[U-Boot] [PATCH] sunxi: Add defconfig and dts file for Polaroid MID2407PXE03 tablet
The Polaroid MID2407PXE03 is an a23 based 7" tablet based on a M86_MB V2.0 PCB, featuring a 800x480 LCD, 512MB RAM, 4G NAND, esp8089 wifi, gsl1680 touchschreen, micro-sd slot, 3.5mm headphone jack and a micro-usb otg connector which doubles as charging port.
The dts file is identical to the one submitted to the upstream kernel.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/axp22x.dtsi | 10 + arch/arm/dts/sun8i-a23-polaroid-mid2407pxe03.dts | 292 +++++++++++++++++++++++ board/sunxi/MAINTAINERS | 1 + configs/polaroid_mid2407pxe03_defconfig | 24 ++ 5 files changed, 328 insertions(+) create mode 100644 arch/arm/dts/sun8i-a23-polaroid-mid2407pxe03.dts create mode 100644 configs/polaroid_mid2407pxe03_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a827613..f76475e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -216,6 +216,7 @@ dtb-$(CONFIG_MACH_SUN7I) += \ dtb-$(CONFIG_MACH_SUN8I_A23) += \ sun8i-a23-evb.dtb \ sun8i-a23-gt90h-v4.dtb \ + sun8i-a23-polaroid-mid2407pxe03.dtb \ sun8i-a23-polaroid-mid2809pxe04.dtb \ sun8i-a23-q8-tablet.dtb dtb-$(CONFIG_MACH_SUN8I_A33) += \ diff --git a/arch/arm/dts/axp22x.dtsi b/arch/arm/dts/axp22x.dtsi index 0cfec50..458b668 100644 --- a/arch/arm/dts/axp22x.dtsi +++ b/arch/arm/dts/axp22x.dtsi @@ -141,5 +141,15 @@ regulator-max-microvolt = <3000000>; regulator-name = "rtc_ldo"; }; + + reg_drivevbus: drivevbus { + regulator-name = "drivevbus"; + status = "disabled"; + }; + }; + + usb_power_supply: usb_power_supply { + compatible = "x-powers,axp221-usb-power-supply"; + status = "disabled"; }; }; diff --git a/arch/arm/dts/sun8i-a23-polaroid-mid2407pxe03.dts b/arch/arm/dts/sun8i-a23-polaroid-mid2407pxe03.dts new file mode 100644 index 0000000..bb2f073 --- /dev/null +++ b/arch/arm/dts/sun8i-a23-polaroid-mid2407pxe03.dts @@ -0,0 +1,292 @@ +/* + * Copyright 2016 Hans de Goede hdegoede@redhat.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-a23.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + model = "Polaroid MID2407PXE03 tablet"; + compatible = "polaroid,mid2407pxe03", "allwinner,sun8i-a23"; + + aliases { + serial0 = &r_uart; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + pinctrl-names = "default"; + pinctrl-0 = <&bl_en_pin_mid2407>; + pwms = <&pwm 0 50000 PWM_POLARITY_INVERTED>; + brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; + default-brightness-level = <8>; + enable-gpios = <&pio 7 6 GPIO_ACTIVE_HIGH>; /* PH6 */ + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; + /* + * The gsl1680 is rated at 400KHz and it will not work reliable at + * 100KHz, this has been confirmed on multiple different tablets. + * The gsl1680 is the only device on this bus. + */ + clock-frequency = <400000>; + + gsl1680: touchscreen@40 { + compatible = "silead,gsl1680"; + reg = <0x40>; + interrupt-parent = <&pio>; + interrupts = <1 5 IRQ_TYPE_EDGE_FALLING>; /* PB5 */ + pinctrl-names = "default"; + pinctrl-0 = <&ts_power_pin_mid2407>; + power-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ + touchscreen-size-x = <960>; + touchscreen-size-y = <640>; + touchscreen-inverted-x; + touchscreen-inverted-y; + touchscreen-max-fingers = <5>; + touchscreen-fw-name = "silead/gsl1680-polaroid-mid2407pxe03.fw"; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_a>; + status = "okay"; +}; + +&lradc { + vref-supply = <®_vcc3v0>; + status = "okay"; + + button@200 { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + channel = <0>; + voltage = <200000>; + }; + + button@400 { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + channel = <0>; + voltage = <400000>; + }; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_mid2407>; + vmmc-supply = <®_dcdc1>; + bus-width = <4>; + cd-gpios = <&pio 1 4 GPIO_ACTIVE_HIGH>; /* PB4 */ + cd-inverted; + status = "okay"; +}; + +&pio { + bl_en_pin_mid2407: bl_en_pin@0 { + allwinner,pins = "PH6"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + mmc0_cd_pin_mid2407: mmc0_cd_pin@0 { + allwinner,pins = "PB4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + ts_power_pin_mid2407: ts_power_pin@0 { + allwinner,pins = "PH1"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH8"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; +}; + +&pwm { + pinctrl-names = "default"; + pinctrl-0 = <&pwm0_pins>; + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp22x: pmic@3a3 { + compatible = "x-powers,axp223"; + reg = <0x3a3>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + eldoin-supply = <®_dcdc1>; + x-powers,drive-vbus-en; + }; +}; + +&r_uart { + pinctrl-names = "default"; + pinctrl-0 = <&r_uart_pins_a>; + status = "okay"; +}; + +#include "axp22x.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-io"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <2350000>; + regulator-max-microvolt = <2650000>; + regulator-name = "vdd-dll"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dc1sw { + regulator-name = "vcc-lcd"; +}; + +®_dc5ldo { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-cpus"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-3v0"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-sys"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + +®_ldo_io1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-touchscreen"; + status = "okay"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +&simplefb_lcd { + vcc-lcd-supply = <®_dc1sw>; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usb_power_supply { + status = "okay"; +}; + +&usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>; + usb0_id_det-gpio = <&pio 7 8 GPIO_ACTIVE_HIGH>; /* PH8 */ + usb0_vbus_power-supply = <&usb_power_supply>; + usb0_vbus-supply = <®_drivevbus>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 2cb8a75..4f8d950 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -58,6 +58,7 @@ F: configs/orangepi_2_defconfig F: configs/orangepi_one_defconfig F: configs/orangepi_pc_defconfig F: configs/orangepi_plus_defconfig +F: configs/polaroid_mid2407pxe03_defconfig F: configs/polaroid_mid2809pxe04_defconfig F: configs/q8_a23_tablet_800x480_defconfig F: configs/q8_a33_tablet_800x480_defconfig diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig new file mode 100644 index 0000000..9bf6fbf --- /dev/null +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -0,0 +1,24 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_A23=y +CONFIG_DRAM_CLK=432 +CONFIG_DRAM_ZQ=63351 +CONFIG_MMC0_CD_PIN="PB4" +CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" +CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" +CONFIG_USB0_ID_DET="PH8" +CONFIG_AXP_GPIO=y +CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:40,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_DCLK_PHASE=0 +CONFIG_VIDEO_LCD_POWER="PH7" +CONFIG_VIDEO_LCD_BL_EN="PH6" +CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2407pxe03" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_AXP_DLDO1_VOLT=3300 +CONFIG_USB_MUSB_HOST=y
Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
