[U-Boot] [PATCH 1/4] mtd: nand: denali: allow to override corrupted revision register
The Denali IP does not update the revision register properly. Allow to override it with SoC data associated with compatible.
Linux had already finished big surgery of this driver, but I need to prepare the NAND core before the full sync of the driver. For now, I am fixing the most fatal problem on UniPhier platform.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/mtd/nand/denali.c | 27 +++++++++++++++------------ drivers/mtd/nand/denali.h | 7 +++++-- drivers/mtd/nand/denali_dt.c | 30 ++++++++++++++++++++++++++++++ 3 files changed, 50 insertions(+), 14 deletions(-)
diff --git a/drivers/mtd/nand/denali.c b/drivers/mtd/nand/denali.c index 47cf37d..54718f4 100644 --- a/drivers/mtd/nand/denali.c +++ b/drivers/mtd/nand/denali.c @@ -10,7 +10,7 @@ #include <malloc.h> #include <nand.h> #include <linux/errno.h> -#include <asm/io.h> +#include <linux/io.h>
#include "denali.h"
@@ -433,17 +433,13 @@ static void find_valid_banks(struct denali_nand_info *denali) */ static void detect_max_banks(struct denali_nand_info *denali) { - uint32_t features = readl(denali->flash_reg + FEATURES); - /* - * Read the revision register, so we can calculate the max_banks - * properly: the encoding changed from rev 5.0 to 5.1 - */ - u32 revision = MAKE_COMPARABLE_REVISION( - readl(denali->flash_reg + REVISION)); - if (revision < REVISION_5_1) - denali->max_banks = 2 << (features & FEATURES__N_BANKS); - else - denali->max_banks = 1 << (features & FEATURES__N_BANKS); + uint32_t features = ioread32(denali->flash_reg + FEATURES); + + denali->max_banks = 1 << (features & FEATURES__N_BANKS); + + /* the encoding changed from rev 5.0 to 5.1 */ + if (denali->revision < 0x0501) + denali->max_banks <<= 1; }
static void detect_partition_feature(struct denali_nand_info *denali) @@ -1154,6 +1150,13 @@ static void denali_cmdfunc(struct mtd_info *mtd, unsigned int cmd, int col, static void denali_hw_init(struct denali_nand_info *denali) { /* + * The REVISION register may not be reliable. Platforms are allowed to + * override it. + */ + if (!denali->revision) + denali->revision = swab16(ioread32(denali->flash_reg + REVISION)); + + /* * tell driver how many bit controller will skip before writing * ECC code in OOB. This is normally used for bad block marker */ diff --git a/drivers/mtd/nand/denali.h b/drivers/mtd/nand/denali.h index 694bce5..08db488 100644 --- a/drivers/mtd/nand/denali.h +++ b/drivers/mtd/nand/denali.h @@ -166,8 +166,6 @@
#define REVISION 0x370 #define REVISION__VALUE 0xffff -#define MAKE_COMPARABLE_REVISION(x) swab16((x) & REVISION__VALUE) -#define REVISION_5_1 0x00000501
#define ONFI_DEVICE_FEATURES 0x380 #define ONFI_DEVICE_FEATURES__VALUE 0x003f @@ -462,8 +460,13 @@ struct denali_nand_info { uint32_t blksperchip; uint32_t bbtskipbytes; uint32_t max_banks; + unsigned int revision; + unsigned int caps; };
+#define DENALI_CAP_HW_ECC_FIXUP BIT(0) +#define DENALI_CAP_DMA_64BIT BIT(1) + int denali_init(struct denali_nand_info *denali);
#endif /* __DENALI_H__ */ diff --git a/drivers/mtd/nand/denali_dt.c b/drivers/mtd/nand/denali_dt.c index 0a6155c..4afd679 100644 --- a/drivers/mtd/nand/denali_dt.c +++ b/drivers/mtd/nand/denali_dt.c @@ -12,15 +12,38 @@
#include "denali.h"
+struct denali_dt_data { + unsigned int revision; + unsigned int caps; +}; + +static const struct denali_dt_data denali_socfpga_data = { + .caps = DENALI_CAP_HW_ECC_FIXUP, +}; + +static const struct denali_dt_data denali_uniphier_v5a_data = { + .caps = DENALI_CAP_HW_ECC_FIXUP | + DENALI_CAP_DMA_64BIT, +}; + +static const struct denali_dt_data denali_uniphier_v5b_data = { + .revision = 0x0501, + .caps = DENALI_CAP_HW_ECC_FIXUP | + DENALI_CAP_DMA_64BIT, +}; + static const struct udevice_id denali_nand_dt_ids[] = { { .compatible = "altr,socfpga-denali-nand", + .data = (unsigned long)&denali_socfpga_data, }, { .compatible = "socionext,uniphier-denali-nand-v5a", + .data = (unsigned long)&denali_uniphier_v5a_data, }, { .compatible = "socionext,uniphier-denali-nand-v5b", + .data = (unsigned long)&denali_uniphier_v5b_data, }, { /* sentinel */ } }; @@ -28,9 +51,16 @@ static const struct udevice_id denali_nand_dt_ids[] = { static int denali_dt_probe(struct udevice *dev) { struct denali_nand_info *denali = dev_get_priv(dev); + const struct denali_dt_data *data; struct resource res; int ret;
+ data = (void *)dev_get_driver_data(dev); + if (data) { + denali->revision = data->revision; + denali->caps = data->caps; + } + ret = dev_read_resource_byname(dev, "denali_reg", &res); if (ret) return ret;
The main difference between Pro4 and PXs2/LD6b is the Denali NAND IP version. This is now distinguished by DT. Merge the two defconfig files into uniphier_v7_defconfig.
Update the README.uniphier too.
arch/arm/mach-uniphier/Kconfig | 21 +++++----- configs/uniphier_pro4_defconfig | 49 ---------------------- ...r_pxs2_ld6b_defconfig => uniphier_v7_defconfig} | 4 +- doc/README.uniphier | 33 ++++++++------- 4 files changed, 31 insertions(+), 76 deletions(-) delete mode 100644 configs/uniphier_pro4_defconfig rename configs/{uniphier_pxs2_ld6b_defconfig => uniphier_v7_defconfig} (93%)
diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index ee22112..c8b5ab4 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -12,18 +12,14 @@ config ARCH_UNIPHIER_32BIT
choice prompt "UniPhier SoC select" - default ARCH_UNIPHIER_PRO4 + default ARCH_UNIPHIER_V8_MULTI
config ARCH_UNIPHIER_LD4_SLD8 bool "UniPhier LD4/sLD8 SoCs" select ARCH_UNIPHIER_32BIT
-config ARCH_UNIPHIER_PRO4 - bool "UniPhier Pro4 SoC" - select ARCH_UNIPHIER_32BIT - -config ARCH_UNIPHIER_PRO5_PXS2_LD6B - bool "UniPhier Pro5/PXs2/LD6b SoCs" +config ARCH_UNIPHIER_V7_MULTI + bool "UniPhier Pro4/Pro5/PXs2/LD6b SoCs" select ARCH_UNIPHIER_32BIT
config ARCH_UNIPHIER_V8_MULTI @@ -44,19 +40,24 @@ config ARCH_UNIPHIER_SLD8 depends on ARCH_UNIPHIER_LD4_SLD8 default y
+config ARCH_UNIPHIER_PRO4 + bool "Enable UniPhier Pro4 SoC support" + depends on ARCH_UNIPHIER_V7_MULTI + default y + config ARCH_UNIPHIER_PRO5 bool "Enable UniPhier Pro5 SoC support" - depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B + depends on ARCH_UNIPHIER_V7_MULTI default y
config ARCH_UNIPHIER_PXS2 bool "Enable UniPhier Pxs2 SoC support" - depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B + depends on ARCH_UNIPHIER_V7_MULTI default y
config ARCH_UNIPHIER_LD6B bool "Enable UniPhier LD6b SoC support" - depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B + depends on ARCH_UNIPHIER_V7_MULTI default y
config ARCH_UNIPHIER_LD11 diff --git a/configs/uniphier_pro4_defconfig b/configs/uniphier_pro4_defconfig deleted file mode 100644 index 7348675..0000000 --- a/configs/uniphier_pro4_defconfig +++ /dev/null @@ -1,49 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_UNIPHIER=y -CONFIG_SYS_TEXT_BASE=0x84000000 -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SPL_MMC_SUPPORT=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_NAND_SUPPORT=y -CONFIG_MICRO_SUPPORT_CARD=y -CONFIG_DEFAULT_DEVICE_TREE="uniphier-pro4-ref" -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set -CONFIG_SPL=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_CONFIG=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_XIMG is not set -# CONFIG_CMD_ENV_EXISTS is not set -# CONFIG_CMD_FPGA is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -# CONFIG_CMD_MISC is not set -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -# CONFIG_SPL_DOS_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_GPIO_UNIPHIER=y -CONFIG_MISC=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 -CONFIG_MMC_UNIPHIER=y -CONFIG_NAND=y -CONFIG_NAND_DENALI=y -CONFIG_NAND_DENALI_DT=y -CONFIG_SYS_NAND_DENALI_64BIT=y -CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 -CONFIG_SPL_NAND_DENALI=y -CONFIG_USB=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_GENERIC=y -CONFIG_USB_STORAGE=y diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_v7_defconfig similarity index 93% rename from configs/uniphier_pxs2_ld6b_defconfig rename to configs/uniphier_v7_defconfig index c242776..3c25484 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_v7_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y -CONFIG_ARCH_UNIPHIER_PRO5_PXS2_LD6B=y +CONFIG_ARCH_UNIPHIER_V7_MULTI=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_DEFAULT_DEVICE_TREE="uniphier-pxs2-vodka" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set @@ -45,4 +45,6 @@ CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SPL_NAND_DENALI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y diff --git a/doc/README.uniphier b/doc/README.uniphier index fa1f9bc..e4fd9a3 100644 --- a/doc/README.uniphier +++ b/doc/README.uniphier @@ -27,17 +27,17 @@ The following tables show <defconfig> and <device-tree> for each board.
32bit SoC boards:
- Board | <defconfig> | <device-tree> ----------------|------------------------------|------------------------------ -LD4 reference | uniphier_ld4_sld8_defconfig | uniphier-ld4-ref (default) -sld8 reference | uniphier_ld4_sld8_defconfig | uniphier-sld8-def -Pro4 reference | uniphier_pro4_defconfig | uniphier-pro4-ref (default) -Pro4 Ace | uniphier_pro4_defconfig | uniphier-pro4-ace -Pro4 Sanji | uniphier_pro4_defconfig | uniphier-pro4-sanji -Pro5 4KBOX | uniphier_pxs2_ld6b_defconfig | uniphier-pro5-4kbox -PXs2 Gentil | uniphier_pxs2_ld6b_defconfig | uniphier-pxs2-gentil -PXs2 Vodka | uniphier_pxs2_ld6b_defconfig | uniphier-pxs2-vodka (default) -LD6b reference | uniphier_pxs2_ld6b_defconfig | uniphier-ld6b-ref + Board | <defconfig> | <device-tree> +---------------|-----------------------------|------------------------------ +LD4 reference | uniphier_ld4_sld8_defconfig | uniphier-ld4-ref (default) +sld8 reference | uniphier_ld4_sld8_defconfig | uniphier-sld8-def +Pro4 reference | uniphier_v7_defconfig | uniphier-pro4-ref +Pro4 Ace | uniphier_v7_defconfig | uniphier-pro4-ace +Pro4 Sanji | uniphier_v7_defconfig | uniphier-pro4-sanji +Pro5 4KBOX | uniphier_v7_defconfig | uniphier-pro5-4kbox +PXs2 Gentil | uniphier_v7_defconfig | uniphier-pxs2-gentil +PXs2 Vodka | uniphier_v7_defconfig | uniphier-pxs2-vodka (default) +LD6b reference | uniphier_v7_defconfig | uniphier-ld6b-ref
64bit SoC boards:
@@ -47,17 +47,18 @@ LD11 reference | uniphier_v8_defconfig | uniphier-ld11-ref LD11 Global | uniphier_v8_defconfig | uniphier-ld11-global LD20 reference | uniphier_v8_defconfig | uniphier-ld20-ref (default) LD20 Global | uniphier_v8_defconfig | uniphier-ld20-global +PXs3 reference | uniphier_v8_defconfig | uniphier-pxs3-ref
For example, to compile the source for PXs2 Vodka board, run the following:
- $ make uniphier_pxs2_ld6b_defconfig + $ make uniphier_v7_defconfig $ make CROSS_COMPILE=arm-linux-gnueabihf- DEVICE_TREE=uniphier-pxs2-vodka
The device tree marked as (default) can be omitted. `uniphier-pxs2-vodka` is -the default device tree for the configuration `uniphier_pxs2_ld6b_defconfig`, -so the following gives the same result. +the default device tree for the configuration `uniphier_v7_defconfig`, so the +following gives the same result.
@@ -178,4 +179,4 @@ newer SoCs. Even if it is, EA[25] is not connected on most of the boards.
-- Masahiro Yamada yamada.masahiro@socionext.com -Jul. 2017 +Sep. 2017
Starting from PXs3, the bit fields of RSTCTRL, CLKCTRL registers will change every SoC. There is no more point to define bitfields in the common header file.
arch/arm/mach-uniphier/clk/clk-ld11.c | 2 +- arch/arm/mach-uniphier/sc64-regs.h | 18 ------------------ 2 files changed, 1 insertion(+), 19 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/clk-ld11.c b/arch/arm/mach-uniphier/clk/clk-ld11.c index 0266e7e..a4b7419 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld11.c +++ b/arch/arm/mach-uniphier/clk/clk-ld11.c @@ -40,7 +40,7 @@ void uniphier_ld11_clk_init(void) int ch;
tmp = readl(SC_CLKCTRL4); - tmp |= SC_CLKCTRL4_MIO | SC_CLKCTRL4_STDMAC; + tmp |= BIT(10) | BIT(8); /* MIO, STDMAC */ writel(tmp, SC_CLKCTRL4);
for (ch = 0; ch < 3; ch++) { diff --git a/arch/arm/mach-uniphier/sc64-regs.h b/arch/arm/mach-uniphier/sc64-regs.h index d0a51f2..80efb4e 100644 --- a/arch/arm/mach-uniphier/sc64-regs.h +++ b/arch/arm/mach-uniphier/sc64-regs.h @@ -15,34 +15,16 @@ #define SC_RSTCTRL (SC_BASE_ADDR | 0x2000) #define SC_RSTCTRL3 (SC_BASE_ADDR | 0x2008) #define SC_RSTCTRL4 (SC_BASE_ADDR | 0x200c) -#define SC_RSTCTRL4_ETHER (1 << 6) -#define SC_RSTCTRL4_NAND (1 << 0) #define SC_RSTCTRL5 (SC_BASE_ADDR | 0x2010) #define SC_RSTCTRL6 (SC_BASE_ADDR | 0x2014) #define SC_RSTCTRL7 (SC_BASE_ADDR | 0x2018) -#define SC_RSTCTRL7_UMCSB (1 << 16) -#define SC_RSTCTRL7_UMCA2 (1 << 10) -#define SC_RSTCTRL7_UMCA1 (1 << 9) -#define SC_RSTCTRL7_UMCA0 (1 << 8) -#define SC_RSTCTRL7_UMC32 (1 << 2) -#define SC_RSTCTRL7_UMC31 (1 << 1) -#define SC_RSTCTRL7_UMC30 (1 << 0)
#define SC_CLKCTRL (SC_BASE_ADDR | 0x2100) #define SC_CLKCTRL3 (SC_BASE_ADDR | 0x2108) #define SC_CLKCTRL4 (SC_BASE_ADDR | 0x210c) -#define SC_CLKCTRL4_MIO (1 << 10) -#define SC_CLKCTRL4_STDMAC (1 << 8) -#define SC_CLKCTRL4_PERI (1 << 7) -#define SC_CLKCTRL4_ETHER (1 << 6) -#define SC_CLKCTRL4_NAND (1 << 0) #define SC_CLKCTRL5 (SC_BASE_ADDR | 0x2110) #define SC_CLKCTRL6 (SC_BASE_ADDR | 0x2114) #define SC_CLKCTRL7 (SC_BASE_ADDR | 0x2118) -#define SC_CLKCTRL7_UMCSB (1 << 16) -#define SC_CLKCTRL7_UMC32 (1 << 2) -#define SC_CLKCTRL7_UMC31 (1 << 1) -#define SC_CLKCTRL7_UMC30 (1 << 0)
#define SC_CA72_GEARST (SC_BASE_ADDR | 0x8000) #define SC_CA72_GEARSET (SC_BASE_ADDR | 0x8004)
The driver for Linux is out of control of Socionext, so set up reset / clock in here.
arch/arm/mach-uniphier/clk/clk-ld20.c | 12 ++++++++++++ arch/arm/mach-uniphier/clk/clk-pxs3.c | 12 ++++++++++++ 2 files changed, 24 insertions(+)
diff --git a/arch/arm/mach-uniphier/clk/clk-ld20.c b/arch/arm/mach-uniphier/clk/clk-ld20.c index 5bb560c..f79fb38 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld20.c +++ b/arch/arm/mach-uniphier/clk/clk-ld20.c @@ -4,14 +4,26 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <linux/bitops.h> #include <linux/io.h>
#include "../init.h" +#include "../sc64-regs.h"
#define SDCTRL_EMMC_HW_RESET 0x59810280
void uniphier_ld20_clk_init(void) { + u32 tmp; + + tmp = readl(SC_RSTCTRL6); + tmp |= BIT(8); /* Mali */ + writel(tmp, SC_RSTCTRL6); + + tmp = readl(SC_CLKCTRL6); + tmp |= BIT(8); /* Mali */ + writel(tmp, SC_CLKCTRL6); + /* TODO: use "mmc-pwrseq-emmc" */ writel(1, SDCTRL_EMMC_HW_RESET); } diff --git a/arch/arm/mach-uniphier/clk/clk-pxs3.c b/arch/arm/mach-uniphier/clk/clk-pxs3.c index 2dee857..3b9cc62 100644 --- a/arch/arm/mach-uniphier/clk/clk-pxs3.c +++ b/arch/arm/mach-uniphier/clk/clk-pxs3.c @@ -4,14 +4,26 @@ * SPDX-License-Identifier: GPL-2.0+ */
void uniphier_pxs3_clk_init(void) { + u32 tmp; + + tmp = readl(SC_RSTCTRL6); + tmp |= BIT(8); /* Mali */ + writel(tmp, SC_RSTCTRL6); + + tmp = readl(SC_CLKCTRL6); + tmp |= BIT(8); /* Mali */ + writel(tmp, SC_CLKCTRL6); + /* TODO: use "mmc-pwrseq-emmc" */ writel(1, SDCTRL_EMMC_HW_RESET); }
2017-09-15 21:43 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Series, applied to u-boot-uniphier/master.
Masahiro Yamada
