[U-Boot] [PATCH 01/10 v2] net: rtl8169: Add initialized eth_device structure
rtl8169 does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/rtl8169.c | 7 ++++++- 1 files changed, 6 insertions(+), 1 deletions(-)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index e45d1a5..d6bc514 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -894,7 +894,12 @@ int rtl8169_initialize(bd_t *bis) debug ("rtl8169: REALTEK RTL8169 @0x%x\n", iobase);
dev = (struct eth_device *)malloc(sizeof *dev); - + if (!dev) { + printf("Can not allocate memory of rtl8169\n"); + break; + } + + memset(dev, 0, sizeof(*dev)); sprintf (dev->name, "RTL8169#%d", card_number);
dev->priv = (void *) devno;
rtl8139 driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/rtl8139.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/net/rtl8139.c b/drivers/net/rtl8139.c index db8a727..c2779db 100644 --- a/drivers/net/rtl8139.c +++ b/drivers/net/rtl8139.c @@ -220,6 +220,11 @@ int rtl8139_initialize(bd_t *bis) debug ("rtl8139: REALTEK RTL8139 @0x%x\n", iobase);
dev = (struct eth_device *)malloc(sizeof *dev); + if (!dev) { + printf("Can not allocate memory of rtl8139\n"); + break; + } + memset(dev, 0, sizeof(*dev));
sprintf (dev->name, "RTL8139#%d", card_number);
Dear Nobuhiro Iwamatsu,
Applied, thanks.
dc2114x driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/dc2114x.c | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 5ae53e8..9fd0ec8 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -279,6 +279,12 @@ int dc21x4x_initialize(bd_t *bis) debug ("dc21x4x: DEC 21142 PCI Device @0x%x\n", iobase);
dev = (struct eth_device*) malloc(sizeof *dev); + + if (!dev) { + printf("Can not allocalte memory of dc21x4x\n"); + break; + } + memset(dev, 0, sizeof(*dev));
#ifdef CONFIG_TULIP_FIX_DAVICOM sprintf(dev->name, "Davicom#%d", card_number);
Applied, thanks.
eepro100 driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/eepro100.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/net/eepro100.c b/drivers/net/eepro100.c index 22e14e3..2d165af 100644 --- a/drivers/net/eepro100.c +++ b/drivers/net/eepro100.c @@ -450,6 +450,11 @@ int eepro100_initialize (bd_t * bis) }
dev = (struct eth_device *) malloc (sizeof *dev); + if (!dev) { + printf("eepro100: Can not allocate memory\n"); + break; + } + memset(dev, 0, sizeof(*dev));
sprintf (dev->name, "i82559#%d", card_number); dev->priv = (void *) devno; /* this have to come before bus_to_phys() */
Applied, thanks.
This prevents access to the member of eth_device which is not initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/fec_mxc.c | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 2d4ffed..071276e 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -707,6 +707,7 @@ static int fec_probe(bd_t *bd) puts("fec_mxc: not enough malloc memory\n"); return -ENOMEM; } + memset(edev, 0, sizeof(*edev)); edev->priv = fec; edev->init = fec_init; edev->send = fec_send;
Applied, thanks.
natsemi driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/natsemi.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/net/natsemi.c b/drivers/net/natsemi.c index e09da1d..072ea3a 100644 --- a/drivers/net/natsemi.c +++ b/drivers/net/natsemi.c @@ -321,6 +321,11 @@ natsemi_initialize(bd_t * bis) }
dev = (struct eth_device *) malloc(sizeof *dev); + if (!dev) { + printf("natsemi: Can not allocate memory\n"); + break; + } + memset(dev, 0, sizeof(*dev));
sprintf(dev->name, "dp83815#%d", card_number); dev->iobase = bus_to_phys(iobase);
Applied, thanks.
ns8382x driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/ns8382x.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/net/ns8382x.c b/drivers/net/ns8382x.c index 198f73d..a5196bb 100644 --- a/drivers/net/ns8382x.c +++ b/drivers/net/ns8382x.c @@ -340,6 +340,11 @@ ns8382x_initialize(bd_t * bis) }
dev = (struct eth_device *) malloc(sizeof *dev); + if (!dev) { + printf("ns8382x: Can not allocate memory\n"); + break; + } + memset(dev, 0, sizeof(*dev));
sprintf(dev->name, "dp8382x#%d", card_number); dev->iobase = bus_to_phys(iobase);
Applied, thanks.
pcnet driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/pcnet.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/net/pcnet.c b/drivers/net/pcnet.c index 99b6942..e994cb6 100644 --- a/drivers/net/pcnet.c +++ b/drivers/net/pcnet.c @@ -187,6 +187,11 @@ int pcnet_initialize (bd_t * bis) * Allocate and pre-fill the device structure. */ dev = (struct eth_device *) malloc (sizeof *dev); + if (!dev) { + printf("pcnet: Can not allocate memory\n"); + break; + } + memset(dev, 0, sizeof(*dev)); dev->priv = (void *) devbusfn; sprintf (dev->name, "pcnet#%d", dev_nr);
Applied, thanks.
tsi108_eth driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/tsi108_eth.c | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/drivers/net/tsi108_eth.c b/drivers/net/tsi108_eth.c index 079354a..f100ec1 100644 --- a/drivers/net/tsi108_eth.c +++ b/drivers/net/tsi108_eth.c @@ -731,7 +731,11 @@ int tsi108_eth_initialize (bd_t * bis)
for (index = 0; index < CONFIG_TSI108_ETH_NUM_PORTS; index++) { dev = (struct eth_device *)malloc(sizeof(struct eth_device)); - + if (!dev) { + printf("tsi108: Can not allocate memory\n"); + break; + } + memset(dev, 0, sizeof(*dev)); sprintf (dev->name, "TSI108_eth%d", index);
dev->iobase = ETH_BASE + (index * ETH_PORT_OFFSET);
Applied, thanks.
uli526x driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/uli526x.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/net/uli526x.c b/drivers/net/uli526x.c index 56eee7b..fca5c09 100644 --- a/drivers/net/uli526x.c +++ b/drivers/net/uli526x.c @@ -225,6 +225,11 @@ int uli526x_initialize(bd_t *bis) iobase &= ~0xf;
dev = (struct eth_device *)malloc(sizeof *dev); + if (!dev) { + printf("uli526x: Can not allocate memory\n"); + break; + } + memset(dev, 0, sizeof(*dev)); sprintf(dev->name, "uli526x#%d", card_number); db = (struct uli526x_board_info *) malloc(sizeof(struct uli526x_board_info));
In message 1287464627-12302-10-git-send-email-iwamatsu@nigauri.org you wrote:
Applied, thanks.
Hi, Ben and Wolfgang.
Could you take in these patches?
Best regards, Nobuhiro
2010/10/19 Nobuhiro Iwamatsu iwamatsu@nigauri.org:
- if (!dev) {
- printf("Can not allocate memory of rtl8169\n");
- break;
- memset(dev, 0, sizeof(*dev));
1.7.1
In message AANLkTinTt5pD40-Z+rvyWyf303nG9cMTE6wpAo_R2i+3@mail.gmail.com you wrote:
Are these bug fixes, or can they wait for the "next" branch?
Hi, Wolfgang.
2010/10/28 Wolfgang Denk wd@denx.de:
There are bug fix. When we don't apply these patches, the board with the network device of the object does not work.
Applied, thanks.
Nobuhiro Iwamatsu
