[PATCH v3 0/2] imx: support for conga-QMX8 board
Second patch is still needed for booting. Tipps to get rid of that patch would be helpfull.
Between u-boot-imx-20200511 and u-boot-imx-20200609 something more is broken, I run into this issue:
U-Boot 2020.07-rc3-00002-gbf3f929aa6 (Jun 16 2020 - 14:36:58 +0200)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
Model: Congatec QMX8 Qseven series Board: conga-QMX8 Build: SCFW 494c97f3, SECO-FW d7523fe8, ATF 09c5cc9 Boot: SD2 DRAM: 6 GiB Device 'gpio@5d090000': seq 0 is in use by 'gpio@5d080000' Device 'gpio@5d0a0000': seq 1 is in use by 'gpio@5d090000' MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... OK In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 "Synchronous Abort" handler, esr 0x96000004 elr: 000000008005cf48 lr : 0000000080022f94 (reloc) elr: 00000000fff22f48 lr : 00000000ffee8f94 x0 : fffffffffdaf3540 x1 : 00000000fff2d8a0 x2 : 0000000000000000 x3 : 0000000000000000 x4 : 0000000000000000 x5 : fffffffffdaf3540 x6 : 00000000fff068a8 x7 : 00000000fff3bca0 x8 : 00000000fdaf3ac0 x9 : 0000000000000008 x10: 00000000fdaecb30 x11: 00000000fdaefdd0 x12: 0000000000000000 x13: 0000000000000200 x14: 00000000fdadebf8 x15: 00000000ffffffff x16: 0000000000001080 x17: 0000000000000000 x18: 00000000fdae4da0 x19: 0000000000000002 x20: 00000000fff3b000 x21: 000000007fec6000 x22: 0000000000000000 x23: 0000000000000000 x24: 0000000000000000 x25: 0000000000000000 x26: 0000000000000000 x27: 0000000000000000 x28: 0000000000000000 x29: 00000000fdadfd90
Code: aa0503e4 17fffff2 aa0003e5 d2800003 (386368a4) Resetting CPU ...
resetting ...
Oliver Graute (2): imx: support for conga-QMX8 board hack to boot with 2020.01
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8qm-cgtqmx8.dts | 427 +++++++++++++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 7 + board/congatec/cgtqmx8/Kconfig | 14 + board/congatec/cgtqmx8/MAINTAINERS | 6 + board/congatec/cgtqmx8/Makefile | 11 + board/congatec/cgtqmx8/README | 46 +++ board/congatec/cgtqmx8/cgtqmx8.c | 479 ++++++++++++++++++++++++++++ board/congatec/cgtqmx8/imximage.cfg | 21 ++ board/congatec/cgtqmx8/spl.c | 76 +++++ board/congatec/common/Kconfig | 48 +++ board/congatec/common/Makefile | 23 ++ board/congatec/common/mmc.c | 50 +++ configs/cgtqmx8_defconfig | 82 +++++ drivers/core/device.c | 7 +- include/configs/cgtqmx8.h | 194 +++++++++++ 16 files changed, 1487 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/imx8qm-cgtqmx8.dts create mode 100644 board/congatec/cgtqmx8/Kconfig create mode 100644 board/congatec/cgtqmx8/MAINTAINERS create mode 100644 board/congatec/cgtqmx8/Makefile create mode 100644 board/congatec/cgtqmx8/README create mode 100644 board/congatec/cgtqmx8/cgtqmx8.c create mode 100644 board/congatec/cgtqmx8/imximage.cfg create mode 100644 board/congatec/cgtqmx8/spl.c create mode 100644 board/congatec/common/Kconfig create mode 100644 board/congatec/common/Makefile create mode 100644 board/congatec/common/mmc.c create mode 100644 configs/cgtqmx8_defconfig create mode 100644 include/configs/cgtqmx8.h
Add i.MX8QM qmx8 congatec board support
U-Boot 2020.04-00002-g1ff5446a63 (Jun 16 2020 - 13:47:28 +0200)
Model: Congatec QMX8 Qseven series Board: conga-QMX8 Build: SCFW 494c97f3, SECO-FW d7523fe8, ATF 09c5cc9 Boot: SD2 DRAM: 6 GiB Device 'gpio@5d090000': seq 0 is in use by 'gpio@5d080000' Device 'gpio@5d0a0000': seq 1 is in use by 'gpio@5d090000' MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... OK In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 switch to partitions #0, OK mmc2 is current device Net: eth0: ethernet@5b040000 Hit any key to stop autoboot: 0
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Ye Li ye.li@nxp.com Cc: uboot-imx uboot-imx@nxp.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8qm-cgtqmx8.dts | 427 +++++++++++++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 7 + board/congatec/cgtqmx8/Kconfig | 14 + board/congatec/cgtqmx8/MAINTAINERS | 6 + board/congatec/cgtqmx8/Makefile | 11 + board/congatec/cgtqmx8/README | 57 ++++ board/congatec/cgtqmx8/cgtqmx8.c | 478 ++++++++++++++++++++++++++++ board/congatec/cgtqmx8/imximage.cfg | 21 ++ board/congatec/cgtqmx8/spl.c | 76 +++++ board/congatec/common/Kconfig | 48 +++ board/congatec/common/Makefile | 23 ++ board/congatec/common/mmc.c | 50 +++ configs/cgtqmx8_defconfig | 82 +++++ include/configs/cgtqmx8.h | 194 +++++++++++ 15 files changed, 1454 insertions(+) create mode 100644 arch/arm/dts/imx8qm-cgtqmx8.dts create mode 100644 board/congatec/cgtqmx8/Kconfig create mode 100644 board/congatec/cgtqmx8/MAINTAINERS create mode 100644 board/congatec/cgtqmx8/Makefile create mode 100644 board/congatec/cgtqmx8/README create mode 100644 board/congatec/cgtqmx8/cgtqmx8.c create mode 100644 board/congatec/cgtqmx8/imximage.cfg create mode 100644 board/congatec/cgtqmx8/spl.c create mode 100644 board/congatec/common/Kconfig create mode 100644 board/congatec/common/Makefile create mode 100644 board/congatec/common/mmc.c create mode 100644 configs/cgtqmx8_defconfig create mode 100644 include/configs/cgtqmx8.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9900b44274..6eb6399468 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -735,6 +735,7 @@ dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-com.dtb \ dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qm-apalis.dtb \ fsl-imx8qm-mek.dtb \ + imx8qm-cgtqmx8.dtb \ imx8qm-rom7720-a1.dtb \ fsl-imx8qxp-ai_ml.dtb \ fsl-imx8qxp-colibri.dtb \ diff --git a/arch/arm/dts/imx8qm-cgtqmx8.dts b/arch/arm/dts/imx8qm-cgtqmx8.dts new file mode 100644 index 0000000000..43334147bb --- /dev/null +++ b/arch/arm/dts/imx8qm-cgtqmx8.dts @@ -0,0 +1,427 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2017 NXP + * Copyright 2017 congatec AG + * Copyright (C) 2019 Oliver Graute oliver.graute@kococonnector.com + */ + +/dts-v1/; + +/* First 128KB is for PSCI ATF. */ +/memreserve/ 0x80000000 0x00020000; + +#include "fsl-imx8qm.dtsi" + +/ { + model = "Congatec QMX8 Qseven series"; + compatible = "fsl,imx8qm-qmx8", "fsl,imx8qm"; + + chosen { + bootargs = "console=ttyLP0,115200 earlycon=lpuart32,0x5a060000,115200"; + stdout-path = &lpuart0; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_usdhc2_vmmc: usdhc2_vmmc { + compatible = "regulator-fixed"; + regulator-name = "sw-3p3-sd1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio4 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + off-on-delay-us = <3000>; + }; + + reg_usdhc3_vmmc: usdhc3_vmmc { + compatible = "regulator-fixed"; + regulator-name = "sw-3p3-sd2"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio4 9 GPIO_ACTIVE_HIGH>; + enable-active-high; + off-on-delay-us = <3000>; + }; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii"; + phy-handle = <ðphy0>; + fsl,magic-packet; + fsl,rgmii_txc_dly; + fsl,rgmii_rxc_dly; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@6 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <6>; + at803x,eee-disabled; + at803x,vddio-1p8v; + }; + }; +}; + +&gpio2 { + status = "okay"; +}; + +&gpio5 { + status = "okay"; +}; + +&i2c0 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpi2c0>; + clock-frequency = <100000>; + status = "okay"; + + rtc_ext: m41t62@68 { + compatible = "st,m41t62"; + reg = <0x68>; + }; +}; + +&i2c1 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpi2c1>; + status = "okay"; + + wm8904: wm8904@1a { + compatible = "wlf,wm8904"; + reg = <0x1a>; + + clocks = <&clk IMX8QM_AUD_MCLKOUT0>; + clock-names = "mclk"; + wlf,shared-lrclk; + /* power-domains = <&pd_mclk_out0>; */ + + assigned-clocks = <&clk IMX8QM_AUD_PLL0_DIV>, + <&clk IMX8QM_AUD_ACM_AUD_PLL_CLK0_DIV>, + <&clk IMX8QM_AUD_ACM_AUD_REC_CLK0_DIV>, + <&clk IMX8QM_AUD_MCLKOUT0>; + + assigned-clock-rates = <786432000>, <49152000>, <24576000>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + imx8qm-qmx8 { + + pinctrl_hog: hoggrp{ + fsl,pins = < + SC_P_M40_GPIO0_01_LSIO_GPIO0_IO09 0x00000021 + SC_P_USB_SS3_TC1_LSIO_GPIO4_IO04 0x00000021 + SC_P_M40_GPIO0_00_LSIO_GPIO0_IO08 0x00000021 + SC_P_ESAI1_SCKT_LSIO_GPIO2_IO07 0x00000021 + SC_P_SPDIF0_TX_LSIO_GPIO2_IO15 0x00000021 + SC_P_FLEXCAN1_RX_LSIO_GPIO3_IO31 0x00000021 + SC_P_ESAI1_TX0_LSIO_GPIO2_IO08 0x00000021 + SC_P_FLEXCAN1_TX_LSIO_GPIO4_IO00 0x00000021 + SC_P_ESAI1_TX1_LSIO_GPIO2_IO09 0x00000021 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + SC_P_ENET0_MDC_CONN_ENET0_MDC 0x06000020 + SC_P_ENET0_MDIO_CONN_ENET0_MDIO 0x06000020 + SC_P_ENET0_RGMII_TX_CTL_CONN_ENET0_RGMII_TX_CTL 0x06000020 + SC_P_ENET0_RGMII_TXC_CONN_ENET0_RGMII_TXC 0x06000020 + SC_P_ENET0_RGMII_TXD0_CONN_ENET0_RGMII_TXD0 0x06000020 + SC_P_ENET0_RGMII_TXD1_CONN_ENET0_RGMII_TXD1 0x06000020 + SC_P_ENET0_RGMII_TXD2_CONN_ENET0_RGMII_TXD2 0x06000020 + SC_P_ENET0_RGMII_TXD3_CONN_ENET0_RGMII_TXD3 0x06000020 + SC_P_ENET0_RGMII_RXC_CONN_ENET0_RGMII_RXC 0x06000020 + SC_P_ENET0_RGMII_RX_CTL_CONN_ENET0_RGMII_RX_CTL 0x06000020 + SC_P_ENET0_RGMII_RXD0_CONN_ENET0_RGMII_RXD0 0x06000020 + SC_P_ENET0_RGMII_RXD1_CONN_ENET0_RGMII_RXD1 0x06000020 + SC_P_ENET0_RGMII_RXD2_CONN_ENET0_RGMII_RXD2 0x06000020 + SC_P_ENET0_RGMII_RXD3_CONN_ENET0_RGMII_RXD3 0x06000020 + >; + }; + + pinctrl_lpi2c0: lpi2c0grp { + fsl,pins = < + SC_P_HDMI_TX0_TS_SCL_DMA_I2C0_SCL 0xc600004c + SC_P_HDMI_TX0_TS_SDA_DMA_I2C0_SDA 0xc600004c + >; + }; + + pinctrl_lpi2c1: lpi2c1grp { + fsl,pins = < + SC_P_GPT0_CLK_DMA_I2C1_SCL 0xc600004c + SC_P_GPT0_CAPTURE_DMA_I2C1_SDA 0xc600004c + >; + }; + + pinctrl_lpuart0: lpuart0grp { + fsl,pins = < + SC_P_UART0_RX_DMA_UART0_RX 0x06000020 + SC_P_UART0_TX_DMA_UART0_TX 0x06000020 + >; + }; + + pinctrl_lpuart1: lpuart1grp { + fsl,pins = < + SC_P_UART1_RX_DMA_UART1_RX 0x06000020 + SC_P_UART1_TX_DMA_UART1_TX 0x06000020 + SC_P_UART1_CTS_B_DMA_UART1_CTS_B 0x06000020 + SC_P_UART1_RTS_B_DMA_UART1_RTS_B 0x06000020 + >; + }; + + pinctrl_lpuart3: lpuart3grp { + fsl,pins = < + SC_P_M41_GPIO0_00_DMA_UART3_RX 0x06000020 + SC_P_M41_GPIO0_01_DMA_UART3_TX 0x06000020 + >; + }; + + pinctrl_mlb: mlbgrp { + fsl,pins = < + SC_P_MLB_SIG_CONN_MLB_SIG 0x21 + SC_P_MLB_CLK_CONN_MLB_CLK 0x21 + SC_P_MLB_DATA_CONN_MLB_DATA 0x21 + >; + }; + + pinctrl_isl29023: isl29023grp { + fsl,pins = < + SC_P_ADC_IN2_LSIO_GPIO3_IO20 0x00000021 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000021 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000021 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000021 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000021 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000021 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000021 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000021 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000021 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000021 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000041 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000021 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000040 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000020 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000020 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000020 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000020 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000020 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000020 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000020 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000020 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000020 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000040 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000020 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000040 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000020 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000020 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000020 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000020 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000020 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000020 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000020 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000020 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000020 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000040 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000020 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grpgpio { + fsl,pins = < + SC_P_USDHC1_DATA6_LSIO_GPIO5_IO21 0x00000021 + SC_P_USDHC1_DATA7_LSIO_GPIO5_IO22 0x00000021 + SC_P_USDHC1_RESET_B_LSIO_GPIO4_IO07 0x00000021 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000021 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000021 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000021 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000021 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000021 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000040 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000020 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000020 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000020 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000020 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000020 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000040 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000020 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000020 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000020 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000020 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000020 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc3_gpio: usdhc3grpgpio { + fsl,pins = < + SC_P_USDHC2_RESET_B_LSIO_GPIO4_IO09 0x00000021 + SC_P_USDHC2_CD_B_LSIO_GPIO4_IO12 0x00000021 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000041 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000021 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000021 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000021 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000021 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000021 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp100mhz { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000040 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000020 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000020 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000020 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000020 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000020 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp200mhz { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000040 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000020 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000020 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000020 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000020 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000020 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000020 + >; + }; +/* + pinctrl_usbotg1: usbotg1 { + fsl,pins = < + SC_P_USB_SS3_TC0_CONN_USB_OTG1_PWR 0x00000021 + >; + }; +*/ + }; +}; + +&lpuart0 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart0>; + status = "okay"; +}; + +&lpuart1 { /* Q7 connector */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart1>; + status = "okay"; +}; + +&pd_dma_lpuart0 { + debug_console; +}; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + bus-width = <4>; + cd-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>; + vmmc-supply = <®_usdhc2_vmmc>; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>, <&pinctrl_usdhc3_gpio>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>, <&pinctrl_usdhc3_gpio>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>, <&pinctrl_usdhc3_gpio>; + bus-width = <4>; + cd-gpios = <&gpio4 12 GPIO_ACTIVE_LOW>; + vmmc-supply = <®_usdhc3_vmmc>; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + status = "okay"; +}; +/* +&usbotg1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg1>; + srp-disable; + hnp-disable; + adp-disable; + power-polarity-active-high; + disable-over-current; + status = "okay"; +}; + +&usb2 { + status = "okay"; +}; +*/ diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index 9d1f73dfc7..5cbcaa7b9e 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -80,6 +80,12 @@ config TARGET_IMX8QM_MEK select BOARD_LATE_INIT select IMX8QM
+config TARGET_CONGA_QMX8 + bool "Support congatec conga-QMX8 board" + select BOARD_LATE_INIT + select SUPPORT_SPL + select IMX8QM + config TARGET_IMX8QM_ROM7720_A1 bool "Support i.MX8QM ROM-7720-A1" select BOARD_LATE_INIT @@ -95,6 +101,7 @@ endchoice
source "board/freescale/imx8qm_mek/Kconfig" source "board/freescale/imx8qxp_mek/Kconfig" +source "board/congatec/cgtqmx8/Kconfig" source "board/advantech/imx8qm_rom7720_a1/Kconfig" source "board/toradex/apalis-imx8/Kconfig" source "board/toradex/colibri-imx8x/Kconfig" diff --git a/board/congatec/cgtqmx8/Kconfig b/board/congatec/cgtqmx8/Kconfig new file mode 100644 index 0000000000..7273039261 --- /dev/null +++ b/board/congatec/cgtqmx8/Kconfig @@ -0,0 +1,14 @@ +if TARGET_CONGA_QMX8 + +config SYS_BOARD + default "cgtqmx8" + +config SYS_VENDOR + default "congatec" + +config SYS_CONFIG_NAME + default "cgtqmx8" + +source "board/congatec/common/Kconfig" + +endif diff --git a/board/congatec/cgtqmx8/MAINTAINERS b/board/congatec/cgtqmx8/MAINTAINERS new file mode 100644 index 0000000000..a242e534c8 --- /dev/null +++ b/board/congatec/cgtqmx8/MAINTAINERS @@ -0,0 +1,6 @@ +i.MX8QM CGTQMX8 BOARD +M: Oliver Graute oliver.graute@kococonnector.com +S: Maintained +F: board/congatec/cgtqmx8/ +F: include/configs/cgtqmx8.h +F: configs/cgtqmx8_defconfig diff --git a/board/congatec/cgtqmx8/Makefile b/board/congatec/cgtqmx8/Makefile new file mode 100644 index 0000000000..4b59dbb6bc --- /dev/null +++ b/board/congatec/cgtqmx8/Makefile @@ -0,0 +1,11 @@ +# +# Copyright 2017 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += cgtqmx8.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +endif diff --git a/board/congatec/cgtqmx8/README b/board/congatec/cgtqmx8/README new file mode 100644 index 0000000000..5724eb89f7 --- /dev/null +++ b/board/congatec/cgtqmx8/README @@ -0,0 +1,46 @@ +U-Boot for the Congatec conga-QMX8 board + +Quick Start +=========== + +- Build the ARM Trusted firmware binary +- Get scfw_tcm.bin and ahab-container.img +- Get imx-mkimage +- Build U-Boot +- Build imx-mkimage +- Flash the binary into the SD card +- Boot + +Get and Build the ARM Trusted firmware +====================================== + +$ git clone https://source.codeaurora.org/external/imx/imx-atf +$ cd imx-atf/ +$ git checkout origin/imx_4.14.78_1.0.0_ga -b imx_4.14.78_1.0.0_ga +$ make PLAT=imx8qm bl31 + +Get scfw_tcm.bin and ahab-container.img +============================== + +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-sc-firmware-1.1.bin +$ chmod +x imx-sc-firmware-1.1.bin +$ ./imx-sc-firmware-1.1.bin +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin +$ chmod +x firmware-imx-8.0.bin +$ ./firmware-imx-8.0.bin + +Or use this to avoid running random scripts from the internet, +but note that you must agree to the license the script displays: + +$ dd if=imx-sc-firmware-1.1.bin of=imx-sc-firmware-1.1.tar.bz2 bs=37185 skip=1 +$ tar -xf imx-sc-firmware-1.1.tar.bz2 +$ cp imx-sc-firmware-1.1/mx8qx-val-scfw-tcm.bin $(builddir) + +$ dd if=firmware-imx-8.0.bin of=firmware-imx-8.0.tar.bz2 bs=37180 skip=1 +$ tar -xf firmware-imx-8.0.tar.bz2 +$ cp firmware-imx-8.0/firmware/seco/mx8qm-ahab-container.img $(builddir) + +Build U-Boot +============ + +$ export ATF_LOAD_ADDR=0x80000000 +$ export BL33_LOAD_ADDR=0x80020000 +$ make cgtqmx8_defconfig +$ make u-boot.bin +$ make flash.bin + +Flash the binary into the SD card +================================= + +Burn the flash.bin binary to SD card offset 32KB: + +$ sudo dd if=flash.bin of=/dev/sd[x] bs=1k seek=32 conv=fsync diff --git a/board/congatec/cgtqmx8/cgtqmx8.c b/board/congatec/cgtqmx8/cgtqmx8.c new file mode 100644 index 0000000000..9a7f3ac309 --- /dev/null +++ b/board/congatec/cgtqmx8/cgtqmx8.c @@ -0,0 +1,479 @@ +//SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 congatec AG + * Copyright (C) 2019 Oliver Graute oliver.graute@kococonnector.com + */ +#include <common.h> +#include <errno.h> +#include <linux/libfdt.h> +#include <fsl_esdhc.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/arch/clock.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/imx8-pins.h> +#include <usb.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sys_proto.h> +#include <linux/delay.h> +#include <power-domain.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define ESDHC_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ESDHC_CLK_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ENET_INPUT_PAD_CTRL ((SC_PAD_CONFIG_OD_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_18V_10MA << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ENET_NORMAL_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_18V_10MA << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define FSPI_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define GPIO_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define I2C_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_LOW << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define UART_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +static iomux_cfg_t uart0_pads[] = { + SC_P_UART0_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + SC_P_UART0_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx8_iomux_setup_multiple_pads(uart0_pads, ARRAY_SIZE(uart0_pads)); +} + +int board_early_init_f(void) +{ + /* sc_ipc_t ipcHndl = 0; */ + sc_err_t sciErr = 0; + + /* When start u-boot in XEN VM, directly return */ + /* if (IS_ENABLED(CONFIG_XEN)) */ + /* return 0; */ + + /* ipcHndl = gd->arch.ipc_channel_handle; */ + + /* Power up UART0, this is very early while power domain is not working */ + sciErr = sc_pm_set_resource_power_mode(-1, SC_R_UART_0, SC_PM_PW_MODE_ON); + if (sciErr != SC_ERR_NONE) + return 0; + + /* Set UART0 clock root to 80 MHz */ + sc_pm_clock_rate_t rate = 80000000; + sciErr = sc_pm_set_clock_rate(-1, SC_R_UART_0, 2, &rate); + if (sciErr != SC_ERR_NONE) + return 0; + + /* Enable UART0 clock root */ + sciErr = sc_pm_clock_enable(-1, SC_R_UART_0, 2, true, false); + if (sciErr != SC_ERR_NONE) + return 0; + + setup_iomux_uart(); + + return 0; +} + +#ifdef CONFIG_FSL_ESDHC_IMX + +#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 22) +#define USDHC2_CD_GPIO IMX_GPIO_NR(4, 12) + +static struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { + {USDHC1_BASE_ADDR, 0, 8}, + {USDHC2_BASE_ADDR, 0, 4}, + {USDHC3_BASE_ADDR, 0, 4}, +}; + +static iomux_cfg_t emmc0[] = { + SC_P_EMMC0_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_EMMC0_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA4 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA5 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA6 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA7 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_STROBE | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +static iomux_cfg_t usdhc1_sd[] = { + SC_P_USDHC1_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_USDHC1_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA6 | MUX_MODE_ALT(2) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA7 | MUX_MODE_ALT(3) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_VSELECT | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +static iomux_cfg_t usdhc2_sd[] = { + SC_P_USDHC2_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_USDHC2_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_VSELECT | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_WP | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_CD_B | MUX_MODE_ALT(3) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + struct power_domain pd; + + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 (onboard eMMC) USDHC1 + * mmc1 (external SD card) USDHC2 + * mmc2 (onboard µSD) USDHC3 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + /* onboard eMMC */ + if (!power_domain_lookup_name("conn_sdhc0", &pd)) + power_domain_on(&pd); + + imx8_iomux_setup_multiple_pads(emmc0, ARRAY_SIZE(emmc0)); + init_clk_usdhc(0); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + case 1: + /* external SD card */ + if (!power_domain_lookup_name("conn_sdhc1", &pd)) + power_domain_on(&pd); + + imx8_iomux_setup_multiple_pads(usdhc1_sd, ARRAY_SIZE(usdhc1_sd)); + init_clk_usdhc(1); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + gpio_request(USDHC1_CD_GPIO, "sd1_cd"); + gpio_direction_input(USDHC1_CD_GPIO); + break; + case 2: + /* onboard µSD */ + if (!power_domain_lookup_name("conn_sdhc2", &pd)) + power_domain_on(&pd); + + imx8_iomux_setup_multiple_pads(usdhc2_sd, ARRAY_SIZE(usdhc2_sd)); + init_clk_usdhc(2); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + gpio_request(USDHC2_CD_GPIO, "sd2_cd"); + gpio_direction_input(USDHC2_CD_GPIO); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return 0; + } + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; + } + + return ret; +} + +#endif /* CONFIG_FSL_ESDHC_IMX */ + +#ifdef CONFIG_FEC_MXC +#include <miiphy.h> + +static iomux_cfg_t pad_enet0[] = { + SC_P_ENET0_RGMII_RX_CTL | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXD0 | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXD1 | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXD2 | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXD3 | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXC | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_TX_CTL | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXD0 | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXD1 | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXD2 | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXD3 | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXC | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_MDC | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_MDIO | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx8_iomux_setup_multiple_pads(pad_enet0, ARRAY_SIZE(pad_enet0)); +} + +static void enet_device_phy_reset(void) +{ + gpio_set_value(FEC0_RESET, 0); + udelay(50); + gpio_set_value(FEC0_RESET, 1); + + /* The board has a long delay for this reset to become stable */ + mdelay(200); +} + +int board_eth_init(bd_t *bis) +{ + int ret; + struct power_domain pd0; + + /* if (!power_domain_lookup_name(FEC0_PDOMAIN, &pd0)) */ + /* power_domain_on(&pd0); */ + + setup_iomux_fec(); + + /* ret = fecmxc_initialize_multi(bis, CONFIG_FEC_ENET_DEV, */ + /* CONFIG_FEC_MXC_PHYADDR, IMX_FEC_BASE); */ + if (ret) + printf("FEC0 MXC: %s:failed\n", __func__); + + return ret; +} + +int board_phy_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +static int setup_fec(void) +{ + /* Reset ENET PHY */ + enet_device_phy_reset(); + + return 0; +} +#endif + +#ifdef CONFIG_MXC_GPIO + +#define LVDS_ENABLE IMX_GPIO_NR(1, 6) +#define BKL_ENABLE IMX_GPIO_NR(1, 7) + +static iomux_cfg_t board_gpios[] = { + SC_P_LVDS0_I2C0_SCL | MUX_MODE_ALT(3) | MUX_PAD_CTRL(GPIO_PAD_CTRL), + SC_P_LVDS0_I2C0_SDA | MUX_MODE_ALT(3) | MUX_PAD_CTRL(GPIO_PAD_CTRL), + SC_P_ESAI1_FST | MUX_MODE_ALT(3) | MUX_PAD_CTRL(GPIO_PAD_CTRL), +}; + +static void board_gpio_init(void) +{ + imx8_iomux_setup_multiple_pads(board_gpios, ARRAY_SIZE(board_gpios)); + + /* enable LVDS */ + gpio_request(LVDS_ENABLE, "lvds_enable"); + gpio_direction_output(LVDS_ENABLE, 1); + + /* enable backlight */ + gpio_request(BKL_ENABLE, "bkl_enable"); + gpio_direction_output(BKL_ENABLE, 1); + + /* ethernet reset */ + gpio_request(FEC0_RESET, "enet0_reset"); + gpio_direction_output(FEC0_RESET, 1); +} +#endif + +int checkboard(void) +{ + puts("Board: conga-QMX8\n"); + + build_info(); + print_bootinfo(); + + /* Note: After reloc, ipcHndl will no longer be valid. If handle + * returned by sc_ipc_open matches SC_IPC_CH, use this + * macro (valid after reloc) for subsequent SCI calls. + */ + /* + if (gd->arch.ipc_channel_handle != SC_IPC_CH) { + printf("\nSCI error! Invalid handle\n"); + } + */ + + return 0; +} + +int board_init(void) +{ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + +#ifdef CONFIG_MXC_GPIO + board_gpio_init(); +#endif + +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + + return 0; +} + +void detail_board_ddr_info(void) +{ + puts("\nDDR "); +} + +/* + * Board specific reset that is system reset. + */ +void reset_cpu(ulong addr) +{ +/* + puts("SCI reboot request"); + sc_pm_reboot(SC_IPC_CH, SC_PM_RESET_TYPE_COLD); + while (1) + putc('.'); +*/ + /* TODO */ +} + + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + return 0; +} +#endif + +int board_mmc_get_env_dev(int devno) +{ + /* Use EMMC */ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + + return devno; +} + +int mmc_map_to_kernel_blk(int dev_no) +{ + /* Use EMMC */ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + + return dev_no; +} + +extern uint32_t _end_ofs; +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "QMX8"); + env_set("board_rev", "iMX8QM"); +#endif + + env_set("sec_boot", "no"); +#ifdef CONFIG_AHAB_BOOT + env_set("sec_boot", "yes"); +#endif + +#ifdef CONFIG_ENV_IS_IN_MMC + board_late_mmc_env_init(); +#endif + +#ifdef IMX_LOAD_HDMI_FIMRWARE + char *end_of_uboot; + char command[256]; + end_of_uboot = (char *)(ulong)(CONFIG_SYS_TEXT_BASE + _end_ofs + fdt_totalsize(gd->fdt_blob)); + end_of_uboot += 9; + + /* load hdmitxfw.bin and hdmirxfw.bin*/ + memcpy(IMX_HDMI_FIRMWARE_LOAD_ADDR, end_of_uboot, + IMX_HDMITX_FIRMWARE_SIZE + IMX_HDMIRX_FIRMWARE_SIZE); + + sprintf(command, "hdp load 0x%x", IMX_HDMI_FIRMWARE_LOAD_ADDR); + run_command(command, 0); + + sprintf(command, "hdprx load 0x%x", + IMX_HDMI_FIRMWARE_LOAD_ADDR + IMX_HDMITX_FIRMWARE_SIZE); + run_command(command, 0); +#endif + + return 0; +} + +#ifdef CONFIG_FSL_FASTBOOT +#ifdef CONFIG_ANDROID_RECOVERY +int is_recovery_key_pressing(void) +{ + return 0; /*TODO*/ +} +#endif /*CONFIG_ANDROID_RECOVERY*/ +#endif /*CONFIG_FSL_FASTBOOT*/ + +/* Only Enable USB3 resources currently */ +int board_usb_init(int index, enum usb_init_type init) +{ + return 0; +} diff --git a/board/congatec/cgtqmx8/imximage.cfg b/board/congatec/cgtqmx8/imximage.cfg new file mode 100644 index 0000000000..e324c7ca37 --- /dev/null +++ b/board/congatec/cgtqmx8/imximage.cfg @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#define __ASSEMBLY__ + +/* Boot from SD, sector size 0x400 */ +BOOT_FROM SD 0x400 +/* SoC type IMX8QM */ +SOC_TYPE IMX8QM +/* Append seco container image */ +APPEND mx8qm-ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ +IMAGE SCU mx8qm-val-scfw-tcm.bin +/* Add ATF image with exec attribute */ +IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ +DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/board/congatec/cgtqmx8/spl.c b/board/congatec/cgtqmx8/spl.c new file mode 100644 index 0000000000..bdf9fee541 --- /dev/null +++ b/board/congatec/cgtqmx8/spl.c @@ -0,0 +1,76 @@ +/* + * Copyright 2018 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <log.h> +#include <spl.h> +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> +#include <dm/lists.h> + +DECLARE_GLOBAL_DATA_PTR; + +void spl_board_init(void) +{ + struct udevice *dev; + int offset; + + uclass_find_first_device(UCLASS_MISC, &dev); + + for (; dev; uclass_find_next_device(&dev)) { + if (device_probe(dev)) + continue; + } + + offset = fdt_node_offset_by_compatible(gd->fdt_blob, -1, "nxp,imx8-pd"); + while (offset != -FDT_ERR_NOTFOUND) { + lists_bind_fdt(gd->dm_root, offset_to_ofnode(offset), + NULL, true); + offset = fdt_node_offset_by_compatible(gd->fdt_blob, offset, + "nxp,imx8-pd"); + } + + uclass_find_first_device(UCLASS_POWER_DOMAIN, &dev); + + for (; dev; uclass_find_next_device(&dev)) { + if (device_probe(dev)) + continue; + } + + arch_cpu_init(); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + puts("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + board_init_r(NULL, 0); +} diff --git a/board/congatec/common/Kconfig b/board/congatec/common/Kconfig new file mode 100644 index 0000000000..5c205bd830 --- /dev/null +++ b/board/congatec/common/Kconfig @@ -0,0 +1,48 @@ +if !ARCH_IMX8M && !ARCH_IMX8 + +config CHAIN_OF_TRUST + depends on !FIT_SIGNATURE && SECURE_BOOT + imply CMD_BLOB + imply CMD_HASH if ARM + select FSL_CAAM + select SPL_BOARD_INIT if (ARM && SPL) + select SHA_HW_ACCEL + select SHA_PROG_HW_ACCEL + select ENV_IS_NOWHERE + select CMD_EXT4 if ARM + select CMD_EXT4_WRITE if ARM + bool + default y + +config CMD_ESBC_VALIDATE + bool "Enable the 'esbc_validate' and 'esbc_halt' commands" + default y if CHAIN_OF_TRUST + help + This option enables two commands used for secure booting: + + esbc_validate - validate signature using RSA verification + esbc_halt - put the core in spin loop (Secure Boot Only) + +endif + +config VOL_MONITOR_LTC3882_READ + depends on VID + bool "Enable the LTC3882 voltage monitor read" + default n + help + This option enables LTC3882 voltage monitor read + functionality. It is used by common VID driver. + +config VOL_MONITOR_LTC3882_SET + depends on VID + bool "Enable the LTC3882 voltage monitor set" + default n + help + This option enables LTC3882 voltage monitor set + functionality. It is used by common VID driver. + +config USB_TCPC + bool "USB Typec port controller simple driver" + default n + help + Enable USB type-c port controller (TCPC) driver diff --git a/board/congatec/common/Makefile b/board/congatec/common/Makefile new file mode 100644 index 0000000000..d4ddfbf971 --- /dev/null +++ b/board/congatec/common/Makefile @@ -0,0 +1,23 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +MINIMAL= + +ifdef CONFIG_SPL_BUILD +ifdef CONFIG_SPL_INIT_MINIMAL +MINIMAL=y +endif +endif + +ifdef MINIMAL +# necessary to create built-in.o +obj- := __dummy__.o +else + +obj-y += mmc.o + +endif diff --git a/board/congatec/common/mmc.c b/board/congatec/common/mmc.c new file mode 100644 index 0000000000..9fc3e68728 --- /dev/null +++ b/board/congatec/common/mmc.c @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2018 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <linux/errno.h> +#include <asm/io.h> +#include <stdbool.h> +#include <mmc.h> + +static int check_mmc_autodetect(void) +{ + char *autodetect_str = env_get("mmcautodetect"); + + if ((autodetect_str != NULL) && + (strcmp(autodetect_str, "yes") == 0)) { + return 1; + } + + return 0; +} + +/* This should be defined for each board */ +__weak int mmc_map_to_kernel_blk(int dev_no) +{ + return dev_no; +} + +void board_late_mmc_env_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_dev(); + + if (!check_mmc_autodetect()) + return; + + env_set_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", + mmc_map_to_kernel_blk(dev_no)); + env_set("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig new file mode 100644 index 0000000000..21c788cb98 --- /dev/null +++ b/configs/cgtqmx8_defconfig @@ -0,0 +1,82 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_CONGA_QMX8=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/congatec/cgtqmx8/imximage.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_IMX_BOOTAUX=y +CONFIG_LOG=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_CPU=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8qm-cgtqmx8" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_SPL_DM=y +CONFIG_SPL_CLK=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPL_TINY_MEMSET=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h new file mode 100644 index 0000000000..0abafdbb51 --- /dev/null +++ b/include/configs/cgtqmx8.h @@ -0,0 +1,194 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2018 NXP + * Copyright 2018 congatec AG + * + */ + +#ifndef __CGTQMX8_H +#define __CGTQMX8_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_TEXT_BASE 0x0 +#define CONFIG_SPL_MAX_SIZE (124 * 1024) +#define CONFIG_SYS_MONITOR_LEN (1024 * 1024) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x800 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 0 + +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x013E000 +#define CONFIG_SPL_BSS_START_ADDR 0x00128000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x00120000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x3000 /* 12 KB */ +#define CONFIG_SERIAL_LPUART_BASE 0x5a060000 +#define CONFIG_MALLOC_F_ADDR 0x00120000 + +#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE + +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#define CONFIG_OF_EMBED +#endif + +#define CONFIG_REMAKE_ELF + +#define CONFIG_BOARD_EARLY_INIT_F + +/* Flat Device Tree Definitions */ +#define CONFIG_OF_BOARD_SETUP + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV +#undef CONFIG_CMD_IMLS + +#undef CONFIG_CMD_CRC32 +#define CONFIG_SYS_BOOTMAPSZ (256 << 20) +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define USDHC1_BASE_ADDR 0x5B010000 +#define USDHC2_BASE_ADDR 0x5B020000 +#define USDHC3_BASE_ADDR 0x5B030000 +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +/* FUSE command */ +#define CONFIG_CMD_FUSE + +/* Boot M4 */ +#define M4_BOOT_ENV \ + "m4_0_image=m4_0.bin\0" \ + "m4_1_image=m4_1.bin\0" \ + "loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_0_image}\0" \ + "loadm4image_1=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_1_image}\0" \ + "m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0\0" \ + "m4boot_1=run loadm4image_1; dcache flush; bootaux ${loadaddr} 1\0" \ + +#ifdef CONFIG_NAND_BOOT +#define MFG_NAND_PARTITION "mtdparts=gpmi-nand:128m(boot),32m(kernel),16m(dtb),8m(misc),-(rootfs) " +#else +#define MFG_NAND_PARTITION "" +#endif +#define FEC0_RESET IMX_GPIO_NR(2, 5) +#define FEC0_PDOMAIN "conn_enet0" + +#define CONFIG_MFG_ENV_SETTINGS \ + "mfgtool_args=setenv bootargs console=${console},${baudrate} " \ + "rdinit=/linuxrc " \ + "g_mass_storage.stall=0 g_mass_storage.removable=1 " \ + "g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF "\ + "g_mass_storage.iSerialNumber="" "\ + MFG_NAND_PARTITION \ + "clk_ignore_unused "\ + "\0" \ + "initrd_addr=0x83800000\0" \ + "bootcmd_mfg=run mfgtool_args;booti ${loadaddr} ${initrd_addr} ${fdt_addr};\0" \ + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_MFG_ENV_SETTINGS \ + M4_BOOT_ENV \ + "script=boot.scr\0" \ + "image=Image\0" \ + "panel=NULL\0" \ + "console=ttyLP0\0" \ + "fdt_addr=0x83000000\0" \ + "boot_fdt=try\0" \ + "fdt_file=imx8qm-cgt-qmx8.dtb\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot} earlycon\0 " \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "echo wait for boot; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp rw earlycon\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "booti; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else booti ${loadaddr} - ${fdt_addr}; fi" + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x80280000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_SP_ADDR 0x80200000 + +/* Default environment is in SD */ +#define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +/* On LPDDR4 board, USDHC1 is for eMMC, USDHC2 is for SD on CPU board */ +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ +#define CONFIG_SYS_FSL_USDHC_NUM 3 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN ((CONFIG_ENV_SIZE + (32 * 1024)) * 1024) + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_2 0x880000000 +#define PHYS_SDRAM_1_SIZE 0x80000000 /* 2 GB */ +#define PHYS_SDRAM_2_SIZE 0x100000000 /* 4 GB */ + +/* Serial */ +#define CONFIG_BAUDRATE 115200 + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 8000000 /* 8MHz */ + +/* Networking */ +#define CONFIG_FEC_MXC_PHYADDR -1 +#define CONFIG_FEC_XCV_TYPE RGMII +#define FEC_QUIRK_ENET_MAC + +#endif /* __CGTQMX8_H */
Hallo Oliver,
I see some small issues after merging this. There are some warnings that should be fixed before merging, mainly they are missing prototypes that can be easy fixed. This is the log by building the board:
+ 174 | if (!power_domain_lookup_name("conn_sdhc0", &pd)) + | ^~~~~~~~~~~~~~~~~~~~~~~~ + | imx8_power_domain_lookup_name + 178 | init_clk_usdhc(0); + | ^~~~~~~~~~~~~~ + 208 | ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + | ^~~~~~~~~~~~~~~~~~~~ + | fecmxc_initialize + 278 | struct power_domain pd0; + | ^~~ + 442 | board_late_mmc_env_init(); + | ^~~~~~~~~~~~~~~~~~~~~~~ + | board_late_init + 287 | if (ret) + | ^ + 16 | char *autodetect_str = env_get("mmcautodetect"); + | ^~~~~~~ + 41 | env_set_ulong("mmcdev", dev_no); + | ^~~~~~~~~~~~~ + 46 | env_set("mmcroot", mmcblk); + | ^~~~~~~ + 49 | run_command(cmd, 0); + | ^~~~~~~~~~~ + 46 | arch_cpu_init(); + | arch_misc_init + 48 | board_early_init_f(); + | ^~~~~~~~~~~~~~~~~~ + 50 | timer_init(); + | ^~~~~~~~~~ + 75 | board_init_r(NULL, 0); + | ^~~~~~~~~~~~ + | board_init_f
w+board/congatec/cgtqmx8/cgtqmx8.c: In function 'board_mmc_init': w+board/congatec/cgtqmx8/cgtqmx8.c:174:9: warning: implicit declaration of function 'power_domain_lookup_name'; did you mean 'imx8_power_domain_lookup_name'? [-Wimplicit-function-declaration] w+board/congatec/cgtqmx8/cgtqmx8.c:178:4: warning: implicit declaration of function 'init_clk_usdhc' [-Wimplicit-function-declaration] w+board/congatec/cgtqmx8/cgtqmx8.c:208:9: warning: implicit declaration of function 'fsl_esdhc_initialize'; did you mean 'fecmxc_initialize'? [-Wimplicit-function-declaration] w+board/congatec/cgtqmx8/cgtqmx8.c: In function 'board_eth_init': w+board/congatec/cgtqmx8/cgtqmx8.c:278:22: warning: unused variable 'pd0' [-Wunused-variable] w+board/congatec/cgtqmx8/cgtqmx8.c: In function 'board_late_init': w+board/congatec/cgtqmx8/cgtqmx8.c:442:2: warning: implicit declaration of function 'board_late_mmc_env_init'; did you mean 'board_late_init'? [-Wimplicit-function-declaration] w+board/congatec/cgtqmx8/cgtqmx8.c:287:5: warning: 'ret' is used uninitialized in this function [-Wuninitialized] w+board/congatec/common/mmc.c: In function 'check_mmc_autodetect': w+board/congatec/common/mmc.c:16:25: warning: implicit declaration of function 'env_get' [-Wimplicit-function-declaration] w+board/congatec/common/mmc.c:16:25: warning: initialization of 'char *' from 'int' makes pointer from integer without a cast [-Wint-conversion] w+board/congatec/common/mmc.c: In function 'board_late_mmc_env_init': w+board/congatec/common/mmc.c:41:2: warning: implicit declaration of function 'env_set_ulong' [-Wimplicit-function-declaration] w+board/congatec/common/mmc.c:46:2: warning: implicit declaration of function 'env_set' [-Wimplicit-function-declaration] w+board/congatec/common/mmc.c:49:2: warning: implicit declaration of function 'run_command' [-Wimplicit-function-declaration] w+board/congatec/cgtqmx8/spl.c: In function 'spl_board_init': w+board/congatec/cgtqmx8/spl.c:46:2: warning: implicit declaration of function 'arch_cpu_init'; did you mean 'arch_misc_init'? [-Wimplicit-function-declaration] w+board/congatec/cgtqmx8/spl.c:48:2: warning: implicit declaration of function 'board_early_init_f' [-Wimplicit-function-declaration] w+board/congatec/cgtqmx8/spl.c:50:2: warning: implicit declaration of function 'timer_init' [-Wimplicit-function-declaration] w+board/congatec/cgtqmx8/spl.c: In function 'board_init_f': w+board/congatec/cgtqmx8/spl.c:75:2: warning: implicit declaration of function 'board_init_r'; did you mean 'board_init_f'? [-Wimplicit-function-declaration]
Can you fix them and repost it ? Thanks !
Best regards, Stefano
As proposed here:
https://lists.denx.de/pipermail/u-boot/2020-January/396749.html
Both of my imx8qm boards (Advantech and Congatec) aren't booting 2020.01 without this change. Whats the proper way to fix this on my side? --- drivers/core/device.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index a7408d9c76..2bff618f6c 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -448,11 +448,8 @@ int device_probe(struct udevice *dev)
if (CONFIG_IS_ENABLED(POWER_DOMAIN) && dev->parent && (device_get_uclass_id(dev) != UCLASS_POWER_DOMAIN) && - !(drv->flags & DM_FLAG_DEFAULT_PD_CTRL_OFF)) { - ret = dev_power_domain_on(dev); - if (ret) - goto fail; - } + !(drv->flags & DM_FLAG_DEFAULT_PD_CTRL_OFF)) + dev_power_domain_on(dev);
ret = uclass_pre_probe_device(dev); if (ret)
On Tue, Jun 16, 2020 at 04:27:22PM +0200, Oliver Graute wrote:
As proposed here:
Did you mean to say something newer than that? I thought something around here had finally been debugged and fixed at least in some of the failing cases. Thanks!
resetting ...
Currently I try to rebase this patch to v2020.10. But still run into crashes. After some fun with bisect I could blame this commit:
commit 09140113108541b95d340f3c7b6ee597d31ccc73 Author: Simon Glass sjg@chromium.org Date: Sun May 10 11:40:03 2020 -0600
command: Remove the cmd_tbl_t typedef
09140113108541b95d340f3c7b6ee597d31ccc73 BAD 691d719db7183dfb1d1360efed4c5e9f6899095f GOOD
But I assume that I need to fix something on my patch. Perhaps someone could comment and help me on this.
Oliver
U-Boot 2020.07-rc2-00147-g17a341f285 (Nov 04 2020 - 16:13:36 +0100)
sc_pm_get_clock_rate: resource:507 clk:2: res:3 Could not read CPU frequency: -22 CPU: NXP i.MX8QM RevB A35 at 0 MHz
Model: Congatec QMX8 Qseven series Board: conga-QMX8 Build: SCFW 494c97f3, SECO-FW d7523fe8, ATF 09c5cc9 Boot: SD2 DRAM: 6 GiB Device 'gpio@5d090000': seq 0 is in use by 'gpio@5d080000' Device 'gpio@5d0a0000': seq 1 is in use by 'gpio@5d090000' MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 "Synchronous Abort" handler, esr 0x96000004 elr: 000000008005cf54 lr : 0000000080022f94 (reloc) elr: 00000000fff22f54 lr : 00000000ffee8f94 x0 : fffffffffdaf0e40 x1 : 00000000fff2d89f x2 : 0000000000000000 x3 : 0000000000000000 x4 : 0000000000000000 x5 : fffffffffdaf0e40 x6 : 00000000fff068f4 x7 : 00000000fff3bca0 x8 : 00000000fdaf1390 x9 : 0000000000000008 x10: 00000000fdaec9a0 x11: 00000000fdaee528 x12: 0000000000000000 x13: 0000000000000200 x14: 00000000fdadebf8 x15: 00000000ffffffff x16: 0000000000001080 x17: 0000000000000000 x18: 00000000fdae4da0 x19: 0000000000000002 x20: 00000000fff3b000 x21: 000000007fec6000 x22: 0000000000000000 x23: 0000000000000000 x24: 0000000000000000 x25: 0000000000000000 x26: 0000000000000000 x27: 0000000000000000 x28: 0000000000000000 x29: 00000000fdadfd90
resetting ...
Oliver Graute
Oliver Graute
Stefano Babic
