ea8d77c0a26..0e3bd4ffa7b 100644 --- a/configs/mt7629_rfb_defconfig +++ b/configs/mt7629_rfb_defconfig @@ -48,7 +48,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index a9c10cdbb0b..cc64facd5f2 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -45,7 +45,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index ce0c47e505d..b1943cfd39b 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -41,7 +41,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_SLEEP is not set CONFIG_CMD_PMIC=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index e27e27d0143..5571722ea6d 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -33,7 +33,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 909f10ee790..0a8a1c77ea4 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index 7e75f44c743..dcfd3eb99a5 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 2543a2d11f8..5b91631367b 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_LIVE=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index 47a0a62d252..7e2829e3a0d 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index e3b978eb1ed..ae235058afd 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index c99a24eef40..0ea47192dda 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/p3450-0000_defconfig b/configs/p3450-0000_defconfig index e280be8f2ec..b0d538f0f83 100644 --- a/configs/p3450-0000_defconfig +++ b/configs/p3450-0000_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_LIVE=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index fadf7fdeb07..8c125c39b2f 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 4fee9df94f8..ab9aef5e478 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index f29a5aa0f81..6a539a859e0 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -47,7 +47,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_TIME=y CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 9bf29647fe5..a7c37b8b0e1 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_TIME=y CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 00cca911710..f8759f25546 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index cc0ecad11b3..2f466d23a54 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_PBSIZE=1024 # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index f6b59a6e9b8..c762d75aec1 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_I2C_LEGACY=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 6b67021064a..7727e4669d7 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -57,7 +57,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index ad95274879a..4a149133db6 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 442cee33a9f..4776e92683d 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 461c46c725d..8a5d959a5c0 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig index 43dab09316e..69499e17f4c 100644 --- a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y diff --git a/configs/theadorable-x86-conga-qa3-e3845_defconfig b/configs/theadorable-x86-conga-qa3-e3845_defconfig index 5aec52733e6..e2e64b74349 100644 --- a/configs/theadorable-x86-conga-qa3-e3845_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index d5a28a2df4b..751ae3497ec 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index d94a0b408b5..9ec08bda883 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index fd538da3ac5..ebd1754fc8b 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 5e2ff877ca8..2da8ba94d62 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 4ee64c332b3..5cacecc7cbc 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -30,7 +30,6 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set # CONFIG_CMD_SLEEP is not set CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y
v1: drop RFC tag
diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index 54a67c5aa98..b76f31b009f 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index fc73c0613d0..13da353d7eb 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/CMPC885_defconfig b/configs/CMPC885_defconfig index f5bc6d6c004..54873daa156 100644 --- a/configs/CMPC885_defconfig +++ b/configs/CMPC885_defconfig @@ -51,7 +51,6 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_MTD=y CONFIG_CMD_NAND=y CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_MII_INIT=y CONFIG_CMD_PING=y diff --git a/configs/CMPCPRO_defconfig b/configs/CMPCPRO_defconfig index 80913e653be..d817274a936 100644 --- a/configs/CMPCPRO_defconfig +++ b/configs/CMPCPRO_defconfig @@ -136,7 +136,6 @@ CONFIG_CMD_MTD=y CONFIG_CMD_NAND=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 36d28a249cd..fda85c2d6ae 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -43,7 +43,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index d7342c4968b..eff4039b008 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -65,7 +65,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 516552584c7..83aab2450be 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 4e59d513cdc..a44c9b714be 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 3820a333ecb..0d8a74be7aa 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index c38ba15cd03..3995d41ce1b 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -55,7 +55,6 @@ CONFIG_CMD_PART=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 2c9b0662159..653620263cd 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -64,7 +64,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index 00ef3d9908e..05ee4c5797e 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -56,7 +56,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_CACHE=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 1e55ed7c60d..94943fccf1a 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -73,7 +73,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 1c437e9743c..b50aef0aad9 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -63,7 +63,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_ITEST is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 00fea793f92..4fe4621f037 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index c00e6bec5a3..b920ac2ae40 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -41,7 +41,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/cherryhill_defconfig b/configs/cherryhill_defconfig index 4137b1c77e9..00799715e8f 100644 --- a/configs/cherryhill_defconfig +++ b/configs/cherryhill_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 8c75d654290..558609e13d6 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -50,7 +50,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 3098857d6e1..96c26f1c377 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 0d20891d2bc..4019c169a4c 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 96c739cbfbc..f050d066be4 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index a307e83d1d4..12d010ab64b 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -62,7 +62,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index e25cde9e5fa..3e193349e23 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -64,7 +64,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index cdf9e8b1d01..eb2e202f6f2 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index fed867a8eb2..8098ff7abc1 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index c47bfc801a2..4d4d0e4aaf4 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -51,7 +51,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT4=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 14f00b6212e..656d575998c 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 613dcd3ca59..54dc59e8a13 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -40,7 +40,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/coreboot64_defconfig b/configs/coreboot64_defconfig index 60a1924e9e5..8aadaa68c27 100644 --- a/configs/coreboot64_defconfig +++ b/configs/coreboot64_defconfig @@ -30,7 +30,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/coreboot_defconfig b/configs/coreboot_defconfig index 058caf008f9..0f3512d23c6 100644 --- a/configs/coreboot_defconfig +++ b/configs/coreboot_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/corstone1000_defconfig b/configs/corstone1000_defconfig index 2d391048cd6..112d502e91f 100644 --- a/configs/corstone1000_defconfig +++ b/configs/corstone1000_defconfig @@ -30,7 +30,6 @@ CONFIG_CMD_LOADM=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 47834bb6fef..da5ff5573d0 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 69ad017f987..70e1a50a244 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -33,7 +33,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 936787bb39c..92f4436eebd 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 14e6e6c2d84..9313e7fbd12 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/edison_defconfig b/configs/edison_defconfig index 00342aace9a..8692a8a9995 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_DFU=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_TIMER=y CONFIG_CMD_HASH=y CONFIG_CMD_EXT4=y diff --git a/configs/efi-x86_payload32_defconfig b/configs/efi-x86_payload32_defconfig index a5c629b46f3..4149eea6cf6 100644 --- a/configs/efi-x86_payload32_defconfig +++ b/configs/efi-x86_payload32_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/efi-x86_payload64_defconfig b/configs/efi-x86_payload64_defconfig index 5cde04a5ac9..d41f73cccfc 100644 --- a/configs/efi-x86_payload64_defconfig +++ b/configs/efi-x86_payload64_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 0d2ebdab926..c6d989ea6ef 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index c8c8469d8a6..7901a195aa7 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -123,7 +123,6 @@ CONFIG_SYS_LOADS_BAUD_CHANGE=y CONFIG_CMD_MMC=y CONFIG_CMD_AXI=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index f005e91e0bc..2ef560ccaa4 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index b1d9399b860..8b49505a650 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index b2a39e0c844..d8086281582 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -40,7 +40,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index 03de1616840..a69e1934fe8 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index 3ea9fa9857e..21a291d341c 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 317b422a6b6..8c76ebbb155 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 3e4d2beda2f..4abd3b15580 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 47fcf1574e4..e99bb8f5b52 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 6082b8d70d6..8347a9dcecf 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -43,7 +43,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index b30b804dbf2..e3ff906098a 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index 9a1e0c3e064..e811bc97e1f 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -46,7 +46,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index a372b21f66b..f3246f22196 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_MTD=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index 055ed68305a..4ff7933717b 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -41,7 +41,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index 6e225a69389..5f6ed73c2ed 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -40,7 +40,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y # CONFIG_NET_TFTP_VARS is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" diff --git a/configs/mt7620_mt7530_rfb_defconfig b/configs/mt7620_mt7530_rfb_defconfig index 96f10926b13..af9df547d57 100644 --- a/configs/mt7620_mt7530_rfb_defconfig +++ b/configs/mt7620_mt7530_rfb_defconfig @@ -38,7 +38,6 @@ CONFIG_SYS_BOOTM_LEN=0x1000000 CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_SPI=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y # CONFIG_CMD_MDIO is not set CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupts resets reset-names" diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig index d96da91df36..fe57fd1892d 100644 --- a/configs/mt7620_rfb_defconfig +++ b/configs/mt7620_rfb_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y # CONFIG_CMD_MDIO is not set CONFIG_CMD_FAT=y diff --git a/configs/mt7621_nand_rfb_defconfig b/configs/mt7621_nand_rfb_defconfig index 5291bb300e4..368bf800968 100644 --- a/configs/mt7621_nand_rfb_defconfig +++ b/configs/mt7621_nand_rfb_defconfig @@ -49,7 +49,6 @@ CONFIG_CMD_MTD=y CONFIG_CMD_PART=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_USB=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/mt7621_rfb_defconfig b/configs/mt7621_rfb_defconfig index b50fbec92dd..49c9e7411d8 100644 --- a/configs/mt7621_rfb_defconfig +++ b/configs/mt7621_rfb_defconfig @@ -47,7 +47,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PART=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_SPI=y -# CONFIG_CMD_NFS is not set CONFIG_DOS_PARTITION=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set diff --git a/configs/mt7623a_unielec_u7623_02_defconfig b/configs/mt7623a_unielec_u7623_02_defconfig index a7687b54f0c..20c84d65df7 100644 --- a/configs/mt7623a_unielec_u7623_02_defconfig +++ b/configs/mt7623a_unielec_u7623_02_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_READ=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/mt7623n_bpir2_defconfig b/configs/mt7623n_bpir2_defconfig index 62a17f2cbc7..5e7c1fefadb 100644 --- a/configs/mt7623n_bpir2_defconfig +++ b/configs/mt7623n_bpir2_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_READ=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig index 0e100fca498..7e5b76c590a 100644 --- a/configs/mt7628_rfb_defconfig +++ b/configs/mt7628_rfb_defconfig @@ -37,7 +37,6 @@ CONFIG_SYS_BOOTM_LEN=0x1000000 CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_SPI=y -# CONFIG_CMD_NFS is not set CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/mt7629_rfb_defconfig b/configs/mt7629_rfb_defconfig index ea8d77c0a26..0e3bd4ffa7b 100644 --- a/configs/mt7629_rfb_defconfig +++ b/configs/mt7629_rfb_defconfig @@ -48,7 +48,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index a9c10cdbb0b..cc64facd5f2 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -45,7 +45,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index ce0c47e505d..b1943cfd39b 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -41,7 +41,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_SLEEP is not set CONFIG_CMD_PMIC=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index e27e27d0143..5571722ea6d 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -33,7 +33,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 909f10ee790..0a8a1c77ea4 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index 7e75f44c743..dcfd3eb99a5 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 2543a2d11f8..5b91631367b 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_LIVE=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index 47a0a62d252..7e2829e3a0d 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index e3b978eb1ed..ae235058afd 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index c99a24eef40..0ea47192dda 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/p3450-0000_defconfig b/configs/p3450-0000_defconfig index e280be8f2ec..b0d538f0f83 100644 --- a/configs/p3450-0000_defconfig +++ b/configs/p3450-0000_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_LIVE=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index fadf7fdeb07..8c125c39b2f 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 4fee9df94f8..ab9aef5e478 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index f29a5aa0f81..6a539a859e0 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -47,7 +47,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_TIME=y CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 9bf29647fe5..a7c37b8b0e1 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_TIME=y CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 00cca911710..f8759f25546 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index cc0ecad11b3..2f466d23a54 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_PBSIZE=1024 # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y # CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index f6b59a6e9b8..c762d75aec1 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_I2C_LEGACY=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 6b67021064a..7727e4669d7 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -57,7 +57,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index ad95274879a..4a149133db6 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 442cee33a9f..4776e92683d 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 461c46c725d..8a5d959a5c0 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig index 43dab09316e..69499e17f4c 100644 --- a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y diff --git a/configs/theadorable-x86-conga-qa3-e3845_defconfig b/configs/theadorable-x86-conga-qa3-e3845_defconfig index 5aec52733e6..e2e64b74349 100644 --- a/configs/theadorable-x86-conga-qa3-e3845_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index d5a28a2df4b..751ae3497ec 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index d94a0b408b5..9ec08bda883 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index fd538da3ac5..ebd1754fc8b 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 5e2ff877ca8..2da8ba94d62 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 4ee64c332b3..5cacecc7cbc 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -30,7 +30,6 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_BOOTFILESIZE=y -# CONFIG_CMD_NFS is not set # CONFIG_CMD_SLEEP is not set CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y -- 2.41.0
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
While NFS is widely used in data centres, and private networks it's quite a nuanced usecase for device firmware. A lot of devices already disable it.
Various network protocols should really be opt in, not opt out, because they add extra size and are potential attack vectors from a security PoV. In the NFS case it doesn't really make sense for a lot of devices like tables, SBCs etc. It's also something we don't really want for SystemReady-IR due to security concerns.
Signed-off-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
Peter Robinson
