[U-Boot] [PATCH 1/2] ext4: Rename block group descriptor table from gd to bgd
On x86 machines gd is unfortunately a #define, so we should avoid using gd for anything. This patch changes uses of gd to bgd so that ext4fs can be used on x86.
Signed-off-by: Simon Glass sjg@chromium.org --- fs/ext4/ext4_common.c | 85 ++++++++++++++++++++------------------- fs/ext4/ext4fs.c | 105 +++++++++++++++++++++++++------------------------ include/ext4fs.h | 2 +- 3 files changed, 98 insertions(+), 94 deletions(-)
diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index 3deffd5..d6d55b9 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -314,7 +314,7 @@ int ext4fs_checksum_update(unsigned int i) struct ext_filesystem *fs = get_fs(); __u16 crc = 0;
- desc = (struct ext2_block_group *)&fs->gd[i]; + desc = (struct ext2_block_group *)&fs->bgd[i]; if (fs->sb->feature_ro_compat & EXT4_FEATURE_RO_COMPAT_GDT_CSUM) { int offset = offsetof(struct ext2_block_group, bg_checksum);
@@ -874,17 +874,17 @@ long int ext4fs_get_new_blk_no(void) char *zero_buffer = zalloc(fs->blksz); if (!journal_buffer || !zero_buffer) goto fail; - struct ext2_block_group *gd = (struct ext2_block_group *)fs->gdtable; + struct ext2_block_group *bgd = (struct ext2_block_group *)fs->gdtable;
if (fs->first_pass_bbmap == 0) { for (i = 0; i < fs->no_blkgrp; i++) { - if (gd[i].free_blocks) { - if (gd[i].bg_flags & EXT4_BG_BLOCK_UNINIT) { - put_ext4(((uint64_t) (gd[i].block_id * + if (bgd[i].free_blocks) { + if (bgd[i].bg_flags & EXT4_BG_BLOCK_UNINIT) { + put_ext4(((uint64_t) (bgd[i].block_id * fs->blksz)), zero_buffer, fs->blksz); - gd[i].bg_flags = - gd[i]. + bgd[i].bg_flags = + bgd[i]. bg_flags & ~EXT4_BG_BLOCK_UNINIT; memcpy(fs->blk_bmaps[i], zero_buffer, fs->blksz); @@ -897,16 +897,16 @@ long int ext4fs_get_new_blk_no(void) fs->curr_blkno = fs->curr_blkno + (i * fs->blksz * 8); fs->first_pass_bbmap++; - gd[i].free_blocks--; + bgd[i].free_blocks--; fs->sb->free_blocks--; - status = ext4fs_devread(gd[i].block_id * + status = ext4fs_devread(bgd[i].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail; if (ext4fs_log_journal(journal_buffer, - gd[i].block_id)) + bgd[i].block_id)) goto fail; goto success; } else { @@ -935,19 +935,19 @@ restart: if (bg_idx >= fs->no_blkgrp) goto fail;
- if (gd[bg_idx].free_blocks == 0) { + if (bgd[bg_idx].free_blocks == 0) { debug("block group %u is full. Skipping\n", bg_idx); fs->curr_blkno = fs->curr_blkno + blk_per_grp; fs->curr_blkno--; goto restart; }
- if (gd[bg_idx].bg_flags & EXT4_BG_BLOCK_UNINIT) { + if (bgd[bg_idx].bg_flags & EXT4_BG_BLOCK_UNINIT) { memset(zero_buffer, '\0', fs->blksz); - put_ext4(((uint64_t) (gd[bg_idx].block_id * fs->blksz)), - zero_buffer, fs->blksz); + put_ext4(((uint64_t) (bgd[bg_idx].block_id * + fs->blksz)), zero_buffer, fs->blksz); memcpy(fs->blk_bmaps[bg_idx], zero_buffer, fs->blksz); - gd[bg_idx].bg_flags = gd[bg_idx].bg_flags & + bgd[bg_idx].bg_flags = bgd[bg_idx].bg_flags & ~EXT4_BG_BLOCK_UNINIT; }
@@ -961,18 +961,18 @@ restart: /* journal backup */ if (prev_bg_bitmap_index != bg_idx) { memset(journal_buffer, '\0', fs->blksz); - status = ext4fs_devread(gd[bg_idx].block_id + status = ext4fs_devread(bgd[bg_idx].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail; if (ext4fs_log_journal(journal_buffer, - gd[bg_idx].block_id)) + bgd[bg_idx].block_id)) goto fail;
prev_bg_bitmap_index = bg_idx; } - gd[bg_idx].free_blocks--; + bgd[bg_idx].free_blocks--; fs->sb->free_blocks--; goto success; } @@ -1000,19 +1000,21 @@ int ext4fs_get_new_inode_no(void) char *zero_buffer = zalloc(fs->blksz); if (!journal_buffer || !zero_buffer) goto fail; - struct ext2_block_group *gd = (struct ext2_block_group *)fs->gdtable; + struct ext2_block_group *bgd = (struct ext2_block_group *)fs->gdtable;
if (fs->first_pass_ibmap == 0) { for (i = 0; i < fs->no_blkgrp; i++) { - if (gd[i].free_inodes) { - if (gd[i].bg_itable_unused != gd[i].free_inodes) - gd[i].bg_itable_unused = - gd[i].free_inodes; - if (gd[i].bg_flags & EXT4_BG_INODE_UNINIT) { + if (bgd[i].free_inodes) { + if (bgd[i].bg_itable_unused != + bgd[i].free_inodes) + bgd[i].bg_itable_unused = + bgd[i].free_inodes; + if (bgd[i].bg_flags & EXT4_BG_INODE_UNINIT) { put_ext4(((uint64_t) - (gd[i].inode_id * fs->blksz)), + (bgd[i].inode_id * + fs->blksz)), zero_buffer, fs->blksz); - gd[i].bg_flags = gd[i].bg_flags & + bgd[i].bg_flags = bgd[i].bg_flags & ~EXT4_BG_INODE_UNINIT; memcpy(fs->inode_bmaps[i], zero_buffer, fs->blksz); @@ -1025,17 +1027,17 @@ int ext4fs_get_new_inode_no(void) fs->curr_inode_no = fs->curr_inode_no + (i * inodes_per_grp); fs->first_pass_ibmap++; - gd[i].free_inodes--; - gd[i].bg_itable_unused--; + bgd[i].free_inodes--; + bgd[i].bg_itable_unused--; fs->sb->free_inodes--; - status = ext4fs_devread(gd[i].inode_id * + status = ext4fs_devread(bgd[i].inode_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail; if (ext4fs_log_journal(journal_buffer, - gd[i].inode_id)) + bgd[i].inode_id)) goto fail; goto success; } else @@ -1047,13 +1049,13 @@ restart: fs->curr_inode_no++; /* get the blockbitmap index respective to blockno */ ibmap_idx = fs->curr_inode_no / inodes_per_grp; - if (gd[ibmap_idx].bg_flags & EXT4_BG_INODE_UNINIT) { + if (bgd[ibmap_idx].bg_flags & EXT4_BG_INODE_UNINIT) { memset(zero_buffer, '\0', fs->blksz); - put_ext4(((uint64_t) (gd[ibmap_idx].inode_id * + put_ext4(((uint64_t) (bgd[ibmap_idx].inode_id * fs->blksz)), zero_buffer, fs->blksz); - gd[ibmap_idx].bg_flags = - gd[ibmap_idx].bg_flags & ~EXT4_BG_INODE_UNINIT; + bgd[ibmap_idx].bg_flags = + bgd[ibmap_idx].bg_flags & ~EXT4_BG_INODE_UNINIT; memcpy(fs->inode_bmaps[ibmap_idx], zero_buffer, fs->blksz); } @@ -1069,21 +1071,22 @@ restart: /* journal backup */ if (prev_inode_bitmap_index != ibmap_idx) { memset(journal_buffer, '\0', fs->blksz); - status = ext4fs_devread(gd[ibmap_idx].inode_id + status = ext4fs_devread(bgd[ibmap_idx].inode_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail; if (ext4fs_log_journal(journal_buffer, - gd[ibmap_idx].inode_id)) + bgd[ibmap_idx].inode_id)) goto fail; prev_inode_bitmap_index = ibmap_idx; } - if (gd[ibmap_idx].bg_itable_unused != gd[ibmap_idx].free_inodes) - gd[ibmap_idx].bg_itable_unused = - gd[ibmap_idx].free_inodes; - gd[ibmap_idx].free_inodes--; - gd[ibmap_idx].bg_itable_unused--; + if (bgd[ibmap_idx].bg_itable_unused != + bgd[ibmap_idx].free_inodes) + bgd[ibmap_idx].bg_itable_unused = + bgd[ibmap_idx].free_inodes; + bgd[ibmap_idx].free_inodes--; + bgd[ibmap_idx].bg_itable_unused--; fs->sb->free_inodes--; goto success; } diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c index 93dcb7e..4eded1a 100644 --- a/fs/ext4/ext4fs.c +++ b/fs/ext4/ext4fs.c @@ -209,14 +209,14 @@ static void ext4fs_update(void)
/* update block groups */ for (i = 0; i < fs->no_blkgrp; i++) { - fs->gd[i].bg_checksum = ext4fs_checksum_update(i); - put_ext4((uint64_t)(fs->gd[i].block_id * fs->blksz), + fs->bgd[i].bg_checksum = ext4fs_checksum_update(i); + put_ext4((uint64_t)(fs->bgd[i].block_id * fs->blksz), fs->blk_bmaps[i], fs->blksz); }
/* update inode table groups */ for (i = 0; i < fs->no_blkgrp; i++) { - put_ext4((uint64_t) (fs->gd[i].inode_id * fs->blksz), + put_ext4((uint64_t) (fs->bgd[i].inode_id * fs->blksz), fs->inode_bmaps[i], fs->blksz); }
@@ -231,7 +231,7 @@ static void ext4fs_update(void) gd_index = 0; }
-int ext4fs_get_bgdtable(void) +int ext4fs_get_gdtable(void) { int status; int grp_desc_size; @@ -266,7 +266,7 @@ fail:
static void delete_single_indirect_block(struct ext2_inode *inode) { - struct ext2_block_group *gd = NULL; + struct ext2_block_group *bgd = NULL; static int prev_bg_bmap_idx = -1; long int blknr; int remainder; @@ -280,7 +280,7 @@ static void delete_single_indirect_block(struct ext2_inode *inode) return; } /* get block group descriptor table */ - gd = (struct ext2_block_group *)fs->gdtable; + bgd = (struct ext2_block_group *)fs->gdtable;
/* deleting the single indirect block associated with inode */ if (inode->b.blocks.indir_block != 0) { @@ -295,18 +295,18 @@ static void delete_single_indirect_block(struct ext2_inode *inode) bg_idx--; } ext4fs_reset_block_bmap(blknr, fs->blk_bmaps[bg_idx], bg_idx); - gd[bg_idx].free_blocks++; + bgd[bg_idx].free_blocks++; fs->sb->free_blocks++; /* journal backup */ if (prev_bg_bmap_idx != bg_idx) { status = - ext4fs_devread(gd[bg_idx].block_id * + ext4fs_devread(bgd[bg_idx].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail; if (ext4fs_log_journal - (journal_buffer, gd[bg_idx].block_id)) + (journal_buffer, bgd[bg_idx].block_id)) goto fail; prev_bg_bmap_idx = bg_idx; } @@ -326,7 +326,7 @@ static void delete_double_indirect_block(struct ext2_inode *inode) unsigned int blk_per_grp = ext4fs_root->sblock.blocks_per_group; unsigned int *di_buffer = NULL; unsigned int *DIB_start_addr = NULL; - struct ext2_block_group *gd = NULL; + struct ext2_block_group *bgd = NULL; struct ext_filesystem *fs = get_fs(); char *journal_buffer = zalloc(fs->blksz); if (!journal_buffer) { @@ -334,7 +334,7 @@ static void delete_double_indirect_block(struct ext2_inode *inode) return; } /* get the block group descriptor table */ - gd = (struct ext2_block_group *)fs->gdtable; + bgd = (struct ext2_block_group *)fs->gdtable;
if (inode->b.blocks.double_indir_block != 0) { di_buffer = zalloc(fs->blksz); @@ -362,11 +362,11 @@ static void delete_double_indirect_block(struct ext2_inode *inode) ext4fs_reset_block_bmap(*di_buffer, fs->blk_bmaps[bg_idx], bg_idx); di_buffer++; - gd[bg_idx].free_blocks++; + bgd[bg_idx].free_blocks++; fs->sb->free_blocks++; /* journal backup */ if (prev_bg_bmap_idx != bg_idx) { - status = ext4fs_devread(gd[bg_idx].block_id + status = ext4fs_devread(bgd[bg_idx].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); @@ -374,7 +374,7 @@ static void delete_double_indirect_block(struct ext2_inode *inode) goto fail;
if (ext4fs_log_journal(journal_buffer, - gd[bg_idx].block_id)) + bgd[bg_idx].block_id)) goto fail; prev_bg_bmap_idx = bg_idx; } @@ -391,19 +391,19 @@ static void delete_double_indirect_block(struct ext2_inode *inode) bg_idx--; } ext4fs_reset_block_bmap(blknr, fs->blk_bmaps[bg_idx], bg_idx); - gd[bg_idx].free_blocks++; + bgd[bg_idx].free_blocks++; fs->sb->free_blocks++; /* journal backup */ if (prev_bg_bmap_idx != bg_idx) { memset(journal_buffer, '\0', fs->blksz); - status = ext4fs_devread(gd[bg_idx].block_id * + status = ext4fs_devread(bgd[bg_idx].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail;
if (ext4fs_log_journal(journal_buffer, - gd[bg_idx].block_id)) + bgd[bg_idx].block_id)) goto fail; prev_bg_bmap_idx = bg_idx; } @@ -427,7 +427,7 @@ static void delete_triple_indirect_block(struct ext2_inode *inode) unsigned int *tib_start_addr = NULL; unsigned int *tip_buffer = NULL; unsigned int *tipb_start_addr = NULL; - struct ext2_block_group *gd = NULL; + struct ext2_block_group *bgd = NULL; struct ext_filesystem *fs = get_fs(); char *journal_buffer = zalloc(fs->blksz); if (!journal_buffer) { @@ -435,7 +435,7 @@ static void delete_triple_indirect_block(struct ext2_inode *inode) return; } /* get block group descriptor table */ - gd = (struct ext2_block_group *)fs->gdtable; + bgd = (struct ext2_block_group *)fs->gdtable;
if (inode->b.blocks.triple_indir_block != 0) { tigp_buffer = zalloc(fs->blksz); @@ -477,20 +477,21 @@ static void delete_triple_indirect_block(struct ext2_inode *inode) bg_idx);
tip_buffer++; - gd[bg_idx].free_blocks++; + bgd[bg_idx].free_blocks++; fs->sb->free_blocks++; /* journal backup */ if (prev_bg_bmap_idx != bg_idx) { status = - ext4fs_devread(gd[bg_idx].block_id * - fs->sect_perblk, 0, - fs->blksz, - journal_buffer); + ext4fs_devread( + bgd[bg_idx].block_id * + fs->sect_perblk, 0, + fs->blksz, + journal_buffer); if (status == 0) goto fail;
if (ext4fs_log_journal(journal_buffer, - gd[bg_idx]. + bgd[bg_idx]. block_id)) goto fail; prev_bg_bmap_idx = bg_idx; @@ -516,20 +517,20 @@ static void delete_triple_indirect_block(struct ext2_inode *inode) fs->blk_bmaps[bg_idx], bg_idx);
tigp_buffer++; - gd[bg_idx].free_blocks++; + bgd[bg_idx].free_blocks++; fs->sb->free_blocks++; /* journal backup */ if (prev_bg_bmap_idx != bg_idx) { memset(journal_buffer, '\0', fs->blksz); status = - ext4fs_devread(gd[bg_idx].block_id * + ext4fs_devread(bgd[bg_idx].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail;
if (ext4fs_log_journal(journal_buffer, - gd[bg_idx].block_id)) + bgd[bg_idx].block_id)) goto fail; prev_bg_bmap_idx = bg_idx; } @@ -546,19 +547,19 @@ static void delete_triple_indirect_block(struct ext2_inode *inode) bg_idx--; } ext4fs_reset_block_bmap(blknr, fs->blk_bmaps[bg_idx], bg_idx); - gd[bg_idx].free_blocks++; + bgd[bg_idx].free_blocks++; fs->sb->free_blocks++; /* journal backup */ if (prev_bg_bmap_idx != bg_idx) { memset(journal_buffer, '\0', fs->blksz); - status = ext4fs_devread(gd[bg_idx].block_id * + status = ext4fs_devread(bgd[bg_idx].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail;
if (ext4fs_log_journal(journal_buffer, - gd[bg_idx].block_id)) + bgd[bg_idx].block_id)) goto fail; prev_bg_bmap_idx = bg_idx; } @@ -590,13 +591,13 @@ static int ext4fs_delete_file(int inodeno) unsigned int blk_per_grp = ext4fs_root->sblock.blocks_per_group; unsigned int inode_per_grp = ext4fs_root->sblock.inodes_per_group; struct ext2_inode *inode_buffer = NULL; - struct ext2_block_group *gd = NULL; + struct ext2_block_group *bgd = NULL; struct ext_filesystem *fs = get_fs(); char *journal_buffer = zalloc(fs->blksz); if (!journal_buffer) return -ENOMEM; /* get the block group descriptor table */ - gd = (struct ext2_block_group *)fs->gdtable; + bgd = (struct ext2_block_group *)fs->gdtable; status = ext4fs_read_inode(ext4fs_root, inodeno, &inode); if (status == 0) goto fail; @@ -631,19 +632,19 @@ static int ext4fs_delete_file(int inodeno) debug("EXT4_EXTENTS Block releasing %ld: %d\n", blknr, bg_idx);
/* journal backup */ if (prev_bg_bmap_idx != bg_idx) { status = - ext4fs_devread(gd[bg_idx].block_id * + ext4fs_devread(bgd[bg_idx].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail; if (ext4fs_log_journal(journal_buffer, - gd[bg_idx].block_id)) + bgd[bg_idx].block_id)) goto fail; prev_bg_bmap_idx = bg_idx; } @@ -676,19 +677,19 @@ static int ext4fs_delete_file(int inodeno) bg_idx); debug("ActualB releasing %ld: %d\n", blknr, bg_idx);
- gd[bg_idx].free_blocks++; + bgd[bg_idx].free_blocks++; fs->sb->free_blocks++; /* journal backup */ if (prev_bg_bmap_idx != bg_idx) { memset(journal_buffer, '\0', fs->blksz); - status = ext4fs_devread(gd[bg_idx].block_id + status = ext4fs_devread(bgd[bg_idx].block_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail; if (ext4fs_log_journal(journal_buffer, - gd[bg_idx].block_id)) + bgd[bg_idx].block_id)) goto fail; prev_bg_bmap_idx = bg_idx; } @@ -701,7 +702,7 @@ static int ext4fs_delete_file(int inodeno)
/* get the block no */ inodeno--; - blkno = __le32_to_cpu(gd[ibmap_idx].inode_table_id) + + blkno = __le32_to_cpu(bgd[ibmap_idx].inode_table_id) + (inodeno % __le32_to_cpu(inode_per_grp)) / inodes_per_block;
/* get the offset of the inode */ @@ -731,15 +732,15 @@ static int ext4fs_delete_file(int inodeno) /* update the respective inode bitmaps */ inodeno++; ext4fs_reset_inode_bmap(inodeno, fs->inode_bmaps[ibmap_idx], ibmap_idx); - gd[ibmap_idx].free_inodes++; + bgd[ibmap_idx].free_inodes++; fs->sb->free_inodes++; /* journal backup */ memset(journal_buffer, '\0', fs->blksz); - status = ext4fs_devread(gd[ibmap_idx].inode_id * + status = ext4fs_devread(bgd[ibmap_idx].inode_id * fs->sect_perblk, 0, fs->blksz, journal_buffer); if (status == 0) goto fail; - if (ext4fs_log_journal(journal_buffer, gd[ibmap_idx].inode_id)) + if (ext4fs_log_journal(journal_buffer, bgd[ibmap_idx].inode_id)) goto fail;
ext4fs_update(); @@ -793,11 +794,11 @@ int ext4fs_init(void)
/* get the block group descriptor table */ fs->gdtable_blkno = ((EXT2_MIN_BLOCK_SIZE == fs->blksz) + 1); - if (ext4fs_get_bgdtable() == -1) { + if (ext4fs_get_gdtable() == -1) { printf("Error in getting the block group descriptor table\n"); goto fail; } - fs->gd = (struct ext2_block_group *)fs->gdtable; + fs->bgd = (struct ext2_block_group *)fs->gdtable;
/* load all the available bitmap block of the partition */ fs->blk_bmaps = zalloc(fs->no_blkgrp * sizeof(char *)); @@ -811,7 +812,7 @@ int ext4fs_init(void)
for (i = 0; i < fs->no_blkgrp; i++) { status = - ext4fs_devread(fs->gd[i].block_id * fs->sect_perblk, 0, + ext4fs_devread(fs->bgd[i].block_id * fs->sect_perblk, 0, fs->blksz, (char *)fs->blk_bmaps[i]); if (status == 0) goto fail; @@ -828,7 +829,7 @@ int ext4fs_init(void) }
for (i = 0; i < fs->no_blkgrp; i++) { - status = ext4fs_devread(fs->gd[i].inode_id * fs->sect_perblk, + status = ext4fs_devread(fs->bgd[i].inode_id * fs->sect_perblk, 0, fs->blksz, (char *)fs->inode_bmaps[i]); if (status == 0) @@ -842,7 +843,7 @@ int ext4fs_init(void) * reboot of a linux kernel */ for (i = 0; i < fs->no_blkgrp; i++) - real_free_blocks = real_free_blocks + fs->gd[i].free_blocks; + real_free_blocks = real_free_blocks + fs->bgd[i].free_blocks; if (real_free_blocks != fs->sb->free_blocks) fs->sb->free_blocks = real_free_blocks;
@@ -907,7 +908,7 @@ void ext4fs_deinit(void)
free(fs->gdtable); fs->gdtable = NULL; - fs->gd = NULL; + fs->bgd = NULL; /* * reinitiliazed the global inode and * block bitmap first execution check variables @@ -929,7 +930,7 @@ static int ext4fs_write_file(struct ext2_inode *file_inode, int previous_block_number = -1; int delayed_start = 0; int delayed_extent = 0; - int delayed_skipfirst = 0; + __maybe_unused int delayed_skipfirst = 0; int delayed_next = 0; char *delayed_buf = NULL;
@@ -1087,7 +1088,7 @@ int ext4fs_write(const char *fname, unsigned char *buffer, goto fail; ibmap_idx = inodeno / ext4fs_root->sblock.inodes_per_group; inodeno--; - itable_blkno = __le32_to_cpu(fs->gd[ibmap_idx].inode_table_id) + + itable_blkno = __le32_to_cpu(fs->bgd[ibmap_idx].inode_table_id) + (inodeno % __le32_to_cpu(sblock->inodes_per_group)) / inodes_per_block; blkoff = (inodeno % inodes_per_block) * fs->inodesz; @@ -1105,7 +1106,7 @@ int ext4fs_write(const char *fname, unsigned char *buffer, } ibmap_idx = parent_inodeno / ext4fs_root->sblock.inodes_per_group; parent_inodeno--; - parent_itable_blkno = __le32_to_cpu(fs->gd[ibmap_idx].inode_table_id) + + parent_itable_blkno = __le32_to_cpu(fs->bgd[ibmap_idx].inode_table_id) + (parent_inodeno % __le32_to_cpu(sblock->inodes_per_group)) / inodes_per_block; blkoff = (parent_inodeno % inodes_per_block) * fs->inodesz; diff --git a/include/ext4fs.h b/include/ext4fs.h index b6eedde..23298fc 100644 --- a/include/ext4fs.h +++ b/include/ext4fs.h @@ -94,7 +94,7 @@ struct ext_filesystem { /* Superblock */ struct ext2_sblock *sb; /* Block group descritpor table */ - struct ext2_block_group *gd; + struct ext2_block_group *bgd; char *gdtable;
/* Block Bitmap Related */
This patch fixes the following warnings with my gcc 4.6:
ext4fs.c:932:6: error: variable 'delayed_skipfirst' set but not used [-Werror=unused-but-set-variable] ext4_common.c:381:8: error: variable 'ptr' set but not used [-Werror=unused-but-set-variable] ext4_common.c:1170:8: error: variable 'status' set but not used [-Werror=unused-but-set-variable]
I'm not exactly sure whether this is the best fix, but it did look like each variable is actually needed.
Signed-off-by: Simon Glass sjg@chromium.org --- common/cmd_ext4.c | 2 +- fs/ext4/ext4_common.c | 7 ++++--- fs/ext4/ext4_journal.c | 4 ++-- fs/ext4/ext4fs.c | 1 + 4 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/common/cmd_ext4.c b/common/cmd_ext4.c index ca46561..75bb8c1 100644 --- a/common/cmd_ext4.c +++ b/common/cmd_ext4.c @@ -107,7 +107,7 @@ int do_ext4_write(cmd_tbl_t *cmdtp, int flag, int argc,
/* mount the filesystem */ if (!ext4fs_mount(info.size)) { - printf("Bad ext4 partition %s %d:%lu\n", argv[1], dev, part); + printf("Bad ext4 partition %s %d:%d\n", argv[1], dev, part); goto fail; }
diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index d6d55b9..b66beaa 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -36,6 +36,7 @@ #include <ext4fs.h> #include <malloc.h> #include <stddef.h> +#include <linux/compiler.h> #include <linux/stat.h> #include <linux/time.h> #include <asm/byteorder.h> @@ -378,7 +379,7 @@ void ext4fs_update_parent_dentry(char *filename, int *p_ino, int file_type) struct ext_filesystem *fs = get_fs(); /* directory entry */ struct ext2_dirent *dir; - char *ptr = NULL; + __maybe_unused char *ptr = NULL; char *temp_dir = NULL;
zero_buffer = zalloc(fs->blksz); @@ -531,7 +532,7 @@ static int search_dir(struct ext2_inode *parent_inode, char *dirname) int direct_blk_idx; long int blknr; int found = 0; - char *ptr = NULL; + __maybe_unused char *ptr = NULL; unsigned char *block_buffer = NULL; struct ext2_dirent *dir = NULL; struct ext2_dirent *previous_dir = NULL; @@ -1170,7 +1171,7 @@ static void alloc_double_indirect_block(struct ext2_inode *file_inode, { short i; short j; - short status; + __maybe_unused short status; long int actual_block_no; /* di:double indirect */ long int di_blockno_parent; diff --git a/fs/ext4/ext4_journal.c b/fs/ext4/ext4_journal.c index 8a252d6..7281269 100644 --- a/fs/ext4/ext4_journal.c +++ b/fs/ext4/ext4_journal.c @@ -34,6 +34,7 @@ #include <malloc.h> #include <ext_common.h> #include "ext4_common.h" +#include <linux/compiler.h>
static struct revoke_blk_list *revk_blk_list; static struct revoke_blk_list *prev_node; @@ -410,7 +411,7 @@ int ext4fs_check_journal_state(int recovery_flag) int transaction_state = TRANSACTION_COMPLETE; int prev_desc_logical_no = 0; int curr_desc_logical_no = 0; - int ofs, flags, block; + int ofs, flags; struct ext2_inode inode_journal; struct journal_superblock_t *jsb = NULL; struct journal_header_t *jdb = NULL; @@ -453,7 +454,6 @@ int ext4fs_check_journal_state(int recovery_flag)
i = be32_to_cpu(jsb->s_first); while (1) { - block = be32_to_cpu(jsb->s_first); blknr = read_allocated_block(&inode_journal, i); memset(temp_buff1, '\0', fs->blksz); ext4fs_devread(blknr * fs->sect_perblk, diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c index 4eded1a..ccdaa15 100644 --- a/fs/ext4/ext4fs.c +++ b/fs/ext4/ext4fs.c @@ -37,6 +37,7 @@ #include <malloc.h> #include <ext_common.h> #include <ext4fs.h> +#include <linux/compiler.h> #include <linux/stat.h> #include <linux/time.h> #include <asm/byteorder.h>
Actually I think this problem was due to a broken toolchain, which helps explain why I couldn't work out what the compiler was complaining about. I think we should ignore this patch unless others also see it. Sorry for the distraction.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Is there any way to change x86 to not be using a #define for gd?
- -- Tom
Hi Tom,
I wasn't brave enough to look hard at that, although Graeme is on copy and will know. It is actually using inline assembly to access this special variable.
Tom -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.11 (GNU/Linux) Comment: Using GnuPG with Mozilla - http://www.enigmail.net/
iQIcBAEBAgAGBQJQbJpVAAoJENk4IS6UOR1WdFgP/15lB4qT6FMGny9cqYn3aylV PuzqYZOhpTzhNywFoUyPjWkp4Zgga+BB+lJ/1wu0GLv6o3aBDCBrwsoTO22RWmo0 dO0hADtycOjVTFAWUz1ORfxD1w2f06ZQPQkW72vOZCqAYMND+OqgVjwHHbWi5388 ra27zxa2nS0r3DFn+H47d3yhnooZ32jv5ChAgUfGzvU/yA8SUqfwhpt/9s2zxO40 O+Wl6FKavg4sGw4RCfAD9Cz2AR1vR80YzHcI6qFA/UUIf9M5Ai9Ka3yO/N+UBfaT pjdc4MUh4j3Nd/l0mPxVBDNE8KQ6m56BhXLjAoPcSNisT8Dh1Uzz5nH2pJrGXNHk JQUFXXQNEoNN8jQJKK6mrFlUYJ/YlFIYCQXPkC76WjyNmbz1Qd7wL2NmIbV9bQLZ F3VTqXhXwjt8FG0x14+X17Q8eEABe/ONvdzAP1QZyG4UFxYKsIOumVM4T4QdY2sP MYF4nX7tmVBxn3CVW6kwN1E8J7jxDnSWUjfiK+Sqpdw6V9biR+2Ozf8kXzWNZ0xs QMvEiX08jyg/f6JxjvXLuess+fk0xskwIliM4WCkxZ1H3dbo1hXSVRJMTXNohEp0 hDxg9qypkrLcS9PIFHWr/oqWCIeOpOrwbVa4el/E6UboU6t91WyIxQICjxosLCg4 ViGSt12tKVckDH5yn7up =bvjH -----END PGP SIGNATURE-----
Hi Simon,
On Oct 4, 2012 6:40 AM, "Simon Glass" sjg@chromium.org wrote:
Hi Tom,
Isn't 'gd' used by everyone (global data)? I fail to see how this ever worked.
Regards,
Graeme
Hi Graeme,
On Wed, Oct 3, 2012 at 1:47 PM, Graeme Russ graeme.russ@gmail.com wrote:
Hi Simon,
Hi Tom,
Well only x86 uses a #define for it, so other archs cause no problem. It means that we can't use 'gd' as a symbol anywhere in U-Boot. I suppose the only sensible use is a structure member, as here.
Regards,
Graeme
Hi Simon,
On Oct 4, 2012 6:58 AM, "Simon Glass" sjg@chromium.org wrote:
Hi Graeme,
Hi Simon,
Hi Tom,
Ah, I see - and I don't see a quick and easy way out. Let me look a bit deeper...
Regards,
Graeme
Hi Simon,
On Thu, Oct 4, 2012 at 7:44 AM, Graeme Russ graeme.russ@gmail.com wrote:
Hi Simon,
Hi Graeme,
Hi Simon,
Hi Tom,
I remember now... commit 9e6c572ff03cda84c88663b23c7157d8b1f275ac explains why the #define gd came about:
"Use the base address of the 'F' segment as a pointer to the global data structure. By adding the linear address (i.e. the 'D' segment address) as the first word of the global data structure, the address of the global data relative to the 'D' segment can be found simply, for example, by:
fs movl 0, %eax
This makes the gd 'pointer' writable prior to relocation (by reloading the Global Desctriptor Table) which brings x86 into line with all other arches
NOTE: Writing to the gd 'pointer' is expensive (but we only do it twice) but using it to access global data members (read and write) is still fairly cheap"
The other option was rather ugly - create gd_get() and gd_set() inline functions and replace all instances of gd-> in all U-Boot source with gd_get()-> or gd_set(foo). I don't think it would have made any difference to code size, but the amount of code touched would have been massive.
The only other option I can think of is to change gd into something much less likely to be used as a symbol (__gd for example), but again, the patch to do so would be huge
I'm open to alternatives
Regards,
Graeme
On 10/03/12 15:59, Graeme Russ wrote:
Hi Simon,
Hi Simon,
Hi Graeme,
Hi Simon,
Hi Tom,
> On x86 machines gd is unfortunately a #define, so we > should avoid using gd for anything. This patch changes > uses of gd to bgd so that ext4fs can be used on x86. > > Signed-off-by: Simon Glass sjg@chromium.org
fs movl 0, %eax
OK, we'll just go with re-naming the ext4 part and build-testing things on x86 more often :) Thanks for digging up the details!
- -- Tom
Hi Simon,
Hi Simon,
Hi Graeme,
Hi Simon,
Hi Tom,
On Wed, Oct 3, 2012 at 1:04 PM, Tom Rini trini@ti.com wrote: > -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 > > On 10/03/12 12:53, Simon Glass wrote: > >> On x86 machines gd is unfortunately a #define, so we >> should avoid using gd for anything. This patch changes >> uses of gd to bgd so that ext4fs can be used on x86. >> >> Signed-off-by: Simon Glass sjg@chromium.org > > Is there any way to change x86 to not be using a #define > for gd?
fs movl 0, %eax
Sounds good, thank you both.
Regards Simon
Tom
iQIcBAEBAgAGBQJQbMTaAAoJENk4IS6UOR1WWmkP/2eRqqVTtCMwNZ6JP7W/lKDl bGu2PrIqufPdM2CnQJPpgWWT0PcBIV8thkw5DPhJovjkH7bjFc9bmjXjX6sNZU7V EnMxU/v6GUdCtM2QKeRv2x7a8iLj2uOcZS4tTg68vA7iD7fj5PwDBTNIGLCSh9EC VbDo2juPXjz+jSRvuhU7w0MzbeRhwdZ2yACZjlNbnX5TdWam1iXMnxlPPh/pC0Td ejwy0RuQwHPM7Gxy88b2wIc5DOXn8zoWrqLo1tx8B5S4b6jG+vI8zsFozi4lL9NJ iCinGd56xDNBIQKPr2NjdpSqkh01efpHqaa7tuBa5mzswNDQikoOXE/ncPFqW618 6kaAHfzCAmSQb/QbwV5576LWw2LcQPGDzz8Mb8iL03nAgHZI8an/blEdJjK6j+1G EpwzXQ6YkAWnrjCuAMGwfm/ARXai/Qh2YSnT5SPMxIXlWxIfAT7PsBRNbXOLQQp0 M/+NNE25cqAiZqwCxAT/eYR/huJtXbOqOj7GiH9NCn5L8c0Vm3mJ+o+YzRiraNro D2INZRE1B7347wxb/wkjHlLTfz219RrkSNJE7HBHGPbrtSQOXZaeTa44TZPwZbKP YuDojx9jMeuVQz1xqAoZECjdIgSEDjNcWcXU6l0JZYQClqDhxtS3GTdnlmMY0kdm kcZsmBCbojJchtN+VUp8 =0NwK -----END PGP SIGNATURE-----
On 10/03/12 13:40, Simon Glass wrote:
Hi Tom,
On Wed, Oct 3, 2012 at 1:04 PM, Tom Rini trini@ti.com wrote: On 10/03/12 12:53, Simon Glass wrote:
Yeah, I took a quick stab at it myself earlier and didn't make it work. We need to fix this for the release. My concern was "we must share this with the kernel" but, we don't (I realized as I was drafting this reply). So I'm more OK with taking the change now than I was at first, but if we can not #define gd that will help prevent the problem from popping up in the future.
- -- Tom
Hi Tom,
Hi Tom,
Yes - if there is a fix for the x86 gd implementation then we could skip this patch (or perhaps revert it later if the fix is really complicated). Still, I think the patch should be harmless.
Unfortunately thought there are a few errors in the patches, so I will resend.
iQIcBAEBAgAGBQJQbKTnAAoJENk4IS6UOR1WJCEP/35rXvf/aAastlgJz5R/RCdM PNfOqJrfladuRW8BcQBE2wjRR3V1D7O61AboDQmnwCuknEX+NZhEgDcTWQFBw93o p8A0OKOMjWyMWtoJgwcTuvnJqRLaldqGyvcBaRv8X0uPYw9OJObIAmVb9n/tx6X3 i2kN0bfoPDGCgvEYm2ygXGyjvAGJ5A+5W/Cxsd+nGdjUGEBgS4q1GqEA24H++NAG pQLo2r59pjd6IzjzHeDqPRImi9Cu5seiajjkA34fGwxZY06wreSokaut/WiTIMwb VsYyZX6OXLcKmz2SbC8haY5FabgmF8bvkNJUMh4wMX02O3h09cOU25cWBjl0D3Lz rfVl9sQwuyXEx5WAo0GK18wa/rt9q0mRDgaBfPeFNPoLa4lZuUZE9qEKtidX9A+G aRjECVmCJYEq14atSqKZzeB1EshU066mN9y1XlV5B0/N95gztElQDkArFiuBmYXh vhGvduxmR33W0EizhbZH9w53eTittKfa83GwV+SwVnYXxrytWiMPDYJzjaJ3pAcC sxuTW65GcRbm5AEUpY3+8Uozdu7m00jGeCMi1pya+UqTam5gFVm7ee2g6PpdL2p3 mUi5cVHU58IuQdxhZqM2Omk5ptzHh23oPR0JdiG2kUoVLt3KZn9HmST9yUrLT/DP pJ+twKTqC6YDqyLsfcDM =Zfek -----END PGP SIGNATURE-----
Graeme Russ
