[U-Boot-Users] [PATCH 1/2] Move 64bit division from avr32 to generic lib
Move the 64bit division from lib_avr32 to lib_generic. With this, all boards can do_div/__div64_32 if needed, not only avr one. Code is put to lib_generic, so no larger memory footprint if not used. No code modifications. Thanks for proposal by Håvard Skinnemoen.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Index: uboot/include/div64.h =================================================================== --- /dev/null +++ uboot/include/div64.h @@ -0,0 +1,39 @@ +#ifndef _ASM_GENERIC_DIV64_H +#define _ASM_GENERIC_DIV64_H +/* + * Copyright (C) 2003 Bernardo Innocenti bernie@develer.com + * Based on former asm-ppc/div64.h and asm-m68knommu/div64.h + * + * The semantics of do_div() are: + * + * uint32_t do_div(uint64_t *n, uint32_t base) + * { + * uint32_t remainder = *n % base; + * *n = *n / base; + * return remainder; + * } + * + * NOTE: macro parameter n is evaluated multiple times, + * beware of side effects! + */ + +#include <linux/types.h> + +extern uint32_t __div64_32(uint64_t *dividend, uint32_t divisor); + +/* The unnecessary pointer compare is there + * to check for type safety (n must be 64bit) + */ +# define do_div(n,base) ({ \ + uint32_t __base = (base); \ + uint32_t __rem; \ + (void)(((typeof((n)) *)0) == ((uint64_t *)0)); \ + if (((n) >> 32) == 0) { \ + __rem = (uint32_t)(n) % __base; \ + (n) = (uint32_t)(n) / __base; \ + } else \ + __rem = __div64_32(&(n), __base); \ + __rem; \ + }) + +#endif /* _ASM_GENERIC_DIV64_H */ Index: uboot/lib_generic/div64.c =================================================================== --- /dev/null +++ uboot/lib_generic/div64.c @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2003 Bernardo Innocenti bernie@develer.com + * + * Based on former do_div() implementation from asm-parisc/div64.h: + * Copyright (C) 1999 Hewlett-Packard Co + * Copyright (C) 1999 David Mosberger-Tang davidm@hpl.hp.com + * + * + * Generic C version of 64bit/32bit division and modulo, with + * 64bit result and 32bit remainder. + * + * The fast case for (n>>32 == 0) is handled inline by do_div(). + * + * Code generated for this function might be very inefficient + * for some CPUs. __div64_32() can be overridden by linking arch-specific + * assembly versions such as arch/ppc/lib/div64.S and arch/sh/lib/div64.S. + */ + +#include <linux/types.h> + +uint32_t __div64_32(uint64_t *n, uint32_t base) +{ + uint64_t rem = *n; + uint64_t b = base; + uint64_t res, d = 1; + uint32_t high = rem >> 32; + + /* Reduce the thing a bit first */ + res = 0; + if (high >= base) { + high /= base; + res = (uint64_t) high << 32; + rem -= (uint64_t) (high*base) << 32; + } + + while ((int64_t)b > 0 && b < rem) { + b = b+b; + d = d+d; + } + + do { + if (rem >= b) { + rem -= b; + res += d; + } + b >>= 1; + d >>= 1; + } while (d); + + *n = res; + return rem; +} Index: uboot/lib_generic/Makefile =================================================================== --- uboot.orig/lib_generic/Makefile +++ uboot/lib_generic/Makefile @@ -27,7 +27,7 @@ LIB = $(obj)libgeneric.a
COBJS = bzlib.o bzlib_crctable.o bzlib_decompress.o \ bzlib_randtable.o bzlib_huffman.o \ - crc32.o ctype.o display_options.o ldiv.o sha1.o \ + crc32.o ctype.o display_options.o div64.o ldiv.o sha1.o \ string.o vsprintf.o zlib.o
SRCS := $(COBJS:.o=.c) Index: uboot/lib_avr32/Makefile =================================================================== --- uboot.orig/lib_avr32/Makefile +++ uboot/lib_avr32/Makefile @@ -29,7 +29,7 @@ LIB = $(obj)lib$(ARCH).a
SOBJS = memset.o
-COBJS = board.o interrupts.o avr32_linux.o div64.o +COBJS = board.o interrupts.o avr32_linux.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) Index: uboot/include/asm-avr32/div64.h =================================================================== --- uboot.orig/include/asm-avr32/div64.h +++ /dev/null @@ -1,39 +0,0 @@ -#ifndef _ASM_GENERIC_DIV64_H -#define _ASM_GENERIC_DIV64_H -/* - * Copyright (C) 2003 Bernardo Innocenti bernie@develer.com - * Based on former asm-ppc/div64.h and asm-m68knommu/div64.h - * - * The semantics of do_div() are: - * - * uint32_t do_div(uint64_t *n, uint32_t base) - * { - * uint32_t remainder = *n % base; - * *n = *n / base; - * return remainder; - * } - * - * NOTE: macro parameter n is evaluated multiple times, - * beware of side effects! - */ - -#include <linux/types.h> - -extern uint32_t __div64_32(uint64_t *dividend, uint32_t divisor); - -/* The unnecessary pointer compare is there - * to check for type safety (n must be 64bit) - */ -# define do_div(n,base) ({ \ - uint32_t __base = (base); \ - uint32_t __rem; \ - (void)(((typeof((n)) *)0) == ((uint64_t *)0)); \ - if (((n) >> 32) == 0) { \ - __rem = (uint32_t)(n) % __base; \ - (n) = (uint32_t)(n) / __base; \ - } else \ - __rem = __div64_32(&(n), __base); \ - __rem; \ - }) - -#endif /* _ASM_GENERIC_DIV64_H */ Index: uboot/lib_avr32/div64.c =================================================================== --- uboot.orig/lib_avr32/div64.c +++ /dev/null @@ -1,54 +0,0 @@ -/* - * Copyright (C) 2003 Bernardo Innocenti bernie@develer.com - * - * Based on former do_div() implementation from asm-parisc/div64.h: - * Copyright (C) 1999 Hewlett-Packard Co - * Copyright (C) 1999 David Mosberger-Tang davidm@hpl.hp.com - * - * - * Generic C version of 64bit/32bit division and modulo, with - * 64bit result and 32bit remainder. - * - * The fast case for (n>>32 == 0) is handled inline by do_div(). - * - * Code generated for this function might be very inefficient - * for some CPUs. __div64_32() can be overridden by linking arch-specific - * assembly versions such as arch/ppc/lib/div64.S and arch/sh/lib/div64.S. - */ - -#include <linux/types.h> - -#include <asm/div64.h> - -uint32_t __div64_32(uint64_t *n, uint32_t base) -{ - uint64_t rem = *n; - uint64_t b = base; - uint64_t res, d = 1; - uint32_t high = rem >> 32; - - /* Reduce the thing a bit first */ - res = 0; - if (high >= base) { - high /= base; - res = (uint64_t) high << 32; - rem -= (uint64_t) (high*base) << 32; - } - - while ((int64_t)b > 0 && b < rem) { - b = b+b; - d = d+d; - } - - do { - if (rem >= b) { - rem -= b; - res += d; - } - b >>= 1; - d >>= 1; - } while (d); - - *n = res; - return rem; -}
Looks good, although I'm afraid it will break avr32 as it still expects to find div64.h under asm/. Could you include this change as well to avoid any breakage when it is merged?
diff --git a/cpu/at32ap/interrupts.c b/cpu/at32ap/interrupts.c index c9e0499..bef1f30 100644 --- a/cpu/at32ap/interrupts.c +++ b/cpu/at32ap/interrupts.c @@ -20,8 +20,8 @@ * MA 02111-1307 USA */ #include <common.h> +#include <div64.h>
-#include <asm/div64.h> #include <asm/errno.h> #include <asm/io.h> #include <asm/processor.h>
Dirk Behme
Håvard Skinnemoen
